VWVortex.com - Poll for current/future TDI owners - Are/Will you be using Diesel fuel additive?
    View Poll Results: Poll for current/future TDI owners - Are/Will you be using Diesel fuel additive?
    Voters
    29. You may not vote on this poll
    • Yes, Stanadyne Performance Formula
      3 10.34%
    • Yes, Stanadyne Lubricity Formula
      0 0%
    • Yes, Other brand formula
      10 34.48%
    • No, not using diesel fuel additive
      16 55.17%
    Page 2 of 2 FirstFirst 12
    Results 26 to 31 of 31
    Thread: Poll for current/future TDI owners - Are/Will you be using Diesel fuel additive?
      Apr 21st, 2012
      Millersville, MD
      2012 Passat TDI, 2005 Ford F-250 6.0 diesel, 5 2015 Lincoln MKZ Hybrid, 2007 Artitic Fox 5th Wheel
      04-27-2012 01:15 PM #26
      Ask them all if they would give you a recommended cetane rating number to use. Again, Europe has ratings from 51 to 55. Be lucky to see 45 here in the states. Higher the cetane, better the fuel mileage. (Up to about 55)
      And seeing a number of dealers are using the "bad fuel" excuse for denying warranty, request where they recommend we buy our fuel.
      2012 Passat SE TDI NAV
      2005 F250 PSD 4X4 LB CrewCab Arizona Beige / Blue Spring / Gauges / Coolant Filter / SG-II / Peragon Bed Cover
      2007 Arctic Fox 30' Fifth Wheel
      Apr 29th, 2012
      Mid-Coast Maine
      01 TDI Jetta, 02 TDI Golf
      04-29-2012 09:57 AM #27
      I presently use Diesel-Kleen, gray bottle, in my 02 Golf, I have since first fuel-up. The engine is a little quieter and fuel economy is slightly better, and it adds some lubrication for the IP. I am considering an '12 Passat, if I get one, I will be using the Opti-lube XPD. If you read the scar wear tests on the ULSD, most fuels barely meet the minimum requirments for lubricity. The only one that I have read that easily meets the specs is the fuel from Irving, and that is still not that great. Because of the HPFP issues, and the associated costs IF something goes wrong, which seems to be rare, I will be using an additive as cheap insurance. Also, because of the HPFP issues, I am also going to see if the CAT 2 micron fuel filter is still available and if it will fit on the Passat.
      Jim
    3. Member Kyosho's Avatar
      Feb 15th, 2012
      NJ
      2005.5 VW JETTA TDI PKG 1, 2012 VW PASSAT TDI SEL
      04-29-2012 05:54 PM #28
      For those of you who do add additives, how much of what product do you put in, and how often.
      Thanks!
      ~Kyosho
      Apr 21st, 2012
      Millersville, MD
      04-29-2012 06:06 PM #29
      Every fill-up using this formula:
      Gallons of Diesel Fuel to Treat Ounces of Additive Required
      3 gallons 1 ounce
      40 gallons 16 ounces
      100 gallons 32 ounces
      250 gallons 80 ounces
      So, 15 gal = about 5 oz. No one runs their tank dry, right? I use a marked funnel to add the Diesel Kleen. Yeah, it stinks as bad or worse as diesel fuel! Gloves are good.
      Over adding doesn't hurt anything except wallet!
      See here: http://www.powerservice.com/dk/
    5. Member compu_85's Avatar
      Aug 17th, 2004
      Springfield, VA
      04-30-2012 09:33 PM #30
      I use a little splash of power service with every fill in all my Diesels. It's hard to get high cetane fuel around here, and it does make a small, but real difference. You can really tell on a car with worn out injectors, it knocks down the knocking
      -J
      2012 Passat TDI SE DSG. 99,000 miles. LED tails, VCDS tweaks (wipers, alarm, cluster)
      2004 Touareg V10 TDI. 150,000 miles.
      1999 Jetta "GLX" TDI. 309,000 miles. RCIII, BV49, S520, Knois.
      1991 Mercedes 350SDL. 230,000 miles, 60k on the replacement motor
      Past: 91 Jetta ECOdiesel. Totaled. 92 Jetta ECOdiesel. 87 Audi 5000S Q. 85 Jetta 1.8.
    6. 01-04-2014 11:34 PM #31
      I haven't yet used Opti Lube in my 2013 Passat but have been using it in my Ford 2008 6.4 diesel.
