Results 1 to 16 of 16
Thread: FS: New Techtonics big valve head, 266 cam & adj. cam gear
  1. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    11-14-2011 09:50 AM #1
    SOLD
    This was a package set up that was bought for a 2.0 8v motor build that never came to fruition. This set on an Audi 3a 2.0 bubble block will give you 16v power. I'm not interested in splitting this up. The head is currently setup for CIS injectors but the seats can easily be swapped out, they are merely threaded in, for Digi injector seats.
    This will include all the necessary install hardware new OEM bolts and gaskets.
    $650 shipped (lower 48)
    266 Techtonics cam PN 109 078. Polished Techtonics Adj. cam gear PN 109 060
    NEW Cylinder Head PN 109 029 8V GTI/GLI. Complete and ready for install. 40mm intake x 33mm exhaust valves with standard cam. Direct replacement for '85-'87 8V GTI/GLI/Audi 4000S. Upgrade from 38mm intake to 40mm for standard '85-'87 Golf/Jetta with GX engine and '87-'90 Fox. Will upgrade(replace) solid lifter 1.8L heads with CIS to hydraulic lifter for no valve adjustments and a quieter engine. This was mocked up on a 2.0 block on the stand. And comes w/ Bosch Platinum +3 plugs.
  2. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    11-15-2011 08:39 AM #2
    Up PM's replied
  3. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    11-16-2011 08:58 AM #3
    All PM's replied
  4. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    11-18-2011 09:08 AM #4
    UP UP UP PM's Replied
  5. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    11-19-2011 08:38 AM #5
    Saturday bump
  6. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    11-21-2011 05:44 PM #6
    Up all PM's replied busy day on the tex
  7. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    11-22-2011 09:47 PM #7
  8. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    11-25-2011 08:03 AM #8
    http://www.ebay.com/itm/250936906655...84.m1555.l2649
    3 Days left 8 watchers looks like it's gonna be a sniper war
  9. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    11-26-2011 11:33 AM #9
    Bump it UP watching finally qualifying for the 2011 F1 season whats it's been a crazy season
  10. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    11-28-2011 07:36 AM #10
  11. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    04-10-2012 10:13 AM #11
    Up
  12. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    04-13-2012 12:40 PM #12
  13. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    04-15-2012 06:38 PM #13
    Up
  14. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    04-17-2012 07:07 AM #14
  15. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    04-25-2012 10:18 PM #15
    Bump
  16. Member vwtechr32's Avatar
    Apr 8th, 2006
    On Track
    The one you envy
    04-27-2012 05:43 PM #16
    UPDATE
    This will now include all the necessary install hardware new OEM bolts and gaskets.
