Page 1 of 4 1 2 3 4 LastLast
Results 1 to 35 of 114
Thread: HPA Motorsports Gen.2 Haldex Controller
  1. 10-26-2011 05:24 PM #1
    Most Mk5 based 4-motion equipped cars use Haldex's second generation of AWD systems. The Gen 2 Sport controller takes into account the TPS signal more so than the OEM software and therefore can proactively begin applying power to the RWD clutch packs before wheel spin begins, and as power is increased, more power lock occurs in the RWD unit until full lock is achieved.
    This product offers the following benefits:
    • increases torque transmission at acceleration
    • provides consistent performance with increased over-steer
    • torque-transmission is influenced by how quickly you depress the accelerator
    • transmits torque before the engine delivers torque
    • at greater speeds, the torque will decrease enabling less over-steer and safer driving properties
    Instead of the standard Blue Gen 2 controller, HPA Motorsports is proud to exclusively offer our "Stealth" Gen2 Sport Haldex controller. Identical in appearance to your stock controller, you can now enjoy all the benefits of this performance component without jeopardizing your powertrain warranty. The Stealth controller is undetectable by your dealership; both visually as well as through a scan of your Haldex all wheel drive system.
    By default, the controller is designed to be in Sport mode which transforms the handling characteristics of your AWD car by increasing torque transfer to the rear axle and giving more rear wheel bias.
    With the installation of a specially engineered wiring harness and switch, you can have instant access to all three of the programs built in to the controller; Stock, Sport, and Race.
    As an enthusiastic driver you may not find yourself using Stock mode very often, but it will come in useful when loaning your car to an inexperienced driver, or when you are driving in slippery conditions and want to engage the conservative safety parameters set out by the factory.
    Race mode will unleash further potential as it provides faster reaction time to vehicle inputs in the AWD communication system, and allows for even greater amounts of torque transfer to the rear axle.
    Orders can be placed by PayPal through our website, or by calling HPA directly at 604.598.8520.
  2. 10-26-2011 05:25 PM #2
    NEW LOWER PRICING!
    Our HPA website has been updated to reflect new pricing ($100.00 lower) on our Gen. 2/4 Switchable Controllers, and our popular controller "Combos".
    As part of our product mix, we are also now featuring, in addition to the Haldex cable/switch, the Haldex remote.
    These remotes can be purchased separately, or as part of a Combo with the Gen.2 or Gen.4 controller.
    IM or e-mail me for a quote including shipping to your destination.
    May 18th, 2003
    Buffalo, NY
    2012 Golf R
    10-29-2011 03:04 PM #4
    I've had the gen 2 controller installed for quite some time now, paired with the wireless switch.
    I recently bought a VCDS cable and did a full auto-scan. This came up:
    22-AWD -- Status: Malfunction 0010
    Address 22: AWD Labels: None
    Part No: HW0 5Ha lde x
    Component: Tuning
    Coding: 0000001
    Shop #: WSC 00000 000 00000
    VCID: 5AB02EE19504631
    No fault code found.
    Is this normal when using the aftermarket controller? There are never any fault codes for the AWD system but it still shows a malfunction. I have no idea why it says Malfunction.
    Anyone else out there with the aftermarket haldex controller and VCDS that could do a full auto-scan to see if they receive the same thing?
  4. Member JRutter's Avatar
    Nov 25th, 2009
    Bellingham, WA
    07 A3 3.2
    10-31-2011 12:42 PM #5
    VAD does not show any malfunction status for mine.
    A VR6 AWD w/ lots of goodies
    May 18th, 2003
    Buffalo, NY
    2012 Golf R
    10-31-2011 04:15 PM #6
    Quote Originally Posted by JRutter View Post
    hrm
    Any input from the HPA guys?
  6. 10-31-2011 04:22 PM #7
    Quote Originally Posted by Rdurty2 View Post
    Component: Tuning
    Coding: 0000001
    Definately not normal. Did this message jusr recently appear? Are there other "communication" errors in the CAN-Bus or other modules because of this?
    May 18th, 2003
    Buffalo, NY
    2012 Golf R
    10-31-2011 05:18 PM #8
    Quote Originally Posted by VAD@HPA View Post
    No idea when this started as I just got vagcom the other week.
    No other communication problems.
    The only other issue that popped up was for an intermittent failure of the ignition switch, but despite that soft code I have never noticed any problems with the ignition switch.
  8. 10-31-2011 05:36 PM #9
    Fire me over a quick e-mail with these details and your scan. I will see what I can do about getting you an answer, either from my techs or from Haldex directly.
    May 18th, 2003
    Buffalo, NY
    2012 Golf R
    10-31-2011 05:41 PM #10
    Thanks Darryl. Sending the email now.
  10. Member
    May 18th, 2003
    Buffalo, NY
    2012 Golf R
    11-01-2011 12:41 PM #11
    Darryl you can disregard my email. Replacing my ignition switch fixed my AWD showing up as malfunction.
  11. 11-01-2011 01:03 PM #12
    Thats why the full scan is always recommended...codes in other modules are usually related...good news anyway!
