Page 1 of 2 1 2 LastLast
Results 1 to 35 of 44
Thread: FWD drift video..how?
  1. Member rlsib16's Avatar
    May 30th, 2002
    NY state of mind
    saloon/specialized
    10-17-2002 11:33 AM #1
    http://www.g-speed.com/eg2/videos/drift2.wmv 18.6mb(sorry its kinda big 56kers)
    how does he hold his drifts like that? i know you can pull the e-brake on fwd cars to slide the backend around but how does he keep the drift going?
    Feb 5th, 2002
    Ohio
    08 Sonata, 10 Ford Flex
    10-17-2002 11:44 AM #2
    Left foot braking - Keep on the gas while applying a little brake
    pressure with your left foot. Weight transfers to front, back end gets
    light & comes around. Road racers do it to settle the car down in the turns & reduce plow(fwd). Rally drivers do it to get the tail out so
    they're pointed in the right direction sooner and therefore can get
    on the gas (full throttle) sooner. Someone else can explain it much better.
    I do it all the time...........IN MY DREAMS!
    [Modified by 2.DOH!!, 8:52 AM 10-17-2002]
    “We need to do this every day of the week, and just really brainwash people into thinking about guns in a vastly different way."” ~ Eric Holder
  3. Geriatric Member Obin Robinson's Avatar
    Oct 20th, 2000
    League City, Texas
    2001 Boxster, 2012 Kia Soul
    10-17-2002 11:47 AM #3
    anyone know Taber Street in Ithaca? i used to swing the rear end out on the Scirocco 16V every day using this method:
    1) gas hard in 2nd gear
    2) hard right turn and simultaneous lift off of gas pedal followed 1/4 second later by snap countersteer
    3) gas hard (still in 2nd gear)
    4) rotate car back to correct direction
    it's called lift-off oversteer and then you "power out" of it.
    front wheel drift
    by the way, it kills your tires!
    obin
  4. Geriatric Member AKADriver's Avatar
    Nov 20th, 2001
    Unreal VA
    NB Miata
    10-17-2002 11:58 AM #4
    It takes a lot of skill and a very well balanced car. People don't appreciate FF drifting because it never looks quite as impressive, but when you can make a FF dance like an average FR then you're doing very, very good!
    Integra Type-Rs, rear swaybar equipped Neons, and probably some others can be thrown into a drift as delivered... I used to get plenty of lift throttle oversteer in my Neon, but not a full drift (I was losing traction in mid-corner, not corner entry), someone with more skill and a better feel for weight transfer could probably do a better job unloading the rear than I did. Since this Civic shares a chassis with the ITR it shouldn't be hard to modify the suspension for better balance.
    I don't practice llanteria
  5. 10-17-2002 11:59 AM #5
    there is really no way to drift in a FWD car. You can do power slides and stuff though... I used to practice lift-off oversteer all the time in my Golf... it's exactly how Obin described it. You go around a corner accelerating hard in 2nd (you can do this in a higher gear too, but 2nd is the easiest, imo), then let off the throttle, increase the turn, and the back end should come around.
    It's all about weight transfer. You want the weight to be moving over the front wheels, so the back will slide around. In the video you can see when the weight shifts over the front axles, it's right before the rear slides around. Good luck!
  6. 10-17-2002 12:54 PM #6
    First of all, it doesn't look to me like the person is left foot braking or using the e-brake, so he is probbaly throttle lifting.
    Secondly, it looks a bit like he is using different tires front and back which implies that he might have also done some suspension modifications (but no negative camber or slamming, or stuff like that you usually see in drift competitions).
    Thirdly, while some are just oversteer slides (can't be a powerslide... and yes that's also technically a drift), he does sustain a pretty good four wheel drift at least once in the video.
    It's not that hard to do drifts in FWD... Okay, harder than on a RWD, but...
    You can sustain donuts in a FWD, and he could have if he knew how to keep the right pressure on the throttle and not countersteer as much as he did (but I think he did that to show off). My personal best is one and a half circle on my stock suspensioned and tire-ed Jetta. Which was initiated purely on throttle lift (can't really do it any other way due to the throttle lag on drive by wire in these things).
  7. 10-17-2002 01:02 PM #7
    add to the list the 2000+ Celica GT & GT-S (seen a GT do it at the autocross) and also the old Escorts.
