Results 36 to 70 of 88
Thread: Hello all
  1. Member V4310W's Avatar
    Nov 18th, 2011
    Wilsonville, OR
    1993 Corrado VR6, 1991 Sentra
    01-12-2012 02:04 PM #36
    Got some more done the last few days. New flywheel, clutch and pressure plate installed Photobucket
    Photobucket
    Got the transmission bolted on. Talk about a project And a half...Photobucket
    Photobucket
    Hopefully today we can get the axles back in, transmission support bracket, starter and thermostat installed.
  2. Member V4310W's Avatar
    Nov 18th, 2011
    Wilsonville, OR
    01-15-2012 11:07 PM #37
    Made some more progress the last few days. Put the new crack pipe and thermostat housing in. The crack pipe looks sharp; too bad it is invisible with the car fully assembled.
    Photobucket
    Got the starter back in and changed the oil pan gasket today. Also put the intake manifold back on today. Photobucket
    In the process of putting the transmission back in I bumped a wire and the end fell to the floor with a piece of electrical tape on the end. Instead of doing it properly the PO just taped the two ends together Needless to say we redid that wire properly. I think the intake manifold looks pretty cool polished up next to the polished portions of the valve cover
    Photobucket
    Anyway hoping to complete the project this week
  3. Member V4310W's Avatar
    Nov 18th, 2011
    Wilsonville, OR
    01-29-2012 04:53 AM #38
    Its been awhile since I last posted. I had a pretty gnarly case of bronchitis and was sidelined for almost a week. Anyhow I got everything assembled and fired her up. The engine sounds great but when I take my foot off the clutch I get some grinding sounds. Not 100% sure what it is but its not right so the transmission will be coming back out to search for the cause of the problem. Since I'll be doing this I want to replace anything that might be causing the problem. The throwout bearing is new but I want to put a new one in. Thinking about doing a new clutch fork also. What else is worth doing? I want to eliminate as many variables as possible to reduce chances of having to take it out a third time. This has been quite a letdown but I'm glad to have found out now rather than having it go bad on the road. And the part I was most worried about (chains/timing) sounds great so there is some good news despite the bad. Does anyone have experience with the 13 lb flywheel from MJM? I've read some mixed reviews about lightened flywheels and am considering putting the old one back on. Any and all input/insight is appreciated
  4. Member V4310W's Avatar
    Nov 18th, 2011
    Wilsonville, OR
    02-01-2012 11:35 PM #39
    Pulled the transmission back out today and it appears that the rivet things on the pressure plate are rubbing on the transmission once the clutch is disengaged
    So the question now is why is there contact? The new flywheel appears to be thicker than the one I took off ). Is my assumption that this added width makes the plate that much closer to the transmission? I'm going to take everything off and measure and weigh everything and probably wind up with the original flywheel back on (I have a feeling that the new flywheel is actually heavier than the one i took off f not then maybe some grinding of the rivets and and/or transmission to allow clearance but I'd prefer to not go that route. More disassembling tomorrow and comparing new and old parts tomorrow.
  5. Member V4310W's Avatar
    Nov 18th, 2011
    Wilsonville, OR
    02-26-2012 09:24 PM #40
    I figure its time for a quick update. Finished the chains/clutch project a few weeks ago. I saved the broken pieces that I found while doing the chains. This piece I have no idea where it originated
    This is from the upper tensioner; completely separated from the tensioner rail
    This is the upper guide rail. Wasn't a cause for any noises but very close to completely failing
    Some lovely gifts from previous owners:
    Coolant pipe cut and put back together using pipe and hose clamps
    Wires split and put back together using electrical tape
    I ordered clear turn signals in October and they finally came 2 weeks ago. I wasn't aware that slc's came with them stock and was disappointed when they didn't fit in my bumper so I ordered some French fogs and trimmed the holes to make the social foglight assemblies fit. I also got a better grill than the one that came with the car. I love the look. Before:
    After:
    My next project is to get this fixed and get a new paint job
    Some smaller goals in the meantime are to replace broken drivers door handle (the lock cylinder broke), put the new sunroof in, carpet the trunk and undelete the rear VW badge. I hope that you are having a super awesome day! Until next time
  6. Member vdub_n's Avatar
    May 23rd, 2004
    the dalles oregon
    1990 G60 Corrado , 2004 R32 (dead), 2006 Audi A4 Quattro
    02-27-2012 01:44 AM #41
    looking good man. keep it up..
