VWVortex.com - how to remove the carpet on a jetta
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 28
    Thread: how to remove the carpet on a jetta
    1. Member cm123's Avatar
      Jun 3rd, 2010
      Westchester/Long Island NY
      98 mkIII Jetta Wolfsburg(sold), 2005 Volvo s60R
      11-02-2011 09:38 PM #1
      im sending my car out to the body shop to fix the floorboards on my car before the winter comes.
      does anyone have a DIY for it or could tell me how to do it that way i don't damage the carpet.
      before you say to search i did already couldn't find anything.
      hope someone can help me out.
    2. Member cm123's Avatar
      Jun 3rd, 2010
      11-02-2011 10:42 PM #2
      anyone?
    3. Moderator vanaman's Avatar
      Aug 26th, 2003
      OhiO
      97 Jetta GLX, 99 Cabrio, 03 Sierra SLE, 97 tracker, 84 ATC200X, 78 CB750F, 66 S90
      11-02-2011 11:14 PM #3
      you have to virtually take everything out.
      take out seats, center console, door sill, and all the rest of the lower trim.
    4. Member
      Sep 16th, 2011
      simpsonville ky
      91 Jetta Coupe
      11-02-2011 11:20 PM #4
      you cant really mess anything up. unless you try really hard. just unhook the seats unbolt the one bolt on the front pull the seats out. remove thee center console and all of the plastic molding pieces around the edges of thee carpet unbolt the seatbelts and the rear seat brackets. then the clip/ push pin things up under the dash.. then start pulling
      hope this helped a little
    5. Member cm123's Avatar
      Jun 3rd, 2010
      11-03-2011 12:13 AM #5
      Quote Originally Posted by cll2993 View Post
      thanks for the reply im gonna remove it tomorrow will let you know how it goes.
      the only reason i asked because my friend did it on his mk2 and he said he had to cut the carpet the where the seat rails were. So i thought maybe the mk3 would be the same. unless he was doing it wrong
    6. Member killercoconuts's Avatar
      Nov 24th, 2008
      Connecticut
      2010 Jetta 2.5L 1986 Scirocco ABA 1998 Golf ABA 2004 Harley Davidson Heritage Softail
      11-03-2011 12:22 AM #6
      Nope, should pull right out when you get all the above mentioned out of the way. Front seats, rear seat bottom, whole front and rear center console, and the lower door sills. Just be careful of the loops going around the clips under the sills. If you just yank it, they'll rip.
      I like ride height alteration in either direction.
    7. Member The Big V's Avatar
      Jul 11th, 1999
      NYC
      '99 mk3 Golf Wolfsburg (Black, 5spd, 239k mi +), '89 BMW E30 325iS 5spd RACE CAR
      11-03-2011 01:04 AM #7
      hey bro...there is DIY for part of the rear of the center console for replacing the ebrake and stuff...i used it when i put new ebrake lines in.
      http://faculty.ccp.edu/faculty/dreed...rake/index.htm
      thanks o great Mr Reed for the countless references/resources. more
      take the road less travelled...
      __________________________
      GermanAutoParts | TyrolSport | USRT | HGB transmissions
      TT | 4Season | BrokeVW | Dan Reed's DIY VW site
    8. Member JohnStamos's Avatar
      Feb 3rd, 2010
      A4, A6, Mk3, Shelby, 650x
      11-03-2011 05:59 AM #8
      Quote Originally Posted by killercoconuts View Post
      Came in to say this.
    9. Member cm123's Avatar
      Jun 3rd, 2010
      11-03-2011 08:03 PM #9
      so the removal of the carpet was a success.. managed to no break anything which is always good haha.
      i only snapped 2 pics here they are:
      surprisingly this was actually the only visible hole on the floor board. other spots in the car were weak so ill probably just get a majority cut and redone.
      Also behind the sideskirts is a mess not sure if thats complicated to fix or not, but its gotta get fixed.
    10. Member
      Sep 16th, 2011
      simpsonville ky
      91 Jetta Coupe
      11-03-2011 10:05 PM #10
      thats why i pulled mine out... start hitting the floor with a hammer youll find more holes.. i thought i had 2... nope 5
    11. Member killercoconuts's Avatar
      Nov 24th, 2008
      Connecticut
      11-03-2011 10:48 PM #11
      Quote Originally Posted by cm123 View Post
      WOOF. Been there, done that. You're lucky someone else is doing it for you.