  8. Senior Member cougar's Avatar
    Nov 24th, 1999
    10-17-2002 01:33 PM #8
    obin
    Can't this be said about pretty much any drifting? I mean.. the tires are moving in a different direction than the rest of the car.. that's no good
    Unpaid shill
    Well, then, I'm here to "ruin" the vortex for you. I'm sorry you hate fun.
  9. 10-17-2002 02:08 PM #9
    Okay, I don't know what kind of car you drive, and since you ask about techniques, I will write out how I did the donut in the Jetta:
    You can do in first or second gear, I've done it in either. First is a bit more twitchy so it's easier to initiate, but harder to hold. The longest one I did was done in second gear.
    You take the gear right up to the redline. Around 4000 rpms or so you ease into a turn as you are still accelarating so that you are turning at your limit (tires squeeling but not really understeering... at the very limit it might help to understeer just a little bit). When you get to redline (careful, because VW lets you overshoot) lift suddenly off the throttle and the car immediately does the dog pissing position (one rear wheel off the ground) and goes into a rather violent oversteer (comparatively anyway). Keep on letting it spin to the perfect angle and get back on the throttle. Too little of an angle and you will pull out, too steep... Well let's just say that unless you are spinning out or stopping there really is no too steep.
    The key is to get as steep an angle as possible without letting the revs get too low. I'd say around 4000 rpms as a ballpark is when you want to be getting on the throttle. The rest is just throttle modulation to just the right amount of pressure to keep the fronts spinning just a little bit while not so fast that your nose doesn't stay tucked in.
    Your steering angle should range from pointing straight ahead to just a bit of countersteer.
    Well, that's about it... Find a huge parking lot and have fun!
  10. Geriatric Member Obin Robinson's Avatar
    Oct 20th, 2000
    League City, Texas
    10-17-2002 03:24 PM #10
    obin
    do it on wet pavement or gravel and it's easier on tires. but the real thing to do if you want to drift is put really HARD compound tires on the back. use snow tires if possible. then get some sticky ones on the front.
    i am going to take a trip to the junkyard to pick up some $5 tires maybe in a month or so. i have some spare rims i could mount them to. all i need to do is mount these cheap hard tires on the rear and i'll be the "crazy Type-GTI drifto action-san."
    obin
  11. Member
    Feb 5th, 2002
    Ohio
    10-17-2002 03:36 PM #11
    quote:
    ...i have some spare rims i could mount them to. all i need to do is mount these cheap hard tires on the rear and i'll be the "crazy Type-GTI drifto action-san."
    You bring up a good point. I was driving my sisters Protege a while back & she had just bought 2 new tires, which they put on the front. It was a bit rainy out, & the back end kept steppin out. I wasn't really
    going that fast either. Fun, but not the 'safest' set up I imagine.
    Mark
  12. Member Daemon42's Avatar
    Feb 9th, 2001
    colorado
    04 R32T, 95/98 4runner
    10-17-2002 04:43 PM #12
    BTW, snow tires are very soft compound. Often more soft than high perf rubber.
    Get em heated up with a turn or two and they turn to goo. I know this.. because.. well.. let's just
    say I know this. They'd work for this application, but not for long.
    Running some high perf tires on the front and A/S on the back at high pressure
    should be enough to duplicate what he's doing in the video (and I suspect is
    what he does do). It indeed does not look like he's left foot or hand braking.
    If he was, I'm pretty sure you'd see the inside rear tire locking up and smoking
    bigtime. The drifts he's doing look like fairly well modulated lift throttle oversteer.
    I used to do the same thing in my Saab 99 with new tires on the front, and balding
    tires on the back.
    As for doing it in the rain. I've found that usually the front tires just don't
    maintain enough grip relative to the front to let it happen in the rain.
    VW's in particular need to get up on 3 wheels to swing around like that, and
    when it's wet, they generally can't (not for lack of trying on my part).
    Gravel is a different story. You lift off the throttle with the front tires turned
    hard and the side of the tires digs deep into the gravel and the rear will come
    right around. I've been surprised a couple times barrelling down some
    cool twisty paved road I've never been on before, (always at night) and
    had it suddenly turn to gravel and I'll lift off to drop to a reasonable speed
    and the rear end is *all over* the place. I could have a lot of
    fun with my suspension in the gravel, or I could kill myself. Seems to
    be pretty close to a little of both everytime it happens.
