VWVortex.com - Manual transmission won't shift into gear
    Results 1 to 13 of 13
    Thread: Manual transmission won't shift into gear
    1. 11-06-2011 05:35 PM #1
      Hi Guys. I have a 2011 Jetta SE with a manual transmission and it has been driving perfectly fine until yesterday. I had to make a left turn on a busy street and i think I accelerated very fast. It only lasted a few seconds before i stopped on a traffic light after which i couldn't shift into first gear. or second. The shifter moves but it doesn't seem to be engaging into gear. I drove off in what it seemed like 3rd gear, parked and shut the engine off. When i started again it shifted, but the shifter felt somewhat more lose than normally. The i drove off and I was in a bad traffic where i had to stop and go for about 20 min and this happened one more time - where it felt like i drove off 3rd gear. i made it home since the rest of my drive was on highway at higher speeds. This morning i backed out the garage but I couldn't get into first or second again and i couldn't shift into reverse either.
      So now i can;t even drive the car to the dealership.
      I guess I am wondering if anyone knows what the problem might be. I suppose it would be covered by the warranty, but I am so worried, and they are closed today and I just can;t wait to call.
      Does anyone know if the warranty will cover towing since I can't drive there?
      Apr 7th, 2011
      Alberta
      11-06-2011 05:54 PM #2
      something like a gearbox or clutch failure?...should be covered, including the tow. call the 1 800 number for roadside assist.
    3. 11-06-2011 06:09 PM #3
      the clutch doesn't feel different than usual. I also noticed this morning that i couldn't start the car unless i had the gear shift in neutral, even with the clutch pressed down. Very weird.
    4. Junior Member
      Jun 15th, 2011
      Warren county, nj
      14 Jetta TDI VE - 11 jetta s - sold
      11-06-2011 07:33 PM #4
      Quote Originally Posted by Vale View Post
      sounds like a linkage to me, still should be covered in the warranty.
      Vag-com hex-can in Washington twp, NJ 07882.
      Pm me if u need something vagged...
    5. Member mwayner69's Avatar
      Jul 1st, 2010
      Quinlan, TX
      11 Jetta TDI
      11-07-2011 03:13 PM #5
      Quote Originally Posted by indifferent1 View Post
      +1 I had that happen on another car a while back. The part that held the linkage to the shifter broke off. The shifter would move all around, but nothing was happening. I got to make a 50 mile drive home in 3rd gear.
    6. 11-07-2011 08:23 PM #6
      Was this covered in warranty? I really hope I don't have to pay...
    7. Member NotLowEnough's Avatar
      Mar 23rd, 2011
      Chatham County, NC
      Mk.6. 2013 Mondeo Hybrid. 2015 Mondeo Hybrid. Jeep 4x4. Disco II.
      11-07-2011 09:13 PM #7
      New guys: READ THIS FIRST. | 8V Society: #369 | VW / Audi & BMW Indy Technician (PM for VCDS / GT1 Coding) | Help find Grant's pictures.
      Quote Originally Posted by xombiesarelove View Post
      Seems like it would be pretty self explanatory. Just hand the guy a bomb and an IKEA level instruction sheet and call it day.
      GirlsLoveIt.
    8. Junior Member
      Jun 15th, 2011
      Warren county, nj
      11-07-2011 10:00 PM #8
      ..... Still should be covered in warranty....
    9. 11-08-2011 12:12 AM #9
      Definitely a linkage and even if it isn't covered its easy/cheap to fix. I've popped off few VW linkages shifting hard (even ducked taped one back on which held just long enough to get me home lol). Should look something like this (not a MKVI jetta but they havent changed the basic design since MKIIIs)
      If any of those two linkages break, come off or the adjustment screw thing behind the spring comes loose you get just what you got. Nothing major.
    10. Junior Member
      Jun 15th, 2011
      Warren county, nj
      11-09-2011 06:12 AM #10
      Quote Originally Posted by 02GTI-VR6-same1 View Post
      Wow, doesn't get much easier than that... You even have a clear shot... I have a 5 speed mkvi, maybe later in the day I can post something up
      I would like to know what happened with this though, if it was covered under warranty or not...
      I think If no aftermarket mods are in place ur fine.
    11. 01-20-2013 09:01 PM #11
      Was just reading your post looking to see if anyone has experienced the same problem we did. And what do you know - You did!
      My lovely was driving her new VW Beetle 2012. Second day of owning it. She drove it 30 miles and was just approaching my home. She was headed down a small hill, and tried to downshift into 2nd Gear. Car Shifter would not move into 2nd. Then she rolled to a stop. Then Tried to Shift into 1st, 2nd or any GEAR. Would not shift at all. She sat in car for over 30 minutes. Turned the Car off and on multiple times. No Luck. Then waited for 10 minutes. And Then Luckily it Was able to Shift on the 10th try. We're both concerned about Her driving it anywhere at this point. especially after these problems. It's a SUNDAY night so we can't take it back to DEALER till tomorrow.
      Anywhere, that's our story. We'll take it to dealer in the morning. Will check back to let you know what we find out.
      Pastalanna.
    12. 11-28-2014 06:54 PM #12
      Quote Originally Posted by Pastalanna View Post
      Pastalanna.
      I'm getting my '93 Fox back on the road and everything works fine after being on stands for the last twelve years EXCEPT the four speed transmission I put in won't go into any gear. when I first put the tranny in I ran it through the standard H pattern and it worked well. It sat for a few days while I worked some bugs out in the fuel line. When I got the car running on the stands I wanted to put power to the wheels. No luck. I can't buy a gear. It feels like there is no gating at all. Did I do something wrong? Or is it an alignment issue internal that I need to be educated on?
    13. Former Advertiser
      Nov 26th, 2014
      Manchester, CT
      2012 Jetta 2.5, 1974 Mercedes 240D, 1934 Rolls Royce 20/25
      11-28-2014 07:26 PM #13
      I had this happen once, in my case I just readjusted the shift linkage and it was good. Might be a good idea to try that before bringing it in.
