Results 36 to 70 of 85
Thread: NEW EA888 1.8 TSI / 2.0 TSI Engine Details
  1. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    12-31-2011 03:36 PM #36
    Quote Originally Posted by VWRedux View Post
    This new engine, the EA888 if transformed into higher displacements other than 1.8L will be a significant achievement for the VW Group.
    Will only be able to get it to 2.0L as none of the Diesel's are following the EA888 block format as yet. They are still on EA113 format (old school 06A format).
    Still 2008cc is a huge bonus. This motor looks ALOT cleaner than the TSI motor it is replacing.
    Still not a fan of the oil filter
  2. Member VWRedux's Avatar
    Jun 3rd, 2009
    Potomac Maryland
    Started NHTSA DSG Campaign/'09WolfieDSG died@623mi. VW took it back.Bought MkVI/GTI Blk 6spMT/SR/Xen
    01-01-2012 02:24 PM #37
    Quote Originally Posted by Issam Abed View Post
    Hey, use you own pictures...
    "There's nothing like a well tuned car on an open road". Paul Newman
    *The New 2011 VW Jetta... At Least You Pay Less To Get Less!*
  3. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    01-01-2012 03:16 PM #38
    Ive got a few to upload. Just waiting on the gallery integration to be completed (which should be today) and ill upload the pdf file.
    If you want me to remove them I can
  4. Member VWRedux's Avatar
    Jun 3rd, 2009
    Potomac Maryland
    01-01-2012 04:56 PM #39
    Chill... just having a little fun with ya...
  5. Junior Member
    Aug 23rd, 2011
    somewhere
    01-01-2012 05:38 PM #40
    I think in the time that this engine will be on the market, that the ecu cant be accesed anymore, so tuning will not be posible...
    Lets all hope i am wrong.
    Audi S3 8L @ 400whp
  6. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    01-01-2012 05:46 PM #41
    Quote Originally Posted by dick tracy View Post
    The ECU will always be accessable. It will just be a race to see which tuner figures it out first.
  7. Junior Member
    Aug 23rd, 2011
    somewhere
    01-02-2012 05:30 AM #42
    I very much doubt that, at this moment there are allready a few ecu's that cant be tuned anymore ...
    The new bmw 5 series F10 cant be tuned, the 1.6TDI cant be tuned, ....
    Audi S3 8L @ 400whp
    Aug 30th, 2009
    Santo André SP Brasil
    Passat Wagon 2.0 TSI 09; APR K04 ;carbonio; DP APR;cat 200 cels inox;paddle shifts; VCDS;
    01-02-2012 11:33 AM #43
    It´s just a matter of time!
  9. Junior Member
    Aug 23rd, 2011
    somewhere
    01-02-2012 11:36 AM #44
    Quote Originally Posted by zucchini View Post
    Yeah, loads of time... the 1.6TDI is allready 2.5 years old ...
    Audi S3 8L @ 400whp
  10. Member Track5tar's Avatar
    Feb 16th, 2010
    Salt Lake City, UT and Las Vegas, NV
    Mine: 2010 Passat Hers: 2012 B8 A4
    01-02-2012 12:07 PM #45
    what company has been working on it?
    Unitronic > APR Switched from APR to UNI and never looking back
    CW '10 Passat 2.0TSI: UNI Stage 2 VMR V705 19x8.5 et45 Podi Boost gauge/pod AWE DV, Turbo Outlet Pipe BSH Boost Tap BillyBoat 3" TBE BFI Stg2 Dogbone/motor mount/trans. mount KW V2 coils Forge Twintake(1st on Passat/CC) JBL W12GTi MKII HEX+CAN vagcom, Podi.ca podi free ship code: NINOSHIP, VMR | Wheels velocitymotoring.com, VolksBHAN in September
  11. Junior Member
    Aug 23rd, 2011
    somewhere
    01-02-2012 01:01 PM #46
    Quote Originally Posted by Track5tar View Post
    CMD, Byteshooter, Alientech, ....., ......
    Audi S3 8L @ 400whp
  12. Member DRedman45's Avatar
    Aug 7th, 2009
    NOVA
    07 SB Rabbit(sold), 10 UG 4dr GTI(sold), e86 //M coupe
    01-02-2012 05:10 PM #47
    all the big budget companies that can afford to put their time and money into tuning a 1.6L diesel
  13. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    01-02-2012 06:36 PM #48
    These are tool suppliers. Not software mapping suppliers...
    There is a difference between "cant be tuned" and "we can not crack the ecu security locks to get access to the maps".
    APR was the first to crack the B8 S4 ECU , an ecu that was "unbreakable". They ran the market for over a year before Revo & others caught on.
    Supply & Demand...1.6TDI is not a popular motor in Europe and it is non existent in USA.
