Page 1 of 4 1 2 3 4 LastLast
Results 1 to 35 of 118
Thread: - EXTENDED - **Introducing Solo-Werks Coilovers for MK2, MK3, MK4 @ AMI - $499 Shipped**
  1. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    11-09-2011 08:42 PM #1
    AMI is proud to introduce Solo-Werks Coilovers to the market!
    Designed by a joint engineering staff from Germany and the USA, the S1 coilover is built for the enthusiast that is looking for an ideal balance of ride quality and performance.
    MK2/3 PLATFORM
    In the front the S1 coilover for the MK2, MK3 VW/Audi Group platform features 400 lb/inch
    spring rate matched to a twin tube low pressure gas damper mounted in a
    heavy gold zinc plated threaded coilover housing that provides not only
    great handling, but also exceptional corrosion resistance.
    The rear features a 285 lb/inch coil spring & helper spring matched with a
    specially tuned sport damper mounted inside the rear version of the
    high quality heavy gold zinc plated threaded coilover housing.
    Features at A Glance
    - Front & Rear 45-85mm (1.8-3.4") Lowering Range
    - Heavy Gold Zinc Plated Housings
    - 400lbs Front Spring Rate (VR6 rating)
    - 285lbs Rear Spring Rate
    - Slotted Front Spindle Mount for camber adjustment
    - Silver spring perches - double lock ring design
    - Platform Specific Spring Rates and Matched Valving
    - 3 year Limited Warranty
    Fitments:
    All 2wd MK2 /MK3
    aka A2/A3 platform & Corrado
    All Motors inc:
    1.3- 2.0 4cyl, VR6, TDI
    Intro Sale Price: $499.00 Shipped (within lower 48 states)
    CLICK HERE TO ORDER MK2/MK3/CORRADO/PASSAT S1 COILOVER
    MK4 2WD PLATFORM
    In the front the S1 coilover for the MK4 VW/Audi Group platform features 400 lb/inch spring
    rate matched to a twin tube low pressure gas damper mounted in a heavy gold zinc plated
    threaded coilover housing that provides not only great handling, but also exceptional
    The rear features a progressive coil spring and adjustable threaded
    perch system with a specially tuned sport damper that is
    matched to the lowering range of the coil/perch combination.
    - Front & Rear 35-55mm (1.4-2.2") Lowering Range
    Fitments:
    All 2wd MK IV, aka PQ34 platform
    All Motors inc:
    2.0, 2.5, 1.8T, VR6, TDI
    CLICK HERE TO ORDER MK4 SOLO WERKS S1
    Don't hesitate to ask us any questions!
    AMI - extremely euro
    sales@amimotorsports.com
    Toll Free 1 (888) 362-3117
    www.amimotorsports.com
    Contact us for a personalized quote!
  2. Member first9t!'s Avatar
    Jul 13th, 2009
    South Hill, washington
    02 GTI 85 Slammed Volva
    11-10-2011 04:35 AM #2
    any pictures of these installed on a mk2 and a mk4? both all the way down?
    Quote Originally Posted by Capt. Obvious View Post
    Do you not f*ck your girlfriend because you want her to be in better condition for her next boyfriend?
  3. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    11-10-2011 03:51 PM #3
    We did an install on the MK4 kit a month or so ago and worked with their engineers to find out what the max lowering that could be achieved and still be within a safe range for shock operation and it was fairly aggressive. Click here for more info
    We have a MK2 & MK3 lined up for next week and will be posting the same info for your reading enjoyment.
    Stay tuned!
    Glen @ AMI
  4. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    11-10-2011 03:52 PM #4
    Here are some additional pics from the small photo shoot we did after the suspension was installed
    The Golf above is not at full lowering for the kit, it has been raised up to suit the owner and the car.
    On our test Golf, the Front measurement is set at 12.5" front, and 12.5" rear using the measurement style of the center of wheel to fender.
    The Fender to ground on this vehicle in its current setup is 24 1/4" Front and 24 1/8" rear. At this setting, the vehicle is visually level to the naked eye.
    At this level the passenger side drive shaft WILL RUB on the OEM Sway bar setup under hard left turns or large bumps, but is fine under normal driving conditions.
    The owner has removed the front inner fender wells previous to the installation.
