VWVortex.com - MK2 Transmission removal/install
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 34
    Thread: MK2 Transmission removal/install
    1. 10-31-2011 07:47 AM #1
      Hi, just dropped a tranny from a 1987 Golf.. wow what a pain. I had moved the DS axle shaft out of the way, completely removed the front mount and ended up taking off the diff mount and 5th gear housing mount. It was tough getting it to drop.
      Any suggestions on smooth ways to drop the tranny and more importantly, how to install one? thanks
    2. Moderator The_Hamster's Avatar
      Jul 31st, 2000
      Alberta
      Barbie Jeep Power Wheel
      10-31-2011 09:41 AM #2
      I usually remove the trans mount hardware as it sounds like you did. When you are ready to completely remove it rotate it so the diff is up, then you can unhook the PS drive flange easily and it comes off quick. That rotation is important to your sanity.
      Sep 20th, 2010
      Salem, Oregon
      1977 VW Scirocco 1.8/Weber carbs, 1986 VW Golf Diesel, 1978 Rabbit 1.6
      10-31-2011 11:20 AM #3
      I've found it easier and faster to just pull the moptor and tranny together......much easier than trying to tilt/twist/etc.
    4. Member VasDrafts's Avatar
      Apr 23rd, 2004
      610 PA
      2 Jettas
      10-31-2011 11:48 AM #4
      Quote Originally Posted by rdezsofi View Post
      NO WAY is it easier to pull the whole thing together.
      Do exactly as The Hamster said. Rotating the diff up makes it so the trans comes out easily.
    5. Member wantacad's Avatar
      Apr 3rd, 2003
      Belleville,Ill
      I haz a bunnah
      10-31-2011 12:05 PM #5
      Quote Originally Posted by vastxpunk View Post
      yup
      pulling both axles out all together help too, it's one little more step but prevents you from screwing them and having your balls fall out.
      Quote Originally Posted by WackyWabbitRacer View Post
      You're new here but don't be a DORK.....
      Cheers, WWR.
      Quote Originally Posted by rte7x9 View Post
      Don't swap if you can't weld or fabricate. It's not a trivial task just to bolt everything up. There's a lot of nut-scratching involved. Take your time and do it right.
    6. Member Greg_J's Avatar
      Oct 30th, 2005
      Ontario, Canada
      '03 Wagon TDI, '16 GLI Autobahn 6MT
      10-31-2011 01:04 PM #6
      it is when you have no ac or power steering
      i can pull my engine/trans, replace clutch, put everything back in and drive, in about 2.5 hours.
      than again sometimes im 'lazy' and do it the old fashion way as The Hamster says to do. takes longer though
      Quote Originally Posted by ennui_delphian View Post
      Don't anger canadiun lesbian...
    7. Member VasDrafts's Avatar
      Apr 23rd, 2004
      610 PA
      2 Jettas
      10-31-2011 01:24 PM #7
      Quote Originally Posted by Greg_J View Post
      I still don't agree personally. No wiring to disconnect, no coolant lines to open or mess with, no unbolting the exhaust, and no need to get the engine hoist out.
      If you can do all that in 2.5 hours, you should be able to change the trans in an hour and fifteen minutes. There's half as many processes to do when just pulling the trans.
      I guess that's just my opinion. Either way isn't difficult in these cars, unless your exhaust hasn't been unbolted in a while.
    8. Member VasDrafts's Avatar
      Apr 23rd, 2004
      610 PA
      2 Jettas
      10-31-2011 01:25 PM #8
      Quote Originally Posted by wantacad View Post
      I hate when my balls fall out.
    9. Member spoon!'s Avatar
      Sep 1st, 2005
      Bay Area, CA
      '05 A4 3.0Q 6MT | '92 Jetta | '69 T3 Squareback
      10-31-2011 01:34 PM #9
      Crazy? lol
      I pulled the trans all by myself this past time, twice, because I installed the wrong input shaft seal (yeah!). Sure, I had my chick come out and lift the transmission up/down (using floor jack) while I was supporting and rotating the trans from above, but that only took about what, a minute-and-a-half of her time? I'm a skinny dude too, and it wasn't very difficult for me to grab the trans from above and perform the diff rotation. Like others said, I couldn't imagine having to unclip all that wiring, remove the radiator hoses and let the coolant drain, refill the coolant... forget that. What if you no has lift... remove entire front end? No way.
