Page 1 of 4 1 2 3 4 LastLast
Results 1 to 35 of 123
Thread: VCDS (VAG-COM Diagnostic System) scans and tweaks for 2012 Passat/NMS
  1. Forum Sponsor Andy@Ross-Tech.com's Avatar
    Jun 5th, 2002
    2012 Passat TDI 6MT
    10-14-2011 06:47 PM #1
    Update (1/18/12), here's a quick work in progress Wiki page:
    http://wiki.ross-tech.com/wiki/index...t_%28NMS/A3%29
    and a Tweaks page:
    http://wiki.ross-tech.com/wiki/index...S/A3%29_Tweaks
    Post your AutoScan (and any changes you've made here ) and we can figure out what tweaks are possible. I'll start with mine:
    Code:
    Wednesday,05,October,2011,16:47:19:65521
    VCDS Version:
    Data version: 20110831
    Chassis Type: 7N0
    Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 62 72 77
    VIN: 1VWBN7A3xCC014xxx
    01-Engine -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    1C-Position Sensing -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CKRA) Labels: None
    Part No SW: 03L 906 012 HW: 03L 907 309 S
    Component: R4 2,0L EDC H21 2157
    Revision: 71H21--- Serial number:
    Coding: 00190012042400000000
    Shop #: WSC 09003 957 00200
    ASAM Dataset: EV_ECM20TDI01103L906012 004009
    ROD: EV_ECM20TDI01103L906012.rod
    VCID: E1C2E53DF06756
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
    Component: ESP MK60EC1 H31 0121
    Revision: 00H31001
    Coding: C54BC0F5492300FEA31403E692220042A70000
    VCID: 7BFE3755FACB1C
    Address 08: Auto HVAC (J255) Labels: None
    Part No SW: 561 907 044 D HW: 561 907 044 D
    Component: Climatronic 042 0102
    Revision: 00001001
    Coding: 0010001002
    ASAM Dataset: EV_ACClimaBHBVW411 A01001
    ROD: EV_ACClimaBHBVW411.rod
    VCID: 183408D9E3BDD7
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 5K0 937 085 P HW: 5K0 937 085 P
    Component: BCM PQ35 B+ 011 0047
    Revision: BH011001
    Coding: 6F200E18902B08D408880001160004480071008650A0056064 8060000C70
    VCID: 408480B9D3ADBF
    Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 080911 05 54 0403
    Coding: 22300A
    1 Fault Found:
    01038 - Central Locking Thermal Protection
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 41
    Mileage: 8 km
    Time Indication: 0
    Date: 2000.14.11
    Time: 12:18:05
    Freeze Frame:
    Term 15 Off
    Voltage: 12.45 V
    OFF
    OFF
    OFF
    OFF
    OFF
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 5C0 959 655 HW: 5C0 959 655
    Component: AirbagVW10G 013 0809
    Serial number: 003END09CN5G
    Coding: 00003548
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
    ROD: EV_AirbaVW10SMEVW360_VW41.rod
    VCID: EFE6930536B3F0
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339
    Component: BF-Gewichtss. H10 0027
    Serial number: 6940000Y1100006ZYN0O
    Coding: 30324D
    Crash sensor for side airbag; driver side:
    Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Fahr.V H01 ----
    Serial number: 3572MSME79730342ZZZS
    Crash sensor for side airbag; passenger side:
    Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Beif.V H01 ----
    Serial number: 3582MSME47300042ZZZE
    Crash sensor for side airbag; rear driver side:
    Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
    Component: S.Sens.Fahr.H H02 ----
    Serial number: 3516KSME155C1713ZZZO
    Crash sensor for side airbag; rear passenger side:
    Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
    Component: S.Sens.Beif.H H02 ----
    Serial number: 3526KSME38072312ZZZG
    Crash sensor for front airbag; driver side:
    Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
    Component: F.Sens.Fahr H02 ----
    Serial number: 3556LSME65015610ZZZI
    Crash sensor for front airbag; passenger side:
    Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
    Component: F.Sens.Beif H02 ----
    Serial number: 3566LSME264B1B12ZZZX
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 1K5 953 521 AK HW: 5K0 953 569 B
    Component: LENKS.MODUL 014 0140
    Revision: FF010040 Serial number: 20110724200787
    Coding: 008A140000
    ASAM Dataset: EV_SMLSNGVOLWSXS A01004
    ROD: EV_SMLSNGVOLWSXS_VW41.rod
    VCID: 76E82661C9E941
    Multifunction steering wheel control module:
    Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
    Component: E221__MFL-YVJ H06 0022
    Coding: E20000
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 561 920 970 C HW: 561 920 970 C
    Component: KOMBI H07 0507
    Serial number: 00000000000000
    Coding: 231E01
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
    ROD: EV_Kombi_UDS_VDD_RM09_VW41.rod
    VCID: 1A3012D11DB1C5
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 K HW: 1K0 907 951
    Component: J533 Gateway H40 1620
    Revision: H40 Serial number: 06091101290350
    Coding: 461000
    VCID: 3874E8598B7DF7
    Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
    Part No SW: 561 919 965 HW: 561 919 965
    Component: Kompass 001 0001
    Revision: 00001000 Serial number: 1829227R03TZ05
    Coding: 0000002
    VCID: E3CEEF35227B44
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H07 0507
    Serial number:
    Coding: 000000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
    ROD: EV_Immo_UDS_VDD_RM09_VW41.rod
    VCID: EAD082110D5115
    Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 561 959 701 HW: 3C0 959 793 B
    Component: TUER-SG FT 002 0525
    Revision: 13110009 Serial number: 0002592944
    Coding: 0404F5
    ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
    ROD: EV_TSGFPQ25BRFVW46X.rod
    VCID: DBBED7D5D20B7C
    Slave Driver:
    Subsystem 1 - Part No SW: 561 959 811 HW: 561 959 811 Labels: 3C0-959-70X-GEN4.CLB
    Component: J388__TSG_HL 004 4472
    Serial number: --------------------
    Coding: 800000
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 M
    Component: EPS_ZFLS Kl. 290 3201
    Revision: 00H20000
    Shop #: WSC 01357 011 00200
    VCID: 346CDC69571513
    Address 46: Central Conv.
