Anyone else notice C2 chips are on sale for 150? Well, I've told you.. so..
#211
If you want to make your 2.0 8v faster, read the thread below!
http://forums.vwvortex.com/showthrea...owerful-2.0-8v.
#212
#213
Surf Green love <3
Cars: MK3 Surf Green Golf Sport VR6, MK3 Teal GTI 20v
#214
Hi guys!
As some of you might know I have a OBD2 Golf with a 2.0 with a Neuspeed P-Flo intake (with the heatshield!), a 260 TT camshaft, a 2.25" exhaust system, and a giac chip for aftermarket camshafts..
Now, I hear mixed opinions about the intake.
Some people say i should put the stock airbox back in. Some say I should buy a KN filter in the box. Some say I should cut holes in the bottom passenger side of the box. Some say I should keep the P-Flo! I'm really confused. Can anyone give me a definite answer with proof of dyno gains, please? thank you!!
Surf Green love <3
#215
#216
Hey, guys. I spent the afternoon with OC80 - we designed an airbox together. It integrates ram-air (Via a velocity stack behind the lower bumper opening sealed to 3" ducting straight to the bottom of the airbox) and switched the little air intake elbow that goes into the fender on the front of the airbox for 3" ducting with a velocity stack inside of the fender. It has a K&N panel filter. Does it make more power than stock? Maybe. Does it look cool? Hell yeah! I'm going to put a mesh backing infront of the duct, just so no leaves get sucked up in there. It looks good, if you ask me. This golf sport of mine is just basically a try-new-things car. Hell, I have a 70mm exhaust on it with a VIBRANT muffler on the end, which actually sounds good. Here are the pics from during the install:
Edit: pictures don't work. FU camera. FU.
#217
bump for the forum![]()
#218
I'm trying to put together a transmission area.
#219
Surf Green love <3
#220
The ratios are:
3.3
1.94
1.31
1.09
.89
.75
3.94 F/D
@ 7k I'm going
1st - 35
2nd - 60
3rd - 90
4th - 110
5th - 130
6th - never tried to top it out.. I cruise at 3000 RPM @ 70mph.
If you swap a corrado g60 transmission into your car, it'll be able to put up with more abuse. Personally I like the cable shift linkage better than the 020 rod shift. If you really want to do it, I can help you. I'm selling the GTI as soon as I finish fixing the little bugs. If you want it, you can have it. Call me (phone's on now!), I don't want to clutter up the thread.
#221
Bump for the forum
#222
#223
No no, I realize the Neuspeed and autotech chips aren't the best. I had a friend run both in his ABA rabbit. Minimal power gains, and they sucked down gas like you would(n't) believe.
I really hate how autotech's chip says "gains the ability to rev faster to the new 6900 rpm redline". I mean, seriously? A non cammed aba revving to nearly 7k?! Sounds like a recipe for disaster!
The Neuspeed chip is a little better IMO. But I hate how neuspeed lies about their products (well, they sort of post a generic hp gain, "gain 5-8whp!" for their P-flo intake systems. Even for the Jetta 2.0. I mean.. come on. That kind of upsets me, as I love Neuspeed for their suspension components.
As I state all the time, TT is my favorite chip. The cam file is slightly different than the non-cam file. I saw the dyno on TT's website, I think. It advances the timing a little more, gives it more gas, balances the idle, etc.
The C2 chips are sort of problematic. They are probably the newest chip tune on the market for the ABA, but tons of people are coming forward with problems with bucking at low RPM, stalling in the cold, throwing check engine lights, etc.
The Stage 1 chip for no cam raises the limiter to 7300 RPM. Useless. It's crazy. I ran a C2 chip in a few cars. 2/3 ABA's with it had a problem.
I have one in my Golf VR6, and I have no problems at all (race file chip, SAI delete plug, 268's, HD valve springs, MK4 HG, intake, and 3" exhaust).. and I have 0 problems. Never. None. I guess something is wrong with the coding in the ABA C2 chips.
All in all, my favorite company for VW performance parts = TT for engine mods, Neuspeed for suspension (because they stock KONI), GIAC, C2, BBM, etc. I have lots of favorites. Lol.
#224
Here's a picture of an INJEN intake system installed in a MK3. Quite nifty IMO.
#225
#226
That injen setup looks nice and all.. but it looks like an exact copy of the stock setup.. all except for the fact the the stock box already has kind of a velocity stack into the MAF, from the looks of it, that's just plane plate aluminum in there.
8VALVETURBO - Sorting the kinks out.
