Page 5 of 64 FirstFirst 1 2 3 4 5 6 7 8 9 15 55 ... LastLast
Results 141 to 175 of 2211
Thread: How to build a relatively inexpensive, reliable, 'powerful' 2.0 8v.
  1. Member B4S's Avatar
    Apr 16th, 2003
    Marionville, Ontario, Canada
    1997 Ford Aspire, 1989 Dodge Colt GT Turbo
    03-30-2012 11:06 AM #142
    Quote Originally Posted by Hurt View Post
    I've noticed that too.. Some OBD1 cars are odd. I've also seen 96's with OBD1 ecu's.. Odd.
    In Canada, our Mk3s didn't switch to OBD2 until mid-1997. OBD1 was from 93-mid 97 up here .
  2. Member Hurt's Avatar
    May 3rd, 2011
    Boston, MA
    1998 Jetta GT, 1998 GTI 2.0, 2012 GLI, 2012 GTI
    03-30-2012 01:50 PM #143
    Quote Originally Posted by B4S View Post
    That's crazy.
    If you want to make your 2.0 8v faster, read the thread below!
    http://forums.vwvortex.com/showthrea...owerful-2.0-8v.
  3. Member B4S's Avatar
    Apr 16th, 2003
    03-30-2012 02:10 PM #144
    Tell me about it, but it works out well. The emissions testing in my area is cake to pass if you're OBD1 and older, and there are a LOT of OBD1 'project' cars around . OBD2 is where it gets difficult to modify anything, since the stock ECU has to remain in place. Chipping is an option, but I can't justify the cost of an aftermarket chip vs. the cost of MS3 (at least in OBD2 anyway, I chip my own OBD1 ).
    BTW: If anyone wants more 'freedom' with their OBD1 cars, it's super easy to write your own chips for the ABA. If you have an ebay chip burner ($16) and some chips ($5), you can custom tune the stock ecu like megasquirt. Custom dyno tuning anyone? .
  4. 03-30-2012 08:04 PM #145
    Canada didn't adopt obd2 until 1996...MY1997.
  5. Member Hurt's Avatar
    May 3rd, 2011
    Boston, MA
    03-30-2012 08:34 PM #146
    I'm going to get my Daily 8v dyno'd sometime this week, hopefully, if I can ever go back home to CT! I've been on business in CA all week! I'm hoping for at least 130whp.
    98 Jetta 2.0
    *my DAILY DRIVER*
    [276* TT cam set to +4 advance ( adds low end tq, no high end loss..)
    3 angle valve job OBD1 head with LW lifters and HD valve springs
    decked/Milled .040"
    90mm HG (+ .5 compression)
    TT non-aluminum cam gear (thanks for the advice, travis!)
    USRT LRI manifold
    MK4 exhaust manifold w/ TT race DP
    2.5" Custom Mandrel Bent exhaust w/ 2 Magnaflow mufflers and a 20" resonator. (quiet <3)
    MSD ignition set up w/ 8.5mm wires
    Battery moved to the trunk
    H&R Ultra Low's 20" ftg front, 20.5" ftg rear
    195/50/R15 15x7" Phone Dials. (kumho Ecsta tires)
    BBM 6 speed 020 with a peloquin LSD. (so worth the money!)
    25mm front sway bar
    28 rear sway bar
    front and rear tie bars
    etc..]
    I'm planning on swapping this powertrain into a MK2 Jetta coupe I just picked up for 500 bucks. It is already wired for an OBD2 ABA (owned by a kid who blew the engine with nitrous , so it'll be a nice, easy swap.
  6. Member Hurt's Avatar
    May 3rd, 2011
    Boston, MA
    03-31-2012 08:51 PM #147
    Well, a plan fell into my lap. I found a nice b3 wagon in south MA, sitting on the side of someone's house. It had been hit really hard in the rear. I asked if it was for sale, the guy said I can have it for 500 bucks. It only had 90k miles on the original 9a 2.0 16v engine! I had it towed home within a few hours.
