Page 20 of 24 FirstFirst ... 10 16 17 18 19 20 21 22 23 24 LastLast
Results 666 to 700 of 814
Thread: My Fahrenheit Build Thread
  1. Member glifahrenheitcameron's Avatar
    Sep 14th, 2011
    Supply NC
    2007 VW Jetta GLI Fahrenheit
    09-11-2012 12:00 AM #666
    finally found a expansion plug that i like
    sanded it down some and
    Quote Originally Posted by PSU View Post
    So many little cry babies in this thread.
  2. Member GTI Fanboy's Avatar
    Feb 29th, 2012
    Melbourne, Australia
    Stage 2+ MkV GTI DSG
    09-11-2012 08:43 PM #667
    Fits in nicely.
    GIAC Stage 2+ | GIAC DSG Tune | Forge Twintake | 3" SPM Downpipe | Revised Diverter Valve | Autotech Fuel Pump| BFI Mount | Eurojet FMIC | R8 Coilpacks | Valeo LED Tails | Whiteline 24mm RSB | BSH PCV Revamp | Whiteline Anti-Lift Kit | K-Mac Custom Springs | OSIR O-Pod Mono GT, NewSouthPerformance Indigo Boost Gauge, OSIR Carbon Headlight Surrounds - Coming Soon!
  3. Member bryangb's Avatar
    Jun 16th, 2010
    Hanover, PA
    '08 GTI, '12 Beetle, '91 Passat
    09-11-2012 08:44 PM #668
    // DROP // DRAG // DESTROY // beer
    // Open Road Tuning
    Instagram: @bryangb
    bags and wheels = build thread
  4. Member glifahrenheitcameron's Avatar
    Sep 14th, 2011
    Supply NC
    09-12-2012 12:07 PM #669
    removed these from the rear
    damn it was dirty
    also topped off the windshield washer fluid, put in a little bit of oil, and tied off some wires in the engine bay to make it look a little neater.
  5. Member glifahrenheitcameron's Avatar
    Sep 14th, 2011
    Supply NC
    09-12-2012 10:02 PM #670
    ripped out the washer fluid neck
    plugged the hole up with a 1 inch tapered rubber plug
    and shabam
    now i have a question, there is this thing
    do i leave it or remove it? if so how do i get it out? i cant get pliers or a socket to fit
  6. Member glifahrenheitcameron's Avatar
    Sep 14th, 2011
    Supply NC
    09-13-2012 02:16 AM #671
    nevermind got it
    Oct 13th, 2011
    Charlotte, NC
    2010 Jetta Wolfsburg Edition
    09-13-2012 10:07 AM #672
    Quote Originally Posted by NmyGLi_06 View Post
    Your car is beautiful!! It's actually my background on my iPad!!
    Lol it's the background on my laptop!
  8. Member glifahrenheitcameron's Avatar
    Sep 14th, 2011
    Supply NC
    09-15-2012 01:23 PM #673
    2 shots for the day, need to lower the back a little now
    and this came
  9. Member KIDVersion 1's Avatar
    Jul 4th, 2011
    Pennsylvania
    '89 Coupe, '12 Passat
    09-15-2012 02:42 PM #674
    I wanted to throw this out there since no one has yet. You mentioned turning off the MIL that is related to your downpipe with VCDS. Unless it is now possible, you won't be able to do that. You can clear the code but it will be back. A tune (I believe stage 2 or higher) will code out that catalyst code.
    2012 Passat Timeline | 2008 R32 Timeline | 1989 Jetta Coupe Timeline | Flick
    For all of your automotive LED needs, visit PerformanceLEDs.
    For all of your air suspension needs, visit Bag Riders.
  10. Member kevin FaKiN spLits's Avatar
    Aug 23rd, 2010
    01001011010011110 1010010
    09-15-2012 02:53 PM #675
    O2 spacers will do the same thing.
    "The Vile Bunch" ll v2lab ll eemilitiatv ll Stay Orange.