      It was a breeze to just drop the tranny, to be quite honest. If this is your first time, yeah it's kind of a pain in the ass because you're hunting around for all the bolts and you may not be sure what all bolts you need to remove, and you don't want to make more work for yourself by removing bolts you don't have to... but your second transmission drop/install will go three times faster than this one!
    10. Member Schnitzelburnr's Avatar
      Nov 12th, 2009
      BC, Canada
      03 gti, 93 ford ranger
      10-31-2011 02:10 PM #10
      Me and 2 friends pulled an 8v in 2 hours once, when I was 18 but that was in pick n pull on a totaled car which we didn't care about, that was cutting and smashing everything. Taking the engine out of my car with 3 guys took like 5 hours then again we were all noobs but then but still, I could not see an engine coming out in less then 4 hours with one person
    11. 11-05-2011 07:58 PM #11
      Well now that I have dropped and re-intalled the tranny, I guess it wasn't that bad if you do it right.
      what I learned:
      1) completely remove the front mount assembly
      2) completely remove the diff and 5th gear housing mounts
      3) unbolt each axle from the diff spindle
      4) just undo the DS a_arm ball joint and tie rod end and swing the DS axle out of the way (into the wheel well and hang it with a wireecoat hanger)
      5) just raise the PS axle and hold it up with a clothes hanger
      Unhook the linkage
      I supported the engine with a bar across the engine bay, also had a simple cargo strap around the tranny and over the bar to hold the tranny so I didn't have to handle the entire weight.
      It wiggles right off, then used a jack to let it down.
      Used a jack to raise it up and then tightend the strap to suspend it, it went right on. I put a couple tranny bolts in to hold it to the block and then raised the tranny high enough so the diff and 5th gear mounts could go on over the mount pedastal with no issue. Put everything else back on with no issues.
      I do recommend getting the PS axle in place with the flange before you tighten the tranny in, makes it a lot easier.
      If I had just taken the mounts off rather than trying to drop it with them on to begin with it would have cut the time and aggravation in half!! I ended up taking them off anyway.
      Not to bad to do actually.
    12. Senior Member Big Dac With Fries's Avatar
      Feb 1st, 2002
      Spatula City
      6000 SUX
      11-05-2011 08:06 PM #12
      If you unbolt that subframe "block" it gives you an inch or two of more room.
      "I was thinking about what a friend had said, I was hoping it was a lie."
    13. Junior Member mkIIGa89's Avatar
      Feb 6th, 2010
      north ga
      1959 ford cutsom 300, 1989 jetta wolfsburg, 1995 cherokee
      04-30-2012 11:32 PM #13
      Im trying to twist it so the dif is up buti have the passanger side cv still in all the bolts ore out and the trand is oose how do i get it o drop out its a wolfsburg jetta 1.8
    14. Member themagellan's Avatar
      Mar 30th, 2007
      East
      1991 Audi 200 20vt Quattro
      04-30-2012 11:50 PM #14
      Easiest way to pull a transmission and reinstall...
      Get the car up HIGH on jackstands.
      Unbolt axles and take them OUT.
      Support the front of the motor with a motor (Jack up as high as possible)
      Remove all bolts (Starter first)
      Remove linkage and transmission wires
      Lay on your back parallel to the car rotate the transmission and pull away from the car (use your feet to support the long end)
      If you are not prepared for the physical challenge you'll spend more time on this forum whining about how hard it is, when you should be out raging on it with that strength.
      Feel free to PM if you get stuck.
    15. Member themagellan's Avatar
      Mar 30th, 2007
      East
      04-30-2012 11:51 PM #15
      Quote Originally Posted by mkIIGa89 View Post
      Take out the axles - your laziness is making you put in more effort
    16. Member under the radar's Avatar
      Mar 5th, 2007
      NOR-CAL COASTSIDE
      disco, new wave, rave era german iron...and a Japanese V8 with a tailgate
      05-01-2012 12:06 AM #16
      sure buddy
      Quote Originally Posted by spoon! View Post
      I'll go if Paul goes.
