Page 9 of 10 FirstFirst ... 5 6 7 8 9 10 LastLast
Results 281 to 315 of 320
Thread: Navigation firmware update for RNS-510
  1. Member jettsy's Avatar
    Mar 28th, 2011
    Orlando, FL
    2011 Jetta
    07-20-2012 02:53 PM #281
    What version rns do you have?
    SteveMKVI JettaMy Car Activate Full MFD MK6 Jetta DIY
  2. Member djanemix's Avatar
    Aug 5th, 2011
    Los Angeles/Pomona
    02 2.7T-A6/06 GTi MkV
    07-22-2012 04:12 AM #282
    Quote Originally Posted by jettsy View Post
    I believe I have the first one:
    3C0 035 684, HW:H17, SW:0210, Date: 29.08.2008
    Last successful update was SW1040. As SW1140 is where I contracted the issue. Thanks for your assistance.
    IG:@dRe4per
    06 MkV-GTi PK 2 with RNS-510 | Apr Stage II+ | Apr HPFP | EVOMS CAI | S3 IC | Forge FMIC | Forge DV | GodSpeed 3" DP | Megan Coilovers | Neuspeed F/R Sways
    Affiliations: SoCal Hooligans (Inland Empire Regiment) / EuroGoons
  3. Member jettsy's Avatar
    Mar 28th, 2011
    Orlando, FL
    2011 Jetta
    07-22-2012 08:18 AM #283
    Have you tried going to the settings and increasing brightness? Worth a shot.
    Also when you restart the unit does it stay dim?
  4. Member djanemix's Avatar
    Aug 5th, 2011
    Los Angeles/Pomona
    07-23-2012 04:55 PM #284
    After reset unit Backlighting does stay off. It's not so much being "dim" as it is the backlight not on.
    IG:@dRe4per
  5. 08-02-2012 08:39 PM #285
    First, thank you all for such great guide. I updated my RNS to 1140 and VIM.
    Second: The speed display is showing up in the top right corner BUT it seems the speed is displayed in KM, not MILES. I have my car configured to Miles (US), Temp F but still it displays the wrong Speed Limit (in KM)
    Any idea?
    Sorry to be such an @ss...
    Thank you
  6. Moderator nater's Avatar
    Apr 10th, 2000
    Downingtown, PA
    2008 Passat 4Mo 3.6L Wagon, 98 VRt, 2010 Routan/Caravan :)
    08-06-2012 02:27 PM #286
    Let's keep the talk of pirating software out of this thread please. Otherwise I'll just delete this thread (which would suck since there's some great info in it).
    Thanks,
    Sep 30th, 2009
    Guelph, ONT \ Daytona Beach, FL
    06 Jetta 2.5L 5spd (LSD+ .717 TDI 5th swap)
    08-07-2012 06:06 PM #287
    The vw CC in the family was updated from 0320 to 1140 and now we can't see any city names when we try to write them under address when entering an address for the nav. thoughts?
    C2 tune, Peloquin LSD, .717 TDI 5TH gear swap, USP test pipe, AWE exhaust (AMAZING), BSH CAI, H&R street sport coilover + 25mm RSB, neuspeed short shifter, 17x8 BBS RGR. **********FOR SALE THREAD:********** http://forums.vwvortex.com/showthrea...-%28OEM-LED%29*****http://forums.vwvortex.com/showthrea...0#post76396880
  8. Member Seki's Avatar
    Nov 19th, 2009
    New York
    2012 A6
    08-08-2012 09:39 AM #288
    Quote Originally Posted by nater View Post
    Thanks,
    Totally agree!
    2012 A6
    Need VAG-COM/VCDS PM me
  9. Member Seki's Avatar
    Nov 19th, 2009
    New York
    2012 A6
    08-08-2012 09:40 AM #289
    Quote Originally Posted by Anile_eight View Post
    You should read this tread from A to Z as some other users had the same problem. I think they all resolved it with reloading the map CD.
    2012 A6
  10. Member jettsy's Avatar
    Mar 28th, 2011
    Orlando, FL
    2011 Jetta
    08-09-2012 12:16 AM #290
    That definitely fixes it
  11. Member
    Sep 30th, 2009
    08-09-2012 08:01 AM #291
    Quote Originally Posted by Seki View Post
    That's what I ended up doing... never got back on here to respond. I stuck the old map disk in and it eventually worked haha. Thanks everyone!
