Page 4 of 10 FirstFirst 1 2 3 4 5 6 7 8 ... LastLast
Results 106 to 140 of 320
Thread: Navigation firmware update for RNS-510
  1. Member Seki's Avatar
    Nov 19th, 2009
    New York
    2012 A6
    12-03-2011 08:45 PM #106
    Will give it a shot.
    2012 A6
    Need VAG-COM/VCDS PM me
  2. 12-06-2011 02:07 AM #107
    After some very brief testing, it looks like the only music you can control is on your phone/iPod, not the music from the HDD on the RNS510.
  3. Member Seki's Avatar
    Nov 19th, 2009
    New York
    2012 A6
    12-13-2011 11:58 AM #108
    Just an FYI you can import destination from a SD card in to your RNS using the following website.
    VW Labs
    2012 A6
  4. Member de_bklyn's Avatar
    Jan 15th, 2011
    Brooklyn
    C7 A6 2.0T, C5 A6 Avant 3.0
    12-13-2011 07:28 PM #109
    Quote Originally Posted by Seki View Post
    VW Labs
    I've used this a couple times. Cool feature.
    2013 A6 2.0T Quattro
    2004 A6 Avant 3.0L Quattro | Depo projector headlights, 6000k HID fogs,35% tint, Pioneer x940bt nav/head-unit, ST Coils, .....
  5. Semi-n00b
    Nov 9th, 2009
    Montreal, Canada
    2013 Touareg TDI, 2010 Jetta TDI Highline
    12-14-2011 12:00 PM #110
    anyone from Canada try this on Canadian Spec cars?
  6. Member Seki's Avatar
    Nov 19th, 2009
    New York
    2012 A6
    12-14-2011 12:57 PM #111
    Quote Originally Posted by shark1048 View Post
    Do you know what firmware you have on it now?
    But it should work. US and Canada units are the same.
    2012 A6
  7. Semi-n00b
    Nov 9th, 2009
    Montreal, Canada
    12-14-2011 02:39 PM #112
    it is 1040
  8. Member Seki's Avatar
    Nov 19th, 2009
    New York
    2012 A6
    12-14-2011 03:02 PM #113
    it is 1040
    You are good to go.
    2012 A6
  9. Member Seki's Avatar
    Nov 19th, 2009
    New York
    2012 A6
    12-15-2011 05:11 PM #114
    MDI UPDATE added to the first post. Works for RNS 510 and RCD 510
    2012 A6
  10. Junior Member Stuart Little's Avatar
    May 26th, 2011
    Denver, CO, USA
    2010 Jetta TDI Cup Edition - 6 Speed Manual
    12-15-2011 05:18 PM #115
    What does the MDI Update entail as far as features, or is it more of a speed/optimization?
    Thanks,
    Stu
    2010 TDI Cup Edition 6MT - Laser Blue (RNS-510 SatNav/DVD, Sunroof, ThunderBunny Bodykit, MDI)
    Tweaks: Bi-Xenon Projectors, Clear Sidemarkers, New Front Plate Position, Vag-Com Changes.
    http://mefi.us/images/fuelly/sig-us/75569.png
  11. Member Seki's Avatar
    Nov 19th, 2009
    New York
    2012 A6
    12-15-2011 05:45 PM #116
    Quote Originally Posted by Stuart Little View Post
    Thanks,
    Stu
    It speeds up the MDI respond and it eliminates the few second gap of the beginning of each song.
    2012 A6
  12. Junior Member Stuart Little's Avatar
    May 26th, 2011
    Denver, CO, USA
    12-15-2011 05:53 PM #117
    Cool, perfectly safe for all versions of the MDI (red/white?) for people on SW1140?
  13. Member Seki's Avatar
    Nov 19th, 2009
    New York
    2012 A6
    12-15-2011 05:55 PM #118
    Yes its for RNS and for RCD. No problem for me on my RNS.
    2012 A6
  14. Junior Member Stuart Little's Avatar
    May 26th, 2011
    Denver, CO, USA
    12-15-2011 05:58 PM #119
    Last question I promise I have the iPhone MDI not the USB one, can I put this on an SD Card?
  15. Member Seki's Avatar
    Nov 19th, 2009
    New York
    2012 A6
    12-15-2011 06:14 PM #120
    Nope SD will not work. You will need a USB adapter part # 000 051 446 B
    2012 A6
  16. Junior Member Stuart Little's Avatar
    May 26th, 2011
    Denver, CO, USA
    12-15-2011 06:16 PM #121
    Gotcha, thanks, now to track someone down with a USB MDI so I don't have to pay $37 for a one time use item
  17. Member Seki's Avatar
    Nov 19th, 2009
    New York
    2012 A6
    12-15-2011 10:33 PM #122
    Were are you located?
    2012 A6
  18. Junior Member Stuart Little's Avatar
    May 26th, 2011
    Denver, CO, USA
    12-16-2011 11:56 AM #123
    Denver, CO
  19. Member Seki's Avatar
    Nov 19th, 2009
    New York
    2012 A6
    12-21-2011 12:37 PM #124
    Denver, CO
    Too far from me.