#227
It's a conical filter inside of that aluminum box. It's bigger, too. It's a really nice set up, because a cone filter on the end of the maf with no way to get more air robs power. This keeps the factory air intake lower box, has more of a surface area than the stock filter, provides nice cold air from the fender, etc. It's a great stealthy modification if you paint it black. But, you can pretty much make your own injen intake by shaving down the outside of the stock airbox where the maf bolts on, so you have the lip of the maf sticking into the airbox. Then you get a cone filter and bolt it up. CAI. It's a good intake system IMO.
#228
Anyone know anything about KENT cams? They have HUGE amounts of lift. The 260* cam has a 440 lift..![]()
#229
Anyone know anything about UnitedMotorsport's N/A stage 1 chip?
From their website:
'Increased horsepower and torque
Speed limiter removed
Smoother idle
Smoother under partial throttle conditions
Improved engine response
Optimized power delivery
Working Immobilizer
Fuel Octane-indifferent performance map
Improved fuel economy'
N/A Stage 1
"Typical gains of 15 whp over OEM
Actual customer dynos :125 whp
Supported ECUs: 021 906 259X
Price: $199"
...15 WHP over OEM? I'm calling BS.
#231
Isn't it a break off of C2? I don't really believe 15 WHP. I mean, that's serious stuff. I don't think taking my chip out of my car for the OEM one would put me down to 120whp. And they're advertising it as stage one - not cam specific. How would you even go about gaining 15 more wheel horsepower without changing the cam? It just seems they're stretching the truth for marketing purposes. But to me, C2 does the same thing. Hell, all aftermarket companies do.![]()
#233
Do you happen to know if the C2 chip issues are squashed yet? I want to buy a C2 chip for mine if they're resolved, especially since they dropped their price. The TT chip I have in it now is starting to act up. Rev hang when I push the clutch in (I've noticed this with nearly every chip), the throttle feels a little off..
Bah.
My VR6 runs 100% better than the stock chip with the C2, and has 0 problems, and I expected it to. It doesn't even have it's Check Engine light on and it has Intake, Exhaust, Cam, HG, Etc.. I wish C2 could squash this problem.
#234
I'm going to add a SRI/LRI section, since so many companies make manifolds for the ABA, and they offer substantial power gains. When I put my USRT manifold on my Race Coupe, it was a competely different car. So much more response. More power (LOADS). Awesome vacuum sound. So versatile. USRT =
Speaking of USRT, does anyone have a USRT smartshift kit installed in their MK3? If so, can you post a video of going through the gears at a stop, and wiggling the shift selector while in gear to see how much play it eliminates? I don't have a rod shift car anymore - And only had my USRT kit sitting on a shelf. Thinking of giving it to my little brother for his 16th birthday. Oh, and he's already off to a good start. I bought him a 97 Jetta Wolfsburg.I think I'll use it as my DIY-thread-car-thing, since my Jetta has everything done already except for a better tune (waiting for C2 chip problems to go away!)
~Colm
#235
I apologize for the lack of updates, I have been busy with work and my family.. Looking to do a few DIY threads soon.
#236
For the forum
#237
Jessi (oc80) noticed that USRT sells high performance panel filters for 25 bucks! I'll add some more information tomorrow, guys.
This calls for a:
#239
The best way top describe the USRT shift kit is like going from a MK3 to a Mini Cooper SC. The shifting motion is more heavier compared to factory and in my case it made me learn were the speed are because unlike the factory one that lets you kinda cheat into a speed with the USRT there is no slack on the stick so you have to know were the gear is. The difference is like dating a 4 and going out with a definite 10 and giving you permission to do with her all the things you wanted to do ....
Make sure to also install it with a quick shifter.
I could make a video of mine but since my car is currently dismantled and on it's way to go from 020 to hydro I can't. But the USRT shifter is all good. Also don't skimp on the lube for the bearings. Other than that just re-lube them with every other oil change.
Why yes; that she tropper has sideburns...
#240
#241
...Went to go look at a beater Jetta TREK today. It has LEATHER TREK seats.. I've never seen that before!
#242
Noticed the amount of views this gets a day, and wow. I'm glad I could help so many people!
#243
Vag-Com up to 2005, pm me
Eastwood Fender Roller for rent, pm me
#244
In the OBD1 P-chip, they change more than one map. GIAC kills them hands down though, if comparing on quantity of maps changed. The P-chip richens the fueling a bit, at WOT, but mostly just changes the main ignition map. Most of the tuners follow the same recipe, from what I've seen of the OBD1 NA chips anyway. Not trying to start a fight, but if we're talking about misinformation...
#245
