VWVortex.com - Loud Fan noise
    Results 1 to 12 of 12
    Thread: Loud Fan noise
    1. Junior Member Hashbrownn's Avatar
      Feb 25th, 2011
      Burlington North Carolina USA
      2003 VW Passat W8 4motion sedan, 2005 VW Phaeton V8, 2010 Chevy Equinox AWD
      10-31-2011 09:13 AM #1
      I started hearing loud fan like noise today. Anybody with ideas? it stayed on for a bit after the car was turned off. I usually wouldn't mind lil bit of fan noise.. but this was horrific loud.. I'm guessing I just need to replace the fan. Any ideas?
    2. Former Advertiser FCP Euro's Avatar
      Sep 4th, 2008
      Milford, CT
      10-31-2011 10:50 AM #2
      If you can, take a video, that may help us at least get a better idea of what you are talking about. I just recently replaced my fan clutch that was bad, and sounded a lot like a diesel!!!
      While it's parked and with the engine running, really take a good look in the bay to see if you can possible see where the noise is coming from. It took me awhile to chase my noise down.
      Jan 29th, 2011
      waukesha wisconsin
      2000 passat 1.8T atw
      10-31-2011 11:43 AM #3
      sounds like your SAIP if it was on while your car was off. its a vacuum sound under the air box?
    4. Former Advertiser FCP Euro's Avatar
      Sep 4th, 2008
      Milford, CT
      10-31-2011 11:59 AM #4
      Quote Originally Posted by john prusinski View Post
      If it that is your noise, it may sound like a vacuum cleaner or jet engine depending how bad the SAI Pump is. If you determine that is the noise, you'll want to follow the hoses that come off of it to inspect for damage.
    5. Junior Member Hashbrownn's Avatar
      Feb 25th, 2011
      10-31-2011 02:48 PM #5
      Thank you all, I will try to get a video of it after work. to be continued
    6. Junior Member Hashbrownn's Avatar
      Feb 25th, 2011
      10-31-2011 05:11 PM #6
      I have put up a video of the loud fan. I think it's the Engine Coolant Temperature sensor.
    7. Member E CODE's Avatar
      Feb 1st, 2005
      Toronto, Ontario
      1 Sedan and 1 Wagon - both Wolfsburg's
      10-31-2011 10:47 PM #7
      You are probably going to want it to NOT be a coolant sensor.... Unless you already know the cost of one for the W8....
      I don't know how it would make noise though...
      VAGKRAFT | Red BBS RS for sale | Mk6 Part Out | Micro Can VagCom in the Toronto Area
      Jan 29th, 2011
      waukesha wisconsin
      11-01-2011 10:50 AM #8
      yeah im not sure. i figured since you said it stays on after you turn you car off.
    9. Junior Member Hashbrownn's Avatar
      Feb 25th, 2011
      11-01-2011 05:13 PM #9
      E code, I'm Pretty sure it's the engine coolant temperature sensor. Failed ECT sensor will make the radiator fans to run at maximum capacity. The noise I hear is my fans running way too hard. I'm not worried about the repair cost. Repair cost on the Passat is nothing compared to repair/maintenance cost on my Phaeton. I also have a extended warranty on the W8.
    10. Member E CODE's Avatar
      Feb 1st, 2005
      Toronto, Ontario
      11-01-2011 07:43 PM #10
      Quote Originally Posted by Hashbrownn View Post
      Sorry - missed the part of the fan running hard.... yeah, that would likely be the ECT then - I thought we meant the sound was coming from the ECT itself somehow.... sometimes my brain doesn't work right... lol...
      TWO V8 VW's!!! You are just a glutton for punishment!
    11. Junior Member Hashbrownn's Avatar
      Feb 25th, 2011
      11-02-2011 11:19 AM #11
      I love to burn fuel. What can I say.
    12. Junior Member Hashbrownn's Avatar
      Feb 25th, 2011
      11-03-2011 09:28 AM #12
      I haven't driven the W8 since the Super Fan action. I don't have a CEL on the gauges. Should the fan act up like that with out the Check Engine Light?