    "Ok.. you need to brake early at the white penis, then go deep at the black vagina. Try to stay on the outside at the shocker, then hug the curb at the yellow rack..."
  11. Member KIDVersion 1's Avatar
    Jul 4th, 2011
    Pennsylvania
    09-15-2012 03:21 PM #676
    Yes but you should not run a larger downpipe without software for an extended period of time. Stage 1 and 1+ will still need a spacer IIRC.
  12. Member kevin FaKiN spLits's Avatar
    Aug 23rd, 2010
    09-15-2012 04:01 PM #677
    I didn't see if he's running cat less or not. Cat less you should run those spacers at any stage. They do cure Mil using a test pipe. I had a mil when I first got mine, and the draft design spacer got rid of it. I also have a 2.5 tho, not sure its that makes any difference.
  13. Member KIDVersion 1's Avatar
    Jul 4th, 2011
    Pennsylvania
    09-15-2012 04:13 PM #678
    A spacer is not needed for stage 2 on a catless downpipe.
  14. Member kevin FaKiN spLits's Avatar
    Aug 23rd, 2010
    09-15-2012 05:08 PM #679
    Quote Originally Posted by KIDVersion 1 View Post
    It'll lengthen the life of the sensor. Either or really, ones just 7 times cheaper than the other.
  15. Member kevin FaKiN spLits's Avatar
    Aug 23rd, 2010
    09-15-2012 05:14 PM #680
    Also depends which dp you have, a few of them come with L shaped O2 extensions already. A spacer will keep his mil off till he goes stage 2 or if he doesn't want stage 2 it'll keep it off anyway
    But, ya your right you can't just use vcds to make it never trip again.
    One serious question, Im not being a smartass, why shouldn't you run a larger dp without software long term? I've never heard that before.
  16. Member KIDVersion 1's Avatar
    Jul 4th, 2011
    Pennsylvania
    09-15-2012 05:23 PM #681
    What I am trying to say, is that the right way to keep the MIL off with an aftermarket downpipe, is to tune the car to stage 2. Sure a spacer will keep the light off, but you are not doing your engine a service by having a larger exhaust exit and not changing the fuel/intake mapping. A spacer should be a temporary fix until a tune can be acquired.
    I had a 42DD spacer (which I prefer over the straight spacers because of fitment) for about a month until I could get a tune. Got the tune and took the spacer off in the same day and that was over 40,000 miles ago.
  17. Member glifahrenheitcameron's Avatar
    Sep 14th, 2011
    Supply NC
    09-15-2012 09:34 PM #682
    i should have clarified. i do have the spacer. when i first installed it, i never had a cel. to pass inspection, i had to cut in my cat and then cut it back out. when i took it back off, the cel came back and just comes and goes. it stays on more than anything now though
    Quote Originally Posted by kevin FaKiN spLits View Post
    its catless
  18. Member bryangb's Avatar
    Jun 16th, 2010
    Hanover, PA
    09-15-2012 09:38 PM #683
    I don't see how running a larger downpipe without a tune would cause harm. Are you getting the most out of the larger downpipe? No. But harming the motor? How?
    // Open Road Tuning
    Instagram: @bryangb
  19. Member kevin FaKiN spLits's Avatar
    Aug 23rd, 2010
    09-15-2012 11:21 PM #684
    Quote Originally Posted by bryangb View Post
    You aren't
  20. Member glifahrenheitcameron's Avatar
    Sep 14th, 2011
    Supply NC
    09-16-2012 12:38 AM #685
    so should i just adjust the spacer til the cel goes away or what?
  21. Member KIDVersion 1's Avatar
    Jul 4th, 2011
    Pennsylvania
    09-16-2012 01:21 AM #686
    You aren't
    Never said it would hurt or harm the engine. I said you aren't doing the engine any good and that the right way would be to get the tune.