  12. Member mfbmike's Avatar
    Feb 5th, 2011
    305 Miami, FL
    2008 CW R32, 1983 CW Rabbit LS
    11-01-2011 03:56 PM #13
    Heh, awesome.
    Holy Milltek.
    Tarmacs cut it close.
    Miami Vase
    Cams A Make Her Dance
  13. Member
    May 18th, 2003
    Buffalo, NY
    2012 Golf R
    11-01-2011 04:05 PM #14
    I have no idea why those 2 things were related but I'll take it.
  14. 11-07-2011 06:59 PM #15
    Thank you for your orders...more Haldex remotes on the way...
  15. Member mfbmike's Avatar
    Feb 5th, 2011
    305 Miami, FL
    11-07-2011 07:06 PM #16
    How come then gen 4 controllers come in race mode by default while the gen 2's come in sport mode by default?
    Holy Milltek.
    Miami Vase
  16. 11-07-2011 07:33 PM #17
    Quote Originally Posted by mfbmike View Post
    The Gen.4's have no Sport mode....they offer stock, race, and eco mode...
  17. Member mfbmike's Avatar
    Feb 5th, 2011
    305 Miami, FL
    11-07-2011 08:08 PM #18
    True. I just assumed eco and stock were one in the same.
    I'm just jealous our controller aren't in race mode by default.
    Holy Milltek.
    Miami Vase
  18. 11-16-2011 01:47 PM #19
    Group Buy Opportunity
    This has been posted for the Gen.4 Controller COMBO (with cable or remote)...anyone interested in a Gen.2 COMBO at similar pricing? Shoot me an IM or e-mail...until November 30th...thanks!
  19. Member mfbmike's Avatar
    Feb 5th, 2011
    305 Miami, FL
    11-16-2011 03:22 PM #20
    Gen 2 controller + switch for 899 shipped?
    Holy Milltek.
    Miami Vase
  20. 11-16-2011 03:27 PM #21
    Thats not what it says...
  21. Member mfbmike's Avatar
    Feb 5th, 2011
    305 Miami, FL
    11-16-2011 03:28 PM #22
    My apologies.
    Gen.4 Haldex with cable/switch US$1048.00
    Is that the similar pricing you were referring to?
    Holy Milltek.
    Miami Vase
  22. 11-16-2011 04:09 PM #23
    My apologies.
    Correct.
  23. 12-05-2011 07:53 PM #25
    NEW LOWER PRICING!
    Gen.2 controllers, switches, and remotes in stock and ready to ship...
  24. Member bazzle's Avatar
    Sep 17th, 2008
    Australia, Vic
    12-12-2011 05:44 PM #26
    Fitted mine 10 days ago
    Fitted switch but left cable under rear seat, (switch fits perfectly in the cutout around the sender
    Left in Sport.
    There is a drivabilty difference, hard cornering pulls around a lot cleaner with less understeer drag.
    Taking off hard front tyre rotation is at a minimum compared to standard.
    One thing, my kit didnt come with the cone washer so I initially left it off (pix show it is supplied)
    I removed and fitted the old one. Hope that was right?
    Bazzle
  25. 12-12-2011 06:18 PM #27
    Quote Originally Posted by bazzle View Post
    Left in Sport.
    Taking off hard front tire rotation is at a minimum compared to standard.
    Bazzle
    That will work.
  26. Member bazzle's Avatar
    Sep 17th, 2008
    Australia, Vic
    12-13-2011 04:14 PM #28
    Thanks for the reply.
    Should there of been one in the kit?
    Bazzle
  27. Member mfbmike's Avatar
    Feb 5th, 2011
    305 Miami, FL
    12-13-2011 04:19 PM #29
    Cone washer?
    Holy Milltek.
    Miami Vase
  28. Member bazzle's Avatar
    Sep 17th, 2008
    Australia, Vic
    12-13-2011 05:05 PM #30
    Sorry, yes, cone washer.
    Looking at the pix of the kit it looks like it is supplied.
    Bazzle
  29. 01-06-2012 08:09 PM #31
    All Haldex configurations in stock and ready to ship.
  30. Member mfbmike's Avatar
    Feb 5th, 2011
    305 Miami, FL
    01-12-2012 05:44 PM #32
    Big props to HPA.
    Really friendly, solid customer service both on this occasion and when I purchased the core interlock mount a few months ago. They really are just a phone call away.
    Appreciate the help guys and can't wait to reap the benefits. Thanks again.
    Holy Milltek.
    Miami Vase
  31. 01-26-2012 01:44 PM #33
    Big props to HPA.
    Really friendly, solid customer service both on this (Haldex) occasion and when I purchased the core interlock mount a few months ago. They really are just a phone call away.
  32. 02-01-2012 04:24 PM #34
    All Controllers are in stock and ready to ship...we will match or beat all competitors' prices...IM or e-mail me for a quote.
  33. 02-08-2012 07:35 PM #35
    Quote Originally Posted by ray32 View Post
    great products! one of the few products i have from HPA and looking foward to add a few more...
Tags for this Thread