  14. Member O_o's Avatar
    Nov 12th, 2009
    Vancouver, BC
    metropass
    01-03-2012 01:15 AM #49
    Quote Originally Posted by cockerpunk View Post
    so i got a question. im an engineer, but by no means an expert in engine design.
    why woudl you want to cool the exuast gas BEFORE the turbocharger? reading that my document that was my understanding. seems to me your just pumping away energy then out the radiator, instead of funneling it through the turbocharger. the entire point of the turbocharger being to recycle the waste heat (energy) in the exaust and turn it into something useful - boost. thus the jump in both performance and fuel economy.
    but cooling the exuast before it gets to the turbo saps out a bunch of that energy.
    so why are they doing that?
    As long as there isn't a pressure loss associated with cooling the exhaust, the turbine output will not be significantly affected. You're right that there is some power loss, but unless they're cooling it by several hundred degrees, it shouldn't make much difference.
    BTW, I used to test turbocharger compressors by using compressed air at substantially room temperature to drive the turbine. The exhaust temperature was sometimes as low as -80C, but there was still loads of power. I did have to increase the TIP a little compared to using hot compressed air, but not as much as you might think. At pressure ratios of about 4, IIRC, I had to run at about 3 psi higher pressure to get the same power output as when it was installed in an engine.
  15. Member
    Aug 30th, 2009
    01-03-2012 09:39 AM #50
    "Market size"....that is the point.
  16. Junior Member
    Aug 23rd, 2011
    somewhere
    01-03-2012 03:56 PM #51
    The ecu from the 1.6TDI can be readed and flashed, the problem is the checksum and RSA. As for the bmw F10, there the problem is the bootpassword.
    FYI: 6 out of 10 vw golf/jetta/A3/octavia being sold here in europe are 1.6TDI.
    and even loads of passats and superb have this engine
    We'll see how this end up,but i hope your right
    Audi S3 8L @ 400whp
  17. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    01-05-2012 02:20 PM #52
    There is ALWAYS a way to get around security issues with computers.
    I like to think of security as a knot, if there is a way to tie the knot, there is a way to untie the knot.
    Its just a matter of time and money.
    :APR -stage 2 :BSH -Intake,Mounts,RSB,TB Pipe :Whiteline -A.L.K.,Endlinks
    :Devils Own -DVC-30+Direct Port Injection :BC Racing -BR Coilovers :Flik-FTD :OSIR
    :Neuspeed -Insert,Brake Lines:Eurojet -Ceramic Coated DP :DEFI :Unibrace :Tyrolsport :Bildon :Hawk
    TSI FAQ: http://forums.vwvortex.com/showthread.php?4042736
  18. Member
    Aug 30th, 2009
    01-05-2012 02:58 PM #53
    Quote Originally Posted by ViRtUaLheretic View Post
  19. Banner Advertiser chris@revotechnik's Avatar
    May 17th, 2007
    Summit Point, WV
    X,80,X,X,98,00,X,06,12
    01-05-2012 04:18 PM #54
    You shouldn't speak for others as you have no clue what everyones current status of their testing is.
    We were testing the B8 S4 stuff for a year before we even made mention on the forums that we were in final beta testing back in september. You often don't have any clue what people are cable of doing until its on the market or a coming soon announcement.
    We don't tune VWs so read my response however you want
  20. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    01-05-2012 09:34 PM #55
    Getting back to the topic at hand!
  21. Forum Sponsor Arin@APR's Avatar
    Jul 29th, 2008
    Auburn, Al
    2010 Audi B8 S4 3.0 TFSI 6MT & 2007 VW MKV GTI 2.0T FSI DSG
    01-05-2012 10:59 PM #56
    I can't wait for this engine to get here.
    GoAPR.com | Facebook | YouTube | Twitter
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    The bitterness of poor quality is remembered long after the sweetness of low price is forgotten.
  22. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    01-06-2012 01:30 AM #57
    back to the topic on hand, wait, wut just happened here?
  23. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    02-18-2012 05:31 PM #58
    Rumour has it 1.4 TSI coming to North America as well!
  24. Member VWRedux's Avatar
    Jun 3rd, 2009
    Potomac Maryland
    02-18-2012 05:55 PM #59
    Nice but that's a 1.8L
  25. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    02-18-2012 07:46 PM #60
    Sorry forgot the 1.4 TSI article.
    I am pretty excited for this new 1.8 TFSI motor.
  26. 02-18-2012 08:24 PM #61
    Quote Originally Posted by chris@revotechnik View Post
    Pretty much
  27. Banner Advertiser chris@revotechnik's Avatar
    May 17th, 2007
    Summit Point, WV
    02-20-2012 08:55 AM #62
    Quote Originally Posted by crew219 View Post
    Pretty much
    Once a troll always a troll, at least you are consistent.