    Cannot be reached
    Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
    Part No SW: 7N0 907 532 HW: 1K0 907 951
    Component: EZE_2 H40 1620
    Coding: 00000008
    VCID: EFE693053EB3F0
    Subsystem 1 - Part No SW: 561 919 204 B HW: 561 919 204 B
    Component: Analoguhr 008 0002
    Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 561 959 702 HW: 3C0 959 792 B
    Component: TUER-SG BT 002 0525
    Revision: 15110009 Serial number: 0003265626
    Coding: 0404F4
    ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
    ROD: EV_TSGBPQ25BRFVW46X.rod
    VCID: DCBCD4C9D7057B
    Slave Passenger:
    Subsystem 1 - Part No SW: 561 959 812 HW: 561 959 812 Labels: 3C0-959-70X-GEN4.CLB
    Component: J389__TSG_HR 004 4472
    Coding: 800000
    Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 1K0 035 180 AD HW: 1K0 035 180 AD
    Component: Radio Prem-8 H04 0018
    Revision: -----17S Serial number: VWZ4Z7L3201337
    Coding: 0500040004
    VCID: 62C06A317D61CD
    Address 62: Door, Rear Left
    Cannot be reached
    Address 72: Door, Rear Right
    Cannot be reached
    Address 77: Telephone (J412) Labels: 7P6-035-730.clb
    Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
    Component: TELEFON H09 2902
    Revision: 1B001001 Serial number: 00007660489052
    Coding: 0A10040000010110
    ASAM Dataset: EV_UHVNA A01719
    ROD: EV_UHVNA_VW41.rod
    VCID: 356AE16D946F0A
    End ---------------------------------------------------------------------
  2. Banned iPinch's Avatar
    Oct 24th, 2008
    Chesapeake, VA
    askavwsalesguy.com
    10-16-2011 01:53 AM #2
  3. Junior Member
    Nov 1st, 2011
    Dayton Ohio
    2012 PASSAT SE
    11-09-2011 05:33 PM #3
    Code:
    Sunday,06,November,2011,16:44:51:07858
    VCDS Version: Release 10.6.5
    Data version: 20110930
    Chassis Type: 7N0
    Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 46 4F 52 56 62 72 77
    VIN: 1VWBH7A33XXXXYYYY
    02-Auto Trans -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    Address 01: Engine (CBT)       Labels: None
       Part No SW: 07K 906 055 AN    HW: 07K 907 309 A
       Component: 2,5l R5/4V      G01 1102
       Revision: T6H02---    Serial number:
       Coding: 0000075
       VCID: 7AF1D0294C44
    Readiness: 0000 0000
    Address 02: Auto Trans        Labels: 09G-927-750.lbl
       Part No SW: 09G 927 750 LH    HW: 09G 927 750 LH
       Component: AQ 250 6F           2043
       Revision: 00H97000    Serial number:
       Coding: 0000840
       VCID: 820128C9A494
       Part No SW: 1K0 907 379 BH    HW: 1K0 907 379 BH
       Revision: 00H31001
       Coding: C54BC0F5492408FBA30B03E8921A1061A60000
       VCID: 79F3CF254942
       Revision: 00001001
       Coding: 0010001002
       ROD: N/A
       VCID: 1835EAA15208
    No ASAM data for: "EV_ACClimaBHBVW411" (VW36)
       Component: BCM PQ35 B+   011 0048
       Revision: BH011001
       Coding: 6F200E1B902B08D408880001160004480071008640A00D60648060000C70
       VCID: 408562C16A18
       Component: RLS 120911 05  54  0403
       Coding: 22300A
       Serial number: 003ENM003YT%
       Coding: 00003548
       ROD: EV_AirbaVW10SMEVW360_VW36.rod
       VCID: EFE7717D8706
       Serial number: 6940000Y1100007AL40B
       Coding: 30324D
       Driver's Airbag Crash Sensor:
       Serial number: 3572MSME66330563ZZZP
       Passenger Side Airbag Crash Sensor:
       Serial number: 3582MSME07592562ZZZU
       Driver's Rear Airbag Crash Sensor:
       Serial number: 3516KSME3A4C3613ZZZV
       Passenger's Rear Airbag Crash Sensor:
       Serial number: 3526KSME08542013ZZZD
       Driver's Front Airbag Crash Sensor:
       Serial number: 3556LSME124E1213ZZZM
       Passenger's Front Airbag Crash Sensor:
       Serial number: 3566LSME2C021D13ZZZT
       Part No SW: 1K5 953 501 Q    HW: 5K0 953 569 H
       Revision: FF010040    Serial number: 20110917301347
       Coding: 098A140000
       ASAM Dataset: EV_VW360SteerWheelUDS A03004
       ROD: EV_VW360SteerWheelUDS_VW36.rod
       VCID: 39730F2509C2
       MFL:
       Coding: E20000
       Part No SW: 561 920 970 B    HW: 561 920 970 B
       Coding: 231E01
       ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
       VCID: 1933EFA5A902
       Revision:   H40       Serial number: 12091101291150
       Coding: 461000
       VCID: 38750A2132C8
       Serial number:
       Coding: 000000
       VCID: EAD16069BCE4
    Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
       Part No SW: 5N0 035 342 E    HW: 5N0 035 342 E
       Component: SG EXT.PLAYER H13 0240
       Revision: A1001003    Serial number: 7660751164
       Coding: 020000
       VCID: 2953DF65F962
    Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
       Part No SW: 1K0 035 274 B    HW: 1K0 035 274 B
       Component: RNS315-NAR    H32 0263
       Serial number: VWZAZ2L8464676
       Coding: 0400042104000B0000008000
       ASAM Dataset: EV_RNS315NARV2UDS A01004
       ROD: N/A
       VCID: 234FCD4D9B4E
       Part No: 3AA 919 866 B
       Component: NAR_V2  0002
    No ASAM data for: "EV_RNS315NARV2UDS" (VW36)
       Revision: 13110009    Serial number: 0003369215
       Coding: 0404F5
       VCID: DBBF35AD63BE
       Slave Driver:
       Coding: 800000
       Coding: 01030108
       VCID: EFE7717D8706
       Part No SW: 561 959 591     HW: 561 959 591
       Component: J245 P05 FFD7  H07 0004
       Coding: 181100
       Revision: 15110009    Serial number: 0003185559
       Coding: 0404F4
       VCID: DCBD36B166B0
       Slave Passenger:
       Coding: 800000
    Cannot be reached
    Cannot be reached
       Revision: 1B001001    Serial number: 00007660470199
       VCID: 356B031525DA
  4. Junior Member
    Nov 1st, 2011
    Dayton Ohio
    2012 PASSAT SE
    11-09-2011 07:29 PM #4
    So far I have enabled the rain sensor, auto-windows up via rain sensor, and enabled the RVC on the RNS-315. The autoscan above was before any changes.
    Mike
  5. Junior Member
    Nov 1st, 2011
    Connecticut,USA
    2012 Passat 2.5L SEL Premium
    11-10-2011 12:17 AM #5
    Quote Originally Posted by mpistone View Post
    Mike
    Hey mpistone, you'll need to tell me which bits you changed for those 3 hacks. Those are exactly what I am going to do as soon as I get my hands on the VCDS interface.
