VWVortex.com - Vw Jetta Backup Camera
    Page 1 of 6 12345 ... LastLast
    Results 1 to 25 of 146
    Thread: Vw Jetta Backup Camera
    1. Member Mo_Focus's Avatar
      Oct 9th, 2005
      2010 Golf Highline TDI DSG, 2011 Jetta Highline TDI
      10-15-2011 04:34 PM #1
      I took a chance and ordered the JSW/Tiguan back-up camera and was hoping it will fit on the Jetta as well. Guess what???? it does
      Part number for the trunk handle on the Jetta is 5N0 827 566
      Part number for the JSW handle with camera is 5N0 827 566J so its the same part and it fits great.
      As for the rest of the install i haven't done it but looks very similar to what has been done on JSW.
      http://www.myturbodiesel.com/forum/f...ortwagen-5930/
      Few changes on the harness side. The harness that i ordered from Poland Ebay does come with Yellow/Black/Red wires. Black/Red wires are really long and go all the way. Yellow wire is short and should be used as "Signal" wire and get connected to the back up lights, no need to run it to CECM on the Jetta.
      Just before everyone starts asking me where i got it from, it was purchased from ebay under the seller www*carsystems*pl
      http://www.ebay.ca/itm/TIGUAN-5N-VW-...ht_3649wt_1185
      Here are the camera pictures.
      Install went really easy.
      Took radio out and connected the plug in the back of the RNS-315.
      I just followed the radio harness and followed the same path.
      then decided to follow another harness that went all the way to the back. took the door sills out and tucked the wire harness under. I've also decided to take 2 more wires and attach to the harness as well. These wires will be used later on for the rear fog and maybe something else as well, mind as well do all the leg work now.
      used the electrical wire and re-wrapped the length of the cable.
      once i got to the trunk, then just followed the same harness that goes into the trunk lid. Rest was easy!
      Sorry, i didnt take too many pictures, rain was on and off and i was trying to finish this ASAP.
      Here is the final product. Overall it was easy to do, lot of thanks goes to others that have finished this task in the past.
      10 VW Golf Highline DSG TDI- wife's , 11 VW Jetta Highline 6spd TDI mine!
    2. Member antwan30184's Avatar
      Jul 21st, 2011
      NE-METRO-ATL, GA
      2012 GLI Autobahn Candy White
      10-15-2011 06:34 PM #2
      Does anybody know if this has been done with the rcd-510 / GLI fender system.
      Pride in the Simple Stuff.
    3. 10-15-2011 06:36 PM #3
      If I want to setup a backup camera I have to get RSD-310 or 510 first.
      But now I have RCD-510..
    4. Member panzer 2.3's Avatar
      May 24th, 2008
      pa
      1979 rabbit VR6T, 2016 Jetta 1.8t sport
      10-15-2011 09:38 PM #4
      Sweet very nice. I may have to do this, great write up
      DCIVW Eastside
    5. Member MAXecutive's Avatar
      Aug 26th, 2011
      2012 VW Jetta TDI, 1997 Nissan Maxima SE
      10-16-2011 02:11 PM #5
      Very nice, how much did it run you in parts? I see that you have a TDI 6spd also . I assume the harness has everything needed for the reverse gear switch. The link you posted doesn't work.
      2012 Volkswagon Jetta TDI - 6spd - Navi - 17" SELs - Votex Lip Kit
      1997 Nissan Maxima SE - V2 Supercharged w/ 11psi
      1986 Nissan 300ZX 2+2 GLL - 5spd
    6. Member Mo_Focus's Avatar
      Oct 9th, 2005
      10-16-2011 03:45 PM #6
      Quote Originally Posted by MAXecutive View Post
      yeah the harness that i got from "www*carsystems*pl", just on ebay search for the seller. It was around 450$ canadian by the time it came to my door.
      As for the harness, its got everything, you just need to connect the 3 wires.
      Yellow- connects to the + signal wire of back-up lights.
      Black- connects to ground, wires are long enough that will allow you to connect to ground near fuse box.
      Red- its connected to a ACC+ in the fuse, but i need to buy the proper connetion to connect to the back of the fuse box. currently its just connected with "add a fuse"
      Hope this helps. Not sure what happened to myturbodiesel site, but if you just google vw back up camera you will get tons of hits.
    7. Member MAXecutive's Avatar
      Aug 26th, 2011
      10-16-2011 10:01 PM #7
      Thanks, that's not a bad deal. Good idea on running a spare wire to the back for future use.
