Page 12 of 18 FirstFirst ... 2 8 9 10 11 12 13 14 15 16 ... LastLast
Results 386 to 420 of 623
Thread: I hate money...
  1. Semi-n00b G60MAT's Avatar
    Feb 13th, 2008
    Manchester, UK
    Audi A5 3.0 Quattro, Audi TT MK1, Mk1 Scirocco GLS G60!
    04-28-2012 05:10 AM #386
    Oh my, this is looking very tasty indeed, great build!
    Trimsport New Owner - Relaunching Summer 2013 www.trimsport.co.uk
    For Sale: Audi A5 3.0 Quattro, Show: Audi TT Mk1, Project: '77 Scirocco GLS G60: Project Patina!
    www.facebook.com/VWShowSeason
    www.facebook.com/TrimsportUK
    Feb 1st, 2003
    Winston-Salem, NC
    81 Rocco x 2, 87 Rocco, 98 Jetta TDI, 01 Eurovan, 05 TDI wagon, 06 GLI, 10 Jetta wolfie, 13 A4Q
    05-01-2012 07:20 PM #387
    progress, sorta...no pics.
    mounted fuel door and tails. not happy with tails. detrimmed and deglazed...really need some NOS units.
    R&P showed up. Ordered new Peloquin.
    I've got a disassembled 02A and 02J on the bench...gotta crunch some numbers with my new R&P and decide on gears...would still like to source a better 5th.
    Engine is on the stand. Block is broken, got a repair kit from Dieselgeek (those guys rock!). New turbo came in today. New timing belt and such laying there waiting. Rise against concert with my son tomorrow...hopefully have engine completely together and ready thursday or friday. Trans depends on when the Peloquin shows up.
    Modified E30 ellipsoids..not happy with them. Fixin to google up some other alternatives.
    Headliner *maybe* this week...man I hope so. Way too much work to do before SoWo yet...stress levels rising. immensely.
  3. Member d-bot's Avatar
    Sep 6th, 2004
    Par 5 from the Space Needle, PNW.
    80 Storm 20vSC Syncro, 93 Corrado VR6
    05-01-2012 07:33 PM #388
    Quote Originally Posted by veedubtek View Post
    I know where a NOS pair is, but I'm no longer anywhere remotely close to them. It's possible to get them though. *ducks and hides waiting for all the PMs.*
  4. Member
    Feb 1st, 2003
    Winston-Salem, NC
    05-01-2012 07:47 PM #389
    Quote Originally Posted by d-bot View Post
    don't tease me like that...if I have to drive to the dirty with a case of hopslam just to get you drunk and take advantage of your parts stash...then I guess it's a good thing I have a very understanding wife.
  5. Member d-bot's Avatar
    Sep 6th, 2004
    05-01-2012 07:54 PM #390
    Like I said, I'm not there anymore (actually moved across country) but I know who has them and how to get them. So yes, if you have hopslam still please send those "yeast samples" over to the PNW asap!
  6. Member VWinston's Avatar
    Jul 25th, 2006
    Manchester
    79 Rocco 1.3 Turbo
    05-02-2012 08:16 PM #391
    Wow!!!
    Im not sure how I have missed this build. I can thank mr brown for pointing me in this direction. Lots of inspiration
    Jun 5th, 2001
    Royal Oak, MI
    86 Jetta Coupe, 99.5 A4
    05-03-2012 12:10 AM #392
    Are these at a certain PG? If so, I can facilitate said transaction.
  8. Member lewp91's Avatar
    May 9th, 2011
    Essex/Warwickshire/Hertfordshire Uni, UK.
    2001 Golf GTI 1.8T
    05-03-2012 05:35 AM #393
    sub'd this is an awesome build!
    Feb 1st, 2003
    Winston-Salem, NC
    05-03-2012 07:51 PM #394
    limited slip - backordered.
    headliner guy - chooch.
    time to assemble engine? LOLFML.
    man, what a ****ty week for progress. 2 weeks til sowo, and absolutely nothing getting done.
  10. Member
    Feb 1st, 2003
    Winston-Salem, NC
    05-04-2012 11:09 PM #396
    finally, something done. to the engine anyway.
    took a little work, but I successfully got the NLS engine mount and the dieselgeek block repair kit to play nice together (well, all the work was to the DG piece...it's for a TDI, I just like it better). Did a rough cut to the engine cover just to get it on with the NLS mount, but got alot more trimming to do once it's in the car to clear the mount.
    So, after a loooooong evening, I managed to:
    Installed new turbo
    Installed new timing belt, tensioner, rollers, water pump
    Pulled intake mani, cleaned all intake ports.
    Installed new injector o-rings and IMRC motor while it was off
    Installed new valve cover
    Installed new PCV valve assembly and rear breather pipe
    Installed new plugs and coilpacks
    Installed new fuel pressure sensors
    Installed all new brackets and studs for engine cover (deleted by PO)
    Installed new thermostat assembly
    Pulled pump, inspected cam and follower (good!)
