Page 1 of 15 1 2 3 4 5 11 ... LastLast
Results 1 to 35 of 501
Thread: Big turbo build- take two
  1. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    01' 570awhp TT, 01' B5 A4, 00' TT225, 91' GTi 16v
    11-18-2011 01:03 AM #1
    Mod list:
    Suspension
    KW Variant 3 coilovers
    H&R front & rear sway bars
    034 track density front strut mounts
    Defcon front control arm inserts
    PowerFlex front control arm bushings
    MadMax lower rear multi-link
    Kmac upper rear multi-link
    Brakes
    Hawk HP+ pads
    Slotted rotors
    ATE SuperBlue Fluid
    Stainless lines
    Drivetrain
    Front Raxles
    Spec billet steel 13 lbs. flywheel
    Clutchnet red pressure plate
    Clutchnet unsprung kevlar pucked disc
    BFI stage 2 motor mount set
    Powerflex polyurethane steering rack bushings
    Diesel Geek Sigma 6 short shifter
    B&M short shifter
    Force Fed Engineering metal shift mount bushings
    Interior
    Hertz Hi-Energy 165K component speakers
    Sundown Audio SD-10-D2
    Audison LS 500.2
    JL Audio 250/1
    Kicker EQ
    Belkin A2DP input
    Apple iPod input
    iPod touch 32gb
    Modshack gadgeTT
    ProSport premium: oil pressure, air/fuel & boost gauges
    OSIR shift ring light
    Euro headlight switch
    Fueling
    Eurodyne Maestro software
    Wideband AWP conversion w/ VVT module
    V8 S4 MAF
    Injector Dynamics ID1000's
    Aeromotive Adj. FPR
    Fuelab 41402 pump
    OBX fuel rail -6AN
    Custom FFE under hood surge tank
    Fragola fittings & braided lines
    2.0T FSI coilpacks & NGK 7 irridium plugs (BKRE7EIX, Stock #2667)
    Motor internals
    IE Rods - 20mm pins/ACL bearings
    JE Pistons - 81mm/8.5:1 CR
    Eurospec main studs
    ARP head studs
    AEB head
    Ferrea valves, springs, retainers
    Forced induction
    Precision 5857 - DBB/4" inlet/v-bands
    Precision 650hp intercooler core
    MadMax Evo DV
    Tial MVS
    OBX intake manifold
    70mm throttle body
    Boost Valve dual stage boost controller
    Magnaflow stragiht through muffler
    EuroJet 4" exhaust tip
    Force Fed Engineering turbo kit:
    -4" turbo inlet pipe
    -2.5" intercooler piping
    -Tubular exhaust manifold
    -3" turbo back exhaust
    Exterior
    Verdict Motorsports antenna delete
    Headlight reflector delete
    smoked turn signals
    badgeless 5 bar grille
    shaved front bumper
    Last night's progress- from empty engine bay to this in about 2 hours thanks to Greg & Vince:
    Tonight:
    bagsarefordeadhookers
    -TCC
  2. Member bklnstunt718's Avatar
    May 29th, 2007
    Audi TT 225
    11-18-2011 02:14 AM #2
    i wanna come by asap! sit on a chair like a little kid... AND WATCH!!!!
  3. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    11-18-2011 09:10 AM #3
    Haha Jaymo you know where to find me man! Not to worry we got the majority of the install on video but last nights work it ran out of space somewhere and I didn't notice.
    I'll get a lot more photos up here this weekend of the work leading up to this.
    Hey anybody mind helping me out? I cannot for the life of me remember which knock sensor goes on which side??
    -TCC
  4. Member 631 Corrado's Avatar
    Jan 13th, 2003
    vermont/long island
    b5 a4
    11-18-2011 02:59 PM #4
    getttin paid.... getting paid.
  5. Member Tempes_TT's Avatar
    Oct 23rd, 2010
    Monticello, MN
    2000 180q TT
    11-18-2011 04:16 PM #5
    Yeeeah buddy! So excited to see some progress from you man!
    ps. what short shifter kit/shift cable end links do you have?
    Quote Originally Posted by DCMS371 View Post
    You do realize women are biologically programmed to ruin men's lives by making them get rid of anything that they might enjoy more than spending time with the woman right?
    Quote Originally Posted by SchmidTT View Post
    Has anyone really been far even as decided to use even go want to do look more like?
    The "This will take longer than it should" build...
  6. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    11-18-2011 05:19 PM #6
    Thanks man!
    I have:
    Diesel Geek stigma 6 under the hood (comes with the cable ends)
    Force Fed bushings on the mount
    B&M short shifter (shift rod side)
    It's super notchy and short
    -TCC
  7. 11-18-2011 05:31 PM #7
    looks great, what are your hp goals?