    Thanks in advance.
  6. Forum Sponsor Andy@Ross-Tech.com's Avatar
    Jun 5th, 2002
    2012 Passat TDI 6MT
    11-10-2011 09:02 AM #6
    Mike
    Excellent, thanks for the scan. FYI, you should use Beta 11.10 which includes more documentation for our cars:
    http://www.ross-tech.com/vcds/downlo...ent.html#11.10
  7. Junior Member
    Oct 11th, 2011
    Virginia
    2012 Passat TDI SE, 2005 Audi A6
    11-10-2011 07:43 PM #7
    Code:
    Thursday,10,November,2011,19:35:45:38918
    VCDS Version: Beta 11.10.1
    Data version: 20111020
    Chassis Type: 7N0
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 62 72 77
    VIN: 1VWBN7A34CC013359
    Address 01: Engine (J623-CKRA)       Labels: 03L-906-012-CKR.clb
       Part No SW: 03L 906 012 BP    HW: 03L 907 309 S
       Component: R4 2,0L EDC   H21 2158
       Coding: 001D0012042400000000
       ASAM Dataset: EV_ECM20TDI01103L906012BP 004004
       ROD: EV_ECM20TDI01103L906012BP.rod
       VCID: 73EF31B9DAAE329
    Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
       Part No SW: 02E 300 054 C    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2806
       Revision: 05351113    Serial number: 00001104261166
       Coding: 0000020
       VCID: 1629282D219C871
       Revision: 00H31001
       Coding: C54BC0F5492300FDA30E03E992220042A70000
       VCID: 7BFF1999FAFE7A9
    Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
       Component: Climatronic   H01 0102
       Revision: 00001001
       Coding: 0010001002
       VCID: 18352615E388B11
       Revision: BH011001
       Coding: 6F200E1B902B08D408880001160004480071008640A00560648060000C70
       VCID: 4085AE75D398D91
       Component: RLS 090811 05  54  0403
       Coding: 02300A
       Serial number: 003END09B9SO
       Coding: 00003548
       VCID: EFE7BDC93686969
       Serial number: 6940000Y1100006PRF0%
       Coding: 30324D
       Serial number: 3572MSME19487060ZZZS
       Serial number: 3582MSME260F0161ZZZP
       Serial number: 3516KSME7C4E5212ZZZ-
       Serial number: 3526KSME40215012ZZZ5
       Serial number: 3556LSME45456B10ZZZU
       Serial number: 3566LSME28092E10ZZZV
       Revision: FF010040    Serial number: 20110724100776
       Coding: 088A140000
       VCID: 76E908ADC9DC271
       Coding: E20000
       Coding: 231E01
       VCID: 1A313C1D1D84A31
       Revision:   H40       Serial number: 25081101290294
       Coding: 461000
       VCID: 3875C6958B48911
       Revision: 00001000    Serial number: 1829227R0ATZ05
       Coding: 0000002
       VCID: E3CFC1F9224E229
       Serial number:
       Coding: 000000
       Shop #: WSC 00000 000 00000
       VCID: EAD1ACDD0D64731
       Revision: 13110009    Serial number: 0002631937
       Coding: 0404F5
       VCID: DBBFF919D23E1A9
       Slave Driver:
       Coding: 800000
       Revision: 00H20000
       VCID: 346DF2A55720751
       Coding: 01030108
       VCID: EFE7BDC93E86969
       Subsystem 1 - Part No SW: 561 959 591     HW: 561 959 591
       Coding: 181100
       Subsystem 2 - Part No SW: 561 919 204 B    HW: 561 919 204 B
       Revision: 15110009    Serial number: 0003186691
       Coding: 0404F4
       VCID: DCBDFA05D7301D1
       Slave Passenger:
       Coding: 800000
       Revision: -----17S    Serial number: VWZ4Z7L3192521
       Coding: 0500040004
       VCID: 62C144FD7D54AB1
       Revision: 1B001001    Serial number: 00007660470009
       VCID: 356BCFA1945A6C9
  8. 11-10-2011 08:17 PM #8
    Possible to do windows down via remote?
  9. Forum Sponsor Andy@Ross-Tech.com's Avatar
    Jun 5th, 2002
    2012 Passat TDI 6MT
    11-10-2011 08:26 PM #9
    Thanks for the scan, jrisingtide.
    Quote Originally Posted by Joyrex View Post
    Not AFAIK.
  10. Member
    Nov 18th, 2006
    Western NC
    2012 Passat TDI SE DSG/ 2013 JSW TDI DSG
    11-10-2011 08:36 PM #10
    I am posting a link to mine. I think I did before but just in case. Scan was pre mods.
    http://db.tt/MvJ4eeFM
    2012 Passat SE TDI. DSG, 35% tint, VCDS Rain Sensor Wiper Mod
    2013 JSW TDI DSG. 35% tint, smoked side markers
  11. Member
    Nov 7th, 2011
    North Dallas, Texas
    2012 Passat TDI SEL Premium Tungsten/Black
    11-11-2011 08:49 AM #11
    Have anyone been able to roll windows down with the key fob?
    I enabled it tru with vag-com but they dont work..
    Nov 18th, 2006
    Western NC
    11-11-2011 10:35 AM #12
    Quote Originally Posted by Andy@Ross-Tech.com View Post
    Not AFAIK.
    Still pending. Andy is on it, hopefully soon.
