VWVortex.com - Need help with wheel fitment for my new B7
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 43
    Thread: Need help with wheel fitment for my new B7
    1. Member cheapa55TDI's Avatar
      Sep 30th, 2011
      2012 Passat TDI SE
      10-25-2011 04:59 PM #1
      I posted in the technical forum but I figure you guys here know best. I think I've decided on what wheels to get.
      Q7 Replicas
      But I'm not sure if this fits the car. I will lower the car on coilovers but I'd like to keep the ride comfortable and not have to worry about rubbing or scratching the car. Any ideas?
      Jan 13th, 2004
      H-Town,TX
      10-25-2011 06:05 PM #2
      Those should be fine.
    3. Member cheapa55TDI's Avatar
      Sep 30th, 2011
      2012 Passat TDI SE
      10-25-2011 06:38 PM #3
      Quote Originally Posted by Coolcrush View Post
      any ideas on what size tires I need to get?
    4. 10-25-2011 07:13 PM #4
      Quote Originally Posted by cheapa55TDI View Post
      255/35/20 or 245/35/20 will work fine.
      Jan 13th, 2004
      H-Town,TX
      10-25-2011 07:14 PM #5
      There has been discussion on this, look in some of the other threads about rims. It will depend on how low you go of course. Some folks are saying 255/40 is good but others are going 245/40 or 35. I believe you can pm one of the tire rack guys on here for assistance.
    6. 10-25-2011 07:16 PM #6
      255/40 or 245/40 will work for a 19" wheel. If going to a 20, you would want a 245/35 or 255/35
    7. Member cheapa55TDI's Avatar
      Sep 30th, 2011
      2012 Passat TDI SE
      10-25-2011 08:42 PM #7
      that replica is a 20x9. I don't want a stretch. 245 vs 255? any pros and cons?
      Jan 13th, 2004
      H-Town,TX
      10-25-2011 09:36 PM #8
      Sorry forgot he was going 20.
    9. 10-25-2011 10:15 PM #9
      255/35 will stretch less
      May 8th, 2010
      Canberra, ACT, AU
      2012 Golf GTI
      10-26-2011 04:34 AM #10
      I run 255/35/20 on a 20x9 wheel on my Tiguan and there's no stretch. I don't believe there would be with 245 either.
    11. Member cheapa55TDI's Avatar
      Sep 30th, 2011
      2012 Passat TDI SE
      10-26-2011 12:55 PM #11
      Thanks Tiggy! Is 35 too much rubber? Does it look fat if it used on a sedan?
      May 8th, 2010
      Canberra, ACT, AU
      2012 Golf GTI
      10-27-2011 01:24 AM #12
      Fatter is better in my opinion lol. I don't think 255's will look overly fat on a Passat though.
    13. Member cheapa55TDI's Avatar
      Sep 30th, 2011
      2012 Passat TDI SE
      11-09-2011 10:50 PM #13
      I finally got my car and I was making some measurements for the 20x9 wheels. The Passat looks like it has a lot of room but when I turned the wheels to see how close it is to the car, there wasn't much room, less than 1" to the inside of the wheel well and the suspension. Is this normal? I'll be lowering the car on coilovers and I want to make sure this fits.
    14. 11-10-2011 12:42 AM #14
      Cheapa,
      MREURO already posted a pic of a Passat on a 20x8.5, 35MM offset with a 245... and it looks fine. Offsets and tire size have alot to do with it. I think there will be plenty of room, keep in mind your 20" wheel with a 245/35/20 as an example, has vitrually (within 1%) the same overal diameter as a 235/45/18.
      Where are the full pics of your ride.. dont hold out on us.
    15. Member cheapa55TDI's Avatar
      Sep 30th, 2011
      2012 Passat TDI SE
      11-10-2011 01:54 AM #15
      Quote Originally Posted by TCM GLX View Post
      Cheapa,
      Yeah, I saw that. my wheel is 20x9 with 40mm offset and I plan to get 245/30/20. I honestly don't understand offset enough to see if it's comparable. I used a calculator on RimnTires.com and it seems it will fit, but the measurements I took looked like there wasn't much room. Thanks for the info. This is my first time getting something that hasn't been done before. I've gotten wheels before but 19" and it was fitted on the same car by many other people before me. Thanks again!
      I'll post more pics this weekend.
    16. Member mreuro's Avatar
      Mar 10th, 2005
      Buford, GA
      07 GLI-F sold, 12 Passat VR6, 14 GLI, 16 GTI,17 A4
      11-10-2011 10:21 AM #16
      hmmm.... 20x9 et:40 you might be ok....
      we just did 20" on a passat but its not what i would do....
      we did 20x8.5 et:35 and i think that is way to aggressive for me.
      I don't think that you might be able to lower the car with those wheels.
    17. 11-10-2011 10:24 AM #17
      I just put a set of 20x8.5" with a 45 mm offset (255/35/20 tires)on my B7 and I can tell you that they fit but are pushed out all the way to the edges. The front tire is almost flush with the fender and the rear needed an 8mm (5mm might be better but I had the 8)spacer on it to match the fronts. With the tires they are pretty much flush.
      According to my calcuations with the stock 17" wheels on the car, If you change to the 20 x9's and a 40 mm offset you will be adding 27mm additional wheel towards the outside of the car.
      IMO I dont think the 20x9's will fit or look right, especially on the front, they will stick out past the edges of the car and not allow you to lower the car in the future unless you camber the hell out of the wheels.
    18. Member mreuro's Avatar
      Mar 10th, 2005
      Buford, GA
      11-10-2011 10:34 AM #18
      Quote Originally Posted by B7Passat View Post
      Do you have any pictures for us to see?
    19. 11-10-2011 10:35 AM #19
      Any pics of your ride.... several of us are looking to run a 20" wheel here pretty soon.
      Also, on your calculations... a 20x9 with a 40mm offset would be 1/2" wider than your setup, 1/4" on each side, plus the 5MM so it should only be approx 12MM further out, not 27. Still might be too aggressive though.
    20. 11-10-2011 10:41 AM #20
      No pics yet...soon thou, probably tomorrow. And the 27mm is based on the stock wheels....27mm pushed out towards the outside.
    21. Member mreuro's Avatar
      Mar 10th, 2005
      Buford, GA
      11-10-2011 10:57 AM #21
      Well.... Yesterday I ordered 20X8 ET:45 those will be here next Wensday, so I will post pictures then. I went with 245/35/20 tires also.
    22. 11-10-2011 11:09 AM #22
      Quote Originally Posted by mreuro View Post
      Sounds like a perfect fit...I choose the 255/35/20 DWS conti. only because the TireRack was closing them out for less then a 245 tire and I ran them before and love them.
      Off the subject, but which wheel did you go with?
    23. Member mreuro's Avatar
      Mar 10th, 2005
      Buford, GA
      11-10-2011 11:43 AM #23
      OZ
    24. 11-10-2011 12:49 PM #24
      What wheel did you go with?
    25. 11-10-2011 12:49 PM #25
      OZ
      That is going to ook great MREURO (Shet, what is your name... I hate calling you by your forum name... hahaha)
