Page 2 of 15 FirstFirst 1 2 3 4 5 6 12 ... LastLast
Results 36 to 70 of 501
Thread: Big turbo build- take two
  1. 12-09-2011 09:48 AM #36
    Quote Originally Posted by DougLoBue View Post
    Cable and ECU are on their way back to me!
    ECU checks out, cable needed some repair- a big thanks goes out to Eurodyne's Chris Tapp
    Now to try and squeeze my car into Force Fed for some intercooler piping and hopefully after that I can finally drive this thing...
    Good news, remember the be anal about the brake-in procedures this time and re-torquing the head (don't put it on the dyno even if it's tempting). I can't wait to get my hands on it to squeeze some power out of maestro on a corn fed BT.
    May 7th, 2009
    02 TT 180Q (daily), 01 TT 225Q (on jackstands), 03 20thAE GTI (daily), 03 GTI 1.8T (on jackstands)
    12-09-2011 09:53 AM #37
    W00T for corn!
    PS I'm real close to converting my lowly 180Q.
  3. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    01' 570awhp TT, 01' B5 A4, 00' TT225 Project
    12-09-2011 10:06 AM #38
    Any motor break in procedures/advice? Fluids to be used/changed and when?
    Edit: LOL
    bagsarefordeadhookers
    -TCC
  4. 12-09-2011 10:29 AM #39
    Most I have seen and I used myself was non syn oil and run through the rev range to get good heat to seat the rings properly. Limiting the revs may keep you from getting a good seal. A hundred miles later, change the oil still with non syn again for 500 miles then back to full syn. There is also break in oils you can try.
  5. 12-09-2011 10:36 AM #40
    Quote Originally Posted by cincyTT View Post
    Yep, that's the way to do it!
    Doug has it under control this time.
  6. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    12-10-2011 02:45 PM #41
    Just did front control arms on the BMW. First side took hours then second about 30 minutes. Nightmare.
    While I did that AAA picked my car up and now I'm going to see it at Force Fed. Intercooler piping should be getting done or at least started today. I'm sure there will be photos to follow.
    I am here: http://maps.google.com/maps?ll=40.772394,-73.333785
    -TCC
  7. 12-10-2011 03:29 PM #42
    I've done these on the race car at work several times and they are not that bad with the right tools and some practice.
  8. Member PLAYED TT's Avatar
    Oct 17th, 2010
    Reading, PA/ Williamsport, PA
    A German thing, and a not so German thing
    12-10-2011 03:49 PM #43
    I spy a sledge hammer.
    Slammed Radio Flyer---flickr---My Build Thread 99% of you are idiots therefore I hate you
    Quote Originally Posted by Marcus_Aurelius View Post
    How much lower can you go when you're already scraping stuff??? Soon you'll have the first subterranean vehicle if you keep chasing that goal
  9. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    12-11-2011 05:53 PM #44
    Quote Originally Posted by The_RoadWarrior View Post
    Yea I learned that. Had to buy a ball joint popper fork and use a sledge hammer hard a bunch of times to remove the balljoint. Second side I got done in under an hour.
    I am here: http://maps.google.com/maps?ll=40.705493,-74.008603
    -TCC
  10. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    audi tt gt3076r 01 aston martin db7 04 land rover disco 99rolls royce seraph
    12-11-2011 06:50 PM #45
    Nice I have been waiting to see a build
  11. 12-12-2011 11:25 AM #46
    more pics!!
  12. 12-12-2011 11:43 AM #47
    IIRC to change your cluster mileage the dealer has to do it.
  13. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    12-12-2011 04:49 PM #48
    I'm being sent teaser pics... aka the car will be done tonight it looks like!
    Ed's the effin' man! - This is the exact way I wanted to route it:
    -TCC
  14. 12-12-2011 05:03 PM #49
    done tonight that excellent.. will she be up and running?
  15. 12-12-2011 06:56 PM #50
    love it... now when you get done ill drive out there and trade you car's and take a fast car home!!
  16. Member MKllllvr28's Avatar
    Sep 15th, 2005
    NC
    01 tt225(parting) 01 jetta vr6 98 vr supercharged 98vr (****box)
    12-12-2011 08:00 PM #51
    Lookin good man.
  17. Member DeckManDubs's Avatar
    Sep 26th, 2004
    Mass
    Corrado SLC , TT 225QC
    12-12-2011 09:29 PM #52
    Good to see the progress Doug! Seems like you will stand a better shot at running me on the way down to H2O
    I'm not endorsing the purchase of a Saab, cause I'd rather gargle battery acid. It was merely the best example I could think of.