  13. Junior Member
    Sep 21st, 2005
    11-11-2011 10:41 AM #13
    Code:
    Friday,11,November,2011,10:40:56:48580
    Chassis Type: 7N0
    VIN: 1VWBN7A3XCC020042
       VCID: 73EE6E5EDAAE329
       Revision: 05351113    Serial number: 00001105140808
       Coding: 0000020
       VCID: 162877CA219C871
       Revision: 00H31001
       Coding: C54BC0F5492400FAA30B03E8921B0042A70000
       VCID: 7BFE467EFAFE7A9
       Revision: 00001001
       Coding: 0010001002
       VCID: 183479F2E388B11
       Revision: BH011001
       VCID: 4084F192D398D91
       Component: RLS 290811 05  54  0403
       Coding: 22300A
       Serial number: 003ENM004S7F
       Coding: 00003548
       VCID: EFE6E22E3686969
       Serial number: 6940000Y1100007XKW0I
       Coding: 30324D
       Serial number: 3572MSME5B442363ZZZV
       Serial number: 3582MSME142C0263ZZZO
       Serial number: 3516KSME454B2213ZZZL
       Serial number: 3526KSME25421D13ZZZL
       Serial number: 3556LSME34431213ZZZF
       Serial number: 3566LSME3E4D1213ZZZ-
       Revision: FF010040    Serial number: 20110621300312
       Coding: 088A140000
       VCID: 76E8574AC9DC271
       Coding: E20000
       Coding: 231E01
       VCID: 1A3063FA1D84A31
       Revision:   H40       Serial number: 25091101291102
       Coding: 461000
       VCID: 387499728B48911
       Revision: 00001000    Serial number: 1829227R078805
       Coding: 0000002
       VCID: E3CE9E1E224E229
       Serial number:
       Coding: 000000
       VCID: EAD0F33A0D64731
       Revision: 13110009    Serial number: 0003255870
       Coding: 0404F5
       VCID: DBBEA6FED23E1A9
       Slave Driver:
       Coding: 800000
       Revision: 00H20000
       VCID: 346CAD425720751
       Coding: 01030108
       VCID: EFE6E22E3E86969
       Coding: 181100
       Revision: 15110009    Serial number: 0003295298
       Coding: 0404F4
       VCID: DCBCA5E2D7301D1
       Slave Passenger:
       Coding: 800000
       Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
       Component: Radio Prem-8  H02 0016
       Revision: -----16S    Serial number: VWZ4Z7L3206615
       Coding: 0500040004000B
       VCID: 63CE1E1E624EA29
       Revision: 1B001001    Serial number: 00007660654431
       VCID: 356A9046945A6C9
  14. Member jkurtzs4's Avatar
    Oct 27th, 2011
    Sarasota, FL
    1990 VW Fox Wagon(SOLD), 1993 VW Jetta GL(SOLD), 2000 Audi S4(MINE), 2012 VW Passat TDI(MINE)
    11-18-2011 08:43 PM #14
    Code
    Wednesday,16,November,2011,18:59:26:58756
    VCDS Version: Release 11.11.0
    Data version: 20111111
    Chassis Type: 7N0
    VIN: 1VWBN7A33CC014194
    VCID: 73EFFCD3DAAE376
    Revision: 05351113 Serial number: 00001107112332
    Coding: 0000020
    VCID: 1629E547219C82E
    Revision: 00H31001
    Coding: C54BC0F5492300FEA30C03ED921D0042A70000
    VCID: 7BFFD4F3FAFE7F6
    Revision: 00001001
    Coding: 0010001002
    VCID: 1835EB7FE388B4E
    Revision: BH011001
    Coding: 6F200E1B902B08D408880001160004480071008640A0056064 8060000C70
    VCID: 4085631FD398DCE
    Component: RLS 050911 05 54 0403
    Coding: 22300A
    Serial number: 003END09D5ZT
    Coding: 00003548
    VCID: EFE770A33686936
    Serial number: 6940000Y1100006R680G
    Coding: 30324D
    Serial number: 3572MSME31550042ZZZD
    Serial number: 3582MSME0C740442ZZZR
    Serial number: 3516KSME15655012ZZZE
    Serial number: 3526KSME5C504212ZZZL
    Serial number: 3556LSME344F5510ZZZV
    Serial number: 3566LSME3A645510ZZZT
    Revision: FF010040 Serial number: 20110724200781
    Coding: 088A140000
    VCID: 76E9C5C7C9DC22E
    Coding: E20000
    Coding: 231E01
    VCID: 1A31F1771D84A6E
    Revision: H40 Serial number: 25081101290508
    Coding: 461000
    VCID: 38750BFF8B4894E
    Revision: 00001000 Serial number: 1829227R041Y05
    Coding: 0000002
    VCID: E3CF0C93224E276
    Serial number:
    Coding: 000000
    VCID: EAD161B70D6476E
    Revision: 13110009 Serial number: 0002635214
    Coding: 0404F5
    VCID: DBBF3473D23E1F6
    Slave Driver:
    Coding: 800000
    Revision: 00H20000
    VCID: 346D3FCF572070E
    Coding: 01030108
    VCID: EFE770A33E86936
    Coding: 181100
    Revision: 15110009 Serial number: 0003183806
    Coding: 0404F4
    VCID: DCBD376FD73018E
    Slave Passenger:
    Coding: 800000
    Revision: -----17S Serial number: VWZ4Z7L3197049
    Coding: 0500040004
    VCID: 62C189977D54AEE
    Revision: 1B001001 Serial number: 00007660486562
    VCID: 356B02CB945A696
  15. 11-20-2011 09:33 PM #15
    2012 Passat TDI SEL Prem :-) this is pre modding
    Sunday,20,November,2011,21:26:13:10051
    Code:
    Chassis Type: 7N0
    Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
              52 56 62 72 77
    VIN: 1VWCN7A38CC014065
    05-Acc/Start Auth. -- Status: OK 0000
    2B-Steer. Col. Lock -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    47-Sound System -- Status: OK 0000
       Coding: 001D0012042400008000
       VCID: 73EE4CB3DAAE376
    Readiness: 0 0 0 0 1
       Revision: 05351113    Serial number: 00001106292021
       Coding: 0000020
       VCID: 16285527219C82E
       Revision: 00H31001
       Coding: C54BC0F5492300FEA30B03EA921E0042A70000
       VCID: 7BFE6493FAFE7F6
    Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
       Part No SW: 5K0 959 434 B    HW: 5K0 959 434 A
       Component: VWKESSYPQ35GP 085 0902
       Revision: 00085000    Serial number: 0151760923
       Coding: 130C0C
       ASAM Dataset: EV_KESSYPQ35G A02014
       ROD: EV_KESSYPQ35G_VW41.rod
       VCID: 346C8FAF9F2070E
       Revision: 00001001
       Coding: 0010001012
       VCID: 18345B1FE388B4E
       Part No SW: 5K0 937 087 Q    HW: 5K0 937 087 Q
       Component: BCM PQ35 H+   111 0147
       Revision: BL111001
       Coding: 6F200E1B982B08D408880201360085480071008645A005F064806000BC70
       VCID: 438EDC73C28EC76
       Component: RLS 060911 05  54  0403
       Coding: 22300A
       Serial number: 003END09DDKM
       Coding: 00003548
       VCID: EFE6C0C33686936
       Serial number: 6940000Y1100006GKX01
       Coding: 303252
