Page 13 of 26 FirstFirst ... 3 9 10 11 12 13 14 15 16 17 23 ... LastLast
Results 421 to 455 of 885
Thread: What's the deal with the AutoPilot v2??
  1. Member VR6VR6's Avatar
    Oct 10th, 2008
    Scottsboro, AL
    lurking hours > post count
    04-12-2012 12:28 PM #421
    Quote Originally Posted by MechEngg View Post
    Alright as i assumed each compressor is drawing 26A according to the spec sheet. BUT this rating is at 13.8V. If you run the compressor at 12V you are pulling 30A. Fuses are usually manufactured with a +-3-5% factor which means that the 30A fuse could really be 28-32 amps which would pop the fuse right away.
    YOU SHOULD BE USING A 40 AMP FUSE PER COMPRESSOR
    I'm using a 30amp fuse PER compressor... The kit came with 30amp fuses and the compressor clearly says 30amp on the label.
    Where I split the power to go to each relay, the fuze is inline right after the split. Only one of them is blowing which makes me think my ground is okay.... because if it were a bad ground it would be blowing both fuses.
  2. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    South Burlington, VT
    335i
    04-12-2012 01:04 PM #422
    Quote Originally Posted by arethirdytwo View Post
    I went to a single 80a fuse and a Stinger 80a relay. LOVE IT. Cleans things up as well. may help ya'll with two compressors.
    This is my favorite way to go about this for sure.
    - Call us at: 802 . 735 . 2574 - Email us at: sales@bagriders.com - - // - - We're open: Monday - Friday 9:00 - 5:00 Eastern -
  3. Member alankitzmiller's Avatar
    Apr 14th, 2009
    Olive Garden
    black blob
    04-12-2012 01:10 PM #423
    Quote Originally Posted by cmcelroy09 View Post
    Any possible way to take the controller apart to clean it ? There has been something under the screen of mine since day one and it's starting to bug me.
    If you get this can you send it to me too? I asked a couple days ago too but no answer
  4. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    04-12-2012 01:44 PM #424
    Quote Originally Posted by VR6VR6 View Post
    And i am telling you that a 30 amp fuse is NOT LARGE ENOUGH. I do electrical designs as well as my air and fluid mechanics for work and i am guaranteeing that a 30A will not be enough in 99% of all cases mentioned here unless you do something to consistently keep the voltage output in the trunk at 13.8V
  5. Member VR6VR6's Avatar
    Oct 10th, 2008
    Scottsboro, AL
    04-12-2012 02:09 PM #425
    So you're recommending I change to 40amp fuses?
    I appreciate the help. I realize you know more about this than I do.. I was just making sure I was being clear about my setup
    Its odd they would send 30amp fuses with the kit if 30amp fuses aren't adequate.
  6. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    04-12-2012 02:29 PM #426
    Yeah no worries. I would definitely recommend a 40A fuse.
    What size of wire are you running to the back? Did you just run a single wire and then branch it off to each relay in the trunk?
  7. Member choey's Avatar
    Feb 10th, 2007
    All over Eastern PA
    Bagged GTI
    04-12-2012 02:36 PM #427
    Every now and then if I leave my car at height when I park it. I come out and it shows the front right bag has 250 psi in and when I hit the preset again it let's out some air not sure if it really has that much psi in it or it's just something whacked when I turn it on. The front right doesn't look like it is raised up
    @gtijoey
  8. Member arethirdytwo's Avatar
    Apr 4th, 2007
    Austin, TX
    '07 335i Sedan, '04 R32, '82 300D, '95 Jetta
    04-12-2012 03:05 PM #428
    This
    http://www.ebay.com/itm/270698355540...84.m1439.l2649
    And an 80a inline to feed it and you will be much happier.
  9. Member VR6VR6's Avatar
    Oct 10th, 2008
    Scottsboro, AL
    04-12-2012 04:03 PM #429
    Good deal.
