VWVortex.com - How to build a relatively inexpensive, reliable, 'powerful' 2.0 8v.
    Page 6 of 99 FirstFirst ... 23456789101656 ... LastLast
    Results 126 to 150 of 2452
    Thread: How to build a relatively inexpensive, reliable, 'powerful' 2.0 8v.
    1. Member Low Sugar's Avatar
      May 30th, 2008
      Westport, MA
      02 Jetta Wagon
      03-27-2012 11:36 AM #126
      http://www.autotech.com/product/chip...jetta-mkiii-2l
      Worth the $100??
      Im not really looking to go fast Id just like my car to be able to get out of its own way, especially on the highway.
      Pebble Pushers Anonymous
    2. Member nemo1ner's Avatar
      May 5th, 2004
      NJ
      1983 GTI; 1993 Trek
      03-27-2012 11:53 AM #127
      I was looking at that chip as well. My engine is 100% stock which I like, but I want to give it a slight bump.
      //COOLWATERmotorsport
      |F0TZ3 HA5E| - The Project
      VWVolkshaus: Haus des Verrückten
    3. Banned Hurt's Avatar
      May 3rd, 2011
      Boston, MA
      1998 Jetta GT, 1998 GTI 2.0, 2012 GLI, 2012 GTI
      03-27-2012 02:29 PM #128
      Quote Originally Posted by Wirt View Post
      Worth the $100??
      Quote Originally Posted by nemo1ner View Post
      Just get a TT non-cam 91 octane chip (85 bucks shipped on MJM) There is no reason to rev to 6900 on a "stock" aba, like autotech advertises it's chip tune redline to be.. You won't make any power past 5500 on an aba without a nice cam, anyway.
    4. Member Low Sugar's Avatar
      May 30th, 2008
      Westport, MA
      02 Jetta Wagon
      03-28-2012 09:30 AM #129
      Quote Originally Posted by Hurt View Post
      Excuse my ignorance to this stuff, but there isn't any gas stations around me that have 91 octane. Would that be an issue with that chip?
    5. Senior Member tdogg74's Avatar
      Mar 1st, 2002
      In a tea cup
      Previous: 1997 8v Golf. Current: 2000 1.8t Passat
      03-28-2012 10:20 AM #130
      The difference in tunes between a 91oct chip and a 93oct chip are little/none. The ABA can take a LOT of timing before it knocks and starts to pull timing.
      And also, you could have two companies that make a 91oct chip, but have totally different ignition tables. Stick with the TT chip. It's a better tune. *my opinion.
    6. Banned Hurt's Avatar
      May 3rd, 2011
      Boston, MA
      03-28-2012 12:57 PM #131
      Quote Originally Posted by 911_fan View Post
      Yeah, I generally stay away from any chip other than GIAC or TT. A friend of mine had a Neuspeed P-Flo chip in his mk1 rabbit aba swap, and that thing sucked down a ton of gas compared to without the chip, and the same with the Q-chip. They suck down gas! I've never really noticed TT's chips changing my MPG, personally. I've used C2 plenty of times, but I'm done dealing with rev-hang and bucking at 2k RPM. Until they fix the tune's issues, I'll be sticking to TT.
    7. Junior Member ELiT3's Avatar
      May 17th, 2011
      Houston, Tx
      00/VW/JETTA 2.0L AEG
      03-28-2012 01:11 PM #132
      hm i would've never known c2 chip had a problem. I guess im going TT, but do you guys think the TT chip will go good with an Autotech 270 cam. I got the cam on black friday for 40% off thats why i went with autotech and not TT.
      "Remember Professionals built the Titanic, Amateurs built the Ark"
    8. 03-28-2012 01:27 PM #133
      Quote Originally Posted by sweetrocco420 View Post
      Not all obd1 cars are solder chips.. My gf's 95' cabby aba as well as my friends 95 passat vr6 are both plug and play
      This is true. My 95 ABA was OBD1 and did not have a soldered chip. Most 95 OBD1's also have the OBD2 diagnostic port too. Majority of ones that are soldered are pre 95. Also, TT has a 4-1 header like stated previously. Noticed it wasn't updated still.
    9. Senior Member tdogg74's Avatar
      Mar 1st, 2002
      In a tea cup
      03-28-2012 01:54 PM #134
      Yea, Im so surprised by that thread and all those issues. I mean, i had some of those issues too, but i ALWAYS managed to get the rev hanging to go away. With every cam/SRI manifold I swapped to. Only thing that persisted was occasional stalling if I let it warm up on a cold morning.
      And the power difference from the TT chip and the C2/PEM was night and day better.