  12. Member Seki's Avatar
    Nov 19th, 2009
    New York
    2012 A6
    08-09-2012 11:11 AM #292
    2012 A6
  13. 08-12-2012 10:14 AM #293
    Just a thought, but isn't it possible to complain to the dealer about issues with the Nav/Radio head unit and have them perform the firmware/software update?
    This assumes your car is still in warranty and the dealer is able to charge VW for the labor through a warranty claim.
    The only reason I ask is that BMW does this for me when I go with in with my car (there are always updates available for the radio, nav, engine control module, transmission, etc) and they put them on without even having to ask since it's covered under warranty
    Thank you
  14. Member jettsy's Avatar
    Mar 28th, 2011
    Orlando, FL
    2011 Jetta
    08-12-2012 12:28 PM #294
    This update was not officially released for vw techs.
  15. 08-13-2012 08:49 AM #295
    Oh, I did not know that, thank you for the heads up.
    So that means this update is from Continental directly then?
  16. 08-14-2012 03:28 PM #296
    Excuse my ignorance, when burning the VIM iso file onto disk, should the actual .iso file be burned, or the expanded content of the .iso file?
  17. Member
    Sep 30th, 2009
    08-14-2012 09:46 PM #297
    Quote Originally Posted by donsmith View Post
    you will or should get 1 of two options an .iso file directly downloaded or a .rar file which you can use winrar to unpack and you will get an .iso file. then burn that to a disk... I use power iso
  18. Junior Member Cpartipilo's Avatar
    Jul 19th, 2012
    Miami - South Florida
    2010 CC Sport 2.0t
    08-20-2012 11:19 AM #298
    Just a warning..
    I tried to do this and left it in the car running, when i came back it had failed with an SWL error. i figured i'd run it again and got all the bars to 100% and then i guess i pulled the disc too early or somthing like that.
    Really i don't know what i did but i know i bricked my unit, all i get is a blank white screen that reboots every few minutes.
    Make sure you read the whole thread and make a print out of your instructions and how to proceed if the update fails.
    If any of you reading this can help me get my unit working again i'd appreciate it.
  19. Member Seki's Avatar
    Nov 19th, 2009
    New York
    2012 A6
    08-20-2012 12:28 PM #299
    Quote Originally Posted by Cpartipilo View Post
    Just a warning..
    Yeah pulling the disk early will do that. You can find the recovery CD on VWNAVI.COM
    Good luck.
    2012 A6
  20. Junior Member Cpartipilo's Avatar
    Jul 19th, 2012
    2010 CC Sport 2.0t
    08-21-2012 01:32 AM #300
    Good luck.
    Thanks Seiki.
    I have the recovery CD but my unit is dead. i can't get the FW disc out and even if i dissasembled it and remove it manually i don't know that i could make it look at the recovery disc.
    I have tried all combinations of buttons unsucessfully, if you have suggestions let me know.
  21. Member jettsy's Avatar
    Mar 28th, 2011
    Orlando, FL
    2011 Jetta
    08-21-2012 06:28 AM #301
    Does your unit power up at all?
  22. Junior Member Cpartipilo's Avatar
    Jul 19th, 2012
    2010 CC Sport 2.0t
    08-21-2012 11:16 AM #302
    Yes, powers up to a completely white screen. Stays white for about a minute or 2 and the unit reboots back to the same white screen, wait, reboot, etc.
  23. 08-22-2012 10:31 AM #303
    Sounds like your MPEG calibration is off. Need SetConfig or MRM to fix this.
    DashMaster
  24. Junior Member Cpartipilo's Avatar
    Jul 19th, 2012
    2010 CC Sport 2.0t
    08-22-2012 03:43 PM #304
    Quote Originally Posted by Dashmaster View Post
    Exactly, i'm trying to find someone with MRM to help me fix this. i was not aware SetConfig though.
    I already contacted motordiag to see if it's worth getting the tool.