    I had stereo equipment before I got air... so I just ditched the amp/sub and used the 8 gauge power and ground I had. I then split that into two 10g that go to the relays. The connections are all soldered and wrapped with shrink tubing. Everything is nice and clean.
    Thanks for your help.
    This
    I may swap to this soon.
  10. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    04-12-2012 04:06 PM #430
    8 gauge should work, just don't plan on running a big system too and you should be fine. I love when people solder and heat shrink, makes it just that much nicer looking
  11. Member VR6VR6's Avatar
    Oct 10th, 2008
    Scottsboro, AL
    04-12-2012 04:22 PM #431
    I'm 27 and I didn't know how to solder. My dad and I pulled all the wiring out, did some trimming, wrapped in wire loom. He taught me how to solder and use the shrink tubing. It felt awesome... my dad and I haven't always been close but we're closer than ever. Glad my VW can bring us together!
  12. Member cmcelroy09's Avatar
    Oct 11th, 2010
    bagged mk4
    04-12-2012 07:44 PM #432
    Quote Originally Posted by alankitzmiller View Post
    Sure thing
    8V Society #352
  13. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    04-12-2012 08:06 PM #433
    A real love story
    Same thing for me except it started when i was 6 years old
  14. Member Rat4Life's Avatar
    Oct 13th, 2004
    Fair Lawn, NJ
    lada 2101,rx7,bmw 318i,87 golf gt,93 1.8t two tone,01 flat blue mk4,02 gti 1.8t. 1JZ e21 in works
    04-12-2012 09:47 PM #434
    Quote Originally Posted by choey View Post
    hey Joe, i remember when you were picking car up it did that once too, i think you need to contact guys at bagridersor or airlift directly and see if they could exchange your valve block/ecu. from 5 or so v2's that i have installed before yours that was the first time i saw something like that.
    i think its a faulty pressure sender inside that block for the right front,because pressure in the bag stays the same, its the reading is going off limit.
    Complete air ride installs,frame notching,welding, in north jersey.
    http://www.flickr.com/photos/rat4life/
    roll cages,race rally preps in upstate new york http://www.rktmotors.com/Gallery.html
    follow me on instagram RAT4LIFE
  15. Member choey's Avatar
    Feb 10th, 2007
    All over Eastern PA
    Bagged GTI
    04-13-2012 02:32 AM #435
    Quote Originally Posted by Rat4Life View Post
    Yeah I'm going to get in contact with airlift. It happened tonight after airing up it showed about 70psi in the front right then I was driving looked down and it was at 250 lol I hit my preset it didn't let any air or add any just corrected the pressure back to 70
    @gtijoey
  16. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    2007 GLI (SOLD) / 2010 Pressurized GTI
    04-13-2012 10:47 AM #436
    your first issue is riding at 70 psi.
  17. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    04-13-2012 10:52 AM #437
    I just want to throw out an idea here, it might be the internal wiring for the pressure sensor. Most pressure sensors have a built in fault to read max pressure when the power is disconnected from it instead of reading 0. It is for the fact that it will set off a question in the users head that something might be overpressurized and to check the system rather than to just assume it is zero and not pressurized and they will just fix it later.
  18. Member choey's Avatar
    Feb 10th, 2007
    All over Eastern PA
    Bagged GTI
    04-13-2012 11:07 AM #438
    Quote Originally Posted by Squirrel Nuts View Post
    you're first issue is riding at 70 psi.
    Lol i just got it still got to get used to it and find the perfect height! Plus the roads were I work are terrible!