    10. Member bluB5s4's Avatar
      Sep 28th, 2011
      somerset nj
      05 GLI, 00 Jetta VR6
      03-28-2012 03:10 PM #135
      I my aba this thread is very informative
    11. Banned Hurt's Avatar
      May 3rd, 2011
      Boston, MA
      03-28-2012 04:32 PM #136
      Quote Originally Posted by ELiT3 View Post
      Just ask TT for a chip for a 270* cam. Just because it's an AutoTech cam doesn't mean you can't get a TT chip, or even a c2 chip. (If your car is a 2000 you should consult with the MK4 forum, this thread is really tailored to MK3's)
      Quote Originally Posted by zero. View Post
      I've noticed that too.. Some OBD1 cars are odd. I've also seen 96's with OBD1 ecu's.. Odd.
      I know TT has 2 different headers, but both are so expensive I didn't bother to add them.. I've only had 1 of their headers, and personally I didn't like it. I'll update it, though.
      I was too. I couldn't get my issues to go away, though. I was sick of running out to start my car in the cold mornings, getting ready, and coming out to a FREEZING car that stalled 5 minutes ago. The rev hang was annoying to say the least, I hated burning the clutch on accident. It seemed to really mess with the TB when I had a c2 270* cam chip, it didn't go away after an adaptation, either.. Now I run a 276* cam and a TT chip. I just installed USRT's SRI on my daily, and had to readapt my throttle, but TT's chip seems to deal with just about anything.. I always use 93 octane, but once I was 200 miles from home, on E, and the only gas station in a 20 square mile area had 89 at best. Didn't have a problem at all. I really tend to stick with TT's products because they do such good dyno tests/comparisons.
    12. Banned Hurt's Avatar
      May 3rd, 2011
      Boston, MA
      03-28-2012 04:53 PM #137
      Quote Originally Posted by bluB5s4 View Post
      Thanks bud
      Here's something for all the haters who think you can't get 140 BHP out of an ABA for about (or less than) 1500 bucks. For this example I will use a OBD1 2.0 Jetta.
      276* cam - 180
      TT exhaust - 225
      TT race DP - 300
      New lifters - 80
      TT cam chip - 125
      MK4 intake and exhaust manifold swap - about 100-150
      That should be good for atleast 120whp, or about 140 at the crank. And it only costs about 1000 dollars. Cheaper if you use the forum to your advantage, and you can daily this set up easily.
    13. Banned Hurt's Avatar
      May 3rd, 2011
      Boston, MA
      03-29-2012 09:19 PM #138
      ..Paid 800 for a brand new Neuspeed system from MJM, then saw it's only 500 on Neuspeed's website.
      Quote Originally Posted by FourEyes View Post
      Return, repurchase.
      MJM ended up refunding the difference. to a good company!
    14. Senior Member tdogg74's Avatar
      Mar 1st, 2002
      In a tea cup
      03-30-2012 08:08 AM #139
      I have some issues with a couple of things you wrote that I don't feel are accurate. (emboldened). In my experience, 4500rpms on a stock motor is the drop-off point in power. Dyno sheets corroborate this fact. Also, can you change this to .432"? I have no idea where you got .433" from. I realize its only .001" difference, but .433" has never been published anywhere and is a bit misleading and contradictory to any discussions out there. Also, please update my SN to 911_fan...tdogg74 doesnt exist on this site anymore. You should also link my thread on cam info as well. Sorry for being so picky, but if you are going to continuously bump an info thread like this, it needs to be as accurate as possible.
      Camshaft: The cam from the factory is good for low end TQ, but not for high end power. Your engine will run out of steam at about 4500 rpm, and shifting beyond that is pointless. There are MULTIPLE options for a performance cam, but it really depends if your car is OBD1 or OBD2, and if you're willing to swap out the valve springs. If you have an OBD2 motor you are limited by the lift of the cam, unless you swap out the valve springs for HD ones, sold by TT tuning, autotech, MJM autohaus, etc. The highest duration cam I'd recommend without swapping out valvesprings in an OBD2 is 260* (max lift is .432). Anything higher, you risk valve float aka internal engine damage. If you have an OBD1, you lucked out, and can run a higher duration/lift cam (.450 max lift)! Now, there are multiple cams, all stating to do different things. I have personally found the TT 276 cam to be the best all around cam for a daily driven car. I followed 911_fan's advice, and set an Adjustable camgear to +4 advance, and it adds a significant amount of low end TQ without sacrificing HP.
    15. Banned Hurt's Avatar
      May 3rd, 2011
      Boston, MA
      03-30-2012 09:28 AM #140
      No problem, I fixed a few things, and updated a little bit.