    My buddy's little brother got his first car last month - a MK3 Golf Wolfsburg which has a MINT interior and barely any rust - which he beat on til the timing belt snapped (The belt was ORIGINAL and the car had ~180k on it). The head is shot, and so is the tranny. I bought it for 300 dollars yesterday. I will be swapping in the passat's 2.0 16v 9a and the CR tranny in the Golf, and possibly daily driving it. I just ordered nearly 5 figures of parts for the Golf. If anyone wants to know the parts I ordered, let me know, and I'll PM you the list.
  7. Member 2.slowduo's Avatar
    Sep 17th, 2008
    the city of wind
    Cars are dumb in the city but I have two
    04-01-2012 10:48 AM #148
    nice find on all the cheap cars, 9a mk3 should be a blast
    would love to hear how your trip to the dyno went on that 8v set up
    I would think 130whp would be a pretty tame estimate since I'm at 120whp with a 268 and stock mani's. similar deck job,p&p and 3 angle V job
    I'm also curious about the non aluminum cam gear? whats wrong with the alum. one?
  8. Member Hurt's Avatar
    May 3rd, 2011
    Boston, MA
    04-01-2012 11:02 AM #149
    Quote Originally Posted by 2.slowduo View Post
    The TT non-aluminum cam gear is basically just a stock cam gear with the inside removed and replaced with an adjustable center. The problem with the aluminum ones is that the teeth are too soft and they'll actually start to get sharp and ruin your timing belt.
  9. Member Jh0104's Avatar
    Jul 15th, 2010
    nazareth, pa
    jetta3 aba
    04-01-2012 06:37 PM #150
    good luck on the dyno
    phillyscca.com
    J&J autosport
  10. Member Hurt's Avatar
    May 3rd, 2011
    Boston, MA
    04-01-2012 07:28 PM #151
    Thanks! I hope so, too. The LRI made a big difference!
    Quote Originally Posted by Jh0104 View Post
    Thanks, bud!
  11. Member Hurt's Avatar
    May 3rd, 2011
    Boston, MA
    04-02-2012 05:31 PM #152
    135WHP on the dyno. The fastback put down much bigger numbers, though, at 450WHP.
  12. Member B4S's Avatar
    Apr 16th, 2003
    04-02-2012 05:32 PM #153
    Nice!
  13. 04-02-2012 06:18 PM #154
    Post the sheet. I want to compare it to my 135 run.
  14. Member Hurt's Avatar
    May 3rd, 2011
    Boston, MA
    04-02-2012 08:03 PM #155
    Quote Originally Posted by 911_fan View Post
    Will do ASAP. I gotta scan it, or have the dyno-operator email it to me. I'm thinking we should be pretty similar, considering we had very similar mods, right? I think the only thing really different I have is the 90mm HG and maybe bigger exhaust? The LRI I bought (after reading your comparison thread, thanks! ) made a huge difference. Sounds like my old ITB b18 Honda!
  15. 04-03-2012 08:44 AM #156
    que?
    decked/Milled 040"
    90mm HG (+5 compression)
  16. Member Hurt's Avatar
    May 3rd, 2011
    Boston, MA
    04-03-2012 03:41 PM #157
    que?
    Oops. That's supposed to say +0.5. It's vended out of BFI, but I got mine at SummitRacing, I believe. They have good deals on gasket sets.
