#142
HGP-T 450PS, Unibrace, 225/40/18 AD08s, OZ Ultraleggera, Light BBK F&R, Recaro Interior, .:R extras, MFD Navi, Phatbox, JCaps, Neuspeed, PSS9s, H2Sport Stage 3, DLI-Teknik, GC links, bHPP, etc...
#143
You talking about adjustable camber plates? That's gonna be METAL on METAL right?
*R32 1518*, biggest head ever to fit in a GOLF!
Congrats, turd burglar.
#144
Right. And you are talking about drag, road, auto x, and track racing.
I daily mine. Its really not such a big deal like people like to make out.
So, its hardly something to worry about. The benefits far outweigh the disadvantages for anyone with performance interests.
#145
you want me to run something like this?
who makes the best?
#146
Just get the UM. Camber plates r a bit harsh for a daily or often driven car
04' RS .:R32
#147
Do you speak from personal experience? I have close on 70,000km on my camber plates, so, respectfully, i think you are wrong. And, the whole point is that whilst there is nothing wrong with UM ones as a replacement for oem at a reasonable price, for cajun im suggesting some adjustability.
The simple choice is either H2Sport which adjust camber and castor together.
Or, at more money, GroundControl which adjust camber & castor independantly.
Both are well proven solutions here on the tex over many years.![]()
#148
I ran ground controls on my mk4 gli 1.8T and the vibration was too much for me. UM seems to be best solution without really have no give at all. But do what u think that's my experience.
04' RS .:R32
#149
jmh2002
Um, your point would be apples and oranges, if the roads you daily are worse than ours.![]()
#150
Our roads here in PA are so so bad camber plates daily would not work tried on my mk4 gti many years ago for a week just wasnt happening.
And i am a fan of harsh car mods lol . Solid motor mounts awesome, straight pipe exhaust daily on the turbo R i love it.
-JAMES-
Daily Drive /Beaten/Built /UM Turbo R - VR NATION
#151
Vibration? Plainly something was wrong if you had vibration.
UM might be a good solution if you are looking for something non adjustable. My post was to cajun, that something adjustable could benefit the way he uses his car.
Oh, not you again... Another one to miss the point altogether.![]()
#152
#153
Anyway I'm a happy UM user that's all I'm saying.![]()
04' RS .:R32
#154
Gents.
There really is no need for any arguing or "aggressive discussion" or finger pointing here. Please lets keep this thread for discussion/feedback of our mounts
We came up with these mounts as a direct OE replacement for a reasonable price. They are aimed at the majority market that DO NOT require any kind of adjust-ability. Our specification was to cure the collapsing issue that ALL OE mounts(VW AUDI SEAT or SKODA, or indeed any mount that is an OE mount passed off as someone elses') suffer when harsher/stiffer suspension is fitted. These mounts also offer a more direct and responsive feel to the steering, they will also reduce tyre/tire wear.
All anyone has to do is email me, my email is in my signature: Matt@unitedmotorsport.co.uk
The ONLY remaining set of the latest batch is Jeff's personal set which he is willing to give up for sale. The next batch will hopefully be ready for sale in ~10 days
No need to go anywhere, your opinion is valid here, as you actually have a set of our mounts.
How would you describe any extra noise or vibration compared to stock mounts on your roads?
Software Developer / Calibrator @ UNITED Motorsport
UK http://unitedmotorsport.co.uk 0844 357 6174
USA http://unitedmotorsport.net (203) 889 0008
E: Matt@unitedmotorsport.co.uk
Follow us on facebook
#156
Glad they have a channel for you guys. Mine seem to be doing there job time will b a better judge but I'm happy to not have to worry about mounts breaking down and I still have no extra vibration!
04' RS .:R32
#157
listen, I need info on everything we have discussed. The roads here are not TOO bad but I plan on living in Louisiana by next year. Could be a problem. I'll still consider them, especially for the right price.
I've considered these UM mounts and I'm very interested.
I've considered the OEM mounts if it's an easy job to replace each year and I do it myself. Easy install might warrant me buying OEM again.