    16. Senior Member tdogg74's Avatar
      Mar 1st, 2002
      In a tea cup
      03-30-2012 09:30 AM #141
    17. Member B4S's Avatar
      Apr 16th, 2003
      Marionville, Ontario, Canada
      2002 Forester S, 1984 Volvo 244
      03-30-2012 12:06 PM #142
      In Canada, our Mk3s didn't switch to OBD2 until mid-1997. OBD1 was from 93-mid 97 up here .
      1984 Volvo 244 DL...with carb.
    18. Banned Hurt's Avatar
      May 3rd, 2011
      Boston, MA
      03-30-2012 02:50 PM #143
      Quote Originally Posted by B4S View Post
      That's crazy.
    19. Member B4S's Avatar
      Apr 16th, 2003
      03-30-2012 03:10 PM #144
      Tell me about it, but it works out well. The emissions testing in my area is cake to pass if you're OBD1 and older, and there are a LOT of OBD1 'project' cars around . OBD2 is where it gets difficult to modify anything, since the stock ECU has to remain in place. Chipping is an option, but I can't justify the cost of an aftermarket chip vs. the cost of MS3 (at least in OBD2 anyway, I chip my own OBD1 ).
      BTW: If anyone wants more 'freedom' with their OBD1 cars, it's super easy to write your own chips for the ABA. If you have an ebay chip burner ($16) and some chips ($5), you can custom tune the stock ecu like megasquirt. Custom dyno tuning anyone? .
    20. Senior Member tdogg74's Avatar
      Mar 1st, 2002
      In a tea cup
      03-30-2012 09:04 PM #145
      Canada didn't adopt obd2 until 1996...MY1997.
    21. Banned Hurt's Avatar
      May 3rd, 2011
      Boston, MA
      03-30-2012 09:34 PM #146
      I'm going to get my Daily 8v dyno'd sometime this week, hopefully, if I can ever go back home to CT! I've been on business in CA all week! I'm hoping for at least 130whp.
      [CENTER]98 Jetta 2.0
      *my DAILY DRIVER*
      [276* TT cam set to +4 advance ( adds low end tq, no high end loss..)
      3 angle valve job OBD1 head with LW lifters and HD valve springs
      decked/Milled .040"
      90mm HG (+ .5 compression)
      TT non-aluminum cam gear (thanks for the advice, travis!)
      USRT LRI manifold
      MK4 exhaust manifold w/ TT race DP
      2.5" Custom Mandrel Bent exhaust w/ 2 Magnaflow mufflers and a 20" resonator. (quiet
    22. Banned Hurt's Avatar
      May 3rd, 2011
      Boston, MA
      03-31-2012 09:51 PM #147
      Well, a plan fell into my lap. I found a nice b3 wagon in south MA, sitting on the side of someone's house. It had been hit really hard in the rear. I asked if it was for sale, the guy said I can have it for 500 bucks. It only had 90k miles on the original 9a 2.0 16v engine! I had it towed home within a few hours.
      My buddy's little brother got his first car last month - a MK3 Golf Wolfsburg which has a MINT interior and barely any rust - which he beat on til the timing belt snapped (The belt was ORIGINAL and the car had ~180k on it). The head is shot, and so is the tranny. I bought it for 300 dollars yesterday. I will be swapping in the passat's 2.0 16v 9a and the CR tranny in the Golf, and possibly daily driving it. I just ordered nearly 5 figures of parts for the Golf. If anyone wants to know the parts I ordered, let me know, and I'll PM you the list.
    23. Member 2.slowduo's Avatar
      Sep 17th, 2008
      the city of wind
      Cars are dumb in the city but I have two
      04-01-2012 11:48 AM #148
      nice find on all the cheap cars, 9a mk3 should be a blast
      would love to hear how your trip to the dyno went on that 8v set up
      I would think 130whp would be a pretty tame estimate since I'm at 120whp with a 268 and stock mani's. similar deck job,p&p and 3 angle V job
      I'm also curious about the non aluminum cam gear? whats wrong with the alum. one?
    24. Banned Hurt's Avatar
      May 3rd, 2011
      Boston, MA
      04-01-2012 12:02 PM #149
      Quote Originally Posted by 2.slowduo View Post
      The TT non-aluminum cam gear is basically just a stock cam gear with the inside removed and replaced with an adjustable center. The problem with the aluminum ones is that the teeth are too soft and they'll actually start to get sharp and ruin your timing belt.
    25. Member Jh0104's Avatar
      Jul 15th, 2010
      nazareth, pa
      jetta3 aba
      04-01-2012 07:37 PM #150
      good luck on the dyno
      phillyscca.com
      J&J autosport