    A 5mm spacer was used with this wheel/tire combination to clear the coilovers.
    Let us know if you have any additional questions!
    Glen @ AMI
  5. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    11-10-2011 03:57 PM #5
    After working with the engineers, and getting the max lowering sorted out here is what we have.
    The measurements below are taken between the center of the wheel and the fender as in the diagram below:
    • The max lowering shown in the tables above is achieved at the lowest position of the threaded adjustment on both front and rear axles.
    • Helper Springs have been retained and should not be removed! See notes below on the Helper Springs.
    • These measurements allow for the shock absorbers both front and rear to have the minimum amount of travel required by the engineers to do their job before full bump stop engagement.
    • You must trim 50% off of the included Front bump stops to achieve this lowering & travel range.
    • Removal of the OEM sway bar is necessary to achieve the max lowering due to contact issues with the drive shaft. Aftermarket units are available that will clear this issue.
    • Depending on your wheel and tire combination, you may need spacers to clear the coilover perch/springs. SOLO WERKS recommends at least 5mm clearance in this case.
    • At the lowest level, you may need to modify one or more of your body panels to allow for sufficient travel of the wheel inside the fenders. Please ensure that you have clearance from all obstacles through the complete travel of the wheels.
    NOTES:
    • The Helper springs are there to keep tension on the main spring during full extension of the shock absorber.
    • The main spring is not long enough on its own to keep the shock at full extension.
    • Removal of the helpers will result in the main spring being able to travel away from its upper and lower spring perches, and will result in damage to your suspension as well as other components.
    • DO NOT REMOVE THEM!!!
  6. Member Der Roboter's Avatar
    Mar 9th, 2010
    Portland, Or.
    '88 GTI 12v + '85 GTI 8v + '01 R6
    11-10-2011 04:57 PM #6
    Beside the two coil perched locking together, is there anything stopping the perched from turning down past the last thread? There appears to be a couple inch gap between the last thread and the next thing to catch the perch, in the event that it winds itself down.
    A giant success in mediocrity! - Bonneville 130mph club - PIR perfect(0.00) light club.
    My 1988 S/C VR6 GTI
    Quote Originally Posted by Noisyninja View Post
    Exactly. That's a problem for future people. Why should I change my life for a bunch of jerks who aren't even born yet? Besides, they'll probably just wear funny clothes and listen to music I don't like.
  7. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    11-10-2011 05:10 PM #7
    Quote Originally Posted by Der Roboter View Post
    Hello Der Roboter, thanks for the question.
    If you were to unlock the perches, you could spin past the last thread.
    With the two perches locked against each other, it is almost impossible to get them apart with out quite a bit of force from two separate spanner wrenches, well past the force that anything the vehicle can put on them.
    Thanks
    Glen @ AMI
  8. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    11-10-2011 06:22 PM #8
    Thanks to everyone who emailed, PM'd and called in today!!!!
    All inquiries have been responded to, and all orders have been processed and are shipping this afternoon.
    If you are interested the order can be placed one of three ways:
    1. Log on to our website CLICK HERE to purchase online
    2. Send us your email address and we can send you an E-invoice that you can pay via PayPal, Visa, MC, Amex or Discover
    3. Give us a call directly at 1-888-362-3117 x 101 and we can process your order over the phone ( Visa, MC, Amex or Discover)
    We look forward to hearing from you!
    Glen @ AMI
  9. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    11-11-2011 08:03 PM #9
    TGIF
    Thanks to everyone who has sent in questions and of course orders!!!!
    All orders received before 3:00 PM pacific time have been processed and are on their way to their new owners.
    Check your inbox for tracking info
    Thanks!
    Glen @ AMI
  10. Member
    Jan 14th, 2004
    Vancouver, WA
    02 GLI
    11-12-2011 01:07 AM #10
    Looking good Glen!!!
    You can sleep in a car, but you can't track a house!
  11. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    11-14-2011 01:09 PM #11
    Quote Originally Posted by Canadian Hybrid View Post
    Thanks buddy!
    Glen @ AMI
  12. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    11-14-2011 08:20 PM #12
    Hello Everyone,
    Now that there are a number of Solo Werks S1 Coilover sets out there and installed, we need your feedback!