    Have a Eastwood fender Roller FOR RENT
    My Corrado-Database
    SPOONFEDTUNING
  7. Member V4310W's Avatar
    Nov 18th, 2011
    Wilsonville, OR
    02-27-2012 07:51 AM #42
    Quote Originally Posted by vdub_n View Post
    Thank you fellow Oregonian
  8. Member V4310W's Avatar
    Nov 18th, 2011
    Wilsonville, OR
    04-11-2012 04:39 PM #43
    Last night I went to see Social Distortion so I have the day off and decided I'd take some time to update. I bought and installed an Autotech rear stress bar. Handling is much improved and I am very pleased with this addition.
    I also picked up a new steering wheel that I found on Craigslist. Nothing was wrong with the other one but I wanted a different look.
    Ever since I bought this car I've tried to learn as much as I can about it and its engine. I read several times that the vr6 is a hot running engine and that, because of the heatsoaking that occurs, the intake filter I have doesn't make any improvements over the stock airbox. So I set out to make some sort of heatshield. I went to goodwill and found some plastic tray things and cut them up and this is what I came up with.
    Its not perfect by any means but I think it makes a small difference. Not being satisfied with that, I decided to add a hose to help feed fresher air.
    I fed it down next to the radiator and zip tied it to the tow hook.
    I received some new motor mounts a couple weeks ago so I'm waiting for some time to get them installed. Last weekend brought nice weather so I took the opportunity to wash and snap some pictures.
    That's all for now.
  9. Member V4310W's Avatar
    Nov 18th, 2011
    Wilsonville, OR
    04-30-2012 07:03 PM #44
    So I've been having some goofy idle issues since I finished doing my chains. At start up it will idle at 1500 rpm for a minute then drop down to 1000. And while driving about half the time I stop, as soon as I engage the clutch the rpms jump to 1500 for 20 seconds then drop down. I pulled the idle control valve to clean it and while cleaning it noticed that it was dripping out the bottom. Found a used one on Craigslist and picked that up, cleaned it and installed it. That helped but not the solution. After doing some research decided that the next course of action would be to try vacuum hoses and the coolant temp sensor. I put them in the other day and what do you know? Idling normal now This weekend I'm going on a cruise to the beach looking forward to seeing some cool cars. Now I need to start saving to get some body work done
  10. Member V4310W's Avatar
    Nov 18th, 2011
    Wilsonville, OR
    05-07-2012 10:24 PM #45
    This last Saturday I went on a cruise with a bunch of over VWs to the beach. It was a lot of fun, a great drive and the best news of all: the rado handled the 200+ mile day without a hitch. I didn't get many pics but I'll put up the few I did take.
    I also found this picture of my car from a cruise last summer. My water pump went out halfway through and started dumping coolant.
    I don't have anything else so
  11. Member V4310W's Avatar
    Nov 18th, 2011
    Wilsonville, OR
    07-29-2012 03:27 AM #46
    I've been doing some cosmetic stuff recently and thought I should share. Last summer some idiot(me) got a little spray paint crazy rattle canned my drivers rear quarter panel . Needless to say it turned out like bloody monkey vomit so I decided to try to fix it. I forgot to take before pictures but I got some during and after. I wet sanded for what seemed like days
    Wet sanded and washed
    Meguiar's ultimate compound is an incredible product. This is after one application
    Final product
    My passenger door has a large piece of body putty near the hinge so I picked up a used one in green and have been working at getting it black and doing it better than the previously mentioned bloody monkey vomit paint job.
    I think it just needs a good buffing and it will be close to matching the rest of the car. Its not perfect but it'll do until I get a respray. I was prowling through pick-n-pull the other day and came across a Passat with a center visor so I yanked it and brought it home.
    I also came across a photo of my first ride, or what was left of it. She was an awesome 1986 Golf named the Mayflower. A lady in an uninsured bmw pulled out in front of me and I t-boned her going 50. Not a good day but this was my first vw experience and got me hooked.
