Page 1 of 2 1 2 LastLast
Results 1 to 35 of 42
Thread: Need help with wheel fitment for my new B7
  1. Member cheapa55TDI's Avatar
    Sep 30th, 2011
    2012 Passat TDI SE
    10-25-2011 04:59 PM #1
    I posted in the technical forum but I figure you guys here know best. I think I've decided on what wheels to get.
    Q7 Replicas
    But I'm not sure if this fits the car. I will lower the car on coilovers but I'd like to keep the ride comfortable and not have to worry about rubbing or scratching the car. Any ideas?
    Jan 13th, 2004
    H-Town,TX
    10-25-2011 06:05 PM #2
    Those should be fine.
  3. Member cheapa55TDI's Avatar
    Sep 30th, 2011
    2012 Passat TDI SE
    10-25-2011 06:38 PM #3
    Quote Originally Posted by Coolcrush View Post
    any ideas on what size tires I need to get?
  4. 10-25-2011 07:13 PM #4
    Quote Originally Posted by cheapa55TDI View Post
    255/35/20 or 245/35/20 will work fine.
    Jan 13th, 2004
    H-Town,TX
    10-25-2011 07:14 PM #5
    There has been discussion on this, look in some of the other threads about rims. It will depend on how low you go of course. Some folks are saying 255/40 is good but others are going 245/40 or 35. I believe you can pm one of the tire rack guys on here for assistance.
  6. 10-25-2011 07:16 PM #6
    255/40 or 245/40 will work for a 19" wheel. If going to a 20, you would want a 245/35 or 255/35
  7. Member cheapa55TDI's Avatar
    Sep 30th, 2011
    2012 Passat TDI SE
    10-25-2011 08:42 PM #7
    that replica is a 20x9. I don't want a stretch. 245 vs 255? any pros and cons?
    Jan 13th, 2004
    H-Town,TX
    10-25-2011 09:36 PM #8
    Sorry forgot he was going 20.
  9. 10-25-2011 10:15 PM #9
    255/35 will stretch less
  10. Member
    May 8th, 2010
    Canberra, ACT, AU
    2012 Golf GTI
    10-26-2011 04:34 AM #10
    I run 255/35/20 on a 20x9 wheel on my Tiguan and there's no stretch. I don't believe there would be with 245 either.
  11. Member cheapa55TDI's Avatar
    Sep 30th, 2011
    2012 Passat TDI SE
    10-26-2011 12:55 PM #11
    Thanks Tiggy! Is 35 too much rubber? Does it look fat if it used on a sedan?
    May 8th, 2010
    Canberra, ACT, AU
    2012 Golf GTI
    10-27-2011 01:24 AM #12
    Fatter is better in my opinion lol. I don't think 255's will look overly fat on a Passat though.
  13. Member cheapa55TDI's Avatar
    Sep 30th, 2011
    2012 Passat TDI SE
    11-09-2011 10:50 PM #13
    I finally got my car and I was making some measurements for the 20x9 wheels. The Passat looks like it has a lot of room but when I turned the wheels to see how close it is to the car, there wasn't much room, less than 1" to the inside of the wheel well and the suspension. Is this normal? I'll be lowering the car on coilovers and I want to make sure this fits.
  14. 11-10-2011 12:42 AM #14
    Cheapa,
    MREURO already posted a pic of a Passat on a 20x8.5, 35MM offset with a 245... and it looks fine. Offsets and tire size have alot to do with it. I think there will be plenty of room, keep in mind your 20" wheel with a 245/35/20 as an example, has vitrually (within 1%) the same overal diameter as a 235/45/18.
    Where are the full pics of your ride.. dont hold out on us.
  15. Member cheapa55TDI's Avatar
    Sep 30th, 2011
    2012 Passat TDI SE
    11-10-2011 01:54 AM #15
    Quote Originally Posted by TCM GLX View Post
    Cheapa,
    Yeah, I saw that. my wheel is 20x9 with 40mm offset and I plan to get 245/30/20. I honestly don't understand offset enough to see if it's comparable. I used a calculator on RimnTires.com and it seems it will fit, but the measurements I took looked like there wasn't much room. Thanks for the info. This is my first time getting something that hasn't been done before. I've gotten wheels before but 19" and it was fitted on the same car by many other people before me. Thanks again!
    I'll post more pics this weekend.
  16. Member mreuro's Avatar
    Mar 10th, 2005
    Buford, GA
    2007 Jetta GLI-F sold, 2012 Passat SEL VR6
    11-10-2011 10:21 AM #16
    hmmm.... 20x9 et:40 you might be ok....
    we just did 20" on a passat but its not what i would do....
    we did 20x8.5 et:35 and i think that is way to aggressive for me.
    I don't think that you might be able to lower the car with those wheels.
  17. 11-10-2011 10:24 AM #17
    I just put a set of 20x8.5" with a 45 mm offset (255/35/20 tires)on my B7 and I can tell you that they fit but are pushed out all the way to the edges. The front tire is almost flush with the fender and the rear needed an 8mm (5mm might be better but I had the 8)spacer on it to match the fronts. With the tires they are pretty much flush.