       Serial number: 3572MSME07140442ZZZF
       Serial number: 3582MSME612B0442ZZZO
       Serial number: 3516KSME34195E12ZZZS
       Serial number: 3526KSME7D015312ZZZM
       Serial number: 3556LSME2A105610ZZZJ
       Serial number: 3566LSME09571B12ZZZV
       Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
       Revision: FF010040    Serial number: 20110720300459
       Coding: 000A140000
       VCID: 7DFA6A8BECEA716
       Coding: E20000
       Coding: 231E01
       VCID: 1A3041171D84A6E
       Revision:   H40       Serial number: 15081101290397
       Coding: 461000
       VCID: 3874BB9F8B4894E
       Serial number:
       Coding: 000007
       VCID: EAD0D1D70D6476E
    Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
       Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
       Component: ELV-PQ35      H20 0230
       Revision: 00000000    Serial number: 11000111452004
       Coding: 4900000000000000
       ASAM Dataset: EV_ELVMarquMPVW36X A01001
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 2E589DC7710C5AE
       Revision: A1001003    Serial number: 7660603027
       Coding: 010000
       VCID: 29526EDB40E23D6
    Address 36: Seat Mem. Drvr (J136)       Labels: None
       Part No SW: 561 959 760     HW: 561 959 760
       Component: MEM-FS        H04 0181
       Revision: AA000000    Serial number: 00000011394121
       Coding: 00581B0000000000000021010100202020202120202020
       VCID: E0C4B3FFF3583CE
    Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
       Part No SW: 3C0 035 684 E    HW: 3C0 035 684 E
       Component: RNS-MID       H59 2625
       Revision: AB001001    Serial number: VWZ6Z7L8226015
       Coding: 04090002010000A4000B
       ASAM Dataset: ------------------------- ------
       VCID: 254A62EB2CFA196
       Part No SW: 561 959 701 A    HW: 3C0 959 793 C
       Revision: 12110009    Serial number: 0002953420
       Coding: 0405FD
       VCID: 1C3C470F17B0D8E
       Slave Driver:
       Coding: 800000
       Revision: 00H20000
       VCID: 346C8FAF572070E
    Address 47: Sound System (R12)       Labels: 3T0-035-456.clb
       Part No SW: 3T0 035 456 B    HW: 3T0 035 456 B
       Component: KonzernAmp10K H06 0362
       Revision: --------    Serial number: BP225309713690
       ASAM Dataset: EV_AudioVerst10KanalSTT3 S01001
       ROD: EV_AudioVerst10KanalSTT3.rod
       VCID: 306483BF6B384CE
       Coding: 01030108
       VCID: EFE6C0C33E86936
       Coding: 181100
       Part No SW: 561 959 702 A    HW: 3C0 959 792 C
       Revision: 14110009    Serial number: 0003223753
       Coding: 0405FC
       VCID: 1D3A4A0B0CAAD16
       Slave Passenger:
       Coding: 800000
    Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
       Revision: 1B001001    Serial number: 00007660491334
       Coding: 0A11040000010110
       VCID: 356AB2AB945A696
  16. Junior Member darrelld's Avatar
    Jul 16th, 2009
    2012 Passat TDI SEL, 2010 Jetta TDI w/DSG
    11-21-2011 10:45 PM #16
    2012 Passat TDI SEL
    Sunday,23,October,2011,09:47:55:37441
    VCDS Version: Beta 11.10.0
    Data version: 20111014
    Chassis Type: 7N0
    52 56 62 72 77
    VIN: 1VWCN7A39XXXXXX
    01-Engine -- Status: Malfunction 0010
    Component: R4 2,0L EDC H20 2158
    Revision: 71H20--- Serial number:
    Shop #: WSC 06745 128 28888
    VCID: 73EFD769DAAE313
    1 Fault Found:
    5523 - Engine Start Blocked by Immobilizer
    P1570 00 [040] - -
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 271 km
    Date: 2002.14.09
    Time: 13:53:23
    Revision: 05351113 Serial number: 00001105080177
    Coding: 0000020
    VCID: 1629CEFD219C84B
    Revision: 00H31001
    Coding: C54BC0F549220000A30E03E8921F0042A70000
    VCID: 7BFFFF49FAFE793
    Revision: 00085000 Serial number: 0146510023
    Coding: 130C0C
    VCID: 346D14759F2076B
    Revision: 00001001
    Coding: 0010001012
    VCID: 1835C0C5E388B2B
    Revision: BL111001
    Coding: 6F200E1B982B08D408880201360085480071008645A005F064 806000BC70
    VCID: 438F47A9C28EC13
    Component: RLS 010711 05 54 0403
    Coding: 02300A
    Serial number: 003END095M14
    Coding: 00003548
    VCID: EFE75B193686953
    Serial number: 6940000Y1100005EUR02
    Coding: 303252
    Serial number: 3572MSME2A6F505DZZZ6
    Serial number: 3582MSME3578515DZZZ+
    Serial number: 3516KSME0058360FZZZQ
    Serial number: 3526KSME25092212ZZZD
    Serial number: 3556LSME16587E0EZZZ6
    Serial number: 3566LSME6F457E0EZZZH
    Revision: FF010040 Serial number: 20110422200285
    Coding: 000A140000
    VCID: 7DFBF151ECEA773
    Coding: E20000
    Coding: 231E01
    VCID: 1A31DACD1D84A0B
    Revision: H40 Serial number: 28061101290329
    Coding: 461000
    VCID: 387520458B4892B
    Serial number:
    Coding: 000007
    VCID: EAD14A0D0D6470B
    Revision: 00000000 Serial number: 11000110726002
    VCID: 2E59061D710C5CB
    Revision: A1001003 Serial number: 7669425089
    Coding: 010000
    VCID: 2953F50140E23B3
    Revision: AA000000 Serial number: 00000006336520
    VCID: E0C52825F3583AB
    Component: RNS-MID H08 2625
    Revision: AB001001 Serial number: VWZ6Z7L8147113
    VCID: 254BF9312CFA1F3
    Component: TUER-SG FT 002 0523
    Revision: 12110009 Serial number: 0002765549
    Coding: 0405FD
    VCID: 1C3DDCD517B0DEB
    Slave Driver:
    Coding: 800000
    Revision: 00H20000
    VCID: 346D1475572076B
    Revision: -------- Serial number: BP225319883158
    VCID: 306518656B384AB
    Coding: 01030108
    VCID: EFE75B193E86953
    Coding: 181100
    Component: TUER-SG BT 002 0523
    Revision: 14110009 Serial number: 0002950922
    Coding: 0405FC
    VCID: 1D3BD1D10CAAD73
    Slave Passenger:
    Coding: 800000
    Revision: 1B001001 Serial number: 00007660203748
    VCID: 356B2971945A6F3
  17. Junior Member
    Aug 20th, 2003
    Chicago
    11-28-2011 02:59 PM #17
    It's annoyingly loud. I'd rather just lock/unlock without sound if possible. I'm not a VAG-COM expert but couldn't seem to find anywhere I could do this. However, I was able to enable the rain sensing wipers and auto-roll up of windows.