I've also considered the Polo Strut bushing and bearings, looks like you can lower the car a little more with the Polo bushings. I probably won't go with these cause going ANY LOWER could cause me problems. Problems with the alignment, problems with the oil pan and problems with the handling.
I'm gonna order something by monday. I think either UM or OEM strut bushings. Thanks for the input, thanks for the advice. The camber plates are NOT out of the question either.
THANKS all !![]()
#158
To be clear, my original post was meant to be short (it was 1 line only) and aimed directly at cajun (he was quoted).
It was not a post against the UM mounts, which I appear to be a valid solution if you dont require any adjustability.
#159
#160
#161
let me explain a little more
my alignment is set at the following:
Front Camber -1.2
Rear Camber -1.5/-1.6
Front Toe 1/16 Toe Out
Rear Toe 1/32 Toe In
I can achieve -1.4 up front if needed and I can get stupid in the rear thanks to GruvenParts. As long as I can achieve -1 in the front I'll probably be happy. The PSS9's are a few turns from rock bottom in the front.
#162
More camber up front is going to give you more grip, for example, on the dragon, especially since you tend to run high performance tires (or you did anyway).
But since you also drag race (less camber for straight line grip), and are thinking about some auto-x and road course, the ability to switch to different settings could prove advantageous.
Yes, there will be more NVH than oem mounts. More than the UM mounts as well? Probably, but it might be closer since they seem quite firm.
But anyway, a lot here on the tex run low profile tires, big exhaust (or flapper open), windows down, big turbos, and i see race seats and roll cages as well, just to give some examples. Most people love the .:R because its raw. So, you are not going to die with a set of camber plates, its all relative.
Plus, just like the UM mounts (because they are much firmer) your suspension will work better because no energy is being dispersed into the mount - the coilover will react more directly.
I dont really want to jack the UM thread anymore, since Im not trying to post against their products.
for any company that keeps bringing out new parts for our cars which are now 2 generations behind (but still the best!)
#163
So i have a Q for you guys. I am planning on running GC camber plates. Do they replace the trut mount or just the silver cap on the top o the strut mount? If not then i may order a set of these mounts.
#164
MKIV DBP .:R32 | Photo Gallery
Projects | Custom Exhaust : It Begins | Solid MKIV Sub-Frame Mounts ||Build Journal| Draxus's GoKart
#165
#166
#167
PM sent Boudah
#168
Any specific strut BEARING you guys recommend to pair with these? Does anybody know if the INA ones offered by 034 are better/worse/same compared to OEM?
http://www.034motorsport.com/oec.php...=Strut+Bearing
OEM plusss...
K&N Typhoon Short Ram Intake / BFI Stg1-Sidemounts Stg2-Dogbone / HPA Short Shifter w Verdict Motorsports + 42DraftDesigns Bushings
8000k HID Angel Eye LED's / 42DD High Intensity LED's / 35% Tint / UnFlapped
#169
#171
I used new stock strut bearings when i installed mine. After a few hundred miles on these mounts they feel the same and have not shown any wear. Where i live the roads are crap and stock mounts deflect and wear within a month or so. So far i am quite happy the mounts!
.:R
Build your car for yourself, not what an internet forum tells you.
#172
last I heard these mounts were 1 to 2 weeks out. When will they be available?
#173
Just ordered the UM mounts.
They do cost a pretty penny but I wanted them because I won't have to swap them out in 40,000 miles. Pulling the suspension out for strut bushings will be a headache. Plus, I got to get the alignment fixed too. Even if these are stiff I still got them for their longevity.
I also purchased the WITW 2012 shirt.
Now all I need is the UM software.
maybe, maybe I'll get the software. Could you guys post a graph of your dyno pulls with the UM software?
#174
just ordered these from Matt in the UK
cannot wait to get them installed and take the R32 for a long drive up some winding roads.
#175
I'm looking at OEM bushings,
Powerflex Bushings,
Defcon bushings,
Spherical Ball bearing bushings
and Darlin Defcon DD bushings
