Results 1 to 8 of 8
Thread: N00b
  1. Member Tate393's Avatar
    Jun 21st, 2011
    P-Vegas, Wiscånsin
    Loretta
    11-02-2011 01:04 AM #1
    Okay guys i have always known about people doing this and seen it.... what the **** does it do? advantages? disadvantages? whats the point? some one please help me out im interested
  2. Forum Sponsor Justin@USRT's Avatar
    Aug 1st, 2011
    Philadelphia
    04.5 PG GLI
    11-03-2011 01:17 PM #2
    Water/Meth injection is used to suppress detonation and to safely allow much greater amounts of boost and or compression. When used the right way, it has benefits similar to running race fuel all the time.
    When a nozzle is placed after the throttle body the droplets reach the combustion chamber and smooth the entire process. It melts away any carbon deposits and eliminates the glowing hotspots. Basically, it allows you to have a more smoother combustion instead of a violent bang bang, which leads to broken internals and pistons. I highly recommend our throttle body flange upgrade because it places the nozzle after the throttle body, and you don't have to tap into your manifold or any other position, and most importantly throttle bodies are expensive. I am sure you are aware of what would happen if you sprayed liquid into an electrical component
    You can also run a dual nozzle kit and put another nozzle post intercooler if you have a turbocharged vehicle. The droplets absorb the heat from the intake air. The droplets start to evaporate causing the intake charge to be cooled even further. (almost like running your in 100degree temps, but your engine thinks it 40degrees) significantly provides better cooling, and you can never have to much cooling.
    Allows for maximum power output while substantially increasing overall engine reliability.
    Depending on what setup your vehicle is (stock turbo or bigger) I would recommend the Snow Performance Boost Cooler Stage 2 Kit
    There are two methods of controlling your spray. Either MAF or MAP based. If you are on a stock turbo or similar you would get best results using MAF controlled. On a turbo bigger, the MAP sensor would be usable as it would give you more accurate readings.
    You need to make sure your nozzle sizes are correct. Too much spray will put the fire out, and too little spray is just under powering your vehicle, then whats the point right? We can help you pick out the precise nozzle sizes that you would need.
    Justin Im, Technical Sales
    US Rally Team
    www.facebook.com/usrallyteam
    AIM-jijust88
    Unitronic Chipped Authorized Dealer
    Feb 12th, 2011
    minnesota
    Skerv -torn up mk3 Golf
    12-23-2011 07:24 PM #3
    what meth parts would you recommend from start to finish (running lugtronic standalone) for this setup:
    16V ABA with an Eaton M62 SC?
    Probably the same setup that you recommended for the op? With the dual nozzle thing?
    Thanks!
    HATERS POST ALL NEGATIVE COMMENTS HERE.
    One day my brain said, "I think my car is going to be good to me today"...but then it remembered its a Volkswagen...
    Quote Originally Posted by SirSpectre View Post
    I need a beer and a hooker.
  4. Forum Sponsor Scott@USRT's Avatar
    Jan 13th, 2005
    Haddon Heights, NJ
    MK4 Jetta 2.0T, Mk1 Scirocco 16v, 323 GTX
    12-25-2011 02:22 PM #4
    Quote Originally Posted by BigJohneyK View Post
    16V ABA with an Eaton M62 SC? Probably the same setup that you recommended for the op? With the dual nozzle thing?
    Yes, sir. The same exact information applies in your case for all the same reasons. We have no 16v throttle spacer to offer, however. So, you'd either tap the intake pipe before the TB or do it just after in the plenum.
    Is this setup intercooled? Do NOT spray before the interooler!
    Scott F. Williams, Team Director
    US Rally Team
    Feb 12th, 2011
    minnesota
    12-25-2011 11:06 PM #5
    Quote Originally Posted by Scott@USRT View Post
    I am in the figuring out the rout stage right now but that would be the idea (to get an intercooler.
    Would the dual nozzles be beneficial for this setup or would it be overkill? Its not really the beastliest setup there is... Or am I misreading this, does the setup already come with 2 nozzles and the dual nozzle mounting is just for mounting both nozzles?
    What size nozzles would be good for me?
  6. Forum Sponsor Scott@USRT's Avatar
    Jan 13th, 2005
    Haddon Heights, NJ
    12-26-2011 07:05 AM #6
    Dual nozzle setup is great for ALL engines so long as the distance between the intercooler and the TB is of sufficient length. There is no question that meaningful gains are realized when that distance is 2' or more.
    Right, an outrageous build isn't needed to gain from the superior intake air cooling. In fact, a small turbo pumps out far more heat than a big turbo. So, such engines may actually benefit more from a dual nozzle configuration.
    That's correct. Each kit comes with two nozzles but only the means to mount one or the other.
    We calculate nozzles at the time of purchase. Get your plans together and then let us know when you're ready to take the next step.
    US Rally Team
    Feb 12th, 2011
    minnesota
    12-26-2011 11:20 AM #7
    cool, thanks man. You are a big help!
  8. Member holladayego's Avatar
    Sep 28th, 2011
    McMinnville, OR
    1997 GTI VR6 S/C, 1999.5 Jetta VR6 (current), 1985 GTI 1.8 16v (sold), 1996 Jetta GLX (sold)
    02-19-2012 12:54 PM #8
    Quote Originally Posted by Justin@USRT View Post
    I have a obd2 vr6 with a stage 2 supercharger kit im currently only running 5 lbs of boost but im wanting to jump to 8 lbs. can you sugest the proper kit for me and if i should run a dual nozzel set up and what size nozzles i should run?
    "Too fast inst fast enough!"