    Are there any new mods out there?
    Thanks!
    2012 Passat TDi 6MT
    1991 Audi 200 20V Quattro
  18. Junior Member
    Nov 28th, 2011
    Colorado
    B7 3.6 SEL Premium
    11-28-2011 03:31 PM #18
    Quote Originally Posted by a4Quattro View Post
    You can do this just by modifying the settings in the dashboard computer (no VAG-COM needed). I think it's under "convenience" and it's called something like "ATS Confirm". Turn that off and the horn won't beep when you lock the doors.
  19. Member bubz0429's Avatar
    Jul 11th, 2007
    Kennesaw, GA
    2003 VW Jetta GLI VR6, 2012 VW Passat VR6 SEL
    11-28-2011 03:32 PM #19
    Thanks!
    No need to VAG it in order to stop the horn from making a sound when locking your car. Its like the first thing I did lol... Its under the MFD, if I remember correctly, its under the Convenience option... should be ATA Confirm.. turn that off and that should stop the horn
  20. Junior Member
    Aug 20th, 2003
    Chicago
    11-28-2011 03:38 PM #20
    Thanks guys! Saw that and was wondering WTF that setting was for Appreciate it!
    Any other nice mods out there? Did anyone get the key fob window up/down to work? I saw some saying it didn't work.
    2012 Passat TDi 6MT
  21. 12-11-2011 08:46 PM #21
    All,
    Here's my scan, after rear camera install. Need to try to clear some of these errors. Advice welcome and appreciated!
    Sunday,11,December,2011,15:13:57:20876
    VCDS Version: Release 11.11.1
    Data version: 20111209
    Chassis Type: 7N0
    Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 46 47 4F 52
    56 62 72 77
    VIN: 1VW....
    05-Acc/Start Auth. -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    2B-Steer. Col. Lock -- Status: Malfunction 0010
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    77-Telephone -- Status: Sporadic communication error 1000
    Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
    Part No SW: 07K 906 055 AL HW: 07K 907 309 A
    Component: 2,5l R5/4V G01 1100
    Revision: T6H01--- Serial number:
    Coding: 0010075
    VCID: 78D13C8E0BC86B4
    Readiness: 1110 1101
    Component: AQ 250 6F 1916
    Revision: 00H90000 Serial number:
    Coding: 0000840
    VCID: 8225DE66DD14B14
    Revision: 00H31001
    Coding: C54BC0F549220800A30B03EC92201061A60000
    VCID: 79D7398AF0C272C
    Revision: 00085000 Serial number: 0146785423
    Coding: 130C0C
    VCID: 3449C8BE9F204F4
    1 Fault Found:
    1057547 - Antenna for Keyless Entry System; Interior Antenna 1
    B1172 13 [008] - Open Circuit
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 45
    Mileage: 63 km
    Date: 2003.14.04
    Time: 13:09:59
    Revision: 00001001
    Coding: 0010001012
    VCID: 18111C0EE3888B4
    1 Fault Found:
    9481748 - High Pressure Sensor
    B10AE 13 [008] - Open Circuit
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 78
    Mileage: 966 km
    Date: 2003.14.31
    Time: 15:04:46
    Revision: BL111001
    Coding: 6F200E1B982B08D408880201360085480071008645A00DF064 806000BC70
    VCID: 43AB9B62C28EF8C
    Component: RLS 120711 05 54 0403
    Coding: 22300A
    4 Faults Found:
    00907 - Intervention load Management
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 5
    Reset counter: 83
    Mileage: 1025 km
    Time Indication: 0
    Date: 2004.14.06
    Time: 00:12:40
    Freeze Frame:
    Term 15 On
    Voltage: 11.65 V
    ON
    ON
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 45
    Mileage: 63 km
    Time Indication: 0
    Date: 2003.14.04
    Time: 13:06:46
    Freeze Frame:
    Term 15 Off
    Voltage: 12.00 V
    OFF
    OFF
    OFF
    OFF
    OFF
    01259 - Fuel Pump Relay (J17)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 43
    Mileage: 1025 km
    Time Indication: 0
    Date: 2004.14.06
    Time: 00:00:05
    Freeze Frame:
    Term 15 Off
    Voltage: 12.10 V
    OFF
    ON
    OFF
    OFF
    OFF
    02894 - Valet Parking Indicator Lamp (K159)
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00101001
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 83
    Time Indication: 0
    Freeze Frame:
    Term 15 Off
    Voltage: 12.05 V
    OFF
    ON
    OFF
    OFF
    OFF
    Serial number: 003END0971L5
    Coding: 00003548
    VCID: EFC387D23686ACC
    Serial number: 6940000Y1100005EHT0Y
    Coding: 303252
    Serial number: 3572MSME1723605FZZZW
    Serial number: 3582MSME3B6F325EZZZA
    Serial number: 3516KSME1A27000FZZZO
    Serial number: 3526KSME25150312ZZZ9
    Serial number: 3556LSME460C3F0FZZZ6
    Serial number: 3566LSME3E0C3F0FZZZE
    Part No SW: 1K5 953 501 S HW: 5K0 953 569 L
    Revision: FF010040 Serial number: 20110404101365
    Coding: 010A140000
    ROD: EV_VW360SteerWheelUDS_VW41.rod
    VCID: 3B5BE382B27E80C
    Coding: E20000
    Coding: 231E01
    VCID: 1917190A188292C
    Revision: H40 Serial number: 29061101290524
    Coding: 461000
    VCID: 3851FC8E8B48AB4
    1 Fault Found:
    01303 - Telephone Transceiver (R36)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00110100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 74
    Mileage: 862 km
    Time Indication: 0
    Date: 2003.14.22
    Time: 21:21:34
    Serial number:
    Coding: 000007
    VCID: EAF596C60D64494
    Revision: 00000000 Serial number: 11000110565002
    VCID: 2E7DDAD6710C654
    1 Fault Found:
    1048842 - Terminal 50
    B11A4 12 [008] - Short to Plus
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 44
    Mileage: 56 km
    Date: 2002.14.00
    Time: 13:20:20
    Revision: A1001003 Serial number: 7669424852
    Coding: 010000
    VCID: 297729CA40E202C
    Revision: AA000000 Serial number: 00000006336635
    VCID: E0E1F4EEF358034
    Revision: AB001001 Serial number: VWZ6Z7L7159169
    Coding: 04090042010000A4000B
    VCID: 256F25FA2CFA26C
    2 Faults Found:
    02873 - Control Module for Back-Up Camera (J772)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 83
    Mileage: 1024 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 74
    Mileage: 862 km
    Time Indication: 0
    Date: 2003.14.22
    Time: 21:21:56
    Revision: 12110009 Serial number: 0002814458
    Coding: 0405FD
    VCID: 1C19001E17B0E74
    Slave Driver:
    Coding: 800000
    1 Fault Found:
    131584 - Motor for Rear Window Regulator
    B11EE 54 [009] - Missing Calibration / Basic Setting
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 43
    Revision: -------- Serial number: BP225309710762
    VCID: 3041C4AE6B38734
    Coding: 01030108
    VCID: EFC387D23E86ACC
    Coding: 181100
    Revision: 14110009 Serial number: 0002822049
    Coding: 0405FC
    VCID: 1D1F0D1A0CAAEEC
    Slave Passenger:
    Coding: 800000
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 43
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 83
    Mileage: 1024 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 74
    Mileage: 862 km
    Time Indication: 0
    Date: 2003.14.22
    Time: 21:21:56
    Revision: 1B001001 Serial number: 00007669835763
    Shop #: WSC 62613 666 28888
    VCID: 354FF5BA945A56C
  22. Member
    Nov 30th, 2011
    2012 Passat V6 SEL Prem/Nav; 2012 Tiguan SEL Prem/Nav
    12-17-2011 10:36 AM #22
    Here is mine; 3.6 SEL Prem/Nav:
    HTML Code:
    Friday,16,December,2011,22:02:50:18647
    Chassis Type: 7N0
              52 56 62 72 77
    VIN: 1VWCM7A32CC......