    2012 A6
  20. Junior Member Stuart Little's Avatar
    May 26th, 2011
    Denver, CO, USA
    12-21-2011 02:39 PM #125
    No worries, a friend with a 2011 TDI Wagon said he put the MFD update via SD Card so I may give it a shot on a small blank card and put that folder at the root (or wherever it specifies), I'll post up if it does as many VW stereos have the SD Card I guess (I know the RNS-510 does)
  21. 12-21-2011 10:46 PM #126
    So after multiple complains to VW middle east , VW dealer in saudi Arabia finally contacted me to upgrade my firmware for free to over come the latency in the rear view camera in addition to other few glitches in the current fire mare in my CC ...
    I would like to know how to get the current firmware version in order to document and share with forum the differences between the old and the new firmware I'm about to get
  22. Member Seki's Avatar
    Nov 19th, 2009
    New York
    2012 A6
    12-23-2011 11:01 AM #127
    You can only update from USB by design, no work arounds.
    This is an update for the MDI, not the radio or the MFD, so radio version does not matter.
    Keep us posted.
    2012 A6
  23. 12-23-2011 06:12 PM #128
    I have to say, you guys are fantastic. Thanks to everybody for posting pics and steps for updating so that even an idiot like me can get through it.
    I am still unsure how to access the sub channels in HD radio though. I think I might have an older RNS (cc 2009) and maybe it wasn't possible before the update but should I be able to with the firmware upgrade.
    By the way, I am in the Boston metro area with the firmware on cd , and the VIM and the midi+cable if anyone needs to use them...
  24. 12-23-2011 06:51 PM #129
    Can I assume that the DVD in motion hack will work on the RNS-510 in my 2012 Passat TDI?
  25. 12-26-2011 06:23 AM #130
    Hi all,
    Let me have a minute of your attention and ask one question. This is my first post and I'm very impressed with the content of this forum.
    I have a RNS 510 with the following Versin Info in hidden menu:
    1T0035680D
    HW-VERSION H60
    SW-VERSION 3800
    SV SW VERSION C_EU_10.341_t2
    In my understanding, this is the latest RNS-510 firmware available, but Wen I tried to install I got the Downgrade Error saying that the version installed is newer than the one I'm installing.
    I also got this other site where show a different firmware schema 3976 that I believe is newer the one I have, but now I'm confused, there are two lines of firmware for RNS ?
    http://www.my-gti.com/3116/volkswage...3974-3976-3978
    Thanks in advance and I hope contribute with this amazing forum
    Jeferson - Brazil
  26. Member Seki's Avatar
    Nov 19th, 2009
    New York
    2012 A6
    12-26-2011 11:01 AM #131
    Yes that is correct there are two type of firmware the US and the RoW. From the info of the version that you have you should be using the one from the link that you provided. Hope this helps.
    2012 A6
  27. 12-26-2011 01:38 PM #132
    Ok, my next 2 natural question are:
    Is there any substantial different from both subset of firmware ?
    Can I move from one type of feature to another ? or this is linked with the type of hardware ?
    Thanks a lot
    Jeferson
  28. Member Seki's Avatar
    Nov 19th, 2009
    New York
    2012 A6
    01-01-2012 12:09 PM #133
    I don’t know what the different is but it is hardware linked. So you will have to use the EU version.
    2012 A6
  29. Junior Member
    Nov 23rd, 2009
    Seattle WA
    2010 MK6 GTI
    01-22-2012 03:09 PM #134
    Can someone please reupload the file onto a different website? It looks like the original website is shutdown. I should've done this long time ago
  30. Member Seki's Avatar
    Nov 19th, 2009
    New York
    2012 A6
    01-22-2012 04:11 PM #135
    I will repost it shortly.
    2012 A6
  31. Member Seki's Avatar
    Nov 19th, 2009
    New York
    2012 A6
    01-22-2012 04:56 PM #136
    File has been reposted.
    2012 A6
  32. Junior Member
    Nov 23rd, 2009
    Seattle WA
    2010 MK6 GTI
    01-22-2012 05:26 PM #137
    Awesome! Thank you so much!!
  33. Junior Member
    Nov 23rd, 2009
    Seattle WA
    2010 MK6 GTI
    01-22-2012 06:54 PM #138
    Just got done burning the iOS file on a cd. Current stuck at "software download - source activated, searching for swl image" screen... For about 10-15min, any Idea? Should I restart? Any advise would be helpful thanks
    Update: nvm, got it working again on my 4th CD. For some reason the other ones doesn't work....
  34. Member Seki's Avatar
    Nov 19th, 2009
    New York
    2012 A6
    01-23-2012 01:00 AM #139
    Quote Originally Posted by nic11 View Post
    2012 A6
  35. Junior Member
    Nov 23rd, 2009
    Seattle WA
    2010 MK6 GTI
    01-23-2012 01:20 AM #140
    Oh no...
    Finally I got to drive around and trying out the new firmware, right when I started play around with the nav.... I realize I can't enter anything into the address bar!!! And the rest of my nav system is also working funky - basically unusable!! I tried to erase all of nav memory and now I can't even enter my own home address.
    Im trying to reinstall the firmware again right now and hopefully it will fix the problem....
    Anyone else encounter this?