    Modified DG TDI block repair kit to fit
    Modified front and rear cover to clear engine mount
    Pressed motor mount bushings into the NLS engine/02A mounts
    Painted an empty 02A case...that's all she's gonna have for SoWo
    sooooo...aside from turbo piping, intercooler, coolant piping, exhaust, wiring, and all that other unimportant stuff, the engine is ready to go!
  11. Member roccodingo's Avatar
    Apr 25th, 2004
    Perth, Australia
    4 x Scirocco 1, 3 x Golf 1, 1 x cabrio 1
    05-05-2012 11:16 AM #397
    mounted tails. not happy with tails. detrimmed and deglazed...really need some NOS units.
    The build detail going into your car is amazing to say the least, A set of new rear lamps will be necessary just to keep up with the rest of the quality !!
    Both the left and right lamps are available from VW Classic parts, only difference is the left has the top chrome strip, the right has a black strip.
    "Schlussleuchte links
    Art.: 531945111E
    Rücklicht links mit Chromrand
    Dieser Artikel ist geeignet für:
    Scirocco 1 ab Fahrgestellnummer 538 200 001
    50,00 EUR"
    and ..
    "Schlussleuchte
    Art.: 531945112P
    rechte Rückleuchte mit schwarzen Rand
    passend für Scirocco 1 z.Bsp. Modell "SL"
    50,00 EUR "
    http://www.volkswagen-classic-parts.de/shop/
    or
    http://www.vwheritage.com/vw_act_vwc...country_GB.htm
    If it aint a Mk1 then it's a donor....
    Brownrocco resto thread....http://www.vwwatercooled.org.au/f55/...esto-2339.html
    Cabrio repair thread......http://www.vwwatercooled.org.au/f55/...irs-21212.html
  12. Member d-bot's Avatar
    Sep 6th, 2004
    05-05-2012 12:47 PM #398
    Quote Originally Posted by detvw View Post
    Not at PG, the ones I'm talking about are NOS.
  13. Member
    Feb 1st, 2003
    Winston-Salem, NC
    05-06-2012 11:17 PM #399
    another meaningless update.
    Got the engine and a freshly painted, empty, trans case to the shop (shop being everything euro, not the dealer I work at), in preparation for the install this week. and, I smoked a mean pork shoulder tonight. Hopefully, between the vw gtg and kickball this week, I get some good progress in.
  14. Member 16v po boy's Avatar
    Oct 26th, 2001
    Winston Salem NC
    02 w8 twin turbo passat wagon, 91 gti vr6, 87 lifted golf, 63 ragtop, 00 jetta,
    05-07-2012 07:24 AM #400
    Clips in pocket
  15. Member
    Feb 1st, 2003
    Winston-Salem, NC
    05-08-2012 08:12 PM #401
    headliner chooch hates time as much as I hate money... gettin there.
  16. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    05-08-2012 08:17 PM #402
    when did you switch from TSI or FSI?
    INA Engineering Inc.
    Email | Facebook
    INA Billet | 034 EFI | Mahle Powerpak | DM Forged | Ferrea | Supertech | ARP | South Bend | HTA Turbochargers | Mocal Oil control | DBW Throttle Body Upgrades
  17. Member
    Feb 1st, 2003
    Winston-Salem, NC
    05-08-2012 08:18 PM #403
    Quote Originally Posted by INA View Post
    bout a month ago...noone would/could do what I needed with the software without stuffing a cluster/key somewhere. I've still got the engine, harness, and computer...maybe for round 2 next year. For now, I could theoretically drive this thing to H20 this year on FSI, so I pulled the trigger and had one shipped in.
  18. Member d-bot's Avatar
    Sep 6th, 2004
    05-08-2012 08:22 PM #404
    black perf. schwing!
  19. Member Chev2dub's Avatar
    Feb 12th, 2008
    not a good point not a bad point but a fairpoint
    07 2.0t passat 84 GLI 16v CIS-M~
    05-09-2012 10:27 PM #405
    wana install my diff into my 02j too?~
    Project where it counts~ http://forums.vwvortex.com/showthrea...4#post78246164
    PBR ASAP: its not a demand.
  20. Member
    Feb 1st, 2003
    Winston-Salem, NC
    05-12-2012 11:50 AM #406
    major setback. went to pick her up from the headliner guy...that didn't go so well. He admitted it didn't turn out near as good as anyone wanted or expected...and by that, I mean it turned out like complete ass. He wouldn't budge off full retail. I told him cut the ****er back out and kiss my ass. Man...all that time wasted.
    Not sure what's happening this weekend...but something will!
  21. Member Falcor's Avatar
    May 26th, 2004
    Sweden
    2003 Golf TDI 130, 964 Carrera 2
    05-12-2012 01:54 PM #407
    A professional who insists that you pay for a job that he himself admitted wasn't good enough?
