Results 1 to 22 of 22
Thread: FS: New Techtonics big valve head, 266 cam & adj. cam gear
  1. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    11-12-2011 12:11 PM #1
    SOLD
    This was a package set up that was bought for a 2.0 8v motor build that never came to fruition. This set on an Audi 3a 2.0 bubble block will give you 16v power. I'm not interested in splitting this up. The head is currently setup for CIS injectors but the seats can easily be swapped out, they are merely threaded in, for Digi injector seats.
    This will include all the necessary install hardware new OEM bolts and gaskets.
    $650 shipped (lower 48)
    266 Techtonics cam PN 109 078. Polished Techtonics Adj. cam gear PN 109 060
    NEW Cylinder Head PN 109 029 8V GTI/GLI. Complete and ready for install. 40mm intake x 33mm exhaust valves with standard cam. Direct replacement for '85-'87 8V GTI/GLI/Audi 4000S. Upgrade from 38mm intake to 40mm for standard '85-'87 Golf/Jetta with GX engine and '87-'90 Fox. Will upgrade(replace) solid lifter 1.8L heads with CIS to hydraulic lifter for no valve adjustments and a quieter engine. This was mocked up on a 2.0 block on the stand. And comes w/ Bosch Platinum +3 plugs.
  2. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    11-13-2011 08:03 AM #2
    UP PM's replied
  3. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    11-13-2011 10:33 PM #3
    All PM's replied and a few have pay-pal info. in hand
  4. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    11-15-2011 08:27 AM #4
    Up PM's replied
  5. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    11-16-2011 08:46 AM #5
    All PM's replied
  6. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    11-18-2011 08:58 AM #6
    UP UP UP PM's Replied
  7. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    11-19-2011 08:23 AM #7
    Saturday bump
  8. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    11-21-2011 06:03 PM #8
    Up all PM's replied busy day on the tex
  9. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    11-22-2011 09:50 PM #9
  10. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    11-25-2011 07:45 AM #10
    http://www.ebay.com/itm/250936906655...84.m1555.l2649
    3 Days left 8 watchers looks like it's gonna be a sniper war
  11. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    11-26-2011 11:31 AM #11
    Bump it UP watching finally qualifying for the 2011 F1 season whats it's been a crazy season
  12. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    11-28-2011 07:35 AM #12
  13. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    04-10-2012 10:17 AM #13
    Up
  14. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    04-13-2012 12:41 PM #14
  15. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    04-15-2012 06:40 PM #15
    Up
  16. Member teknikALLEN's Avatar
    Jul 14th, 2010
    Ithaca, NY 14850
    1985 VW Cabriolet Wolfsberg Ed, Titan Red; 1993 Cabriolet Classic Ed. Classic Green
    04-16-2012 02:07 PM #16
    Pardon me, but is the cam the European GTi or US GTi ?
  17. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    04-16-2012 03:20 PM #17
    Neither this cam was made by Techtonics to there own proprietary specs.
    http://techtonicstuning.com/main/ind...products_id=28
  18. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    04-17-2012 07:16 AM #18
  19. Member
    Dec 14th, 2008
    1983 GTI
    04-17-2012 08:57 PM #19
    Quote Originally Posted by vwtechr32 View Post
    will this head keep the same CR ? (8.5 )
    can a thin head gasket get used for higher CR (w/o cutting the head or block) ?
  20. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    04-17-2012 09:55 PM #20
    Yes
  21. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    04-25-2012 10:26 PM #21
    Bump
  22. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    04-27-2012 05:44 PM #22
    UPDATE
    This will now include all the necessary install hardware new OEM bolts and gaskets.