      Rod Blagojevich - Team My Little Pony
    17. Member spoon!'s Avatar
      Sep 1st, 2005
      Bay Area, CA
      05-01-2012 12:14 AM #17
      Unbolt all the 8mm triple-squares on the axle flanges, unbolt the ball joint and swing the axles out of the way. You probably left the ball joint bolted up so the axle isn't moving anywhere.
    18. Junior Member mkIIGa89's Avatar
      Feb 6th, 2010
      north ga
      05-01-2012 12:42 AM #18
      Than for your comments.... and so far all i have been informed of is that its a 8mm four square head.... that said where do i find one the guys at northern tool today looked at me like i was nuts... one cv i was able to remove wifh a torx that said im not getting clearance on the p.s of the thans. The flange where the cv bolts to is catching on the fly wheel and binding and hanging on the block before i can rotate vertical
    19. Junior Member mkIIGa89's Avatar
      Feb 6th, 2010
      north ga
      05-01-2012 12:47 AM #19
      And everythig is free struts a arms cv's front and back mounts their is a damn inch gap between them almost and i have never ad this mank problems with pulling a trans and its not my 1st or 2nd rodeo i have done this once or twice. So i can get this straight its a tripple-square 8mm i forsee a set
    20. Member spoon!'s Avatar
      Sep 1st, 2005
      Bay Area, CA
      05-01-2012 01:17 AM #20
      Yes, 8mm triple square. You can buy them by the set for cheap at any auto parts place.
      Did you remove the bolts that hold the ball joint? Something tells me you didn't do this, and you're not able to swing the axle out of the way completely. There's more than enough room once you separate the ball joint from the lower control arm.
    21. Junior Member mkIIGa89's Avatar
      Feb 6th, 2010
      north ga
      05-01-2012 01:57 AM #21
      I was able to swing the cv past the a arm by jacking the motor up i i have it droped down im gonna get the right bit tomorrow and pull that cvi hope that will allow the transfer to clear but going on the past day we shall see if i still get snagged up
    22. Senior Member Mr. Knappy's Avatar
      Oct 10th, 2006
      Levittown, PA
      1991 GTI 16v
      05-01-2012 12:22 PM #22
      Wait what? You got the CV joint removed but you're buying a tool to remove it?
      Do have a friend that can help? If you can't get it out, there is NO WAY you are getting it back in. Not a chance.
      I hate doing it on my back. My shoulders are all ****ed up and I don't have the strength anymore to push up. So what I do is put a strap around the trans making sure to have it wrap around the driver's side CV cup. Then while on my back, I have somebody lift with the strap. I also have the engine as low as possible. This allows gravity to help slightly and makes it easier to see the flange going over the flywheel. One other issue you might be having is you didn't remove the half moon shield. You'll never get it out if that's still there.
      In closing, you're screwed.
    23. Member themagellan's Avatar
      Mar 30th, 2007
      East
      05-01-2012 12:33 PM #23
      Quote Originally Posted by Mr. Knappy View Post
      Maybe he's in the business of creating lawn ornaments
    24. Member shwak23's Avatar
      Feb 28th, 2009
      Maine
      1990 VW Golf Diesel, 1984 VW Rabbit Diesel
      05-01-2012 12:53 PM #24
      I find to reinstall I put it on a jack and position it around where it is supposed to be and then reach down from above and lift the tranny into place.
      The cv flange does get caught on the flywheel when removing. You just need to keep rotating and pulling and as stated before raging.
      Sent from my DROID X2
      I have various MKII and MKI parts. Mostly Diesels and some Gasser stuff.
      www.facebook.com/blackdogjunkyard <---------Here for pictures. PM me for More Info.
      Blackdog Junkyard
    25. Junior Member mkIIGa89's Avatar
      Feb 6th, 2010
      north ga
      05-02-2012 03:24 PM #25
      Yeah snce then i have taken a trip to northern tool got the tripple- square set pulled the transmission and it went off without a hitch