    AMI & Solo Werks are looking for current Solo Werks S1 Coilover owners to post their reviews online - Vortex and any other forums - the more detailed the post the better
    Post up your reviews in new threads in the forums and send Solo Werks an email (info@solo-werks.com) with the thread link, as well as your contact info and you will be sent a limited run Solo Werks T-shirt!*
    Sizes Large to 3XL are available!
    Thanks!
    Glen @ AMI
    *Solo Werks will contact you with full details that you will need to provide, and verification of purchase/ownership will be required.
  13. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    11-15-2011 06:47 PM #13
    TUESDAY UPDATE
    All orders received before 3:00PM today Pacific time have been processed and are on the dock ready for UPS & FedEx to pick up!
    All questions in all forms (PM, Email & VM) have been responded to.
    Don't forget, we also have Front Upper Mounts and Bearing sets available at a discounted price with no additional shipping when purchased with a Solo Werks Coilover kit!
    Thanks,
    Glen @ AMI
  14. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    11-16-2011 06:54 PM #14
    SHIPPING INSANITY!!!!
    Crazy day today, not only are the SOLO WERKS S1's flying off the shelf, but our FK airfreight order has arrived... Our shipping department is just flying!!!!!
    All orders received today before 3:30 PM Pacific Time are on the dock ready for UPS to pickup.
    Thanks again to everyone who has ordered!
    Don't forget to get your Solo Werks Reviews in to get your free Solo Werks T-shirt!
    Glen @ AMI
  15. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    11-18-2011 06:58 PM #15
    All PM's, emails and calls have been answered/returned!
    Thanks again to everyone who has ordered, any orders that were received before 3:00 PM PST today are on today's UPS
    Let us know if you have any questions!
    Glen @ AMI
  16. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    01-31-2012 04:47 PM #16
    The Solo Werks $499 sale is back on!
    We are fully stocked on MK2, MK3, MK4, MK5 and MK6 Solo Werks S1 Coilovers and shipping daily!!!!
    If you would like to get your new Solo Werks S1 coilover on its way, your order can be placed one of three ways:
    1. Log on to our website or click the appropriate links above
    Let me know!
    Glen @ AMI
  17. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-01-2012 06:32 PM #17
    Thanks to everyone for their questions & orders!
    Our shipping department is busy getting your kits shipped this afternoon for everyone who has ordered as of 3:00PM pacific time today, watch your email for tracking
    Glen @ AMI
  18. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-04-2012 08:25 PM #18
    Thanks to everyone who ordered last week!!!!
    All orders that were received before 3 PM pacific time on Friday have been shipped, and your tracking information should be in your inbox (check your junk folder just in case!)
    All Questions have also been responded to that have been received as of Saturday evening.
    Thanks!
    Glen @ AMI
  19. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-06-2012 07:04 PM #19
    Thanks again to everyone who ordered over the weekend!
    All kits are on their way that were ordered before 2:30 PM today
    For those who have ordered, do not forget to post your reviews online on Vortex or other forums and email your ship to info & Shirt Size into Solo Werks (info@solo-werks.com) along with the link to the thread and they will get a Solo Werks coilover shirt sent out!
    Glen @ AMI
  20. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-07-2012 07:19 PM #20
    Our shipping department is really busy trying to get out all the orders today!
    They get a bit carried away, but they are pretty sure they can get everyone's order that was placed in the last 24 hours out today!
    Orders shipping out today will have tracking emailed to them via our automated system + UPS/FedEx
    Keep the questions coming!
    Glen @ AMI
  21. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-08-2012 06:55 PM #21
    Another great day!
    As always, all orders received before 3:00 PM pacific time are in process and will be shipping today and tracking information will follow - watch your email boxes for the info (and check your Junk folder just in case)
    Thanks!
    Glen @ AMI
  22. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-09-2012 07:15 PM #22
    Thursday Bump!
    Keep the questions and orders coming!!!
    Thanks
    Glen @ AMI
  23. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-10-2012 08:12 PM #23
    TGIF!!!!
    All orders that were received before 3PM today are on their way via UPS / FedEx
    We will be in and out of the office this weekend, so don't hesitate to send us a PM or email!
    Have a great weekend!