  25. Member Seki's Avatar
    Nov 19th, 2009
    New York
    2012 A6
    08-27-2012 11:24 AM #305
    Just added to the first post a MDI update for cars up to 21/2012. Download and install instructions remain the same.
    Enjoy
    2012 A6
  26. Member
    May 16th, 2012
    2010 VW CC VR6 4Motion Executive
    08-27-2012 09:41 PM #306
    what's the benefit of updating the MDI? I don't have any of the cables or the usb cable to update it. Wondering if it's worth my time to update it? I updated the NAV firmware and all that jazz before... just not the MDI.
  27. Member Seki's Avatar
    Nov 19th, 2009
    New York
    2012 A6
    08-28-2012 10:44 AM #307
    No sure as I did not have on what to test it out yet but it should be able to display cover art from the track on the RNS. And if not it’s always good to be up to date with electronics!
    2012 A6
  28. n00b
    Sep 23rd, 2012
    San Diego
    10-11-2012 04:55 PM #308
    Hi All,
    Does the VIM file work on the 2013 RNS-510?
    Thanks
  29. Junior Member Stuart Little's Avatar
    May 26th, 2011
    Denver, CO, USA
    2010 Jetta TDI Cup Edition - 6 Speed Manual
    10-11-2012 05:30 PM #309
    Quote Originally Posted by usaf-lt-g View Post
    I'm also curious as I don't have the USB connection, just the SD card slot or CD/DVD, but someone mentioned (didn't go back and read the posts otherwise I bet the answer is already there) that USB key is the only way.
    Anyone in Denver have one? I'd hate to buy one just for the single purpose.
    2010 TDI Cup Edition 6MT - Laser Blue (RNS-510 SatNav/DVD, Sunroof, ThunderBunny Bodykit, MDI)
    Tweaks: Bi-Xenon Projectors, Clear Sidemarkers, New Front Plate Position, Vag-Com Changes.
    http://mefi.us/images/fuelly/sig-us/75569.png
  30. Banned BarryT82's Avatar
    Nov 12th, 2005
    Charleston, WV
    '12 F-150 FX4 Super Crew, '11 JSW TDI
    10-11-2012 08:19 PM #310
    Quote Originally Posted by AUTO_CLEARANCE View Post
    Hi All,
    Thanks
    I just ran it on mine and it worked fine.
  31. Junior Member
    Sep 15th, 2012
    burnaby regina vancouver
    2010 CC
    10-13-2012 01:17 AM #311
    I just updated it, everything went good, thx again for the instructions but i just have a couple questions
    first the OPS isnt on... i had a little car show up on the left side of the screen but its now gone, any way to make it come back on?
    and also when i used to turn my lights on or auto at night the maps background used to go black and lights off or auto in daytime it was white, now its always white, any reason y that would be?
  32. 10-16-2012 05:41 AM #312
    I have a 2009 VW Touareg with RNS system, it has been exported from UK to New Zealand, is it possible to just insert a NZ RNS map disc ( which I have) and it will update to NZ maps, or do I need to do something with firmware first?
  33. 01-09-2013 02:50 PM #313
    I just found this thread a few weeks ago and updated my 2010 TDI to this version. All seems to work well except if I go into navigation and Start a Route, the backup camera no longer works. After stopping the car for a few minutes and restarting camera works - until Nav is used again. Anyone else having this issue?
    I am also running the video in motion patch too.
    Glad that it worked for you and thanks for the pictures.
    Do you mind if I post them to the first post? That way we have them all in one spot?
  34. 01-23-2013 09:43 PM #314
    I have a 000 051 446 B cable I'd be willing to trade to someone with a 000 051 446 C...pm me if interested
  35. Member
    Feb 8th, 2000
    Harpers Ferry, WV
    1973 Porsche 911T, 1993 VW Corrado VR6, 2010 VW Jetta TDI Cup
    01-25-2013 11:12 PM #315
    Quote Originally Posted by djanemix View Post
    Was this resolved? I have the same first-gen RNS-510 (built almost exactly 1 month later) and have already burned the ISO file to a disc. I am a little hesitant to upgrade now if there are unresolved issues... that and I don't have the V5 map disc that was loaded to this RNS prior to my purchasing the unit.
    I have been reading every thread I can find on the RNS-510 to try and figure this out.