    12. Member cm123's Avatar
      Jun 3rd, 2010
      11-03-2011 10:54 PM #12
      i can only imagine what will happen haha.
      yeah i know.. all the padding that it had is shot since it was all wet.. did you have to replace yours?
    13. Member
      Sep 16th, 2011
      simpsonville ky
      91 Jetta Coupe
      11-03-2011 10:58 PM #13
      i just ripped it out.. my carpet is still out because i havent fixed the holes yet ive got it all cleaned up and now have to shape the metal and weeld which is a pain. but no i wont put nee padding in or whatever.. i can do without
    14. Member
      Sep 16th, 2011
      simpsonville ky
      91 Jetta Coupe
      11-03-2011 11:00 PM #14
      haha that message obviously wasnt for me..
    15. Member killercoconuts's Avatar
      Nov 24th, 2008
      Connecticut
      11-03-2011 11:15 PM #15
      Just patched it. didn't take the time to take a pic when i was done. Mine was nasty, cancer was up behind the seat rail.
    16. Member cm123's Avatar
      Jun 3rd, 2010
      11-03-2011 11:26 PM #16
      wow yea yours looks pretty bad.. my rocker panels are real bad. ill take some pics of it tomorrow.
      cll2993, did you replace the padding with anything or did use the original?
    17. Member cm123's Avatar
      Jun 3rd, 2010
      11-05-2011 12:06 AM #17
      ok so i forgot to take pics of the rockers since i was busy but ill do it tomorrow when i drop the car off.
      but after doing some searching on google and vortex i found some helpful information.
      for rocker and rear wheel arches RustRepair has them for amazing prices:
      http://rustrepair.com/index-mf.html
      and for those who has their gas cap area all rotted Afazz posted up a DIY on how to replace it which is what im gonna have to do:
      http://forums.vwvortex.com/showthrea...=gas+door+rust
    18. Member
      Sep 16th, 2011
      simpsonville ky
      91 Jetta Coupe
      11-05-2011 01:14 AM #18
      no im just leaving it out i think. i havent gotten to it yet i havent welded yet. but ill probably leave it out
    19. Member coolvr6's Avatar
      Nov 5th, 2011
      South Carolina/ PA
      MK3's
      11-05-2011 07:53 AM #19
      get rubberized undercoating after you get it fixed or it shall happen again, mwahahaha, as for the carpet, unbolt ur interior, the end.
      OBJECTS IN MIRROR APPEAR TO BE LOSING
    20. Member coolvr6's Avatar
      Nov 5th, 2011
      South Carolina/ PA
      MK3's
      11-05-2011 07:53 AM #20
      undercoating- Not spray paint
    21. Member coolvr6's Avatar
      Nov 5th, 2011
      South Carolina/ PA
      MK3's
      11-05-2011 07:54 AM #21
      that rust is badass
    22. Member coolvr6's Avatar
      Nov 5th, 2011
      South Carolina/ PA
      MK3's
      11-05-2011 07:55 AM #22
      get 2 cans lol
    23. Member cm123's Avatar
      Jun 3rd, 2010
      11-05-2011 07:57 PM #23
      Quote Originally Posted by coolvr6 View Post
      thanks for the tip
      i left it at the body shop today so they can start working on it as soon as they can.
      for some good news, the rockers only cost me $110 shipped through some website he gets his part from.
      im hoping to get it back before thanksgiving, but if not w.e haha. as long as it gets done right
      and for the bad news, here are some pics of my rockers
    24. Member coolvr6's Avatar
      Nov 5th, 2011
      South Carolina/ PA
      MK3's
      11-05-2011 08:03 PM #24
      : O... get 4 cans, lol ive had 3 jettas and not 1 of them had any rust, do you live in the salt lake city?? lol
    25. Member coolvr6's Avatar
      Nov 5th, 2011
      South Carolina/ PA
      MK3's
      11-05-2011 08:05 PM #25
      i think i would cry if i saw that on my car, then i would hug my car and sing to it slowly , LOL
