Results 1 to 26 of 26
Thread: MK4 1.8T Jetta Partout in Bellingham, will ship
  1. Member greenraVR6's Avatar
    Mar 10th, 2008
    B'ham WA
    '88 Vanagon, '02 A4 Avant, '03 Accord
    11-14-2011 10:55 PM #1
    TEXT me at 360 820-3060 or email jhelm29@yahoo.com
    Those are the fastest and easiest ways to get in touch with me.
    MECHANICAL PARTS
    1.8t engine AWW code SOLD
    O2J 5speed tranny - SOLD
    cable shifter assembly box/cables - SOLD
    OEM cat converter - SOLD
    rear oxygen sensor $30 - front one is SOLD
    OEM muffler with downturn pipes - SOLD
    pass side axle SOLD
    starter - SOLD
    complete OEM suspension SOLD
    in tank fuel pump/sending unit SOLD
    driver side axle - SOLD
    radiator/fans - SOLD
    front brakes w/knuckles, hubs, calipers, rotors, pads - SOLD
    stock 1.8t flywheel - SOLD
    rear brakes w/hubs, stub axles, rotors $50
    rear trailing arm brake lines, hard and rubber lines with banjo bolts $10 each
    line from clutch master to slave $20
    brake master cylinder $40.00
    brake booster $20.00
    ABS pump/computer $65
    clutch master cylinder $40.00
    clutch slave cylinder $40.00
    brake booster/clutch master bracket $20
    power steering fluid bottle/lines $20
    wiper motor/arms $50.00
    power steering rack $65.00
    ebrake cables $20 each
    heater core $20
    lug nuts with special removal key $25
    axle bolts $10
    evap system $25
    pass side motor mount $20
    widowmaker jack with lugnut tool and tow hook $25
    EXTERIOR PARTS paint code LD5V Royal Navy Pearl
    hood is garbage
    driver fender is garbage
    radiator support is garbage
    front bumper skin is garbage
    driver side headlight is garbage
    15" Avus wheels - SOLD
    spare tire - SOLD
    rear bumper - SOLD
    driver side mirror SOLD
    pass side mirror SOLD
    grill - SOLD
    front bumper lower grills - all SOLD
    passenger side front door - SOLD
    passenger side rear door - SOLD
    driver side front door - SOLD
    driver side rear door - SOLD
    hood latch/release mechanism - SOLD
    tail lights - SOLD
    trunk lid - SOLD
    hood lift strut - SOLD
    bolt in battery tray - SOLD
    roof antenna base with complete harness up to the deck $25
    side marker lights $20.00 - perfect condition
    clear fender turn signals $20.00 perfect condition
    front outer door handles $30 each
    door latch/lock assemblies $25 each - driver door latch SOLD
    windshield washer fluid nozzles $10 each
    windshield washer fluid bottle with pump $25
    hood hinges $15 each
    door latches $10 each
    INTERIOR PARTS
    seats - SOLD
    steering wheel/airbag - SOLD
    wiper/turn signal stalks - SOLD
    pass side airbag - SOLD
    main airbag control module - SOLD
    glove box SOLD
    dash cup holder SOLD
    armrest SOLD
    shift knob/boot SOLD
    door panels -SOLD
    driver door switch panel/switches SOLD
    dome light/sunroof control - SOLD
    dashboard - SOLD
    dash vents SOLD
    rear window decklid - SOLD
    gray carpet - SOLD
    dark gray trunk carpet kit - SOLD
    single din dash pocket - SOLD
    rear pop out cup holder - SOLD
    hvac controls - SOLD
    cd changer - SOLD
    OEM speakers, 4 mid range, 4 tweeters $50 - SOLD
    owners manual $20
    ash tray $20
    front door inner handles $25 each
    steering column clockspring $25
    driver/pass seat airbag control modules $25 each
    double din/heater control dash piece $25
    headunit - $30
    power window motors $40 each
    driver door power window regulator $40
    sunroof assembly $65.00
    sunroof motor $50.00
    dash switches $10.00 each - flasher, defrost, trunk popper, gas door popper, dimmer,
    ASR SOLD, heated seats SOLD
    headlight switch $20
    seatbelts $30 each, PASS REAR SOLD
    manual pedal assembly $50.00
  2. Member NWarty's Avatar
    May 19th, 2011
    Olympia, WA
    11-15-2011 06:20 PM #2
    PM sent
  3. Member plastic_bullet's Avatar
    Mar 11th, 2006
    Marysville, WA
    16v mk1, a mk3 and a mk4
    11-17-2011 05:22 PM #3
    need right rear seatbelt and how is the soft texture stuff on the front right door pull?
  4. Member Sticky Tape's Avatar
    Mar 29th, 2009
    seattlish
    HPA R32, GTD
    11-22-2011 10:39 PM #4
    I may have missed it, but how many miles are on the engine? Also, has the coolant flange and cam adjuster seal been replaced. I see lots of evidence of leaking on the trans. not a bad price though. Just wondering about the mileage. I may be in need of this..
    www.demonrally.com
    www.finetuningperformance.com
    for technical help, post here. http://forums.pnwfahren.com/ I dont offer much help on Vortex anymore
  5. Member sibeGLI's Avatar
    Nov 3rd, 2011
    Canby, OR
    24v GLI
    11-24-2011 04:28 PM #5
    How much for the tweeters shipped to 97045?