  8. Member PLAYED TT's Avatar
    Oct 17th, 2010
    Reading, PA/ Williamsport, PA
    A German thing, and a not so German thing
    11-18-2011 05:45 PM #8
    The teaser pics look a lot better on a computer. Its about time
    Slammed Radio Flyer---flickr---My Build Thread 99% of you are idiots therefore I hate you
    Quote Originally Posted by Marcus_Aurelius View Post
    How much lower can you go when you're already scraping stuff??? Soon you'll have the first subterranean vehicle if you keep chasing that goal
  9. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    11-19-2011 10:20 AM #9
    Hp goals-- I wanna go fast. Realisticly I want 450fwhp pump and 550fwhp e85. I've never dyno'd AWD so I don't know those numbers yet. Last year I made 410fwhp with a small port head, bad tune and pump gas.
    Time to go finish this mechanically speaking. Eurodyne support is trying to help me out reading my ECU but all efforts on my part keep failing. I hate this cars communication system- I even ran a wire straight from the ECU to my OBD2 port and zero luck.
    -TCC
  10. Member PLAYED TT's Avatar
    Oct 17th, 2010
    11-19-2011 11:21 AM #10
    Good luck Doug. Keep us updated.
  11. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    11-20-2011 07:38 PM #11
    Well finishing off today all the mechanics are together. Due to the new intake manifold putting the TB in a different location than stock I'll need new piping so I decided to change it up entirely. Going to change to a passenger side throttle body I'm pretty sure. Will mean shorter piping and less heat soak in comparison to the last setup.
    Motors all together... missing IC piping and a catch can and obviously wiring:
    Cars on the ground:
    Need to order some items for the fuel system. I picked up an adjustable regulator but I'm going to return all that garbage- keeping it stock with the RMR FPR drop in to -6an.
    Also the ongoing saga of being unable to flash my car continues. I'm going to see if a dealer can bench flash it just to get me up and running then I can troubleshoot from there.
    -TCC
    Mar 3rd, 2008
    Green Bay
    01 TT 225
    11-20-2011 08:39 PM #12
    hmmm, curious how this leads to less heat soak...please explain
  13. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    11-21-2011 08:06 AM #13
    Quote Originally Posted by jwalker1.8 View Post
    My old IC piping setup literally ran from the turbo to under the exhaust manifold and wrapped around the passenger side of my car. The new idea I have for a setup won't run under the exhaust manifold and will be maybe 2 feet shorter.
    Old setup:
    -TCC
  14. Member
    Mar 3rd, 2008
    Green Bay
    01 TT 225
    11-21-2011 09:04 AM #14
    yes, old setup was recipe for heat...
  15. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    11-29-2011 06:25 PM #15
    New part for the day. I don't want to deal with an adjustable FPR.
    Going out to install this and try to figure the ECU communication situation out-- total nightmare. About to buy a TT with a stock wideband
    -TCC
  16. Member 631 Corrado's Avatar
    Jan 13th, 2003
    vermont/long island
    b5 a4
    11-29-2011 06:42 PM #16
    your welcome.lol. (12pk) i told you that **** was dope
  17. Member l88m22vette's Avatar
    Mar 1st, 2006
    Chicagoland, IL
    11-29-2011 07:40 PM #17
    Quote Originally Posted by DougLoBue View Post
    How far have you gotten?
  18. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    11-29-2011 09:34 PM #18
    Here's the deal...
    I have a 2001 AMU TT, stock NB 02
    Last year I did a WB swap by using an OEM mk4 harness and unpinning the 02 wires and re-connecting them to my stock harness. I also removed my SAI relay and MAF sensor wiring. My car was running Unitronic at the time off a mk4 AWP WB ECU and the ECU was mailed to them to be flashed. When revisions were made my ECU was installed in a later model mk4 VW because my car could not read or flash the ECU. I had no problem running Vag-Com though.
    Though this time I always had this code, car ran great just couldn't flash the ECU:
    18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
    P1650 - 35-00 - -
    People say this comes when swapping from NB to WB. I'm starting to think the ECU's communicate differently. Digging into AWP vs. AMU wiring diagrams I have found that the AWP has the CAN-BUS connected to the Instrument Cluster specifically the Green connector pin's 18 & 19. The AWP maintains the K line also though- which is the single wire old school diagnostic communications system.
    On my AMU car I have found the CAN lines to run from the ECU,AWD,ABS and possibly other locations but not to the cluster. I decided to install pins and twisted CANBUS wiring from the cluster to the existing CANBUS circuit and I still receive the same code.
