Page 15 of 26 FirstFirst ... 5 11 12 13 14 15 16 17 18 19 25 ... LastLast
Results 491 to 525 of 885
Thread: What's the deal with the AutoPilot v2??
  1. Banner Advertiser Andrew@ORT's Avatar
    Nov 23rd, 2008
    Malvern, PA
    coal powered torque monster.
    04-26-2012 09:52 AM #491
  2. 04-26-2012 09:55 AM #492
    Quote Originally Posted by bryangb View Post
    Is there a specific email I can contact?
    jhart@airliftcompany.com
  3. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    2007 GLI (SOLD) / 2010 Pressurized GTI
    04-26-2012 10:53 AM #493
    Lately, my compressor kicking on whenever I fill the bags with any amount of air has become annoying. I have max/min set at 150/110 but the tank never gets that low.
    Example: I'm at ride height and the tank is at 150psi. I put some air in the front bags to get over a speed bump which drops the tank to 140psi. The compressor turns on even though it's no where close to the 110 minimum.
    I'm guessing it's a problem with my manifold? Two of my friends are wired the exact same as me and do not have this issue so I don't think it's a problem on my end.
    Thankfully I have yet to experience this. Only thing is the compressor will turn on after I turn the car on even if the tank is at like 135 psi (I have the minimum set to 120). I think this was discussed a few pages back as well.
  4. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    04-26-2012 06:21 PM #494
    Forget what I said. Just saw it happen first hand.
  5. Member vdubb3dan's Avatar
    Apr 7th, 2004
    Scranton PA
    Bagged B5.5 1.8T/81 rabbit diesel/tons of B3's
    04-26-2012 07:45 PM #495
    Same with mine on the compressor. Also having an issue when airing the rear out. It will let down to 30 psi where I have it set, and then continue down to zero, air back up to ride height(42psi), back down to 30. I've been shutting the car off when it hits 30 the first time, but it's getting kind of annoying. Anyone else experience this?
  6. Member luke wl.'s Avatar
    Feb 16th, 2010
    Boulder, Co
    2012 Golf R
    04-26-2012 10:57 PM #496
    Dan, run thru the calibration again that should solve that.
  7. Member vdubb3dan's Avatar
    Apr 7th, 2004
    Scranton PA
    04-26-2012 11:13 PM #497
    Tried it a couple of times, and same scenario.
  8. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    04-27-2012 01:20 AM #498
    My only thought is the pressure sensor refresh rate through the ECU is too jumpy or not filtered enough (too high or low a refresh rate) that it senses a sudden jump in pressure and kicks on the compressor because it thinks there is a big leak in the tank or something.
    I think Airlift might need to do a small software upgrade on these initial units if that is the problem.
  9. Banned SoIAteAPancakeToday's Avatar
    Apr 21st, 2009
    mexico
    cheby
    04-27-2012 05:32 AM #499
    Quote Originally Posted by MechEngg View Post
    probably but its going to blow having to send my manifold in especially since i have to drive my car every day :/ ill just ride it out
  10. Member
    Jan 4th, 2012
    Italy
    04-27-2012 07:23 AM #500
    Hope not to have the same problem once I finish installing the bags. Although I opted for a kill switch so I can turn the compressor off when I don't want it on.
  11. Banner Advertiser Andrew@ORT's Avatar
    Nov 23rd, 2008
    Malvern, PA
    04-27-2012 10:34 AM #501
    Quote Originally Posted by vdubb3dan View Post
    Contact Jeremy at AirLift directly for tech support // jhart@airliftcompany.com
  12. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    04-27-2012 11:00 AM #502
    Quote Originally Posted by SoIAteAPancakeToday View Post
    this. car's my daily so it'd be tough to not have it.
  13. Member luke wl.'s Avatar
    Feb 16th, 2010
    Boulder, Co
    2012 Golf R
    04-27-2012 12:48 PM #503
    Jeremy sent me out a new manifold with a return shipping paid box for my old one... Can't speak highly enough about dealing with him/airlift. They are going to diagnose my manifold so hopefully it will solve this for everyone.
  14. Banner Advertiser Andrew@ORT's Avatar
    Nov 23rd, 2008
    Malvern, PA
    04-27-2012 02:12 PM #504
    Quote Originally Posted by luke wl. View Post
  15. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    04-27-2012 02:47 PM #505
    Sick!
    Air Lift.
  16. Member
    Apr 28th, 2004
    Allyn, WA
    03 Audi a4
    04-29-2012 11:03 AM #506
    So I just installed my air-ride last weekend (Airlift components all around) and I'm having problems getting my Presets to work. The system works fine in manual mode, but when I try to get it to hit presets it won't. It only gives me the "STOPPED / FAILED" message. If I fill the bags and then hit a preset it will air down to them, but it won't fill up to them from when I'm parked.
    oh herro.
  17. Member tmg1991's Avatar
    Jan 19th, 2011
    Dover, DE
    Bagged GTI
    04-29-2012 04:03 PM #507
    You calibrate it?