  17. 04-03-2012 05:57 PM #158
    Gotcha, so about 11:1 five or take
  18. Member Hurt's Avatar
    May 3rd, 2011
    Boston, MA
    04-03-2012 08:42 PM #159
    I'm not entirely sure. I never asked my friend for the paperwork for the head, but he does very good jobs. I have had 5 or 6 cylinder heads ported/decked/milled by him. Of course, the exhaust manifold and intake manifold gasket matching was done by me, because I am not THAT inept. I don't have any issues with this engine, really. When I bought it, I replaced pretty much everything. I think 135whp is a pretty good number, though, considering I beat my buddies EM1 civic Si B16a2 160hp 111tq from the factory and he has i/h/e, and our cars weigh about the same. (racing is done on a track, don't street race, people!". He has alot of suspension work, though. He handles a bit better. When I had Koni Yellows and Neuspeed Race springs, it handled amazingly! All in all, I daily this car every single day, and take it to 7,000 RPM occasionally.
  19. Member bigteal's Avatar
    Sep 10th, 2002
    spring grove pa
    1998 mk3 8v 1995 f150 351 1985 fxrs
    04-04-2012 12:43 PM #160
    Actually drove mine last night. I forgot how much fun it is
    Hoping to hit the dyno soon, got to take care of the cel first ( maf issues). 130-135whp and I'll be happy with it.
  20. Member Hurt's Avatar
    May 3rd, 2011
    Boston, MA
    04-04-2012 08:07 PM #161
    Quote Originally Posted by bigteal View Post
    Sounds good, bud. I've been busy working on my 9a MK3 project.
  21. Member Hurt's Avatar
    May 3rd, 2011
    Boston, MA
    04-05-2012 08:19 PM #162
    I have been meaning to make a few little updates, but I have been busy working on a good friends' 95 Golf Sport 2.0 8v. He's new to the VW scene, he has been a "Honda-boy" since High school and that he hated VW's just because they are VW's. ..
    Unfortunately, it was subjected to a ton of abuse by the PO!
    It had a 3aRacing fart-can on the end of a 2" crush bent exhaust, a dented cone filter stuck on the end of the MAF, a "short shifter" (which was a cut shift selector rod) and PURPLE tints.
    I spent the day removing all these horrible modifications with him, and we put on a TT 2.5" catback with a flowmaster muffler, a 42DD testpipe, a Eurosport cool-flow intake, my old Autotech 270* cam, and soldered in my old GIAC cam chip. We put on a SS 60/40 cupkit, as well as removing the tint. We put on a CL lip, too, and some GTI smoked tails. (All of these parts were sitting around my shop.. I have a shed full of VW parts ) Unfortunately, it's riding on OEM flyers for a little bit. He says it's much better than any Honda he has driven except for his old GS-R.
    You ever get that feeling that you took someone over from the land of ignorance and idiocy and put them in a "real car" and educate them? It's such a great feeling.
  22. Member OC80's Avatar
    Aug 9th, 2010
    Fancy MA
    MK3 GTi 20v, Surf Green VR6 GTi
    04-06-2012 08:52 PM #163
    hey guys I have a question about my car I have a 1996 golf and it had a intake, exhaust, and a chip. I added a 260 TT cam. Should I bother getting a new chip? like a bfi one? help is appreciated!
    Surf Green love <3
    Cars: MK3 Surf Green Golf Sport VR6, MK3 Teal GTI 20v
  23. Member
    Aug 26th, 2007
    '08 touareg, '97 jb de x2, '86 vr6 Rocco, '84 8v Rocco, '95 Vr cabby "hers"
    04-06-2012 10:22 PM #164
    a matchin chip for you cam is always the best route if you have the money do it mr. hurt.. what else u got layinaround lol
  24. Member Alingarhs's Avatar
    Dec 2nd, 2010
    Denver, CO
    1996 GTI VR6, 2005.5 Jetta TDI
    04-07-2012 12:54 AM #165
    Wondered this, I've got a Neuspeed supercharger on the car with a 2.25 Magnaflow cat-back.
    Was planning on getting a high flow cat and headers. But do you think the headers will do much with this setup or just stick with the factory manifold and downpipe?
  25. 04-07-2012 08:53 AM #166
    For the money you would spend on those, you can get an ecu/MAF tune upgrade from C2 and get more power. The tune used by Neuspeed runs on the lean side. The c2 tune uses a better tune with upgraded maf and injectors to get more power out of your charger. Couple that with a bigger cam, and you are lookin at 10-15 more whp easy.
