That sounds like the answer. Cool concept.
#1
Well, I've come to the point where I'm not happy with the boost gauge options on the market. I'll be damned if I lose another vent. Add to that, the need for me to put a boost gauge in a place where it's accessible but not distracting from my field of vision. So I've found a great solution. My buddy Gabe works for the company that makes the internals for the digital readout gauges that Podi sells. I've asked him if he can build me a digital unit that we can mount where that useless mobile phone speaker grill is. The plan is to build it the length of the grill (top middle of the pic) so that we can simply cut out the the cross section pieces, and slide in a strip style gauge. He says that the technology they use is 94% accurate (on par with the best on the market. Better than most mechanical units available). The strip would start off at the left side with a plus or minus (depending on vac or boost), 2 digit spaces for numbers, then the rest of the space (from left to right) would be bars (indicating full boost/duration of boost). So far, we just talked about it tonight, so its early. But he's telling me that if we get an order of a minimum of 10, he can get his boss to sign off on it and get some made. Personally, I think it's a great solution. Its the perfect/out of the way location, but still at eye level. I'll tell my Gabe about this thread and I'm sure he can answer a few questions.
As always, discuss
#3
Once again I wish I had a coupe. Roadsters don't have the speaker grill thing.
#5
It's NOT a speaker.. that's your interior alarm motion sensor...
I would be really happy though if they made an actual pod for us like in all the other cars. Now I think that would be something worth talking about.
Instagram: johnny_gtt
#6
Yes its for the motion sensors.and some cars do have it. I think it would be a little too big. Imma stick with the vents
2001 225Q (Function Car): APR Stage 3+, APR 3' Exhaust System, Brembo Brakes, Koni Suspension
2003 180 (Form Car): Rokkor Coilovers,Custom Front Single Frame Bumper with A8 Grill Votex Sideskirts, Votex Rearlip, Axis Penta 19' Wheels, 2 Rockford Fosgate 15' Subwoofers
#7
Sounds like a cool concept. I'd like to see how it turns out.
#8
#11
He says they don't do 3D plastic. But he told me of a place local to me that does. I'll talk to them. I'm sure I'm going to have to get a large run minimum order. So there will be a GB, if they will do it.
#12
Scratch that. I just looked at my car, and there's NO WAY you could squeeze a gauge in that small space. Look at the length of the column in the picture above. It's about twice the length of ours. And as you can see from the profile pic, even they have the bezel sticking out pretty far. For us, moving the steering wheel up would smash your gauge. Unless we can find a gauge that is SUPER shallow and build the pod shallow as well.
#13
This will fit
http://www.dynotunenitrous.com/store...?idproduct=131
At the moment, I'm using an Android app called Torque. Just pick up a bluetooth adapter for the OBD plug from Ebay and you are set! My phone press fits in between the A pillar and the dash and stays there without any mount. Keeps the dash area clean and stock looking.
I'm very pleased with the Torque setup, but at some time, I may go with the above unit and install in in the dash.
#14
question is how accurate the square little unit is
#15
As per ad, 0.1 psi resolution. Accuracy will be as good as any other eletronic unit in that the pressure sender defines the accuracy, and most pressure senders are manufactured the same.
#16
Visibility is why I like gauges with customizable alarms- never take your eyes off the road. If you hear a beep let off the gas.
None the less definitely a really cool concept, can't wait to see how it turns out.
Same reason why they don't make anything else for the TT- too small of an enthusiast market.
bagsarefordeadhookers
-TCC
#17
I remember seeing somewhere that a guy installed something where his boost showed up in top of the info display in our clusters....I would love something like that!
#19
-TCC
#20
#21
Trying to nail down a time to go talk to Gabe and his boss. They have some ideas for us..
They will probably chime in on this thread as soon as we can figure some things out![]()
#22
#23
#24
It's nice! I have it in my roadster, have it set to display boost/vac as default with oil temp on the second line. There was talk of a US supplier (I believe it was Mike MCPI) but not sure if it ever went anywhere. It is a slick setup but honestly isn't the end all as in the roadster with the top down, the display is easily blurred on sunny days.
That said though, in a coupe it would be slick (and no...not selling mine). I am adding the V1 function to mine next (concealed display) if I can find a decently priced V1 Valentine.
I still run a boost gauge in the vent though, as well as an oil pressure one (center vents) then EGT and fuel pressure in the Mantis.
Joe
#25
#26
#27
#28
That "grill" in the cluster is for the stock phone mic setup. All the clusters have it but few have it "wired up" . I took my spare cluster apart, removed the stock mic and intergrated my bluetooth (for the pioneer unit) in this location. I could work well for a simple digital readout boost gauge, etc. I however tend to like the quick response and sweep of the traditional ones. The unit in my EFU4u is slick though.
Setup isn't hard, it has some wiring into the MFA control stalk on the steering column (through which you switch through the different measureables...I have boost/vac, boost max, volts, max mph, current mph, oil temp, v1 option and a few other things).
Vac line feeds directly to efu4u box, wiring is quite simple...nice setup.
I don't worry about my cluster, it's brand new.
You would lose you stock concert radio/station feed if you like that sort of thing.
Joe
#29
all this talk in here sounds very very intriguing.
I am def interested.
I have my boost gauge in the ashtray location, and its a deathwish to look down there during full boost...
Hey warranty, not to threadjack, can you pm me some details of your headliner?
Mine is out and I need to do it right.
any info is appreciated
#30
Does anyone think it'd be possible to cut out the center display to install 1-2 analog gauges? I suppose you may have to bridge connections but I'd have no idea how to do that...here is the cluster wiring (ignore the red circle). J285 is the display circuit
#31
Is it possible, yeah. Will it look good, my guess is no. If you get the same style led screen that would work very well
#32
This,
Fits there with a little modification.
#33
had a column mount on my 01 jet, similar to one posted above but guage centered, thats what i want for my 01 TT
#34
Met my buddy at a car meet on Thursday to take some measurements. We're going to be putting it where the motion sensor grill is.![]()