    That's all for now. Tata
  12. Member V4310W's Avatar
    Nov 18th, 2011
    Wilsonville, OR
    10-15-2012 02:21 AM #47
    I am horrible at posting in this regularly. I've had a busy month upgrading some of my lighting. I ordered a set of DDI gauges in December and never received them. After some angry emails I finally received them in September. My point in this is not to bad mouth DDI, because the situation has been rectified. Long story short, I installed them and am very pleased with them.
    I was sent what I believe to be the UK gauges, but after the headache it was just to receive them, I decided to just use them instead of trying to return them.
    In late August a local pick-n-pull received a Corrado, so I went down to see what kind of goodies I could find. It was pretty well picked over but still had all the tail lights in near mint condition. It just happened to be half-off weekend so I scored all 4 for $40. I liked the smoked look for a while, but I'm over it now and dig the stock tails.
    I found a DIY on the CCC site on how to activate the rear fog lights. I modified the instructions some and turned them into an extra set of brake lights. I hope these lower my chances of being a rear ending target.
    Just tails:
    Brake lights:
    Now for my favorite I picked up a set of French style e-codes. I had to order new bezels and lenses to change to vr6, and the wait was unbearable. I also decided to tint inside the lights.
    I purchased a relayed harness from Eurowires and it works wonderfully. However my brights and lows are opposite from the indicator light in the cluster. If that's the only issue, I can live with it. I'm still tinkering with the proper aiming, but I'm very pleased with this upgrade. I had some HID's in my stock headlights and its nice to not get brights flashed from every oncoming car.
    My next necessary upgrade is going to have to be fixing the poor wiper performance. I'm seeing the Lupo upgrade, but not sure if I can justify spending that money after the e-codes. I'm curious why the Lupo seems to be the only wipers to swap, and will be trying wiper arms from other cars to see if they fit or work any better than what I'm currently using. Living in rain country, wipers that work are a must. I think tying a dog to the roof and using its wagging tail would be as efficient, if not better, than the coverage I'm getting now.
    I ran across this picture on my parents computer and I believe that its the oldest I have/closest to how I purchased the car.
    Sometimes I think I haven't made any progress on my Frankenrado, but then I come across old pictures and am blown away at how different it looks. If you've made it through my novel with few pictures, I thank you for the attention. You deserve a high five. Sweet dreams
  13. Member RedYellowWhite's Avatar
    Apr 21st, 2008
    Limassol, CYPRUS (That's in Europe,lol)
    '90 Corrado 1.8 8V G60 (previously was 1.8 16V KR), '80 MK1 Golf GTI 1.6 8V EG aka "Heron"
    10-15-2012 09:55 AM #48
    French-spec headlights look good!!! Especially with the "Joey-mod"
    I hope you didn't pay too much for them, since its just a yellow cap inside that separates them from normal e-codes
    Quote Originally Posted by dogger View Post
    ... (Corrado) might be the greatest collection of bad VW ideas ever put into one car.
    My Corrado (sort of) build thread / On Database
    My MK1 build thread
    SpoonFedTuning
  14. Member V4310W's Avatar
    Nov 18th, 2011
    Wilsonville, OR
    10-15-2012 10:32 AM #49
    When I first learned of the French specs and began researching them I couldn't believe that people would pay close to $1,000 for these. That's the price I found them on ebay for anyway. I think I got a pretty good deal on them. With the lights and new bezels and lenses I'm still in for less than a set of brand new e-codes.
  15. Member RedYellowWhite's Avatar
    Apr 21st, 2008
    10-15-2012 12:25 PM #50
    Quote Originally Posted by V4310W View Post
    Yup, there are people who paid close to $1K basically for a set of $25 bulb caps
    My MK1 build thread
    SpoonFedTuning
  16. Member V4310W's Avatar
    Nov 18th, 2011
    Wilsonville, OR
    01-26-2013 02:11 AM #51
    Around Christmas I began losing coolant I couldn't find where it was coming from and first thought it was the head gasket. I finally diagnosed the leak to be the radiator and, thankfully, not the head gasket. Upon inspecting the head gasket though, it appears to be seeping some oil. So now I have me a winter project I've also been gathering other odds and ends that I will be doing at the same time.
