Damn, sure looks pretty all put together like that. Thanks for supporting the 2.5L. I received my fuel rail the other day. Looks excellent.![]()
#1
This thread will serve as the IE 2.5L I5 product library that we continuously update with our new releases. This will make it easy for you guys to find what you are looking for and we wont be making new threads for every new product on this fast growing platform. Also, if anyone has any questions, comments, or suggestions please post them in here. We offer a huge inventory for VW/Audi and other makes including internals, valve train, fueling solutions, hardware, OEM parts, billet accessories, turbos, and much more. Not everything will make it into this thread, so if you dont see what you are looking for check www.intengineering.com or e-mail sales@intengineering.com
Valve Train
IE offers a huge selection of valve train parts for your 2.5L to help your 5 cylinder motor breath and rev harder.
Ferrea Intake Valves
Ferrea make's some of the finest quality valvetrain available and is trusted by the top racing teams around the world making them perfect for your 2.5L I5 project!
Complete sets of 10 available in standard size Order here
or
Complete set of 10 available in +1MM oversized Order here
Ferrea Super Alloy Exhaust Valves
Ferrea's Super Alloy valves are made from an extremely heat resistant alloy, that is specifically designed for forced induction and nitrous applications.
or
Complete sets of ten available in +1MM oversized Order here
Integrated Engineering 2.5L 5CYL Spring/Retainer Kits
Integrated Engineering spring kits for 2.5L 5CYL engines are performance tested kits featuring aircraft grade titanium in-house CNC'd retainers to exacting tolerances and surface finish requirements. Optimized to match your vehicle specifications and provide proper valve control under high revving applications, the springs are wound in the USA from the purest spring steel available in the world and nan-peened for incredible fatigue resistance. These are engineered for the wildest setups, and tested to perform with long life and reliability.
Sold as a complete set of high performance valve springs and titanium retainersOrder here
Ferrea Valve Spring and Retainer Kit
Heavy duty valve springs will prevent valve float at higher rpm. Titanium retainers will help keep the weight down, while providing extra strength. Valve springs and retainers are a MUST for high revving engines!
Sold as a complete set of high performance valve springs, and titanium retainers. Order here
Integrated Engineering Valve Guides
It is always a great idea to replace your valve guides when doing a cylinder head build. These valve guides are made in house on our CNC lathe, using a proprietary bronze alloy. This alloy allows for 10% faster heat transfer, as well as better wear characteristics to make for a longer life. We have designed these with an aerodynamic tip design to cut down on airflow restrictions in the port. These valve guides are made with ultra high concentricity for exact valve placement, with precisely sized outer diameters. Standard 2.5L 20V I5 Sized. Sold individually (20 required for MK5 2.5L 5 cylinder engines) Order here
Integrated Engineering 1.8T Valve Seats
Integrated Engineering valve seats are the performance option for replacing factory seats when doing your cylinder head build. In high revving performance head builds, factory seats are prone to excessive wear resulting in premature valve failures. To combat these issues our valve seats are made from a specialized alloy on our in house CNC lathe for dimensional accuracy. Using a proprietary bronze alloy results in faster heat dissipation where thermal conductivity is increased by 10% and extends valve life, seat erosion, and cylinder head component life. More info here
Bottom End
IE offers everything you need to build a strong short block. Everything for all motor or all out forced induction builds, we have what you need with much more coming!
Integrated Engineering H-Beam Connecting Rods
Integrated Engineering is proud to manufacture the highest quality connecting rods available for European applications, at a reasonable price. This is accomplished through careful design, manufacturing, and quality control processes. With hundreds and hundreds of sets of VW and Audi connecting rods in stock, we are your specialist supplier with the inventory and knowledge to make your project a success. Sold standard with ARP2000 bolts. Order here
JE Pistons
JE pistons are a great upgrade for someone looking to build a stout, reliable engine. They have 20mm wrist pins so they will require a set of rods with 20mm pins to match. They feature JE's 2618 alloy which is stronger then most other pistons made from 4032, and are specifically engineered for extreme applications. Custom pistons and coatings available to order.
JE 83MM Bore 8.5:1 CR 92.8mm stroke Orde here
JE 83MM Bore 11:1 CR 92.8mm stroke Order here
SPA T3 Turbo Manifold
This is a high quality SPA Turbo cast iron turbo manifold, these are cast in their own foundry, and thoroughly tested in real world driving conditions. It features a T3 flange, so it can be used with a T3 or T3/T4 turbo. It also has a 2-bolt wastegate flange, for use with 38MM wastegates. Order here
Billet Accessories
Integrated Engineerings billet accessories for your I5 engine are designed, machined, and tested in house. Designed with meticulous detail and machined from the highest quality materials you are ensured to have a exact fit and beautiful finish.