    Glen @ AMI
  24. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-11-2012 06:33 PM #24
    Saturday Update.
    All PM's and emails have been responded to and all orders processed in the warehouse.
    Thanks!
    Glen @ AMI
  25. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-13-2012 06:50 PM #25
    Thanks to everyone who Ordered, PM'd or sent in Emails over the weekend
    All orders placed by 3:00PM today are on the shipping doc ready for pickup by UPS for domestic or FedEx for International - tracking numbers to follow in your inbox later tonight
    Thanks again,
    Glen @ AMI
  26. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-14-2012 06:32 PM #26
    Tuesday Bump!
    All orders from the last 24 hours are on the shipping dock waiting for UPS/FedEx pickup
    Thanks again for all the questions and orders!
    Glen @ AMI
  27. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-16-2012 07:45 PM #27
    Almost the end of another great week!
    As always, orders placed in the last 24 hours are on the dock and ready for UPS/Fedex to pickup and get on their way to their new owners - with tracking numbers automatically going to your inbox!
    Let us know if you have any questions, and don't forget to post your reviews on Vortex and send in the link to the review and your info inc shirt size to info@solo-werks.com for your free shirt!
    Just as a reminder, Solo Werks S1 Coilovers are in stock and shipping for:
    MK2 + MK3's 2wd
    (Golf, Jetta, Passat B3...)
    MK4 2wd (Golf, Jetta, Beetle...)
    MK5 + MK6 (Golf, Rabbit, Jetta, Passat, Eos, CC, R32 ...)
    All for $499 shipped within the lower 48!
    Thanks
    Glen @ AMI
  28. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-17-2012 06:33 PM #28
    Welcome to the Weekend!
    Thanks again to everyone that has ordered and sent in questions on these kits
    Our shipping department has all orders that have been received over the last 24 hours on the dock ready for UPS/FedEx pickup.
    Glen @ AMI
  29. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-20-2012 05:31 PM #29
    Happy Presidents Day for our US Customers & Family Day for many of our Canadian Customers!
    We hope everyone has had a great weekend
    Thanks to everyone who placed their orders over the weekend, our shipping staff is working to get everyone's order on their way today.
    As always, your tracking information will be sent to your inbox from our system as well as UPS/FedEx.
    Please let us know if you have any questions.
    Don't Forget to post pics of your car when you get the kits installed!
    Thanks,
    Glen @ AMI
  30. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-21-2012 06:30 PM #30
    Another Great Day!
    As usual our staff is busy getting all of the orders out
    Tracking numbers are following shortly after pickup by UPS / FedEx
    Keep the questions / PM's / emails coming!
    For those of you interested in more Stormtroopers Check out the artist's page Stormtroopers 365 for a years worth of Stormtrooper goodness
    Thanks,
    Glen @ AMI
  31. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-22-2012 08:12 PM #31
    Happy Hump Day!
    All PM's and Emails have been responded to, and all orders processed and shipping as we speak.
    Thanks again!
    Glen @ AMI
  32. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-23-2012 07:23 PM #32
    Thursday Bump!!! - Another Crazy day in the AMI Shipping Department
    For everyone who sent in a question or ordered today, all questions have been answered and our shipping department has all orders that were in before 2:00 PM today are on the dock ready for pickup by UPS/FedEx.
    Thanks,
    Glen @ AMI
  33. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-27-2012 09:02 PM #33
    Thanks again for a great weekend!
    All PM's and Email questions and quotes have been responded to.
    All orders placed from Friday until today before 3:00PM have been shipped and your tracking numbers should be in your inbox!
    Glen @ AMI
  34. 02-28-2012 04:34 AM #34
    do you have any pictures of a mk3 jetta lowered and how do you compare to raceland
  35. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-28-2012 02:20 PM #35
    Quote Originally Posted by piltz View Post
    Unfortunately we do not have any images on a MK3 yet, still waiting for the customers out there to post up!
    As for a comparison to Raceland, here are the main advantages of Solo Werks vs Raceland:
    • Heavy Gold Zinc Plated bodies for drastically improved corrosion resistance vs standard Silver Zinc (as on the Racelands)
    • 3 Year Warranty to original purchaser (vs 2 on Raceland)
    Thanks
    Glen @ AMI
Tags for this Thread