    Still can't read the ECU with Eurodyne Flash but I can vag-com it no problem.
    I will be digging through the wiring diagrams and comparing the CANBUS more extensivly. I did read a huge article today that describes most CANBUS communications to have a control unit. I don't know if 2003 VW setups are so old school that they don't have this.
    http://marco.guardigli.it/2010/10/hacking-your-car.html
    I haven't attempted to run wires to the OBD2 port yet for can-bus. After a beer I'll go out and try that one next.
    -TCC
  19. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    12-02-2011 09:45 AM #19
    ECU update:
    A couple of days ago I headed down to FFE and tried my ECU & cable read on a MK4 VW- I had the exact same results. Shipped both to Chris @ Eurodyne and hopefully it's an issue with the ECU that can be resolved. If not I'll buy another.
    -TCC
  20. Member PLAYED TT's Avatar
    Oct 17th, 2010
    12-02-2011 10:10 AM #20
    I'm glad your finally willing to scrap that damn ecu.
  21. Member
    May 7th, 2009
    02 TT 180Q (daily), 01 TT 225Q (on jackstands), 03 20thAE GTI (daily), 03 GTI 1.8T (on jackstands)
    12-02-2011 12:39 PM #21
    So why was an adj. FPR an issue?
  22. 12-02-2011 01:09 PM #22
    ^^^ I'm curious too ^^^
  23. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    12-02-2011 01:17 PM #23
    I wasn't interested in having another adjustment. I'll be running 3bar and the stock FPR seems reliable enough.
    I would have spent $300 on an adjustable and all the crap that comes with it just to have set it to 3bar or $70 to use the stock FPR and it came with most of the fittings I'll need.
    -TCC
  24. Member
    May 7th, 2009
    12-02-2011 05:07 PM #24
    Put a gauge on that OEM FPR and you'll see that they aren't very precise, aka it won't be right @ 43.5 psi.
  25. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    12-02-2011 05:20 PM #25
    How off have you seen them be?
    -TCC
  26. Member MKllllvr28's Avatar
    Sep 15th, 2005
    NC
    01 tt225(parting) 01 jetta vr6 98 vr supercharged 98vr (****box)
    12-02-2011 06:14 PM #26
    Mine's off by 4 psi. I run the rmr adapter.
  27. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    12-05-2011 10:54 AM #27
    So an interesting event occurred today:
    I shipped the ECU out from my job to Eurodyne in Canada. My company provides nuclear power products internationally and government defense products to the US. Canadian customs rang up my boss today asking why they were receiving a package for Eurodyne with an invoice for a nuclear valve going to Korea. Seems like paperwork got mixed up and I've become the start of a running office joke.
    Guess my Canadian bound packages I'll pay full price for in the future...
    -TCC
  28. 12-05-2011 11:24 AM #28
  29. Member PLAYED TT's Avatar
    Oct 17th, 2010
    12-05-2011 12:15 PM #29
    Oh boy haha. That must have been a fun time explaining that one to the customs
  30. Member MKllllvr28's Avatar
    Sep 15th, 2005
    NC
    12-05-2011 03:12 PM #30
    Sounds like terrorism to me....
  31. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    12-05-2011 06:53 PM #31
    haha yea it was an adventure. Still hasn't made it there yet even though it was schedueled for delivery today.
    Today got another cluster in the mail. My old one's gas gauge didn't work and it was really super special in the winter- wouldn't function for about 5 minutes. Just crossed my mind how do I change the milage amount on the cluster?
    Aside from this ordered some other toys for inside the car including an A2DP setup.
    -TCC
  32. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    12-08-2011 09:44 AM #32
    While the ECU is out here's some photos from the motor work from a few months back.
    ARP Main studs and IE rods
    JE Pistons and fresh walls and decked block
    AEB head, dipped, decked, new valve guides and seats cut
    -TCC
  33. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    12-08-2011 01:55 PM #33
    Cable and ECU are on their way back to me!
    ECU checks out, cable needed some repair- a big thanks goes out to Eurodyne's Chris Tapp
    Now to try and squeeze my car into Force Fed for some intercooler piping and hopefully after that I can finally drive this thing...
    -TCC
  34. Member PLAYED TT's Avatar
    Oct 17th, 2010
    12-08-2011 01:58 PM #34
    Then after that I will definately drive this thing...and love every second of it
    FTFY
  35. Member RabbitGTDguy's Avatar
    Jul 8th, 2002
    Elmira, NY
    2001 Audi TT-R 225Q, 2009 VW Tiguan SE, 2000 Passat GLS 30v V6 Wagon
    12-09-2011 06:21 AM #35
    Lookin good! Can't wait to hear how it goes!
    Joe