SAI Blockoff Plate Kit
These plates allow the removal of the entire secondary air injection/combi valve system, including the large injection pump on the front of the engine. This results in a much cleaner looking engine bay and less clutter. CNC machined 6061 aluminum alloy, and designed to accept an O ring seal, complete with our aerospace grade Viton O ring, and stainless steel bolts. Order here
External Oil Cooler Adapter Plate Kit
This kit will allow you to remove your factory oil cooler and replace it with a more efficient external oil cooler. These are a direct fit onto the OEM oil filter housing using the included stainless steel mounting bolts. These billet adapter plates are made in house from 6061 aluminum, and completed with a red anodized finish. The inlet/outlet holes on the plate are tapped for -8an o-ring boss fittings. Take care of your oil temps today with this quality piece! Order here
Billet Fuel Rail
These are made in house from a solid piece of 6061 aircraft aluminum, to provide a beautiful, high flowing piece. These rails have mount tabs that use factory screws to attach to your intake manifold. These feature -8an O-ring boss ports, which will be enough flow for even the most wild setups. There is no need to worry about injectors coming out either, as these rails retain the factory injector clips for added safety. The clips install at the same angle as the factory fuel rail, to maintain the factory injector angle. Available in IE red or aluminum raw finish Order here
Billet Fuel Rail Install Kit
These are assembled in house for a perfect fit and shipped as a complete install solution when using our billet fuel rail. This kit features everything needed to install, including stainless steel braided fuel line wrapped in nylon so it wont chew through any engine components, -08AN boss O-ring to -6 rail fitting, -08AN O-ring plug, two 90 degree -6AN fittings, and a -6AN adapter fitting . The fuel line comes pre-assembled for easy install, and features a easy press on fitting to install onto the stock fuel line so you don't have to cut or modify the factory fuel system in any way. Order here
Billet Cam Locking Tool
This tool holds the cams at TDC while you work on the engine, so there is no possibility for timing errors. Made in house on our CNC mill from 6061 aluminum and finished in IE Red anodize. Order here
Boost Tap - Installing a boost gauge or just need a vacuum source? Our FSI/TSI boost taps will make this a breeze. They are offered in black or red anodize and included all necessary hardware. Also included is an OEM retaining clip that eliminates the "kickstand" feature of other designs. For more info CLICK HERE.
Boost Cap - If you plan on removing the factory PCV system, you will need one these. One useful feature of the IE boost cap is that it doubles as a tap and provide you with a vacuum. The kit comes complete with "tap" or "cap" hardware. For more info CLICK HERE or see it installed in our MK5 valve cover install DIY.
Hardware and misc
We have a massive selection of bolts, washers, nuts, etc.. for both your 2.5L and universal applications. Not everything will make its way into here so check www.intengineering.com for a full list of parts.
ARP head stud kit
This is absolutely the highest quality head stud kit you can find. We are genuine ARP Distributors so buying from us guarantees you a valid warantee. This will ensure your head does not lift even under the most extreme boost conditions and is completely reusable, great for race engines. Order here
Integrated Engineering EKagrip 6 Bolt Flywheel Friction Disk
Originally designed for low horsepower, the 6 bolt flywheel interface struggles when subjected to serious power, this interface can become taxed and allow the flywheel to slip around under high torque. This leads to wear between the surfaces, and shortly thereafter complete failure of the bolts and joint. This ruins the flywheel and crankshaft, and can even damage the transmission bell housing. In order to fight this we had EKagrip make some of their patented nickel and diamond coated friction shims. These shims increase the friction between the two components by up to 3 times what is seen with regular steel on steel contact. This greatly increases the load which can be carried. The shims are .008" thick, and do not cause any alignment problems with the clutch / flywheel. Order here
IE engineWear Enthusiast Apparel
Integrated Engineering is proud to announce the release of our line of enthusiast apparel "engineWear". We will be adding many more T-shirts, hoodies, hats, keychains, etc.. in the future!
Boost In Session 2.5L 20V I5 T-shirt
Our very first engineWear high quality printed T-shirt has you 2.5L 5 cylinder owners in mind with a boosted 2.5L graphic under our "Spool is in session" catch phrase. This shirt is guaranteed to show off your love for the 2.5L platform and show off it's potential! Order here.
2.5L I5 Keychain
Show off your love for the 2.5L I5 with the engineWear stainless steel headgasket keychain! Order here.
This thread will continue to grow, so be sure to check back often to see whats new for your 2.5L 20V 5 Cylinder! As always, if you have any questions, comments, or suggestions feel free to post them or contact sales@intengineering.com Or for a complete look at all products offered through IE, check www.intengineering.com
Connecting rods . Forged Pistons . Valve train . Billet accessories
IntegratedEngineering - Performance you can measure
Questions or comments? Contact us: sales@intengineering.com
Get your free "Wallpaper Wednesday" Download
#2
#3
#5
suscribed![]()
magnaflow catback - Unitronic Stage 1+ -FK Coilovers - Neuspeed P-Flo Intake- NLS Short Shifter-c2 sri(pending install and tune)
#6
Oh la la , so many goodies. I'm gonna need to start saving my pennies.