    @gtijoey
  19. Member choey's Avatar
    Feb 10th, 2007
    All over Eastern PA
    Bagged GTI
    04-13-2012 11:08 AM #439
    Good to know, but yesterday when I was driving after seeing at 70 when I started it shot all the way up to 250 out of no whwre
    @gtijoey
  20. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    04-13-2012 11:12 AM #440
    Precisely. That means that the power wire is probably loose on the sensor. It doesn't change the pressure, just when that power wire is disconnected it shoots up to 250 (max pressure) and then when the power wire reconnects itself it reads properly again
  21. Member choey's Avatar
    Feb 10th, 2007
    All over Eastern PA
    Bagged GTI
    04-13-2012 12:19 PM #441
    Snapped a picture while driving it doesn't dump any air when I hit the preset just corrects the pressure
    @gtijoey
  22. Member choey's Avatar
    Feb 10th, 2007
    All over Eastern PA
    Bagged GTI
    04-13-2012 12:28 PM #442
    I talked to the guys at airlift he said it seems like the sensor is bad. He was going to talk to another engineer and then call me back. Thanks for explaining that for me how that works
    @gtijoey
  23. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    04-13-2012 01:44 PM #443
    Is that peeling on the top by the third preset button?
  24. 04-13-2012 08:40 PM #444
    was wondering the same thing
  25. Member choey's Avatar
    Feb 10th, 2007
    All over Eastern PA
    Bagged GTI
    04-13-2012 10:27 PM #445
    nope just **** from the fresh lottery tickets I scratched right before the picture lol
    But air lift is replacing the manifold its due to a faulty pressure sensor.
    @gtijoey
  26. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    04-15-2012 05:51 PM #446
    Put mine in yesterday, like it very much so far. One thing I noticed is my ride height psi's are different than they were on my v1. I'm assuming that's normal?
    Either way, simple to use, simple to install. A+ grade on my side, great product from Air Lift. Only thing that worries me is how easy it would be to hit the all don preset mistakenly while driving instead of hitting another one. I put it as far away from the other presets as possible just to give me peace of mind.
  27. Member choey's Avatar
    Feb 10th, 2007
    All over Eastern PA
    Bagged GTI
    04-15-2012 06:31 PM #447
    i put mine at the 8 preset and dont worry you gota double tap anyway
    @gtijoey
  28. Banned SoIAteAPancakeToday's Avatar
    Apr 21st, 2009
    mexico
    cheby
    04-15-2012 07:02 PM #448
    I did that once already I caught it before it dumped completely out.
  29. Member VR6VR6's Avatar
    Oct 10th, 2008
    Scottsboro, AL
    04-15-2012 11:01 PM #449
    Quote Originally Posted by SoIAteAPancakeToday View Post
    I got to 0,0,0,0 going 65mph once. OOPS
  30. Banned SoIAteAPancakeToday's Avatar
    Apr 21st, 2009
    mexico
    cheby
    04-15-2012 11:02 PM #450
    ouch, im on steelies so i can still roll aired out, probably terrible for my drivers side axle though.
  31. Member VR6VR6's Avatar
    Oct 10th, 2008
    Scottsboro, AL
    04-15-2012 11:06 PM #451
    I'm rocking my oe monte carlos right now so samesies.. and yes poor axle. lol
  32. Member Dutchmastr9's Avatar
    Sep 13th, 2004
    Boston
    2 Door bugatti coupe...er, i mean Golf Racecar
    04-16-2012 02:39 PM #452
    got my v2 installed this weekend. I like it alot. very cool little system.
    You Aint About That Life | ETYolo
    Ruined Blue Golf | 42 Draft Designs
    Buy My Autopilot V2
  33. Member alankitzmiller's Avatar
    Apr 14th, 2009
    Olive Garden
    black blob
    04-16-2012 04:15 PM #453
    I don't even put the two together that the one fuzzy did was yours. Looks like it was put together nicely
  34. Member Dutchmastr9's Avatar
    Sep 13th, 2004
    Boston
    04-16-2012 04:33 PM #454
    yup fuzzy and jon did the install. they did an awesome job
    Buy My Autopilot V2
  35. Member choey's Avatar
    Feb 10th, 2007
    All over Eastern PA
    Bagged GTI
    04-17-2012 09:19 PM #455
    Any one know what this L is under the left rear number. I don't have my Manuel so I can look it up at the moment
    @gtijoey
Tags for this Thread
