Results 1 to 21 of 21
Thread: question about using a walbro inline fuel pump in place of2nd pump on mk2, (any input from vrt/1.8t guys welcome)
  1. Member smugfree3's Avatar
    Feb 20th, 2006
    baltimore
    91 coupe
    10-24-2011 08:39 PM #1
    no response from the mk2 guys:
    i coming close to finishing up my 1.8t swap. on the last car i did, i just put the walbro after the 2nd fuel pump,
    but for the sake of cleanliness, can i just use the walbro in place of the secondary pump?
    is there any way that a walbro fits in the accumulator? or can i just go from intank pump->filter->walbro->motor?
    im just worried that if the accumulator acts as something of a surge tank then wont the walbro outrun the intank pump and ill lose fueling capacity? if it helps to know, the motor is on a bigger turbo with 440's for injectors.
  2. 10-24-2011 09:10 PM #2
    The closest I've heard of people running inline's in conjunction w/ an intank is at the stock filter location by the rear wheel (on MK4s at least) and they'll throw the filters in the bay by the timing belt cover. Personally I run a TT pump w/ a non 044 Bosch inline up in my engine bay. I'm pushing 400wheel and I've never had a lean out condition that was pump related. I even killed my stock intank pump and while I wasn't boosting the crap out of the car until it was fixed, all was well.
    MK4 Junker : PAG 50trim Kit : AEB : RMR : Eurodyne
    P.P.T. - Pag Parts Turbo
    B6 A4 : Slow
  3. Member FlatlanderSJ's Avatar
    Oct 3rd, 2007
    97 GLX, 92 LC3U Corrado VRT
    11-05-2011 09:59 PM #3
    I have my vrt corrado running intank > walboro > filter > motor. the walboro was mounted next to the fuel filter in the rear. Running 22lbs on a 35r @4bar fpr and never had problems leaning out. remember when you decrease pressure on a pump the flow rate increases.
  4. Senior Member Capt.Dreadz's Avatar
    Jun 3rd, 2003
    Long Island, NY
    VRT's & 2.7T's
    11-06-2011 03:16 PM #4
    I run mine Intank>filter>Pump>motor. I hate to think my 044 is sucking up dirty fuel.
    And to answer you question...no, you can't fit the walbro in the stock location. I thought about it myself. If you're looking for a semi submerged setup, IE sells a dual & single surge tanks.
    Chosen Life Clothing. Streetwear for the car culture. Launch Party coming very soon!!
    Meet Long Island The place if you're looking for a euro GTG in the Long Isl./New York City area.
    FaceBook: Carlitus Christensen Sr. - Instagram: @ThatDreadLife - Twitter: @ThatDreadLife
    Kicks...Clothes...Cars...Ho's...THINGS I DO BEST!
  5. n00b
    May 14th, 2011
    03 gli 1.8t, 92 gti supercharged 8v
    02-15-2012 01:24 AM #5
    what about a 255lph alone intank? intank >filter>motor?
  6. Senior Member Capt.Dreadz's Avatar
    Jun 3rd, 2003
    Long Island, NY
    VRT's & 2.7T's
    02-15-2012 12:11 PM #6
    Quote Originally Posted by JettamiahMKIV View Post
    2 intanks?
  7. Member HidRo's Avatar
    Sep 19th, 2003
    Portugal/Europe
    1986 mk2 GTi 20VT
    02-16-2012 11:45 AM #7
    Quote Originally Posted by Capt.Dreadz View Post
    2 intanks?
    I think this way makes more sense?
    I'm not sure, but the CIS intank pump can handle a 255lph "sucking" from them, so it's a + to have both, and I've read also that the fuel filter should be after as the 255lph it better at pushing than pulling fuel.
    EIGH-T6 // "Give me enough traction, and I will spin the WORLD!"
    Portugal // Europe
    MS II V3.0: http://eight620vt.tk/
  8. 02-19-2012 04:13 PM #8
    I have the stock mk2 intake, and a fuel filter right before the 255lph pump... Works fine. You just need to relay the 255lph as the stock harness to the second pump doesn't allow as much volts to make the pump work as it should. I used the stock harness to the old 2nd pump as the trigger wire and ground. Makes the job super easy.
    "I admit that I'm often...vexed by the behavior of my own people..." - Huey Freeman (The Boondocks)
  9. 02-20-2012 08:20 PM #9
    i have a stock mk2 tank and brand new in tank supplying an 044 in the stock location then a factory filter to the motor. I also use the mk5 fuel pump control module to supply variable voltage to the 044 as per the 2.o fsi ecu. never had an issue running lean on my stage 3+ 2.0FSI
  10. Member MEKA NECK's Avatar
    Sep 27th, 2010
    York, PA
    MkII 4dr golf 3.2 24v
    04-20-2012 08:46 PM #10
    [QUOTE=Nevaeh_Speed;75995422]You just need to relay the 255lph as the stock harness to the second pump doesn't allow as much volts to make the pump work as it should. QUOTE]
    Any more info on what you mean by doing this?
