#528
#529
I have a shipping label to ship my manifold to Airlift to be reprogrammed. I've just been lazy
Next week I'll probably send it out so I can have the car drive able for the weekend. Hopefully it fixes my issue of the compressor kicking on all the time![]()
// DROP // DRAG // DESTROY // beer
// Open Road Tuning
Instagram: @bryangb
bags and wheels = build thread
#530
#531
I may have to look into this more I just got a replacement manifold from them a month ago and I'm not sure if it's updated or not
@gtijoey
#532
// Open Road Tuning
Instagram: @bryangb
#534
- Call us at: 802 . 735 . 2574 - Email us at: sales@bagriders.com - - // - - We're open: Monday - Friday 9:00 - 5:00 Eastern -
#535
#537
Does the V2 turn off automatically the compressor if the battery drops to a critical voltage? Sometimes I have the compressor running with the engine turned off...
#538
#540
I did, but you can have the key in key-on position even with the motor turned off...
#541
If you let it run long enough of course it will kill the battery
// Open Road Tuning
Instagram: @bryangb
#542
Yes, I know. But I also know that accuair turns the compressor off if the battery reaches a critical voltage. I just wanted to know if the V2 acts the same way...
#543
for two 440s to drain your battery enough to not start they will have to inflate more than a 7 gallon tank from 0 to 150 and yu can get away with that... regardless there is no need to have them run that long ive used mine for a while like that when i was testing the system out and checking for leaks... you can always buy a yellow topi just bought mine
#544
#545
So if I wire the v2 to a non constant wire it will turn off and stay off compressors and all, without randomly kicking back on on the garage?
Or better yet what has to be done to ensure the compressors aren't draining my 280$ Odyssey fmj battery? Install an inline kill switch for both compressors, that I can just flip off when the display shows the tank full?
#546
Correct. I'm not sure any other way you would want it run, or if the install manual tells you otherwise. Running the compressor to a constant power seems like a great way to cause an issue down the line as it can run and run and run when you don't need it to or if you aren't around (premature failure). Either have a hand switch to turn it off if it is on constant power feed (more effort to remember to turn it off all the time) or just run it to a switched power so it will never accidentally run (possibly constantly if you have a leak) in your garage. This is a basic automotive thing, but just applies to this instance of air ride and not specific to only the V2 system.
Will, just ordered up some front bags last night for the project. Thanks man![]()
#547
And the ecu will be fine wired to a switched power source? As in presets and settings I mean.
#548
You sure about this? With my 3 OB2's running it takes maybe 20 seconds for my battery to reach critical level, and the OB2's are more efficient at filling tanks (yes i realize they draw more amperage yada yada but in total they take less battery power to fill up X gallons)
#550
If your car is idling while you fill the tank you will not reach critical level with a stock alternator (90 or 120A) UNLESS you are running 2/3 OB2's. With 2 OB2's you will need at least a 120A alternator. With 3 i would recommend a 250A running/150A idle alternator.
#552
Yup you are fine filling up your tanks at idle with 480's
Another thing that should be brought up here while we are talking about it is running your compressors with your car off. These compressors SHOULD be run at 13.8V, the closer you get to that magic number the less stress you are putting on the motors and the longer they will last you. If you are constantly running your compressors with your car off you will be running them from 12V, perhaps down to 11V depending on how long the compressors run for.
Lower voltage = higher amperage = higher heat = overheating of compressors = motor failure/mechanical siezing
I NEVER run my compressors with my car off![]()
#554
yea im positive it never happened to me for the 1st few weekends that i would empty and refill the tank with the car in the on position and not have it running, while i checked for leaks i now have yellow top so i dont even worry anymore. and what do you call critical level?
two compressors at 30 amps is like running two 30 amp music amplifiers with the car off and you can run the music for a while let alone the 40 something second it should take to get from 110 to 150
hope this helps![]()
#555
#556
Have any of you guys had fuses being blown for the compressors? My 2nd 444 seams to keep blowing every few days, its wired up correctly as per wiring diagram!
#557
#558
Wish someone would respond to my issues. Everyone keeps telling me that Air lift has such great customer service but so far 2 days with no response. Looks like Ill send another email.
Anyone here have any issues where you set your preset pressures but the system never goes to it? For example one preset is 45 45 35 35 but when i press it goes to like 47 58 29 36 and says complete. I have recalibarated like 80x now and still same issue. Any thoughts?
#559
Instagram: @VinnyGarofoli
#560
// Open Road Tuning
Instagram: @bryangb