    Instagram: trevorgrimes
  18. Member
    Apr 28th, 2004
    Allyn, WA
    03 Audi a4
    04-29-2012 04:09 PM #508
    Quote Originally Posted by tmg1991 View Post
    You calibrate it?
    Yeah, I've ran the calibration a couple of times. I'm gonna read back through all the manuals and see if maybe I missed something.
    oh herro.
  19. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    South Burlington, VT
    335i
    04-29-2012 05:10 PM #509
    Quote Originally Posted by wRek View Post
    Give us a call on Monday, we might be able to help out
    - Call us at: 802 . 735 . 2574 - Email us at: sales@bagriders.com - - // - - We're open: Monday - Friday 9:00 - 5:00 Eastern -
  20. Member
    Apr 28th, 2004
    Allyn, WA
    03 Audi a4
    04-29-2012 07:26 PM #510
    Quote Originally Posted by Will@BagRiders View Post
    I really appreciate it, I think because of time zones I may not be able to call while I'm around my car. I work 7am -4pm west coast time. But I will try to call anyway and maybe you can talk me through it. I'm not allowed to bring my cell phone to work because I have a camera phone, so I'll have to see if I can call from a work phone.
    Thanks again.
    oh herro.
  21. Member DRedman45's Avatar
    Aug 7th, 2009
    NOVA
    07 SB Rabbit(sold), 10 UG 4dr GTI(sold), e86 //M coupe
    04-30-2012 07:44 PM #511
    I hope these issues are cleared up this time next year when I am shopping
  22. Member
    Apr 28th, 2004
    Allyn, WA
    03 Audi a4
    05-01-2012 11:31 PM #512
    My problem is still unresolved. I've re-read the manuals and run the calibration multiple times. My car will air down to presets but won't air up to presets.
    oh herro.
  23. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    335i
    05-01-2012 11:43 PM #513
    Give us a call tomorrow morning. We can help you out.
  24. Member GolfL's Avatar
    Apr 7th, 2012
    MKV GTI Edition 30 DSG
    05-03-2012 10:34 AM #514
    Strange, the one we have on our shop van doesn't do that. I'm going to check in with Air Lift to see if they're aware of this.
    Will, did you had any reply from Airlift about this ? (flickering of the screen)
  25. Member VR6VR6's Avatar
    Oct 10th, 2008
    Scottsboro, AL
    lurking hours > post count
    05-04-2012 09:21 AM #515
    Does the V2 manifold have to be mounted upright or can it be mounted on its side?
  26. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    05-04-2012 09:37 AM #516
    Quote Originally Posted by VR6VR6 View Post
    It can be mounted both ways I believe.
  27. Member
    Apr 28th, 2004
    Allyn, WA
    03 Audi a4
    05-04-2012 09:52 PM #517
    Sorry for not calling yet, I've had a really busy work week and found out today that I'm working all weekend too. I work on a base and can't have a camera phone at work, and where I work I don't get service anyway so I just leave my phone in my car during the day.
    oh herro.
  28. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    335i
    05-04-2012 10:33 PM #518
    You've got a PM
  29. Member
    Apr 28th, 2004
    Allyn, WA
    03 Audi a4
    05-06-2012 10:50 AM #519
    You've got a PM
    I got a PM from you, but when I open it there is no content.
    oh herro.
  30. Member bryangb's Avatar
    Jun 16th, 2010
    Hanover, PA
    '08 GTI, '12 Beetle, '91 Passat
    05-06-2012 09:02 PM #520
    Doesn't matter
    // DROP // DRAG // DESTROY // beer
    // Open Road Tuning
    Instagram: @bryangb
    bags and wheels = build thread
  31. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    335i
    05-07-2012 07:41 AM #521
    Sorry about that, I'll resend it.
  32. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    05-24-2012 11:51 AM #522
    While at SOWO, Air Lift had the new software update done to my V2 management. Fixed the issue where compressor will turn on when you turn the key even if the tank is just about full. Only thing it didn't fix was airing the car up to ride height after the car sits, the compressor will still turn on even if it doesn't get below my tank minimum.
    My only complaint was after all this, my right front bag was leaking the entire trip home. Thought maybe I needed to cut the ends of the airline and reinsert into the manifold. Front right bag still leaks a tad from what I see and my rear has a nice leak on it now. Leaving on a business trip until next month so I'll probably deal with that headache when I get back.
  33. Member choey's Avatar
    Feb 10th, 2007
    All over Eastern PA
    Bagged GTI
    05-24-2012 12:11 PM #523
    Yeah mine always runs when I turn my car on. It started happening ALL the time once my 2nd compressor was added
    @gtijoey
  34. Member Dutchmastr9's Avatar
    Sep 13th, 2004
    Boston
    2 Door bugatti coupe...er, i mean Golf Racecar
    05-24-2012 12:27 PM #524
    Quote Originally Posted by choey View Post
    what relay do you have?
    You Aint About That Life | ETYolo
    Ruined Blue Golf | 42 Draft Designs
  35. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    05-24-2012 12:35 PM #525
    The new update gets rid of that issue. I haven't had the compressors kick on with the key once since Jeff updated it. I've just been dealing with the leaks.
Tags for this Thread