  18. 12-12-2011 11:47 PM #53
    Damn! I wish I lived up by you guys. I'd probably have gone BT by now
  19. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    12-12-2011 11:50 PM #54
    Quote Originally Posted by DeckManDubs View Post
    lol senior Gregory needs the hookup with a verdict kit to keep up!
    Oh and TT info- the battery box fits perfectly. Looks like I will be able to run a full-size battery up front
    -TCC
  20. Member giacTT's Avatar
    May 16th, 2007
    01 Audi TT Gt30r 1552v2 built 400 AWHP 30 psi;)
    12-13-2011 12:00 AM #55
    Let me know how the lag goes is on this...Not sure i would like anything larger than my 3076... Very interested in your wb issues however. Im still on Nb with eurodyne tune. Chris doesnt seem to want to make a bigger
    file for me unless i switch to WB.
  21. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    12-13-2011 12:11 AM #56
    Last year with a small port head and stock intake manifold:
    I'm suspecting the large port head & intake manifold will make spool a little quicker. I'm pretty sure the boost curve is similar to a 3076R... If you're running a vband setup just remember that they are two different size vbands.
    I'll definitely update about the Eurodyne WB file this week. I can assure you that the issues were on my end not his. My post on the first page digging into the differences between NB vs. WB and CAN-BUS vs. K line should all be ignored. All TT's WB or NB had both a CAN-BUS communication system and a K-line diagnostic system.
    The CB system connects ECU/ABS/Haldex. The difference between NB and WB was CB also communicates with the cluster and radio on WB, which is probably just for the information readout.
    The K-line also connects all those devices and more on both NB & WB for diagnostic purposes and also flash purposes.
    -TCC
  22. Member DeckManDubs's Avatar
    Sep 26th, 2004
    Mass
    12-13-2011 08:55 AM #57
    That he does...Got a new toy coming out in the late spring that you can run then
    The new piping is far better than the old setup. No more heat soak
    Quote Originally Posted by warranty225cpe View Post
    Dont need a big turbo to be fast
  23. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    12-13-2011 12:42 PM #58
    You guys like the new wheel and tire setup?
    I am here: http://maps.google.com/maps?ll=40.730739,-73.445465
    -TCC
  24. Member PLAYED TT's Avatar
    Oct 17th, 2010
    12-13-2011 01:14 PM #59
    Lol
  25. Member DeckManDubs's Avatar
    Sep 26th, 2004
    Mass
    12-13-2011 01:44 PM #60
    [QUOTE=DougLoBue;74910521]You guys like the new wheel and tire setup?
    Do it.
  26. Member l88m22vette's Avatar
    Mar 1st, 2006
    Chicagoland, IL
    12-13-2011 05:21 PM #61
    I like rally TTs but that's ridiculous
  27. Member G'D60's Avatar
    Mar 11th, 2002
    Calgary Canada
    01 TTQ 91Gsexty
    12-13-2011 06:33 PM #62
    new batmobile??
    Quote Originally Posted by butterface View Post
    Having said this, I enjoy a little hetero roughing it in the ole' sphincter from time to time.
  28. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    12-13-2011 08:59 PM #63
    Not motor related but:
    Tonight modified a Belkin Bluetooth receiver made for home AC outlets to work off an iPod charger. The EQ I have has an A/B switch so I'll have iPod direct input and charging then Bluetooth wireless audio from any device.
    It just so happens that the Belkin is 5v/180mA so it works perfectly with an iPod charger. I'll hardwire the charger hidden behind the dash. The Belkin has a minijack output so I'll just run a minijack to RCA Cable.
    -TCC
  29. Member MKllllvr28's Avatar
    Sep 15th, 2005
    NC
    12-13-2011 09:19 PM #64
    You sir, are an electronic junkie.
  30. Member PLAYED TT's Avatar
    Oct 17th, 2010
    12-13-2011 09:30 PM #65
    And a genius
  31. 12-14-2011 12:24 AM #66
    Nice, any chance of cloning?
  32. 12-14-2011 01:57 AM #67
    Mmmmm.... (dreams of a F23 on E85....................)
  33. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    12-14-2011 08:29 AM #68
    Yea- no problem. The parts were like $40 total and it took a minute to modify. Do you still have a stock radio though?
    -TCC
  34. 12-14-2011 10:18 AM #69
    Everything is stock besides a few suspension and engine mods here and there !
  35. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    12-14-2011 11:11 AM #70
    We can swap your CD changer for it then if you don't mind sacrificing that.
    ECU should be in today. I think that Ed finished up the piping yesterday. Shooting to turn the motor over for the first time Thursday or possibly Friday at my house if you're around- I'll let ya know when.
    -TCC