    Dieselgeek short shift kit, shift cable bracket bushings, Grüven radiator neck, Autotech lower stress bar and BFI motor mounts.
    Head gasket kit
    And the tear down begins.
    Day 1:
    Day 2:
    Day 3 I forgot to take pictures but got all hoses, wiring and thermostat housing removed.
    Day 4:
  17. Member V4310W's Avatar
    Nov 18th, 2011
    Wilsonville, OR
    01-26-2013 02:50 AM #52
    Head gasket kit
    Day 1:
    Day 2:
    Day 4:
    I sent pictures to a friend who says it looks like cylinder 1 isn't burning all the fuel, causing it to look the way it does. He said it looks like a possible leaky injector. Can anyone confirm his suspicion? This is my first time ever having a motor apart this much and am in uncharted territory. I know the plug wire doesn't snap in as well as the others and kind of think that might be a factor, but again don't know a lot about this subject.
    Tomorrow will be spent cleaning the block and head, as well as doing the motor mounts while better accessibility is available. Until next time,
  18. 01-26-2013 05:59 AM #53
    That corrado has a great owner
    Very awesome work man, keep it up.
  19. Member mateok's Avatar
    Mar 14th, 2001
    Atlanta, GA
    90 G60(since new) 93 VR
    01-26-2013 06:47 AM #54
    Determine if its fuel or oil. Fuel could be from a leaky injector or any of the ignition sources for that cylinder.
    Oil would suggest a leaky valve guide seal.
    Those look remarkably good
  20. Member V4310W's Avatar
    Nov 18th, 2011
    Wilsonville, OR
    01-26-2013 09:59 PM #55
    Quote Originally Posted by blackslcchild View Post
    Why thank you. I have an inkling some idiots owned it before me, so I'm trying to treat it better
  21. Member dogger's Avatar
    Jul 29th, 2005
    Pasadena, CA
    1990 Corrado 2L 16V, 2004 Audi TT 3.2 Quattro S-Line
    01-26-2013 10:17 PM #56
    Must be interesting going 160mph when you are actually going 140mph
  22. Member V4310W's Avatar
    Nov 18th, 2011
    Wilsonville, OR
    01-26-2013 10:28 PM #57
    Quote Originally Posted by mateok View Post
    Maybe I'm too tired at the moment but what looks remarkably good?
    Spent most of today cleaning off some rtv type goop off the head. I didn't know the best way about that so I used a razor blade, carefully of course. I'm not sure how to attack the block though. It also has the goop that doesn't want to come off using a razor blade. I know it will withstand harsher abrasives than the head but I don't want to get debris in the passages and I haven't found a good way to block them while still leaving me room to clean.
    That's how I left it today. I took a break for some food and couldn't get motivated again to get back to work.
  23. Member V4310W's Avatar
    Nov 18th, 2011
    Wilsonville, OR
    01-26-2013 10:36 PM #58
    Haha yeah. I had such a nightmare actually receiving the kit that when I finally received the wrong ones I opted to just accept what I got and not try to exchange them. Just go with the flow of traffic and its not an issue
  24. Member crazynorweegian's Avatar
    May 8th, 2006
    Portland, OR
    1990 1.9L G60-ST5 Black, 02 S60 2.4t
    01-27-2013 12:49 AM #59
    Read through the whole thing. I was iffy at first but solid work! It looks way better. Did you try lacquer thinner on that spray paint?
    Stephen
    Portland, OR
    Black 1990 1.9L Stage 5 G60 - keeper
    Corrados decay in a way that can only be measured using quantum physics
    http://sites.google.com/site/corradoproject/
  25. Member V4310W's Avatar
    Nov 18th, 2011
    Wilsonville, OR
    01-27-2013 04:11 AM #60
    Quote Originally Posted by crazynorweegian View Post
    Thanks! I'm assuming you are referring to the driver's side quarter panel? No, that never occurred to me. Probably could have saved me some time. I wet sanded that for a good 8 hours to get back to original paint.
  26. Member dogger's Avatar
    Jul 29th, 2005
    Pasadena, CA
    01-27-2013 02:49 PM #61
    You can get your cluster programmed to 160mph. IM me and I can tell you who can do it.