  11. Member FlatlanderSJ's Avatar
    Oct 3rd, 2007
    04-20-2012 09:20 PM #11
    [QUOTE=MEKA NECK;77008499]
    Quote Originally Posted by Nevaeh_Speed View Post
    just add a relay with the signal wire attaching to the power from the in tank pump and the power coming directly from the battery.
  12. Member BarryV's Avatar
    Apr 23rd, 2001
    Frederick, MD
    1992 12V 1992 16V 2012 TDI
    04-23-2012 02:00 PM #12
    Quote Originally Posted by MEKA NECK View Post
    The harness that goes to the factory inline pump under the car has 4 wires - 2 are red and yellow, and 2 are brown. The browns are your ground, and I wired the ground for the relay, and the pump into those, using butt connectors. The yellow and red are your original 12 V feeds to the fuel pump. I cut those and butt connected the "relay signal" into them.
    When your car tells your in-tank and in line pumps to turn on, from the under dash relay, that 12 v signal is now used to tell the aftermarket relay under the car to push the 30A 12V direct feed to the Walbro.
    Who is Joel Goodson
    Alpine White
    #realityquest
    DCI MARYLAND
  13. Member Daskoupe's Avatar
    Oct 9th, 2006
    941 frying pan
    mk2 coupe,mk4 golf both 2.0hhhhhhhhh
    04-23-2012 05:08 PM #13
    I have not relayed my walbro.Thinking i should though
    12.2@116mph-293whp305wtq 22psi stock aba-AC-DD My Jetta
    Current Want list-sunroof delete,paint
    Fifteen52 - Urotuning
  14. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    audi tt gt3076r 01 aston martin db7 04 land rover disco 99rolls royce seraph
    04-23-2012 11:46 PM #14
    C2 motor sports sells a awesome kit for the walbro it connects to all the factory lines
    I ran mine Apr in tank and inline walbro then a filter
    http://forums.vwvortex.com/showthrea...t-done-I-guess
    ^^^Big Turbo build lots of pics^^^
    Best shop for repair and custom workin ma
    http://www.wentworthmotorsports.com/
  15. Member HidRo's Avatar
    Sep 19th, 2003
    Portugal/Europe
    1986 mk2 GTi 20VT
    04-24-2012 09:55 AM #15
    If you do not replay it, what can happen?
    I had Megasquirt connected to the output of the fuel pump relay, and I saw a bit of a drop in voltage. Minimum I've seen was like 12V. So, is this bad for the walbro? Will it not work as perfect as it should?
    How many lph can the walbro do @12v? For how many hp is it good for?
    Portugal // Europe
  16. Member Jones84's Avatar
    Sep 5th, 2007
    Gresham Oregon
    84 GTI 2.0 High comp 16vT on MegaSquirt, 00 Subaru Outback
    04-25-2012 01:46 PM #16
    Here is my Walbro set up on a mk2 in the stock pressure pump loction. Still running stock intake pump. I have pushed 25psi on 680cc injectors with out any issues.
    84 Rabbit GTI, 12.1.1 comp 16VT, 15psi 307whp 278wtq Winner 2012 bugRun Pro class
    JONES PERFORMANCE VW, Swaps, Custom Builds, MS install & tuning. MK1, MK2, Specialists
    2vwjones@gmail.com Website under construction.
  17. Member HidRo's Avatar
    Sep 19th, 2003
    Portugal/Europe
    1986 mk2 GTi 20VT
    04-26-2012 04:14 AM #17
    And this connected to the stock power connection? No relay of any kind?
    Portugal // Europe
  18. Member Jones84's Avatar
    Sep 5th, 2007
    Gresham Oregon
    04-26-2012 06:40 PM #18
    Yes, all stock. I have never had any problem with it at all in the 2 years its been in.
  19. 04-26-2012 11:34 PM #19
    You need to relay the fuel pump as the fuel pump works best at 14.4v, and if you test the oem wire from the bottom fuel pump you get much less voltage, thus you relay it. Also I have the fuel filter on the inlet side of the 255 not the out as stated in the walbro instructions.
  20. Member Jones84's Avatar
    Sep 5th, 2007
    Gresham Oregon
    04-27-2012 12:34 AM #20
    Interesting, Its is a 12v pump and a alt is regulated to only put 13.5v to the car max. So not sure were you would get 14.4v from. Its Amps not volts that make it run better. 12v and 100amp will make it work great. were as 12v and 20amp it wont turn on. Not enuff power.
    All a relay does is take the load of the AMPS not volts. The car has a Stock FP relay in the fues block just for that reason.
    I am running a bosh 044 of the stock set up in my MK1 and have installed 5 walbros in customer cars all using the stock FP relay. I have never ever had any issues with the pump not working correct..
  21. Member HidRo's Avatar
    Sep 19th, 2003
    Portugal/Europe
    1986 mk2 GTi 20VT
    04-27-2012 08:26 AM #21
    Thanks for the information Jones!
    Cheers!
    Portugal // Europe