  6. Member Miotke's Avatar
    May 16th, 2010
    Tacoma WA
    2005 Jetta GLI
    11-26-2011 10:19 PM #6
    If you got the front valance and it's not busted up shoot me a PM.
    Feb 17th, 2010
    Kent, WA
    8v mk2 golf
    11-27-2011 12:15 AM #7
    How much for the rear calipers? Dont need the hubs and all that just the calipers.
    Not trying to impress you...... but I am Batman
    Apr 2nd, 2008
    Bend, OR
    2000 Golf 4d, 2013 Golf TDI w/tech, Past cars: 2007 GLI, 2006 2.0T
    11-27-2011 02:12 AM #8
    Is that top middle vent still available on the dash? It's the one closest to the windshield. Thanks.
  9. Member Redvdubdrivah's Avatar
    Jan 23rd, 2007
    Puyallup WA
    1990 GLI
    11-29-2011 01:47 AM #9
    front driver side foglight? or did these not come with them? friend needs one for her 1.8t passat lmk thanks
  10. Member mikegilbert's Avatar
    Nov 29th, 2006
    Seattle, WA
    8 Rings / TDI
    12-01-2011 09:01 PM #10
    Do you still have the hood?
  11. Member mikegilbert's Avatar
    Nov 29th, 2006
    Seattle, WA
    8 Rings / TDI
    12-11-2011 08:51 PM #11
    Quote Originally Posted by greenraVR6 View Post
    tothetop
    Quote Originally Posted by mikegilbert View Post
  12. Awaiting Email Confirmation
    Nov 4th, 2008
    He'll lick your balls
    04' R32, 81' Caddy
    12-11-2011 11:46 PM #12
    still have the front hubs/brakes?
  13. Member niterider03's Avatar
    Apr 19th, 2004
    Germany/WA
    78 Rabbit 2.0
    12-20-2011 03:48 PM #13
    interested in the dash, Ill be back in Wa the 27th of Dec.
  14. n00b
    Dec 21st, 2011
    Woodinville, WA
    1991 Mk2 Jetta Coupe, 2001 Jetta TDI, 2006 Jetta 2.0t 6spd, 2005 Audi A4 USP
    12-22-2011 03:39 PM #14
    Sh*t! Needed that rear color matching bumper so bad!
  15. Member FireStorm005's Avatar
    Jun 23rd, 2007
    Sammamish, WA
    '99 Golf TDI
    12-26-2011 03:46 PM #15
    was this car in an accident? If not or the airbags didn't deploy at all I'll take the driver's seatbelt.
  16. Member Mr.Maus's Avatar
    Apr 30th, 2006
    Lake Stevens, WA
    02 Jetta 1.8t 6 speed conversion
    12-29-2011 10:32 AM #16
    i need the clutch switches off the manual pedal, the bracket that holds then, the #53 relay and maybe even the brake pedal. how much... im in lake stevens... also i need the pigtails for the wiring for the switches.
  17. Member 03VWJettaGLS's Avatar
    Aug 12th, 2011
    Amelia OH
    2003 VW Jetta GLS 2.slow
    01-12-2012 09:50 PM #17
    PM'd
  18. Member 03VWJettaGLS's Avatar
    Aug 12th, 2011
    Amelia OH
    01-17-2012 03:13 PM #18
    Just a reminder, 6 disc CD changer and rear cupholders = sold. Just to let vortex know
  19. Member ca180's Avatar
    Jun 19th, 2011
    Ft Bragg
    1986 Golf MK2 CL
    01-20-2012 09:44 AM #19
    Will you sell rear calipers alone?
  20. Member 03VWJettaGLS's Avatar
    Aug 12th, 2011
    Amelia OH
    01-24-2012 02:29 PM #20
    PM me...
  21. Member GLI_DRIVER's Avatar
    Mar 26th, 2002
    OR.WA.
    04 R 06 A3
    01-26-2012 11:54 PM #21
    Do you have the ebrake lever and bracket that mounts to the body?
    .:R
    Build your car for yourself, not what an internet forum tells you.
  22. 03-11-2012 07:09 PM #22
    How much for A-pillars and the drivers door rubber molding?
  23. Member
    Apr 11th, 2012
    Wading River , NY
    03' passat glx
    04-11-2012 11:23 AM #23
    hazard switch? shipped to 11752
  24. Junior Member tezzaworld's Avatar
    May 29th, 2012
    Ireland
    Volkswagen Golf 1997 16v GTI
    06-11-2012 04:06 PM #24
    Boot lid shipped to ireland?
    Sent from my I-Phone using an app that connects to a toaster in france that tells an asian child he must type to survive.
  25. Member
    Oct 28th, 2010
    Bethlehem, PA 18020
    73 Bug, 02 Jetta
    06-27-2012 04:56 PM #25
    black interior? I need all 4 map lights and oh shoot handles. Pm me a price shipped
  26. Member greenraVR6's Avatar
    Mar 10th, 2008
    B'ham WA
    11-18-2012 01:56 AM #26
    ttt
    Lots of vr6 and some 1.8t parts for sale
    http://forums.vwvortex.com/showthrea...3-GLX-MK4-1.8T