  27. Member V4310W's Avatar
    Nov 18th, 2011
    Wilsonville, OR
    01-27-2013 07:35 PM #62
    Very interesting. I will pm you
  28. 01-27-2013 07:43 PM #63
    looks like your doing some werk...probably would have been easier to do headgasket, timing belt and waterpump the first time around.
    anyway keep up
  29. Member V4310W's Avatar
    Nov 18th, 2011
    Wilsonville, OR
    01-27-2013 07:52 PM #64
    Quote Originally Posted by hatemenow View Post
    anyway keep up
    At one point during the chains project I thought "The head gasket isn't much more work..." but I chose not to do it. I should have just done it. Oh well. I have something to occupy my time now
  30. 01-27-2013 08:35 PM #65
    Yes, same here man.
    I've found problems due to negligence.
  31. Member V4310W's Avatar
    Nov 18th, 2011
    Wilsonville, OR
    02-02-2013 02:19 AM #66
    I've been burning the candle at both ends between work and this project and haven't had any time for updates. So this rtv stuff was baked onto the block pretty good and it took some time to figure out how to get it off without it falling into the coolant passages and finally found some silicone dissolving stuff at napa which worked well in combination with a razor blade. This is what I started with :
    The dissolving stuff is really a weird substance and likes to move around and slide into holes so I tried plugging them with pencils but found my fingers too fat to work between them
    I ended up just leaving the holes open and spread the stuff as evenly as possible to keep it from sliding around. This is the end result
    My dad and I cleaned it further after this but I forgot to photograph this. We then were able to cut the heads off the longest bolts, thread them a little and use them as guides to lower the head onto the block and new mk4 metal head gasket.
    Yesterday I bolted and torqued the head down.
    Also put the guide rail, sprocket and chain back on. The timing marks I made lined back up no problem.
    That's as far as I've gotten. Since the weather improved today I want to pick-n-pull to get a couple wiring connectors. I've also been trying to figure out if my cams are stock or aftermarket. I can't find and vw markings but no other definitive markings of other brands either. I have had little luck trying to find out what cams have what markings. These are what markings are on mine:
    If anyone has more information I would greatly appreciate it. That is all for now
  32. Member Radvr6T's Avatar
    Jun 3rd, 2003
    Vancouver Canada
    1993 Corrado VRSEXT & The Daily Yoda 4runner
    02-02-2013 03:49 AM #67
    Great progress! loving this thread, great pics and love what you have done so far
  33. Member V4310W's Avatar
    Nov 18th, 2011
    Wilsonville, OR
    02-02-2013 06:03 AM #68
    Quote Originally Posted by Radvr6T View Post
    Thank you for the kind words
    I'm hoping to get it running this weekend but I'm sure I'll run into some sort of issue that prevents that from happening. That seems to be a theme for me
  34. Member Radvr6T's Avatar
    Jun 3rd, 2003
    Vancouver Canada
    02-02-2013 06:06 AM #69
    Never rush a good thing, you will be fine
    More pics forsure!
  35. Member V4310W's Avatar
    Nov 18th, 2011
    Wilsonville, OR
    02-03-2013 02:30 AM #70
    Today was productive for the short time I was able to work on my car. I got the exhaust bolted back on
    Upper timing chain cover and tensioner bolt back in place
    And the most important thing: I rotated the engine a few times and all the timing marks line up as they should
    Last year during my chains project, I over-torqued one of the valve cover bolts and snapped the stud off. I ran for a year with that stud unbolted but today I figured I would try to extract the remaining piece and replace it. With some vise grips it came out no problem.
    And lastly, I ran into the snag I was anticipating The hall sensor on my distributor is pretty mangled up. Last year I was able to glue it back in place somewhat, but in disassembly it broke back off. The wires are still connected but there is a little plate underneath the rotor that seems to be much too out of place. Researched a little and found a new ebay replacement for a lot less than a new Bosch piece. Placed an order and hopefully will receive it in a few days.
    Anyway, that's all I have for now. Won't get much done tomorrow as I'll be watching my 49ers win(hopefully) the super bowl. Enjoy the commercials