    Geesh, whatever happened to being proud of your work?
    Scirocco inventory currently at 1% and holding.
    Quote Originally Posted by echassin View Post
    the problem is not with me, you see. The problem is the car. It's a Mk2. It's already gotten way more attention than it deserved
  22. Member ziggirocco's Avatar
    Dec 13th, 2010
    Montreal
    1987 16v scirocco
    05-12-2012 08:48 PM #408
    What a chooch! For real!
    Not sure if anyone has the patterns, but if your old one is intact I am sure Tim at velocity upholstery could make you one, his work is really top notch! Except you would need to install it.
    Just a suggestion....
    Old sciroccos never die....they just go faster....sometimes.......
    www.ziggituning.com
    My Project...
  23. Member d-bot's Avatar
    Sep 6th, 2004
    05-12-2012 08:53 PM #409
    Did he also put the rear windows and wind screen in when doing the headliner? That's the appropriate way. It takes some time and a lot of patience to get those suckers right. Not an easy task.
  24. 05-12-2012 09:32 PM #410
    Surely we can get this guy a good recommendation, in his local area, amongst all the power of the collective 'Vex.
    And remember: "When in trouble, when in doubt, Run in circles, Scream, & Shout."
    And stop calling me Shirley...
  25. Member fredybender's Avatar
    Nov 17th, 2008
    Montreal Canada
    81 Rocco,80 Rocco track, 81 Rocco Haldex twin charge Berg cup project, 84 Mk1 Jetta coupe
    05-12-2012 09:34 PM #411
    I did mine, never done it before, and came out great!
    Just a question of taking your time, skill is secondary...
    And my headliner material was thick vynil from a local fabric shop...
  26. 05-12-2012 09:57 PM #412
    Oh, and that Headliner is going to be a nice dark color... Right?
  27. Member
    Feb 1st, 2003
    Winston-Salem, NC
    05-13-2012 11:02 AM #413
    fredy - how come yours doesn't come all the way down the A/B pillars? just curious...looks great otherwise.
    matt - I've been waiting for this to be done so I can put the windows in.
    tberk - it was black perforated vinyl...I'm sure the next one will be the same...may just wait until I finish building the wiring harness and get all that installed and then have the whole interior done at the same time. that'll give me plenty of time to pick up my windshield from peter
    are mounting brackets sourceable for s1 euro bumpers? are they the same as aftermarket mk1 bumpers? or anything else for that matter?
    all that aside, I figured I could easily run over to the shop yesterday and throw the engine in in 20 minutes or so. I mean, just put car on lift, slide the lump underneath, lower car and pick it up into place. 2 bolts and done, right? Well...8 hours later-
    quite a bit of "massaging" was required...but it's in there.
  28. Member fredybender's Avatar
    Nov 17th, 2008
    Montreal Canada
    05-13-2012 12:50 PM #414
    I took the old headliner to a local seamstress and thats how it was.
    I did glue strips of the same fabric, to finish off the A & B pillars; its easier that way, beacuse you don't have to align the whole length of the pillars, especially because of the stetching involved.
  29. Member 71camaro's Avatar
    Apr 20th, 2009
    Cambridge, MD/Penn State
    MK4 GTI VR6(rip)/ Gen2 Camaro Z28/ MK2 Jetta(rip)/S2 Scirocco 16v/S2 Scirocco/D2 S8/ '95 GMC
    05-13-2012 12:53 PM #415
    Just wanted to say again, this car is sooo effing cool
  30. Member ziggirocco's Avatar
    Dec 13th, 2010
    Montreal
    1987 16v scirocco
    05-13-2012 06:45 PM #416
    Asides the headliner chooch, things seem to be back on track!
    Looking great!
    www.ziggituning.com
    My Project...
  31. Member
    Feb 1st, 2003
    Winston-Salem, NC
    05-13-2012 09:18 PM #417
    eh...workin on it! gotta look into swapping the FSI oil cooler/oil filter housing for a 1.8T or similar, not gonna work with the front engine mount. turbo outlet has exactly zero room at all...not sure what to do about that yet.
    today - got the timing belt cover modified to fit in the car:
    a little vintage rubber / sciroccojim / allensfasteners.com love:
    a little more vintage rubber and dbot love:
    also got the hatch glass prepped for install, and stared at it alot. Hangover days typically always involve lots of staring I've learned...
  32. Member d-bot's Avatar
    Sep 6th, 2004
    05-14-2012 12:31 AM #418
    Love it! <3
  33. Member Jacob Matthew's Avatar
    Sep 27th, 2009
    Lebanon, CT
    1980 Scirocco, 8v 1.6
    05-14-2012 05:49 PM #419
    So sick! Keep going!
    Grime
  34. 05-14-2012 06:50 PM #420
    I really like what I see...
