awic core
vitron rubber for gasketing
#421
#422
awic core
#424
Almost ready for welding.
Now I just need a tig welder.
#429
#431
Ordered a aluminum heat exchanger yesterday.
26" x 7" x 2"
I also pick up a spool gun and tank for tacking eveything in place to have someone tig it for me. A tig welder is not in the cards for me at this time. My money tree isnt liking the weather I guess.
#432
Heat exchanger came in.
Heres a comparison picture of the IC and heat exchanger. I can see why bell ICs are more expensive, a ton more surface area.
#433
Here is what I am thinking for the pulleys. Both will be attached to the same "bar" mount that move the stock idler (green) towards the back of the motor and a second pulley (yellow) straight out from that. The red pulley is the approximate location of the s/c pulley.
I finished the jig for the plenum. I also started tacking some pieces in place and became inpatient, waiting for someone else to tig weld it so Im going the mig and grind method
I can always make another one.
I will be having someone tig the one flange to the C2 flange, that I would not want to buy a second time. The rest will be "modular"/bolt on. That way if in the future I want to cut a big hole in my hood I and throw a M90 on there
Any ideas on getting the modular pulley mount off. I have tried 2 different pulley pullers. One pulled the threads out and the other just slips off. I will take some pictures of this tonight, to see if I can get some input/help.
#434
INA Engineering Inc.
Email | Facebook
INA Billet | 034 EFI | Mahle Powerpak | DM Forged | Ferrea | Supertech | ARP | South Bend | HTA Turbochargers | Mocal Oil control | DBW Throttle Body Upgrades
#435
I will have to look into that. Im not sure how far forward the s/c pulley will be, if there will be a straight line for the belt to run.
This is the modular "hub" that the pulley bolts to on the s/c that I need off. Its a 4 bolt and I have the smaller 5 bolt version from zzp that I need to put on.
#436
Email | Facebook
#437
#439
#440
Bummer, even just a plumbers torch is probably enough. Or rather, hopefully enough.
#441
#444
an item INA just posted o FB.
A/C delete and 2.5 20V Power Steering install kit
posting here because it might be helpful for the SC pulley set up
#445
nice. the 2.5l is finally getting some attention. lots of new parts coming in this yr
#446
#447
Email | Facebook
#448
#449
Like this
If anyone has any ideas, here is the default picture I am using. MS paint it up.
#450
So, double up the green. You will have to have two separate pulleys because they will be spinning different speeds but you have a mounting point at least.
Edit: changed pic to make it a little more clear what i meant. Everything is off the crank/ac belt.
#451
The loss of rap is what I would be worried about here (redline) but I havent messed with belts much so I dont know how big a deal this would be. And the reason for concern is I wouldnt want it to slip there because then it will slow everything acc. wise down.
That definitely looks the easiest. Thanks!
I will also have to recalculate the belt speeds, and possibly get a larger s/c pulley to keep the boost in the range I want.
#452
Could make a bracket going in between the two lower idler pulleys to put the new pulley on to gain some of that wrap back.
I really don't know what exists in there for good mounting points for brackets and stuff though.
#453
#454
Just out of curiosity, when this is all complete can I drive your car?
I can't wait to see this. Seriously, I just put extra money into savings to get this.![]()
#455