    Address 01: Engine (0-32-CDVB)       Labels: None
       Part No SW: 03H 906 023 E    HW: 03H 907 309 A
       Component: 3,6 FSI ULEV2 H03 2415
       Revision: MFH03---    Serial number:
       Coding: 001D0012242400008000
       ASAM Dataset: EV_ECM36FSI01103H906023E 001010
       ROD: EV_ECM36FSI01103H906023E.rod
       VCID: 244DC7BC2FC0E0E
    1 Fault Found:
              P1570 00 [032] - -
              Intermittent - Not Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 0
                        Reset counter: 0
                        Mileage: 0 km
                        Date: 2000.00.00
                        Time: 00:00:00
       Part No SW: 02E 300 057 G    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2701
       Revision: 05351113    Serial number: 00001105010616
       Coding: 0000020
       VCID: 1D3BF258C4AAD16
       Revision: 00H31001
       Coding: C54BC0F5492300FAA30E03E9921D0041A70000
       VCID: 7BFFDCC0FAFE7F6
       Revision: 00085000    Serial number: 0149643923
       Coding: 130C0C
       VCID: 346D37FC9F2070E
       Revision: 00001001
       Coding: 0010001012
       VCID: 1835E34CE388B4E
       Revision: BL111001
       Coding: 6F200E1B982B08D408880201360085480071008645A00DF064806000BC70
       VCID: 438F6420C28EC76
       Component: RLS 100811 05  54  0403
       Coding: 22300A
    1 Fault Found:
    01800 - Light Switch (E1)
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 185
                        Mileage: 4831 km
                        Time Indication: 0
                        Date: 2003.14.12
                        Time: 14:20:08
                 Freeze Frame:
                            Term 15 Off
                        Voltage: 12.50 V
                            OFF
                            ON
                            OFF
                            OFF
                            OFF
       Serial number: 003END099Z9T
       Coding: 0000354A
       VCID: EFE778903686936
       Serial number: 6940000Y1100006JE30B
       Coding: 303252
       Serial number: 3572MSME77377660ZZZ-
       Serial number: 3582MSME507A7460ZZZX
       Serial number: 3516KSME3E113912ZZZN
       Serial number: 3526KSME7C623912ZZZW
       Serial number: 3556LSME5C073410ZZZQ
       Serial number: 3566LSME5A1C3410ZZZV
       Revision: FF010040    Serial number: 20110625301572
       Coding: 001A140000
       VCID: 7DFBD2D8ECEA716
       Coding: E30000
       Coding: 231E01
       VCID: 1933E6481882AD6
       Revision:   H40       Serial number: 08081101290868
       Coding: 461000
       VCID: 387503CC8B4894E
       Serial number:
       Coding: 000007
       VCID: EAD169840D6476E
       Revision: 00000000    Serial number: 11000087044001
       VCID: 2E592594710C5AE
       Revision: A1001003    Serial number: 7660559586
       Coding: 010000
       VCID: 2953D68840E23D6
       Revision: AA000000    Serial number: 00000011394459
       VCID: E0C50BACF3583CE
       Revision: AB001001    Serial number: VWZ6Z7L4212038
       Coding: 0409000201000094000B
       VCID: 254BDAB82CFA196
       Revision: 12110009    Serial number: 0002986496
       Coding: 0405FD
       VCID: 1C3DFF5C17B0D8E
       Slave Driver:
       Coding: 800000
       Revision: 00H20000
       VCID: 346D37FC572070E
       Revision: --------    Serial number: BP225309710199
       VCID: 30653BEC6B384CE
       Coding: 01030108
       VCID: EFE778903E86936
       Coding: 181100
       Revision: 14110009    Serial number: 0002988557
       Coding: 0405FC
       VCID: 1D3BF2580CAAD16
       Slave Passenger:
       Coding: 800000
       Revision: 1B001001    Serial number: 00007660420384
       VCID: 356B0AF8945A696
  23. Member
    Nov 30th, 2011
    12-17-2011 10:39 AM #23
    I've changed:
    - Auto Sense Wiper
    - Auto Close Windows/Sunroof
    - Default Blink on Turn Tap from 3 to 4
    - Selected Prem vice Sportsline Theme on the RNS-510
    Will post the after scan later... the above was pre tweeks.
    Other things I've done, Added Euro Switch, stored my backseat headrests (easier without due to carseats), swapped out three mix match seats for three new Radian combo harness/booster, wrapped seats in BlueWave Hawaii covers.
    Next... tinting today!!!!
  24. Member
    Nov 30th, 2011
    12-20-2011 05:41 PM #24
    post mod scan as promised.
    Have done:
    Auto Sense Wiper
    - Auto Close Windows/Sunroof (on rain sense)
    - Retain Heated Seat position
    - Tried all Comfort Windows... All I get is Open/Close of the tilt sunroof... which isn't all in the right coding since it is ignoring the windows part of the checkmarks, and ignoring the open vs lift version of that. The Sunroof prevent is normal behavior pre vagcom, no? There is prob one more bit to get us past the comfort window coding... ANDY or anyone else????
    ok, my post mod code for now. Orignal Scan above. Also , what's up with my 09 Malfunction - 0010. No faults when it scans.... this is new. Door unlocked and doing it from 09, not 46. What gives???