    I'd love to see one of those full spins caught on video. With my Falken Azenis tires
    there's simply no hope of getting the rear end that far out of control./
    ian
  13. 10-17-2002 04:59 PM #13
    I wonder how many people are gonna try this on their way home from work
  14. 10-17-2002 07:01 PM #14
    You can drift a FWD car, people who say otherwise are lying.... The majority of rally cars are FWD.... Here is how you would do it on gravel (or pavement, but you would need alot more momentum)
    Accelerate into a corner
    turn sharp, and quickly in the opposite direction of the apex....
    and quickly turn back towards the center/inside of the corner, you have no effectively transfered momentum, and a ton of weight to the front outside wheel, digging it into the surface, and creating a pivot point....
    to properly execute the drift/slide whatever, as soon as you feel the rear end slightly unweight, and the front outside tire start to push, begin modulating the brake with your left foot, and the gas with your right... You will probably need to initiate slide with sharp application of the brake, and quick application of the throttle at the moment of tire bite...
    This technique is called the Scandanavian Slide, of Finnish Flick... It is very sucessfull, and works great. You will see almost all rally drivers implement it in someway (except those pesky active diff equipped WRC cars)
    You can slide or, drift, perfectly around many a corner with this technique.
  15. 10-17-2002 07:30 PM #15
    obin- dont forget a camera!
  16. 10-18-2002 08:06 PM #16
    Cool stuff
    [Modified by High Psi VR6, 8:07 PM 10-18-2002]
  17. 10-18-2002 08:09 PM #17
    obin
    obin
    I have a better idea!! Put some cafeteria trays under the rear tires and lock your E-Brake. They last about a minute till they burn through.
    Video here!
    You may need the latest codec in order to view it. My favorite is the zoom in on the rear wheels when he says: "Them 10's! I know I keep them clean YO!"
    -DVScott
  18. 10-18-2002 08:33 PM #18
    obin
    obin
    Video here!
    -DVScott
    When I worked at taco bell, we would tray surf. My manager would take us around the parking lot when no on else was there (like 2 am). You sit on a tray and hold on.
    Jeff
  19. Member bc's Avatar
    Sep 24th, 2001
    River of garbage, Tokyo
    2010 Toyota iQ GRMN
    10-18-2002 09:17 PM #19
    its about 40 times easier when it is wet about. I normally heel toe downshift then pull the ebrake to get the ass to slide, very violent but its always worked for me....
  20. 10-18-2002 09:26 PM #20
    go try it... you'll figure it out for yourself
  21. 10-18-2002 10:38 PM #21
    Video doesn't work for me. I am using the new version of media player that is the beta version. I think it is 9
  22. 10-18-2002 11:53 PM #22
    There's actually a website about this. I believe it's called tray-sliding.
    Where's that video of Tiff Needle driving a Ford Puma when you need it?
    _RevLimit_
    aspiring "crazy Type-GTI dorifto action-san"
  23. Member impact's Avatar
    Feb 6th, 2002
    2006 Škoda Octavia
    10-19-2002 01:10 AM #23
    Is it this? http://equinix.taner.net/topgear/ - Car of the year, 1997 MPG 14MB 2:05 2001.04.06 Ford Puma is Top Gear's Car Of The Year in 1997 - Tiff has some... FUN with it ;-)
  24. Member MartijnGizmo's Avatar
    Apr 21st, 2002
    Groningen, The Netherlands
    2002 Mini Cooper
    10-19-2002 12:04 PM #24
    Traydrifting, it's on the Pornstar-Clothing's website, including some video's:
    http://www.pornstarclothing.com/images/storesite/video/trays2s.mpeg
    http://www.pornstarclothing.com/images/storesite/video/trays1s.mpeg
    http://www.pornstarclothing.com/images/storesite/video/trays1a.mpeg
  25. Member
    Feb 2nd, 2002
    2012 VW Passat 2.5S
    10-19-2002 03:10 PM #25
    mmm... im' gunna go look for some trays now
    2012 VW Passat 2.5 S
  26. 10-19-2002 05:24 PM #26
    Well I know what I'm doing tonight!
    In tomorrow's paper:
    " Fast food restaurants loose record number of food trays
    Trays later found in mall parking lots."
