VWVortex.com - How to make my 1.6d role some coal??
    Results 1 to 13 of 13
    Thread: How to make my 1.6d role some coal??
    1. Member Two . Slow's Avatar
      Aug 4th, 2009
      wrightsville, PA
      82 caddy turbo diesel
      11-11-2011 08:56 AM #1
      Pretty simple question...any thing I can do to make this thing role some coal when it's being lugged down?
      Thanks
      Quote Originally Posted by McSlo2.0 View Post
      Oh that and the fact that more rice has been showing up here lately than in the stir fry I just cooked for dinner
    2. Member Rockerchick's Avatar
      May 10th, 2005
      Cary, NC
      '03 BMP 20th GTI, '84 TD Jetta
      11-11-2011 09:08 AM #2
      Fuel screw, and I think you can tinker with some stuff on the IP. Just remember that black smoke = wasted fuel and lower MPGs.
      There is some info over in the diesel technical section I'm sure. I know I see this question asked about once a month or so.
      Quote Originally Posted by TM87 View Post
      VW-making mechanics out of owners since 1957.
      The project - '84 Jetta 1.6TD
      The Wheelbarrow - '82 Rabbit Pickup
      Hers - '03 BMP 20thAE GTI
      His - '16 GLI SE
    3. Junior Member
      Dec 2nd, 2009
      Edmonton, Alberta
      81 Pickup LX 1.6TD, 81 Rabbit LS 1.6TD
      11-11-2011 09:53 AM #3
    4. Member Two . Slow's Avatar
      Aug 4th, 2009
      wrightsville, PA
      11-11-2011 09:57 AM #4
      ok thanks, ill check it out...maybe ill keep it as is bc its clear exhaust for the most part so that tells me from what i read my egts are good and id rather not melt down a perfectly fine engine
    5. Member Rockerchick's Avatar
      May 10th, 2005
      Cary, NC
      11-11-2011 10:05 AM #5
      Sounds like you don't have an EGT gauge. Get that hooked up if you are concerned about them at all. Worth it to have one.
      His - '16 GLI SE
    6. Member Two . Slow's Avatar
      Aug 4th, 2009
      wrightsville, PA
      11-11-2011 12:44 PM #6
      No I don't and I'm not I'm just gonna keep it as is
    7. Member Rockerchick's Avatar
      May 10th, 2005
      Cary, NC
      11-11-2011 07:04 PM #7
      Is your car completely stock? An EGT gauge isn't that expensive and a worthwhile thing to have.
      His - '16 GLI SE
    8. Member Two . Slow's Avatar
      Aug 4th, 2009
      wrightsville, PA
      11-11-2011 10:35 PM #8
      Yep bone stock
    9. Member 8v-of-fury's Avatar
      Jul 14th, 2008
      Almost the Arctic, Alberta, Canada
      Because MK1
      11-12-2011 12:04 AM #9
      Clear exhaust does not mean low EGT.
      I have a friend who on a good pull, with absolutely ZERO exhaust smoke, managed to top 1300F without a problem..
      If you plan to tinker, you need an EGT gauge. You run the risk of going KA-BOOM if you get it too hot.
    10. Member Two . Slow's Avatar
      Aug 4th, 2009
      wrightsville, PA
      11-12-2011 09:36 AM #10
      Quote Originally Posted by 8v-of-fury View Post
      I understand that but with no mods and it staying stock in not gonna bother seeing as irk what motor may go in it this winter
    11. Member 8v-of-fury's Avatar
      Jul 14th, 2008
      Because MK1
      11-12-2011 10:09 AM #11
      Quote Originally Posted by Two . Slow View Post
      Touché lol. If your gonna scrap it this winter.. Turn it up and roll as much coal as you want!
      A quick and easy flex-pipe side-pipe and an open element/no filter will make the engine breathe much better. It will also make the coal fire a hell of alot better .
      Apr 22nd, 2002
      NJ 08002
      2 clunkers & 2 nicer clunkers
      11-12-2011 10:15 AM #12
      Is this a TD? If na, I don't really think you'll ever see crazy high EGTs.
      Anyhow, remove your throttle linkage, rotate 1 or 2 splines CCW, then turn the fuel screw in until the power seems back to normal. You'll need to play with the idle screw to level things out, but it'll roll coal. You may notice the idle hanging a bit, but that's one of the side effects. You may as well shim the governor while you're at it.
      I did this a while ago, but reversed it so the smoke went away. It got old quickly.
      -Todd
    13. Member Two . Slow's Avatar
      Aug 4th, 2009
      wrightsville, PA
      11-12-2011 10:29 AM #13
      It's na. Either tdi swap or abaT not sure yet. Aba would be much easier and more along the lines o
      f what I want
