****ATTN******
DOUGLAS VW WILL NO LONGER BE SELLING THESE AFTER APRIL 30TH 2013!!!!
THIS PRICE WILL BE ENDING AND GOING BACK TO FULL RETAIL!!! ORDER YOUR SET TODAY!!!!
BASE CARRIER BARS
1K0-071-126
$252+ SHIPPING (ADD TAX IF YOU LIVE IN NJ)
MAKE SURE YOU CALL AND ASK FOR STEVE TO ORDER AT THIS SPECIAL PRICING!!!!
Lockable, set of 2 cross bars complete with mounting instructions and hardware. Two plastic-coated aerodynamic aluminum cross bars. Anodized aluminum section. Plastic supporting feet, cover caps and covers. Galvanized plastic coated steel plate. The lockable unit has built-in cylinder locks mounted into the full length end bracket covers. Supports T-slot. Bar dimensions: 1350 x 180 x 270 mm / weight: 7.0 kg. The maximum permissible roof load is 165 lbs/75 kg, evenly distributed. Consult your Owner,s Manual for weight specifications.