  28. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    02-20-2012 08:59 AM #63
    Chris respectfully please do not continue this in public. Take it to the PM's unless you have something technical to discuss.
  29. Banner Advertiser chris@revotechnik's Avatar
    May 17th, 2007
    Summit Point, WV
    02-20-2012 09:07 AM #64
    Issam I will give you no respect ever since you do not deserve it and your last post just shows why no one should.. grow a pair and respond to Arin who started talking crap and Crew who then continued it weeks later for no reason at all. Don't come after me because you don't like me when i did nothing and you sell APR products, that's just pathetic.
  30. Member snubbs64's Avatar
    Oct 23rd, 2004
    2010 A3q, 2003 20 AE GTi 1.8BT, 2004 CBR 600F4i
    02-20-2012 01:05 PM #65
    Wow. Just wow. I bet he didn't respond to Arin so that sh!t like this wouldn't occur. He did grow a pair, a big enough pair that he's secure enough not to succumb to this type of response.
    Remind me to never purchase ANYTHING associated with revotechnik if this is how their employees represent themselves. Can't imagine what the customer service would be like based on this PUBLIC display.
    Leave it off the boards like Arin was "man" enough to do
  31. Banner Advertiser chris@revotechnik's Avatar
    May 17th, 2007
    Summit Point, WV
    02-20-2012 03:35 PM #66
    Quote Originally Posted by snubbs64 View Post
    Issam didn't reply to Arin because he is an APR dealer and because he has personal issues with me which he has proven time and time again. Arin could have posted exactly what I did and he would have given it a thumbs up. Not to mention his post is a violation of the advertising rules by posting as a private user attacking an advertiser when he has an advertising account.
    Also not sure what you mean by Arin left it off the boards, his post right in this thread is what I am talking about...
    http://forums.vwvortex.com/showthrea...1#post75237534
  32. Member snubbs64's Avatar
    Oct 23rd, 2004
    02-20-2012 04:03 PM #67
    Regardless of all of that, you continued the thread. Period. They may have had their own issues as well but i believe it was kindergarten that taught us 2 wrongs don't make a right? And you're still clogging up the pages by continuing. So, if anything, i take back my singularly directed comment to you and redirect it to all involved, including you, but maintain the point. You have provided me with no information that made your comment or dealings CORRECT, just also implemented them in the behavior. And that, my friend, still reflects on you and your company as your flying your opinions under your company's flag. That is NOT misdirected. I can't imagine any business owner would want to see a representative of their company respond as you did. Defensive is one thing, but attacking is a whole different matter.
    Further, I don't care WHY Issam didn't, you seem to be reading between the lines anyway, he simply didn't. You're going to badmouth someone for NOT participating in this and then point that they did due to your assumption as to why?
    What you point to, my friend, is no where near the anger and hate you spewed. You attacked, he stated a falicy, not saying he couldn't have done it better, or that it was even valid. He was pointing to something directly and you brought all sorts of personal and additional non-related opinions into it. And anyway, I'll restate, this doesn't belong on the boards, any of it. And THAT is my real issue.
  33. Banner Advertiser chris@revotechnik's Avatar
    May 17th, 2007
    Summit Point, WV
    02-20-2012 04:33 PM #68
    I'm not reading between the lines, there are multiple off topic posts in this thread and he chose to pick out mine to tell me to take it elsewhere. Common sense would dictate that you complain to the person who brought it off topic not the person who told someone to stop.
    Issam unfortunately has an agenda as an APR dealer so he will look the other way when someone who he makes money from comments regardless of if he likes it or not. I take money from Issam so he will go after me. IF you want to question professionalism talk to the guy pretending to be a normal user in this thread going after other advertisers.
    AS for your posts, if you feel mine are off topic.. how are your rant posts continuing the off topic BS even remotely helping?
    If you don't like my post report it and have the moderators clean it up, don't add to the BS you are complaining about, just makes you a hypocrite.
  34. Banner Advertiser chris@revotechnik's Avatar
    May 17th, 2007
    Summit Point, WV
    02-20-2012 04:37 PM #69
    Where did I attack APR? I didn't even respond to APR and the reply Arin was quoting of mine and claiming he had any clue about our devopment was a general statement that had nothing to do with APR.
    Sorry but you are completely off base here...
  35. Member Crzypdilly's Avatar
    Feb 19th, 2004
    ABQ
    2012 VW GTI Autobahn, 2003 GTI 20th Anni (For Sale), 2013 Audi Q5 2.0T P+
    02-20-2012 04:59 PM #70
    another pissing contest with Chris@revo... yay
