Where did you get the mirrors and hinge cover???
#281
#283
#284
Hinge cover came from VW, (I got it before you could order the part, as a favor, but you can order the left wire harness cover part and it installs on the right)
Mirrors came from OEMplus, (waited three months for them, as each order is a custom allocation from germany, well worth the wait though)
Shift knob came from Taobaoenglish.com (a chinese site, and I just swapped the leather side pieces with the wood side pieces by popping the DSG cover off)
Next: Spokane Rims
Past Rides: http://www.flickr.com/photos/53558020@N04/sets/
#287
Got my 2012 SEL Premium tinted today. Want to post some pix but how do you post so folks dont see private (contact / name) info from flickr?
#288
I use "Photobucket" to post on forums. I'm sure there are other methods.
TDI, the only reason to own a Volkswagen.
#289
OK here are some pix of my 2012 2.5L SEL Premium before and after tint
Platinum Grey Metallic ext / Titan Black int
I got the 3M Medium film, installed by Xtreme Tint
More pix after I get the rear spoiler installed
http://s1254.photobucket.com/albums/...view=slideshow
#291
#296
Got them from OEMplus, took months, but was worth the wait. They came as a set, and at the time they were not available anywhere else so they were $200 and that was that.
To install, you position the mirrors all the way in toward the car, and ever so gently slide your hand behind and dismantle them from their clips. Then detach the heating cable, and reverse.
When installing be very patient, and don't force. I broke my original passenger mirror by trying to get it off (passenger side is more difficult). It will just shatter just like that. Then the new passenger mirror was not fully installed and almost fell off! But once it clicks into place (gently) it is good, and I have had no problems or blind spots at all.
It is a fairly annoying process since glass is so fragile, but once it is done, it is so worth it. Not to mention no more will the passat be able to get them. 2012.5 models and up have jetta mirrors exclusive to the US which are not made for aspherical glass.
Auto dimming is not available on these cars, and is therefore not wired. The auto dim aspherical mirrors are like $800 as well, so there is a drastic price hike. Considering they do not do anything, and I ran the risk of different connectors, I stuck with the original ones.
I must say though, there is no glare because the headlights are refracted around the bend of the glass, and therefore it is like poor-mans auto dimming![]()
#297
Thank you so much! I did find a video link regarding how to change the mirror for Audi A4, but was wondering if it is the same in Passat. From your reply, I guess they are the same.
I am attempting to get a pair from ECS Tuning, but was hesitated because I didn't know how to. You solved my problem!!
#298
Tint 20 % rear and 30% on the front. Front and rear parking sensors.
If you would like to read how i installed parking sensors follow this link http://allcontravel.blogspot.com/201...all-front.html
2012 Passat SE 2.5l Sun&Nav, Black & Beige.
#299
Bye-bye Golf MK6! Just picked up my new ride:
(Forgive the dirty car due to today's storms, iPhone photos, sunset glare, etc.)
The Ride: 2012 Passat SE 2.5 w/Roof & Nav & Salamancas, Black on Black
The Mods: 15% tint all around
#300
Well after lurking around for a while I figured it was time to post up a pic of my tdi se black on tan. I just got it tinted yesterday and replaced the headlights with the ziza lights from ECS. This has been one of the best cars I have owned.
Not the best picture but it will work for now
#301
#302
#303
Just got my wheels on and thought I would share. 2012 Passat TDI SE with Sunroof, Candy White/Titan Black. Here's what's done to date:
- Tint (done before purchase)
Rear Lip Spoiler
Foglights
18 in. VW OEM Interlagos with ContiProContact 235/45R18
...and, finally...wait for it...wait for it...
...DUAL GROCERY HOOKS!!!
Current VWs: 2012 VW Passat TDI SE with Sunroof (mine); 2012 Jetta Sportwagen TDI (wife's)
Past VWs: 2007 VW Passat Wolfsburg 2.0T; 2001 VW Passat GLX V6; 2000 VW Jetta GLX VR6
#304
<img>https://www.facebook.com/photo.php?fbid=166708840035001&set=a.1453070855085 10.24078.100000876592733&type=3&theater</img>
#305
hi phat7deuce, the wheels are looking extremely good. I am looking for these as well but not sure if they will cause any adverse effect? AFAIK, the offset for these is 41 and the stock wheels that I'll have no my car are with offset 48. Any issues with this difference?
Does VW dishonour warranties if I go ahead with these wheels. I've purchased an additional warranty and wondering if you know the answer?
#306
So far, so good...I had some replica versions of these wheels on there for a couple of weeks with a 45 offset and these look better and ride better. A little more expensive, but I think worth it for the OEM wheels. No issues to report...
Not sure on the warranty, but I can't see why wheels would alter that...
#307
Understood, thanks for clarifying.
Do you have to do any modifications (spacers use etc) with the lower offset to install these?
#308
Nope...no spacers needed. I think the lower offset actually pushes the wheel out more, so none would be needed. (I'm not a pro when it comes to wheels, but that's what I understand.)
I had no intention of lowering, so I kept the overall wheel diameter as my stock 17's, by getting 235/45's.
#309
okay thanks.
I'll do some research online and see if I can have these wheels for my car. BY the way, mine comes with 18'' stocks.
#310
"...if you get confused listen to the music play..."
previous 'dubs - '97 Cabrio, '01 Passat, '03 Passat, '05 Jetta, '08 Jetta, '08 NB Conv, '10 GTI & '11 GTI, '12 Passat SEL
#311
Update: 15% tint all around...
#313
Got mine tinted as well, only 35% all around
#314
I´m thinking of changing wheels on my Passat 2012.Do you think the RS5 replica (20") would look nice on my white Passat?
Maybe someone would like to help me and photoshop my car with these wheels??
#315
Maybe with just H&R and Kansas 18"?
or with H&R and RS5 20"??
