Bump.![]()
#1
On Sale Here for only $139.00
Add Install Kit For Only $69.95 More $208.95 Total!
Want to dress up your engine bay, or need a large rail to feed your thirsty 2.5L? Then you need this billet aluminum fuel rail for 2.5L 5 cylinder engines. These are made from a solid piece of 6061 aircraft aluminum, to provide a beautiful, high flowing piece. These rails have mount tabs that use factory screws to attach to your intake manifold. These feature -8an O-ring boss ports, which will be enough flow for even the most wild setups. There is no need to worry about injectors coming out either, as these rails retain the factory injector clips for added safety. The clips install at the same angle as the factory fuel rail, to maintain the factory injector angle.
These fit all 2.5L 20V 5 cylinder engines.
Features:
Made in house from 6061 aircraft aluminum
Retains factory injector clips
Available in IE RED or raw finish
Includes mounting tabs and bolts
