UP PM's replied![]()
SOLD
This was a package set up that was bought for a 2.0 8v motor build that never came to fruition. This set on an Audi 3a 2.0 bubble block will give you 16v power. I'm not interested in splitting this up. The head is currently setup for CIS injectors but the seats can easily be swapped out, they are merely threaded in, for Digi injector seats.
This will include all the necessary install hardware new OEM bolts and gaskets.
$650 shipped (lower 48)
266 Techtonics cam PN 109 078. Polished Techtonics Adj. cam gear PN 109 060
NEW Cylinder Head PN 109 029 8V GTI/GLI. Complete and ready for install. 40mm intake x 33mm exhaust valves with standard cam. Direct replacement for '85-'87 8V GTI/GLI/Audi 4000S. Upgrade from 38mm intake to 40mm for standard '85-'87 Golf/Jetta with GX engine and '87-'90 Fox. Will upgrade(replace) solid lifter 1.8L heads with CIS to hydraulic lifter for no valve adjustments and a quieter engine. This was mocked up on a 2.0 block on the stand. And comes w/ Bosch Platinum +3 plugs.
Get it here cheaper
http://www.ebay.com/itm/250936906655...84.m1555.l2649
3 Days left 8 watchers looks like it's gonna be a sniper war
#11
Bump it UP watching finally qualifying for the 2011 F1 season whats it's been a crazy season![]()
#12
Under 4 hrs to go
#17
Neither this cam was made by Techtonics to there own proprietary specs.
http://techtonicstuning.com/main/ind...products_id=28
#19
#22
UPDATE
This will now include all the necessary install hardware new OEM bolts and gaskets.