  26. Member Hurt's Avatar
    May 3rd, 2011
    Boston, MA
    04-07-2012 12:37 PM #167
    Quote Originally Posted by OC80 View Post
    I'd get a cam profile chip. From your other threads I gather that your chip is from TT. You can contact them and send the chip back to get reburnt for the cam for a cheap rate which is way better than spending another 100 bucks for a cam chip!
    Quote Originally Posted by sweetrocco420 View Post
    a mr. hurt.. what else u got layinaround lol
    Too many VW parts. I own a bit of property where it's secluded and I keep old VW's hanging around (after builds, or engine swaps). My buddies call it "the dub graveyard".
    Quote Originally Posted by Alingarhs View Post
    High flow cats are useless, really. If you want to gain a few more HP get a 268/260 cam from TT, get their Race DP (it deletes the CAT) and mate that to a MK4 AEG exhaust manifold. You could go to C2 and order 42# injectors, a bigger MAF, and their generic boost tune, too, if you'd like. Then you can crank up the boost. Problem with the neuspeed S/C is that it's so difficult to add a front mount and you're prone to heat soak. You might want to get a bigger exhaust, too, since the 2.25" will choke the engine at high RPM's if you do get the cam upgrade.
  27. Member
    Jun 28th, 2011
    Lewisville,Tx
    1995 VW Jetta 2.0 MK3(R.I.P.), 1985 Golf 1.8 (sold), 2001 Passat Wagon 1.8T, 98 Jetta GLX VR6
    04-08-2012 09:22 PM #168
    What is the vacuum thing below my head? That when I remove the plug it almost kills the motor. And also on hard acceleration it kinda dies a little then goes
  28. Member
    Jun 28th, 2011
    Lewisville,Tx
    04-08-2012 09:30 PM #169
    Because I have my mk4 intake top/bottom and fuel rails. And if I have to have it I can't donmy conversion
  29. Member Hurt's Avatar
    May 3rd, 2011
    Boston, MA
    04-09-2012 11:36 AM #170
    Quote Originally Posted by Audiooutlaw View Post
    Post a picture, I'm really not sure what you mean, unless it's the SAI system? (the pump that has a line going to the side of the airbox)
  30. Member Hurt's Avatar
    May 3rd, 2011
    Boston, MA
    04-10-2012 08:32 PM #171
    Well, guys, I did it again.. I bought a bone stock 2.0 Golf Sport. I couldn't pass it up! It was only 300 bucks. Has a blown engine but good sport plaid seats, interior. Some dings on the exterior, not too much rust. I may end up putting a low-mile 8v in it to replace the blown ABA in it. I may end up slapping on my old BBM lysolm kit.. Dang it. Money pit, money pit, money pit! Did I mention it's Surf Green?
    Here's a few pictures from the seller:
    A few dings here and there..
  31. Member MahTrek=]'s Avatar
    Nov 6th, 2008
    8v Jetta
    04-10-2012 10:54 PM #172
    Great find!!!!
    MKIV 2.0's suck, MKIII 2.0's don't suck.
    JettaIII
    8v
  32. Member Alingarhs's Avatar
    Dec 2nd, 2010
    Denver, CO
    04-10-2012 11:34 PM #173
    Love the seats
  33. Member Hurt's Avatar
    May 3rd, 2011
    Boston, MA
    04-11-2012 12:41 PM #174
    I already have a motor/trans lined up to go into the GTI.. It's just a plain OBD1 engine and 020 trans. I, well, spent some money on TT's website today.. I gave all my Golf parts to my friend for his..
    Had to buy new stuff.
  34. 04-11-2012 12:44 PM #175
    So Im confused....
    Is this a How-to/DIY, or is this now your personal build thread / blog?