  27. Senior Member Bauzen's Avatar
    Oct 5th, 2001
    Hells Kitchen, NYC
    07 Tomos Sprint
    10-19-2002 05:41 PM #27
    hehe
  28. 10-19-2002 08:08 PM #28
    Man, I would try that, but my car would just keep going in a straight line. Cursed RWD
    Maybe I'll steal a couple from the cafeteria tomarrow, I can test it out in the "Student commuter lot" where we have autocrosses. Excpet I'll have to put a couple of trays under my front tires, and I do value my steering....
    Jeff
  29. Member Mabe's Avatar
    Feb 27th, 2002
    Upstate NY
    08 Sierra - 02 Golf 1.8t - 08 MDX Sport
    10-19-2002 11:30 PM #29
    Thats a nice vidieo. On one side it is very easy to get any car bent all sorts of ways when you have a large peice of tarmac to deal with. If he was driving like that around a turn like that and was able to guide the car well enough to maintain the drift through the turn I would be very impressed. Very hard. Drifting, expecally in a fwd car is of little use in any driving aside from on ice. The only real benifit to knowing how to is being able to bring your car out of one.
    As far as the ****ty tires on the back idea...many of the URQuattro guys run 205 series front tires and 195 rear. Gives the car almost perfect balance according to them.
    [Modified by AK-Mabe, 4:31 AM 10-20-2002]
    08 GMC Sierra 5.3 Z71 - BOSS Plow
    08 Acura MDX Tech/Ent/Sport
  30. 10-19-2002 11:46 PM #30
    just be sure to do in a good clear, safe area. Man have you seen some of those Japanese Drifter cars?Not the cars you see in super street mind you. Everyone it seems had got a huge crack in the fender or a dent in the rear quarter panels, scratched up paint..... and a big story to go with each one they have They don't care at all how thier car looks.......
  31. 10-20-2002 04:03 AM #31
    I think there's a video with Tiff Needell from Top Gear (UK) driving a Ford Puma with two other people in the car with him. He was able to do all kinds of crazy stuff. Granted that the track was wet, but it is a tiny hatchback with 3 guys in it, though... He's good.
  32. Member MartijnGizmo's Avatar
    Apr 21st, 2002
    2002 Mini Cooper
    10-20-2002 10:27 AM #32
    Right!!!!!
    Check this article from the site from MTM (MotorenTechnik Mayer, a famous German Audituner):
    http://www.mtmonline.de/S2/pr_gf_595.htm
    "Kurios dabei die Reifenformate. Um in schnellen Kurven das quattro-typische Schieben über die Vorderräder zu verhindern, montieren die findigen Bayern an dieser Stelle einfach etwas breitere Räder. Vorne 265/35-18 auf 10 J x 18 Antera-Felgen, hinten tun's 235/40 auf „nur“ 81/2 Zoll breiten Alus. Das bringt unkompliziertes Handlung auf sehr hohem Geschwindigkeitsniveau. Dabei bleibt der Audi unter nahezu allen Fahrbedingungen traumhaft neutral und läßt sich spielend allein mit Gas und Bremse durch die Kurven zirkeln."
    Translation: The tire formats seem to be strange at the same time. In order to prevent the Quattro-typical pushing over the front wheels in fast curves, the resourceful Bavarians simply mount somewhat wider wheels here. In front 265/35-18 on 10 J xs 18 Antera-rims, in the back there are some 235/40-18 on „only“ 8 1/2 wide custom-wheels. That brings uncomplicated handling on a very high speedlevel. At the same time the Audi remains dreamlike neutral under almost all load conditions and can be thrown trough corners only playing with gas and brakes.
    So when even MTM does it, they can't be wrong.....
  33. Member MartijnGizmo's Avatar
    Apr 21st, 2002
    2002 Mini Cooper
    10-20-2002 10:34 AM #33
    Jeff
    This remembers me of a great story from a friend of mine:
    Some dude at his college wanted to do some 'impressive' handbrake-action in front of the college to impress some chicks. Fact is that he was driving a horrible Citroën BX, which is equiped with a handbrake that works on the frontwheels. So when he pulled it, he went straight into some bushes and damaged the enginemounts.....
    Citroën BX:
  34. Member MartijnGizmo's Avatar
    Apr 21st, 2002
    2002 Mini Cooper
    10-20-2002 10:35 AM #34
    We want video-footage!!!!!
  35. 10-20-2002 02:53 PM #35
    I have a video of how well that lunch tray trick works, its small.
    If anyone can host it for me its cool to see.