      May 16th, 2011
      Vancouver
      2011 Jetta 2.5
      10-17-2011 03:29 AM #8
      Quote Originally Posted by antwan30184 View Post
      shouldnt, the rcd units have no video input iirc
      2011 Jetta 2.5 Highline PGM
      - Autotech Engine Mount Insert - Full Interior LED Conversion + DRL
      Jan 26th, 2011
      Colorado Springs
      '14 GLI
      11-29-2011 06:36 PM #9
      Has anyone talked to the dealership about any warranty issues with doing this?
    10. 11-30-2011 01:31 AM #10
      I've done some searching but couldn't find it anywhere but how do I find out what model radio I have to see if I can do this? I have a 2012 jetta 2.5 SE with convenience and sunroof. I would love to add this feature to my wife's car since she has a horrible time backing up. She backed into several things in her last car.
    11. 11-30-2011 12:49 PM #11
      According to VW's Website the SE with conv & moonroof comes with the Touchscreen VIII radio, the SEL would have provided you with the RNS-315 to hook up the back up camera.
      http://www.vw.com/en/models/jetta/tr...e88b943fe0e53c
    12. Member Mo_Focus's Avatar
      Oct 9th, 2005
      11-30-2011 09:47 PM #12
      Quote Originally Posted by DEEEJ View Post
      why would you want to do that?
    13. Member EuRoGTI86's Avatar
      Sep 27th, 2008
      LongIsland, NY
      12' Jetta S, 95' Passat GLX, 93' Corrado SLC
      12-01-2011 04:00 AM #13
      will this work on an aftermarket gps unit?
      R.I.P. Allen A.K.A. vr6inside98. 89'-11' I LOVE YOU MAN
      Tri state area. VAG-COM (VCDS) Scans/Mods available (HEX+CAN)/Suspension install available/Fender rolling available. Send me a PM for pricing!
      Instagram- @mr_toffee
    14. 12-01-2011 04:16 AM #14
      Quote Originally Posted by Chpwaman View Post
      Dang, so basically I'm out of luck and just have to pray she doesn't back into anything.
    15. 12-01-2011 12:09 PM #15
    16. 12-01-2011 12:25 PM #16
    17. 12-01-2011 12:37 PM #17
      That looks like the touchscreen VIII radio unit...did you install that aftermarket?
    18. 12-01-2011 12:39 PM #18
      It's a circuit board that goes inside the factory rcd 510
    19. 12-01-2011 02:13 PM #19
      Where can one find the card? I can find the external box for sale, but no card.
    20. 12-01-2011 09:53 PM #20
      Any shop that deals with directs. My boss might be down to do deals of you ship the radio I can do the mod and ship it back.
    21. 01-08-2012 12:23 AM #21
      I successfully completed the install today. Thanks Mo_Focus for your help on getting this done!! It wasn't that difficult of an install. I ended up ordering the part off of some guy on ebay. He ordered the JSW latch release / camera combo from VW Japan and the wire from VW Poland. I believe the total price was about $380'ish shipped to my door for both parts and it took about 2 1/2 hours for the install. Would have been done sooner, but my camera lead wasn't connected properly so it took a bit to diagnose.
      Let me know if anyone wants the contact information for this guy.
    22. Member
      Oct 25th, 2011
      Southern California
      01-08-2012 01:37 AM #22
      I am very intrigued about getting the backup camera on the Premium VIII system. How difficult is it to install the circuit board as a DIY for the Premium VIII system? This is very, very interesting
    23. Junior Member
      Jan 8th, 2012
      Jetta MK6
      01-11-2012 05:05 PM #23
      Hi there!
      I bought the same camera from an eBay seller and originally intended to have a VW mechanic install but but having a look at this thread I may have a got at it myself.
      Are you able to give me some pointers on how to start pulling apart the trims and how to take the radio out? Or at least point me to a thread that shows how to do these? It seems straightforward but I don't want to start yanking out parts of the car and break them
      Thanks.
    24. Junior Member
      Jan 8th, 2012
      Jetta MK6
      01-11-2012 06:15 PM #24
      Ok this is just FYI for people thinking of getting a new head unit to install a camera.
      There are 3 RCD510's used by VW worldwide. One of them have definitely got a video input interface at the back, the other 2 may or may not. As I understand it, the head units of Jettas in the US all don't have video inputs. Can someone identify which of the following are used in the US?
      For those with non-touchscreen head units and would like to get one with a video input, I suggest looking for a BOSCH model shipped from overseas (US may only sell those without the input). You can identify the models based on the buttons on the screen.
      BOSCH - this one supposedly all have video input
      BLAUPUNKT - not sure?
      DELPHI - not sure?
    25. 01-11-2012 08:38 PM #25
      Quote Originally Posted by kickapoo View Post
      Pm me and I can help you out if your in so cal then I could do it at my shop.