    Quote Originally Posted by glifahrenheitcameron View Post
    I would first scan it to find out what code it really is. Also check the wires for the O2 sensor to make sure there aren't any kinks or breaks. A spacer won't do crap for an incomplete circuit.
  22. Member glifahrenheitcameron's Avatar
    Sep 14th, 2011
    Supply NC
    09-16-2012 03:22 AM #687
    if i can remember correctly the scan said the 02 sensor was too rich
  23. Member glifahrenheitcameron's Avatar
    Sep 14th, 2011
    Supply NC
    09-18-2012 04:30 PM #688
    horn came today for the honk to chirp mod
  24. Member glifahrenheitcameron's Avatar
    Sep 14th, 2011
    Supply NC
    10-04-2012 08:13 PM #689
    painted the dip stick matte black today and cleaned the car
  25. Member bryangb's Avatar
    Jun 16th, 2010
    Hanover, PA
    10-04-2012 09:12 PM #690
    Can I ask how you removed the dipstick tube to paint it? The orange upper piece of the tube looks terrible and I hate it
    // Open Road Tuning
    Instagram: @bryangb
  26. Member glifahrenheitcameron's Avatar
    Sep 14th, 2011
    Supply NC
    10-04-2012 09:40 PM #691
    i didnt remove it. what i did was took a very thin and fine paint brush, sprayed the spray paint into a small cup, and just carefully painted it like that
  27. Member bryangb's Avatar
    Jun 16th, 2010
    Hanover, PA
    10-04-2012 09:42 PM #692
    // Open Road Tuning
    Instagram: @bryangb
  28. Member glifahrenheitcameron's Avatar
    Sep 14th, 2011
    Supply NC
    10-04-2012 09:44 PM #693
  29. Junior Member
    Oct 4th, 2012
    Poconos PA
    07' Fahrenheit Gti
    10-04-2012 09:58 PM #694
    I like what you've done with the car. It looks pretty good. Only thing is the tail lights might be a bit dark...I would've gone lighter. I myself drive a Fahrenheit Gti, I think with the Gli because its a lighter yellowish orange lighter tints look better. Just my opinion
  30. Member glifahrenheitcameron's Avatar
    Sep 14th, 2011
    Supply NC
    10-05-2012 01:52 AM #695
    Quote Originally Posted by Dgrees_Fahrenheit View Post
    u talkin about the led tails i have now or the tint that i used to have on the stock tails
  31. Member glifahrenheitcameron's Avatar
    Sep 14th, 2011
    Supply NC
    10-05-2012 07:43 PM #696
    bfi torque arm insert installed
    also put in some oil, fuel injection cleaner, greased the DV, and got the rest of the supplies needed to to install the chirp horn
  32. Member glifahrenheitcameron's Avatar
    Sep 14th, 2011
    Supply NC
    10-06-2012 11:08 PM #697
    got productive today....trimmed the back fender liners a little
    also in the back i greased the perches/collars
    trimmed front fender liners
    rolled the little tabs on the front fenders
    chirp horn
    also in the front i lowered it just a hair (there was only like 1 thread left) and greased the collars or whatever they are considered and made sure to tighten the 2 together really nice to try to get rid of the squeaking .
    besides all that i just cleaned the wheels while i had them off
    heres what the horn sounds like
    not sure if it threw a CEL or not since i already had one prior to this lol
  33. Member glifahrenheitcameron's Avatar
    Sep 14th, 2011
    Supply NC
    10-08-2012 03:47 AM #698
    in the market for a shift knob.....forge big knob or osir with the red light to match my interior lights?
  34. Member bryangb's Avatar
    Jun 16th, 2010
    Hanover, PA
    10-08-2012 09:29 AM #699
    Forge big knob is... Big
    // Open Road Tuning
    Instagram: @bryangb
  35. Member KIDVersion 1's Avatar
    Jul 4th, 2011
    Pennsylvania
    10-08-2012 09:41 AM #700
    It is. A friend has it and there is no way I could live with it for daily use.
