Looks good!
#71
Finally put the cross member reinforcement bar I've had laying around for a couple of years in. Center mounting point was welded off center so fitting it was sort of a pain. Also had to rework the horn bracket a bit.
#73
What is this plug in the firewall? Im looking for options for my rabbit. There are a few holes I do not want to weld shut.
Thanks
-Kevin B.
#74
#75
Wow very clean! And as all said you do really good work, and I see you have good ideas running in your mind you put to function, as I do! Haha look for my build thread here shortly, should be similar to your car...
#76
Loving this.bunny and your.attention to details. Keep on man![]()
#78
Love every bit about this! Nice work.
I wanted to ask about the headliner. I have been looking at theirs for my 84 Rabbit GTI with sunroof. I found bows online, but I am uncertain of the clips, etc for them. SO two questions (if you recall):
1) How long is each bow?
2) Do you have any photos of the install, other than those posted?
#79
#80
I looked this morning for the clips, but no joy. Really thought they were here:
http://www.clipsandfasteners.com/Vol...eners_s/68.htm
The P/N is 171867549. On a non sun roof car you need 12.
Bunch of picture, not sure they will show you much more though.
#81
Unbelievably Perfect! If mine turns out half as good as this I will be happy. Great job, sir.
#84
Hauling ass around a clover leaf last night and heard a loud pop in the back. Found this this morning. Torqued to spec when I dropped the beam a few weeks ago. I guess I must have overdone it and it had enough...
Actually wasn't that bad.
Found some tape and started drilling.
Dropped in a 10.9 bolt - had to enlarge the opening to get a 17mm socket down. Pretty tight - probably could have cut some more material away and welded it. But this should be fine.
Lock nut and washer.
#86
didn't know you was goin MS chad...I might be selling a setup here real soon.
#87
#88
Finally worked out/sourced all the junk to allow for water at the wipers.
Found early style squirters at the yard last week. Bottle is for the rear washer from an 85/86 Mk2. I left provisions in the engine compartment when I was building the original harness for the diesel style washer bottle. But I was never able to find one. I added a harness extension to route to the opposite side rain tray. Also made a bracket to support the bottle from the bottom while still allowing the tray to properly drain.
#90
[QUOTE=Mr. Chan;76062077]Finally worked out/sourced all the junk to allow for water at the wipers.
#91
#92
That sucks about that bolt. But at least you fixed it.
How do you like those poly rear bushings?
#93
#94
Honestly, I considered the poly rear axle bushings to be a HUGE improvement to my old Cabby. But, it was also with a SII rear sway and brand new sway bushings....
#96
What are the specs on wheels and tires? I know their Enkei, thanks.
#97
#98
Might steal your wheel/tire/spacer set up!
#100
did you pick your dash out of the donor car? i really want that dash and if you could tell me where it came out of that would be a big help to me.
#101
#102
New 10.1 front brakes. Pedal is a little deeper with the new MC.
Old Mk2 9.4 vented
New Scirocco/4000q 10.1 vented
When I went out to bed the pads I managed to lock the rear. Had a moderately large air bubble in the front driver's side.
#103