#7
OMG Hottness.![]()
United Motorsport Software|AWE-Tuning Cat-Back Exhaust|LNT Intake|Koni Yellows w/ H&R Sports|Neuspeed 25mm RSB|NLS Short Shifter w/ 42dd Bushings & VMS Shift bracket bushings|BFI Torque Mount Insert|Lead foot
Friends don't let friends be like Av. and PSU.
#8
You guys will be excited, last night before we closed up shop we pulled down an '09 2.5L we had on the rack. We started drawing up parts to mount it to our engine dyno. Lots more parts and progress coming! I am going to have Tyler open a blog style post on here to chronicle the R&D as it goes on, hopefully that will keep you guys entertained.Then, to avoid cluttering your forum too much, all new parts will be listed for sale and kept in one place, which will be this thread.
.:IntEngineering.com:. .:Facebook:.
Check out some cutting edge R&D Work on our blog! IE Behind the scenes Blog!
#9
just wow. i am like that "red" fuel rail. Beside looking "Lady in red" pretty, any advantage of having one? i.e. horsepower increase, etc...?
#10
This is awesome guys, to have a 2.5 on an actual engine dyno is what we need. Cant wait to see all the parts you guys are gonna be shelling out soon. Any word on the fuel line kit for your fuel rail that will work with the HEP mani? Very interested in getting one but I wanna make sure the lines will fit first.
http://s529.photobucket.com/albums/d...abbit%20build/
2006 Sage Green Rabbit 5spd| UM SRI manifold | UM 93 SRI tune | NLS Cai | Custom Eurojet exhaust | USP testpipe | ECS lightweight crank pulley | BSH motor/trans mounts |034 Dogbone core| NLS SS w/42DD bushings | GTI brake swap w/SS lines | Koni yellows w/H&R race springs | GTI rear sway |
#15
Any word on the HEP fuel rail kit? Still waiting for an answer.
#16
Been working on it today actually... The rail will need a notch where the sensor goes, and then tabs will have to be fabricated to make the mounts line up, as the HEP does not use OEM mounting locations.
I'm printing a prototype to check fitment with the notch etc right now... I think Gabe at Bluewater is going to buy some modified ones from us for that and handle all the support etc on those. We have something else coming which will have OE style injector angles and mount tabs etc, so I really am not toooooo concerned about all these other SRI where the injector angle & placement is not correct.![]()
#17
Sounds good, let us know when theyre ready to go.
#18
Any documented or known issues with your fuel rail mounting on c2's flange? Im going to be using theirs for the supercharger, and would love to upgrade the rail![]()
#19
The C2 has the same exact issue. The injector angle they used puts the rail WAY closer to the head then stock. A fitting only barely fits in the back side (for a return system), the injectors basically can't go in at the OE angle because the clips will hit the head, etc.
The good news is that I'm pretty sure the HEP solution will work for the C2 one as well.
Here's a pic of today's progress:
#20
Do you think say making a phenolic spacer for the flange would give enough room for the injectors to be placed in the oem configuration?
#21
Another question. Will we be able to use the flywheels shims on a 6mt swapped 2.5l?
#22
Is that mani powdercoated or is that ceramic coating? Id also like to know more about a phenolic gasket for those of us with SRIs. Helping keep intake temps down would be nice but if it would help space out the fuel rail too to make things easier, thats just another plus.
#23
Yes, It would help... Do you guys want some? I'm drawing up the head flange right now anyways for uhmm.... top secret.
Absolutely- the only major bummer about the 2.5L is that really it should have a friction shim between the crank and the trigger wheel, and one between the trigger wheel and the flywheel. In other words, there is already something sandwiched in there. Still, anything over 500whp I would definitely use them, ask Gabe....
The manifold is actually from the Bluewater rabbit- I borrowed it to sort the rail situation out. I believe it is red wrinkle powder, but it may also just be paint. I'm not a huge believer in phenolic gaskets, but they usually can't hurt. They do lengthen the runner slightly which can be a good or bad thing, depending what you are looking for. -Pete
#25
Even with a pair of them in there it is only .016", which is very very minimal.
Pete
#27
Pete you need to hurry up and make more stuff. I already own 95% of what you guys sell for the 2.5L.
#29
I 2nd that.
#30
#33
Seems like plenty of room for the fuel rail with the C2 manifold.
The rail isn't anywhere near as close to the head like it is with the manifold (HEP?) you're using for mock up.
Check out this comparison between C2 and stock..
*Borrowing pictures that were taken from a similar vantage point.
C2
Stock
#34
I'm pretty sure the C2 mani still moves the rail "under" that plug a bit- we shipped one to C2 and they said it did not work. With the chamfer in them as shown in the prototype above, it would work- I just think it will be ugly as hell on stock manifold cars, so I'm on the fence about it.
#35
