VWVortex.com - supercharged 2.5l
    Page 5 of 54 FirstFirst 12345678915 ... LastLast
    Results 101 to 125 of 1327
    Thread: supercharged 2.5l
    1. Member mldouthi's Avatar
      Jun 26th, 2010
      Austin
      08' Rabbit (Lifted), 07' Rabbit (lifted), 04 Audi S4, 02 Audi Allroad, 93 Audi 100s, 72 Type 3 FB
      10-20-2011 03:18 PM #101
      What do the green numbers represent in this map, I thought it was rpm. But it doesnt seen to correspond to this map.
    2. Senior Member kevin splits's Avatar
      Aug 23rd, 2010
      Arizona
      01001011010011110 1010010
      10-20-2011 03:32 PM #102
      Idk I went to a Cobalt forum where obviously they will know more about the charger than us, and the 14,000 rpm s/c redline is what they say is max for the stock pulley. Without the circumferance of the crank I cant realisticaly come up with a suggested s/c pulley size.
      "The Vile Bunch" ll v2lab ll eemilitiatv ll Stay Orange.
      2008 Mkv-sold; 2003 yellow SRT-4-sold; 2009 G8 GT-sold; 1991 Talon TSI- fully built-sold ; 2011 Mk6
    3. Member mldouthi's Avatar
      Jun 26th, 2010
      Austin
      10-20-2011 03:47 PM #103
      Quote Originally Posted by kevin FaKiN spLits View Post
      The data that you showed makes sense with the second map, which is the one on eatons website. but not with the first. I was just curious.
      Is the stock s/c pulley 4 inches?
      Ill get out the calipers later tonight and see if I can get some dims of the pulleys. I also asked ECS what there lightweight pulley diameter was (the standard, not the underdrive). Maybe ill get an answer there.
    4. Senior Member kevin splits's Avatar
      Aug 23rd, 2010
      Arizona
      10-20-2011 03:53 PM #104
      Quote Originally Posted by mldouthi View Post
      If you can get a ratio of 2.3 itll be just right, so if ECS gets back with that info it'll tell us exactly what size pulley we need to achieve 10 psi
    5. Member mldouthi's Avatar
      Jun 26th, 2010
      Austin
      10-20-2011 05:05 PM #105
      ECS
      Diameter of the stock and the lightweight pulley are the same. Our ECS lightweight crank pulley is 70% lighter than stock, that is where the extra throttle response and horsepower is made!
      Dumb, that didnt help.
    6. Member WhatNoGarnish's Avatar
      Jul 6th, 2007
      San Antonio
      Golf 2.5
      10-20-2011 05:25 PM #106
      ECS
      Ha!!
      [Insert Mods Here]
    7. Senior Member kevin splits's Avatar
      Aug 23rd, 2010
      Arizona
      10-20-2011 05:29 PM #107
      ECS
      If the 2.5 and 2.0t have the same diameter crank pulley, I have a 2.0t motor sitting on a tire next door. Ill ask pensy to see if he can maybe measure the diameter of his.
    8. Member mldouthi's Avatar
      Jun 26th, 2010
      Austin
      10-20-2011 05:38 PM #108
      I just measured but I only have 6 inch calipers. but I measured to the from outside of the belt to the inside of that metal ring on the outside. and then the width of that outside ring, if that makes sense. So from outside to outside with the belt is around 6.6 in. And the ac comp. is 5.195in including the belt.
    9. Member mldouthi's Avatar
      Jun 26th, 2010
      Austin
      10-20-2011 05:53 PM #109
      I forgot to measure the inside pulley that drives all the accessories.
    10. Member mldouthi's Avatar
      Jun 26th, 2010
      Austin
      10-20-2011 06:10 PM #110
      The inside pulley on the ac comp, is 4.575in.
    11. Senior Member kevin splits's Avatar
      Aug 23rd, 2010
      Arizona
      10-20-2011 06:59 PM #111
      Can someone with this manifold please give these measurements, I just want to know how wide the plenum is and the distance between the plenum and flange
    12. 10-20-2011 07:30 PM #112
      I'll get those for you tomorrow. I don't have any way to measure it at my apartment right now but will when I'm at the garage tomorrow. If I see my neighbor tonight I'll borrow his tools, but otherwise I'll just get em later.
      You do realize this intake tapers down though. I don't really want to supply that radius or dimensions to that degree. Don't want to tick anyone off. I don't see any harm in giving you the max depth of those two dimensions though. Did you also need that third dimension you marked on the TB side or is that just a mistake in the drawing? Not really sure how to reference that dimension on the TB side you marked actually. If you want to clarify that would be great.
      Why don't you guys pay someone to draft something up for you in inventor or pro e? Does anyone have a template available for the 2.5 MKV bay, intake side to radiator support? Watermark it and send it to tchilds3404@yahoo.com, promise not to give to anyone else.
    13. Senior Member kevin splits's Avatar
      Aug 23rd, 2010
      Arizona
      10-20-2011 08:12 PM #113
      No its not a mistake. I know it tapers so thats why I included the throttle body side as a measurement. Its the widest part. Also just a rough measurement from the plenum to the flange. I think Im going to need shorter runners
    14. 10-20-2011 09:22 PM #114
      I vote ultra budget build, cut the stock intake, bond silicone couplers to the runners, build slip on runners w/clamps, screw the IC, see if you can crack the nylon runners/flange.
      SUPER GHETTO but it would work until the intake runners melted.
    15. Member mldouthi's Avatar
      Jun 26th, 2010
      Austin
      10-20-2011 10:18 PM #115
      Quote Originally Posted by tchilds View Post
      Ill second that. I want a model of the engine bay as well. Although I am stuck using crappy CoCreate. Ill be getting a copy of solidworks soon, 10000X better.