    According to my calcuations with the stock 17" wheels on the car, If you change to the 20 x9's and a 40 mm offset you will be adding 27mm additional wheel towards the outside of the car.
    IMO I dont think the 20x9's will fit or look right, especially on the front, they will stick out past the edges of the car and not allow you to lower the car in the future unless you camber the hell out of the wheels.
  18. Member mreuro's Avatar
    Mar 10th, 2005
    Buford, GA
    11-10-2011 10:34 AM #18
    Quote Originally Posted by B7Passat View Post
    Do you have any pictures for us to see?
  19. 11-10-2011 10:35 AM #19
    Any pics of your ride.... several of us are looking to run a 20" wheel here pretty soon.
    Also, on your calculations... a 20x9 with a 40mm offset would be 1/2" wider than your setup, 1/4" on each side, plus the 5MM so it should only be approx 12MM further out, not 27. Still might be too aggressive though.
  20. 11-10-2011 10:41 AM #20
    No pics yet...soon thou, probably tomorrow. And the 27mm is based on the stock wheels....27mm pushed out towards the outside.
  21. Member mreuro's Avatar
    Mar 10th, 2005
    Buford, GA
    11-10-2011 10:57 AM #21
    Well.... Yesterday I ordered 20X8 ET:45 those will be here next Wensday, so I will post pictures then. I went with 245/35/20 tires also.
  22. 11-10-2011 11:09 AM #22
    Quote Originally Posted by mreuro View Post
    Sounds like a perfect fit...I choose the 255/35/20 DWS conti. only because the TireRack was closing them out for less then a 245 tire and I ran them before and love them.
    Off the subject, but which wheel did you go with?
  23. Member mreuro's Avatar
    Mar 10th, 2005
    Buford, GA
    11-10-2011 11:43 AM #23
    OZ
  24. 11-10-2011 12:49 PM #24
    What wheel did you go with?
  25. 11-10-2011 12:49 PM #25
    OZ
    That is going to ook great MREURO (Shet, what is your name... I hate calling you by your forum name... hahaha)
  26. Member jkurtzs4's Avatar
    Oct 27th, 2011
    Sarasota, FL
    1990 VW Fox Wagon(SOLD), 1993 VW Jetta GL(SOLD), 2000 Audi S4(MINE), 2012 VW Passat TDI(MINE)
    11-10-2011 12:54 PM #26
    here is a very good site to calculate wheel/tire size for proper speed calibration.
    http://www.miata.net/garage/tirecalc.html
  27. 11-10-2011 01:39 PM #27
    I went with the Roderick Wheels RW6 20x8.5 with a 45mm offset
    http://www.elementwheels.com/prodima...rw6blkmach.jpg
  28. Member cheapa55TDI's Avatar
    Sep 30th, 2011
    2012 Passat TDI SE
    11-10-2011 01:43 PM #28
    I used this calculator and this is the info I got:
    http://www.rimsntires.com/specspro.j...&text1=&text2=
    I am definitely lowering the car, not too much, but I don't want to look like a 4x4. There are a few CC's running these wheels that I want 20x9 et40 and lowered and they are fine. I wonder if the space in the wheel well is the same in the CC vs B7 Passat.
    and yes, please post pics of the B7 running 20's, I think we are all waiting for more info and pics.
  29. 11-10-2011 02:04 PM #29
    Thats a good looking wheel!!
  30. Member cheapa55TDI's Avatar
    Sep 30th, 2011
    2012 Passat TDI SE
    11-10-2011 02:12 PM #30
    Cheapa,
    My bad, I did not see the pics mreuro posted. Weird, I'm on this forum all day and I missed all the brakes pics and the wheels. Anyways, it looks ok. I'll input both sizes in the calculator and see what it says.
  31. Member mreuro's Avatar
    Mar 10th, 2005
    Buford, GA
    11-10-2011 04:28 PM #31
    lol.... Thanks.....
    My name is Andy
  32. Member mreuro's Avatar
    Mar 10th, 2005
    Buford, GA
    11-10-2011 04:29 PM #32
    how did you miss that.... lol its 6 pages long....
  33. Member cheapa55TDI's Avatar
    Sep 30th, 2011
    2012 Passat TDI SE
    11-10-2011 05:27 PM #33
    HAHA, I meant the last few pics from 11/07. I might have been pre-occupied since I finally took delivery of my car on Sunday.
  34. Member cheapa55TDI's Avatar
    Sep 30th, 2011
    2012 Passat TDI SE
    11-10-2011 05:28 PM #34
    Yes, those are very nice!
  35. Member cheapa55TDI's Avatar
    Sep 30th, 2011
    2012 Passat TDI SE
    11-17-2011 02:05 AM #35
    So after mreuro got his new wheels, I have a better idea of what might fit. I'm using the rim n tires calculator to compare mreuro's new OZ wheels, vs the black car in his thread with TSW 20", and my potential wheel.
    What do you guys thing? Andy, do you think you have a few mm left until the tires hit the fenders?