    Code:
    Tuesday,20,December,2011,12:26:17:18647
    Chassis Type: 7N0
              52 56 62 72 77
       VCID: 244DC7BC2FC0DF4
       Coding: 0000020
       VCID: 1D3BF258C4AAEEC
       Revision: 00H31001
       VCID: 7BFFDCC0FAFE40C
       Coding: 130C0C
       VCID: 346D37FC9F204F4
       Revision: 00001001
       Coding: 0010001012
       VCID: 1835E34CE3888B4
       Revision: BL111001
       Coding: 6F200E3FF82B08D408880201360085480071008645A00DF064806000BC70
       VCID: 438F6420C28EF8C
       Coding: 06300A
       Coding: 0000354A
       VCID: EFE778903686ACC
       Coding: 303252
       Coding: 001A140000
       VCID: 7DFBD2D8ECEA4EC
       Coding: E30000
       Coding: 231E01
       VCID: 1933E648188292C
       Coding: 461000
       VCID: 387503CC8B48AB4
       Serial number:
       Coding: 000007
       VCID: EAD169840D64494
       VCID: 2E592594710C654
       Coding: 010000
       VCID: 2953D68840E202C
       VCID: E0C50BACF358034
       VCID: 254BDAB82CFA26C
       Coding: 0405FD
       VCID: 1C3DFF5C17B0E74
       Slave Driver:
       Coding: 800000
       Revision: 00H20000
       VCID: 346D37FC57204F4
       VCID: 30653BEC6B38734
       Coding: 01030108
       VCID: EFE778903E86ACC
       Coding: 181100
       Coding: 0405FC
       VCID: 1D3BF2580CAAEEC
       Slave Passenger:
       Coding: 800000
       VCID: 356B0AF8945A56C
  25. Member
    Nov 30th, 2011
    12-25-2011 05:28 AM #25
    Andy,
    Anything new? Are we SOL on the Comfort functions working on Windows....I've only got a Sunroof Venting going on. Really wish I booked marked some other readings... something about a different model that had this issue and then they got around it by changing the MFD options to??? Either from all door to single, or drivers only. I can't remember.... needless to say, I tried all combos in the Convience menus after Enabling the boxes in VCDS. No joy... still only sunroof venting and closing when holding down key fob.
    But I have the auto close windows/sunroof (on rain sense) working.... found that out twice this week! Love the Hawaii 'Winter'.
    Need lable files? I could work through mine next time I plug in.
  26. Forum Sponsor Andy@Ross-Tech.com's Avatar
    Jun 5th, 2002
    2012 Passat TDI 6MT
    12-25-2011 09:01 AM #26
    It still doesn't look like anyone has found a way to enable comfort windows. A pre-label file for the seat mem would be appreciated.
  27. Member
    Nov 30th, 2011
    12-25-2011 09:53 AM #27
    I'll see what I can do for ya next week then Andy.
    Got any clues on this thread?
    http://forums.vwvortex.com/showthrea...uto-Close-Rain)
    Also what is the Sub1 module for 09 Central Elect in my Tiguan? Wischer 19091 013 0203?
    Let me know if there is anything there that you or other Ross-Tech folks need prelabel on.
    Thanks!
  28. Member
    Nov 7th, 2011
    North Dallas, Texas
    12-25-2011 01:47 PM #28
    [QUOTE Selected Prem vice Sportsline Theme on the RNS-510
    [/CODE][/QUOTE]
    What it's this? And what it does on the Nav?
    Can somebody explains me?
    2004 VW Touareg V6 - Traded for the 2006
    2006 VW Touareg V6 - Traded for the Tiguan
    2009 VW 2.0T Jetta Wolfsburg - traded for the Passat
    2012 VW Tiguan 2.0 TSI SEL Premium Nav
    2012 VW Passat TDI SEL Premium w/rear lid spoiler
  29. Member
    Nov 30th, 2011
    12-26-2011 03:42 AM #29
    Quote Originally Posted by Kchorro View Post
    [/CODE]
    Can somebody explains me?[/QUOTE]
    Kchorro,
    take a look at this thread. I didn't flip over to NAV to see what changed, but on the display it changes the colors... that is all.
    First post on this thread.... halfway down it shows the 3 screen shots of the highline, Prem, and sports line look.
    http://forums.vwvortex.com/showthread.php?4121687
  30. Junior Member
    Nov 28th, 2011
    Colorado
    B7 3.6 SEL Premium
    01-11-2012 10:30 PM #30
    Quote Originally Posted by pbafire View Post
    Pbafire, do you recall where the bit was to retain heated seat position? Is it just yes/no, or can you tell it to retain it for a certain amount of time? My last car would keep it in memory for some amount of time, maybe 15-30 min, and after that it would reset, which seems like the way to do it...
    Also, any other cool VCDS mods that you've done since your post? Seems like you spent some time figuring out what cool stuff you can do...
  31. Member
    Nov 30th, 2011
    01-11-2012 11:20 PM #31
    Quote Originally Posted by miff View Post
    The retain is not a while on thing. It's a once in use, then car gets turned off... It will remember or resume the heat level last set when the car is turned back on.
    Will search for the write up I stole that idea from... Bit was the same.
  32. Member
    Nov 30th, 2011
    01-11-2012 11:30 PM #32
    found here...
    http://wiki.ross-tech.com/wiki/index...6/AJ%29_Tweaks
    Try 08 (heat and AC) - adaptations pull down.
  33. Junior Member
    Nov 28th, 2011
    Colorado
    B7 3.6 SEL Premium
    01-11-2012 11:38 PM #33
    found here...
    Thanks!
  34. 01-14-2012 12:08 AM #34
    I purchased my VCDS kit recently but I haven't had the time to connect it up and change the rain sensor settings but I do have a question regarding the remote start feature. Unlike our Equinox, when I active remote start the car will turn off when you unlock the doors and you must then use the push start. Is there a tweak that I can do to keep the car running when I unlock the doors?
    Thanks in advance!
    Scott
  35. Member cfurman's Avatar
    Feb 4th, 2008
    Michigan
    99 Jetta Dsl;96 GTI;05 Jetta 1.8T;10 Jetta 2.5;11 Tiguan SEL;11 GTI;11 Golf TDI;12 Passat 3.6SEL
    01-15-2012 03:13 PM #35
    Quote Originally Posted by swich2mac View Post
    Thanks in advance!
    Scott
    I would like to know this also...
    ________________________
    2012 Tiguan SEL
    2013 GLI Autobahn Nav