      I would love to see that.
    16. Senior Member kevin splits's Avatar
      Aug 23rd, 2010
      Arizona
      10-20-2011 10:44 PM #116
      Lol no thanks. That plastic wont hold under the chargers weight!
    17. 10-20-2011 11:46 PM #117
      Meh sure it would. You have a support bracket to use unless you remove it beneath the intake manifold. Oddly enough I can't remember how it is configured but I do remember it was there!
      A nylon flange w/silicone couplers that has runners slip on over it would be pretty solid I think. It also has the thermal advantages over metal to metal to metal to metal.... to metal... hehe I really don't like super chargers for how much heat they produce though so no idea if this would work. It would be cool having a modular design too, w/dif runner lengths which you could incorporate.
      Welding is easier though and that $300 ain't a bad price at all. The oval runners going to be a pita though.
    18. Member _V-Dubber_'s Avatar
      Jan 29th, 2007
      Tampa, FL
      07 CW Rabbit 2dr 2.6T, 2010 MkVI Golf 2dr
      10-21-2011 03:53 AM #118
      Im considering jumping ship from the Rabbit to the 3.6l Genesis, and putting a blower on it.
      Idk to me this just looks soo much better than a Mkv and puts down 301whp stock, with header, exhaust, tune and larger tb 360whp, and a company makes a 5k$ blower kit that makes over 500whp and it sounds mean as hell
      The Hyundai Genesis is the best performance bargain right now. The GTI is a more complete car for the price and a nicer place to be, but it cant match the Genesis's performance. A Lancer Ralliart is 4 grand more expensive so that's out. A MS3 is more powerful but then again it is FWD....and underneath the big turbo it's just a Mazda3 underneath.
      However all that being said, the base Hyundai Genesis 2.0T R-spec is the better tuner car rather than the V6. The base which is now called the R-spec is lighter and stripped out which is what you want because honestly who gives a frack how many speakers your car has, or if the seats are heated, or if they are leather? None of that has anything to do with performance. And the 2.0T is not the crummy turbo from the Sonata Turbo/Kia Optima Turbo. It's the 2.0T MiVEC engine from the Mitsubishi Lancer Ralliart which is internally the same as the Lancer Evo's. So right out of the box you already have a HUGE tuning potential. But it's a coupe so it's sexier than the Evo. And it's RWD not 4WD which is what you really want. Go for it man. I can't join you because I've modified my Rabbit beyond the point of no return. I couldnt sell it even if I wanted to.
      My choice if my situation were different; I had no car and had to buy one? Get a used 2010 Nissan 370Z with sport package for around 27grand
    19. Member mldouthi's Avatar
      Jun 26th, 2010
      Austin
      10-21-2011 07:18 AM #119
      I have been racking my brain over this one... how to match up those ovals????
      My C2 flange should be here monday though
    20. Member mldouthi's Avatar
      Jun 26th, 2010
      Austin
      10-21-2011 07:36 AM #120
      Heres a little different design. I am really going to need to take the intake manifold off and see Where the sc can be placed, in regards to the pulley hitting other things.
    21. 10-21-2011 08:46 AM #121
      Honestly, for the oval runners. I wouldn't be satisfied unless I modeled and benched a ton of different collectors/stack designs. The cylinder head has some funky stuff going on too. Either way its going to stuff air in the cylinders but you could easily gain or lose a good 40 horsepower because of these stupid ovals. They're a really superior design but a pita to work around unless you want to pay a machine shop like $2,000.
      The other SRI's have cut corners in this respect though so I don't see any reason yours has to be over engineered either.
    22. Member mldouthi's Avatar
      Jun 26th, 2010
      Austin
      10-21-2011 08:54 AM #122
      What are you guys thoughts on runner lenghts and plenum volume?
    23. Senior Member kevin splits's Avatar
      Aug 23rd, 2010
      Arizona
      10-21-2011 10:34 AM #123
      I bought my plenum, runners, and fuel rail, plus bits from here. Always have for the things I need oval tubing from http://rossmachineracing.com/
    24. Senior Member kevin splits's Avatar
      Aug 23rd, 2010
      Arizona
      10-21-2011 10:44 AM #124
      I think this is a little too big to work. Everything hangs down to low, for the alternator where its at. Which is why Im making a manifold similar to your shape, but the ends are going to be rolled so the air flows smooth. Then Im just gonna bolt the charger to the manifold like the Jackson Racing Honda kit, and inquire the spacer awic Josh was talking about if I have cooling issues, or Ill just make a 1" spacer and drill the sides and slip copper nozzles in and run DEI's Cryo2 kit on a electronic management to spray as needed when temps get up a bit
    25. Senior Member kevin splits's Avatar
      Aug 23rd, 2010
      Arizona
      10-21-2011 10:51 AM #125
      Quote Originally Posted by _V-Dubber_ View Post
      Yea, I love this car. I will only get the v6 tho, and supercharge it. I hate the 370z, the Genesis I showed is sexy as hell, but Id get in blue, with CCW Classics 12" rear 10" front, and slam it on Ksports. I have heard the 2.0t is the MIVEC 2.0t which is why I said that its a better motor than VW's 2.0t. My brother has a MS3 and to put it simple its a piece of sh*t to drive, plus it looks like a minivan. The v6 Genesis makes almost an extra 100hp with a tune, headers, and free flowing exhaust(how Hyundai restricted the car), and an intake, or you can leave stock, s/c it and tune it for 430whp, intercool and rods for 500+
