#36
Probably. My understanding is the PagParts kit brings some kind of 90* cobra head or sumtin
Sent from my MB860 using Tapatalk
#38
Yeah its 3" or 3.5" I cant remember...with a cobra head at the end. i'll snap a pic tonight.
#40
Looking good
Pag Parts
Turbocharger Systems, OEM Parts / Fabrication
Garrett / PTE / BW / TiAL / Clutchmasters / Southbend / Brute Con Rods / Wiseco / CP Pistons / Supertech / Ferrea / CatCams / Walbro / EV14 Injectors / Eurodyne Software / Much More... Pag Parts Facebook
#43
Haven't updated this in a while.
So engine is back in, everything is button up. good to have it looking like a car again.
Not much is being done as I am waiting on my 3" Eurojet exhaust to show up. kind of on hold until then.
Went to top off coolant yesterday and found the seal on the hard pipe going to the waterpump/t-stat housing was ripped in half. had a small coolant leak lol. had to loosen the manifold to get at the stupid thing. what a dumb design.
Software has been flashed with a 630 base file that I modified for my 840cc setup. have to alter the alpha n table to suit my 80mm + sem + mafless. probably putts with that until I see my parts from the dealer.
the 550hp core from Arnold was a tight fit! had to modify the bumper slightly to get it to fit back on. other than removing a few inches off the lower lip and modifying the side grills not to much had to be done.
Gonna snap some pics and update the thread this weekend. My SLR is at a friends so im afraid it will be iphone pics for now.
Cheers
#44
Actually, that would be a 600hp core which is 12" high![]()
Pag Parts
#45
#46
#47
#48
Rac are you worried about fueling?
I am trying to decide if I want to run a surge tank or not
CTS 3076 kit, CTS 750hp FMIC, CM FX400, 2L, AEB, RMR IM, Raxles, Eurodyne, 870's...
Vag Scans, pm me
#49
ill post some pics of my 4in setup.
it wasnt too bad.
this was on a tt225.
#50
#51
So I went to put on a set of new rotors that i've had for 2 years but brand new, just to find out they are the wrong ones. right diameter, wrong hub. 5x112 maybe. weak. thank you ECS. first and last time i ever order anything from there.
Front suspension is on.
was able to snag some nice SMC air line from work to use for vacuum line. came out pretty good.
gonna start it tomorrow. straight pipe because my exhaust hasn't arrived yet.
maybe first thing in the morning too. just for s*its and giggles.
heres some iphone pics:
#52
Looking goodI like the SEM Intake Manifold, they looks so damn sexy in our bays
Brute 20mm Connecting Rods, ACL Bearings, Wiseco 83mm Pistons, FSI Crank, AEB Head, CatCams 3658, PagParts GT3076R Bottom Mount V-Banded Turbo Kit, PagParts Garret 550HP Core, VF Engineering Motor Mounts, SEM IM, Labonte W/M, 70mm TB, Tial Q BOV, Tial Wastgate, Turbosmart Dual Stage Boost Controller, Peloquin LSD, Clutchmasters FX400, 910cc Injectors, IE Surge Tank, Eurodyne with Maestro.... PAGPARTSClear Water Dubs
#53
Great build! Glad to see some positivity regarding the 5857 too, I'm using one for my build and most people seem to talk it down. Looks excellent so far though, in for the rest of the build
Isaac
#55
Congrats man, looks good![]()
#56
#58
should do some seriosu damage when its all done
PAGPARTS /SEM /INA /dotuning/ EURODYNE/
check the build thread for deails click here
formerly known as BigAl03GTI
#59
#60
If he is not using any other boost source to the wastegate, it would run shut all the time, which would blow his engine in no time.
▀▀▀ EIGH-T6 // "Give me enough traction, and I will spin the WORLD!"
Portugal // Europe
MS II V3.0: http://eight620vt.tk/
#62
#63
#65
Quick update to the thread.
Heres the dyno:
https://docs.google.com/file/d/1DQdH...G9iMw3X-a/edit
420whp on a dynapack. Ran out of fueling thought as my IDC was like 83% and I couldnt get my stock in tank to keep up lol
Have a genisis intank now. Hopefully next summer will look better![]()
#67
91 Mk2 GTI / 1.8T (Awp) / 6 speed (O2M) / Holset HX27w Turbo / Stainless Log manifold / Tial 38mm WG / TurboSmart MBC / Simens 630cc / Aeromotive FPR / 034 fuel rail / TurboSmart BOV / CxRacing I.C / 2.25'' I.C piping / 3'' downpipe to 2.5'' exhaust /Kirk Rollcage / Rear disks / solid-poly bushings / Custom mafless TUNE / SWAP in PROGRESS......( IE rods coming too )
#69
Nice! Glad to see good results.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
