VWVortex.com - INTEGRATED ENGINEERING's 2.5L 20V I5 product and new release thread.
    Page 4 of 54 FirstFirst 1234567814 ... LastLast
    Results 76 to 100 of 1329
    Thread: INTEGRATED ENGINEERING's 2.5L 20V I5 product and new release thread.
    1. Member zevion's Avatar
      Oct 23rd, 2009
      Newport Beach, CA and Minneapolis, MN
      2015 Golf R, 2015 Audi S3, 2013 Golf R (2.5T swap)
      02-25-2012 02:59 PM #76
      Quote Originally Posted by kevin FaKiN spLits View Post
      ^ lol
      They should make one that says, "Your car just sucks, but mine blows"
      2015 Golf R, 2015 Audi S3, 2013 Golf R (2.5T swap, 600AWHP) SOLD! 2008 R32
      Vortex Thread | GolfMk5 Thread | Old Video | Old Video Compilation | I UM | I Performance Leds
    2. Forum Sponsor Sales@IE's Avatar
      Oct 23rd, 2011
      SLC, UT
      1.8T High power engine dyno.
      03-13-2012 02:14 PM #77
      NEW PRODUCT:
      Integrated Engineering 2.5L 5CYL Spring/Retainer Kits
      Integrated Engineering is proud to release our new spring kits for 2.5L 5CYL engines. These performance tested kits feature aircraft grade titanium in-house CNC'd retainers to exacting tolerances and surface finish requirements. Optimized to match your vehicle specifications and provide proper valve control under high revving applications, the springs are wound in the USA from the purest spring steel available in the world and nan-peened for incredible fatigue resistance. These are engineered for the wildest setups, and tested to perform with long life and reliability. Click here
      High Performance Automotive Components
      Forged Internals - Valve Train - Race Engines - Intake Manifolds - Billet Accessories - Suspension - Brakes - Fueling
      WWW.PERFORMANCEBYIE.COM / IE FACEBOOK
    3. Member bunnyfufu's Avatar
      Jan 24th, 2011
      Pasadena,MD
      2010 cw golf 2.5l(mine) 2002 audi a4 3.0(wifes)
      03-13-2012 02:42 PM #78
      what is the safe rev limit when using these?
      magnaflow catback - Unitronic Stage 1+ -FK Coilovers - Neuspeed P-Flo Intake- NLS Short Shifter-c2 sri(pending install and tune)
    4. Member GTACanuck's Avatar
      Feb 20th, 2009
      08' Rabbit 2.5T, 12' Golf R, 91' Jetta
      03-13-2012 03:09 PM #79
      Quote Originally Posted by Sales@IE View Post
      NEW PRODUCT:
      Isnt the description supposed to read
      Kit includes:
      20 precision wound intake/exhaust valve springs
      20 Titanium intake/exhaust retainers
      PM Me for United Motorsport tuning in the Toronto Area.
    5. Member tay272's Avatar
      Aug 22nd, 2007
      Zionsville, PA
      06 Sage Green Rabbit
      03-13-2012 04:17 PM #80
      Quote Originally Posted by bunnyfufu View Post
      Id say 8500-9k rpms but Im sure theyre good even past that. Ill let IE comment on this one cause Im not positive on any of this.
      http://s529.photobucket.com/albums/d...abbit%20build/
      06 Sage Green Rabbit 5spd| UM SRI | UM SRI tune | NLS Cai | USP testpipe | Evo shorty header | ECS crank pulley | BSH mounts |034 Dogbone core| NLS SS w/42DD bushings | GTI brakes w/slotted and drilled rotors | Sachs racing shocks/struts w/034 strut mounts | H&R race springs | GTI rear sway |
    6. Member bunnyfufu's Avatar
      Jan 24th, 2011
      Pasadena,MD
      03-13-2012 04:24 PM #81
      Quote Originally Posted by tay272 View Post
      well if its near there that wouldnt be bad for $650
    7. Member thygreyt's Avatar
      Jun 7th, 2009
      fort lauderdale, FL
      1k-m-cbta-02q-PTE5858
      03-13-2012 04:56 PM #82
      Ferrea's valvetrain are supposed to be 8500-9000 rpms. or so they claim.
      in reality, i have no clue.
    8. Junior Member
      Mar 13th, 2012
      South Jersey
      07 VW Rabbit
      03-13-2012 06:44 PM #83
      awesome stuff.. great appearance.. thanks for the 2.5 love..
    9. Awaiting Email Confirmation pete@integrated's Avatar
      Jan 1st, 2009
      Salt Lake City, UT
      '92 Gti 20v, '96 M3, '10 Shop Van :)
      03-13-2012 10:37 PM #84
      These exact parts were tested up to 9300 rpm's in Bluewater's awesome 2.5L turbo, and they will push a bit further then that on stock cams. However, there's really no need to push it further then 8k or so on those cams, and you really have to watch out for non valvetrain related issues at those speeds, like oil pressure and aeration, etc.
      These are a true top quality, made in USA option which have been tested to hell and back, at a very fair price. They feature a lighter, stronger retainer then the Ferrea option due to the unique bee-hive spring, an IE exclusive in this application.
      When combined with Ferrea valves and a set of lifter shims this is a very hardcore- but reliable- setup.
    10. Forum Sponsor Sales@IE's Avatar
      Oct 23rd, 2011
      SLC, UT
      03-22-2012 02:25 PM #85
      New Integrated Engineering boost taps and caps for FSI, TSI, and 2.5L 5CYL Engines are designed, engineered, and manufactured in-house CNC'd from 6061 aircraft grade aluminum to exact tolerances and use included OEM mounting hardware. These are available in your choice of finish including IE red or black anodizing at no extra charge, all hardware is included for an easy install.
      Boost Tap - Installing a boost gauge or just need a vacuum source? Our FSI/TSI boost taps will make this a breeze. They are offered in black or red anodize and included all necessary hardware. Also included is an OEM retaining clip that eliminates the "kickstand" feature of other designs. For more info CLICK HERE.
      Boost Cap - If you plan on removing the factory PCV system, you will need one these. One useful feature of the IE boost cap is that it doubles as a tap and provide you with a vacuum. The kit comes complete with "tap" or "cap" hardware. For more info CLICK HERE or see it installed in our MK5 valve cover install DIY.
      www.intengineering.com
    11. 03-29-2012 06:49 PM #86
      just wondering if you guys ever thought about making a low temp thermostat for us warm weather boys?
      powdered donuts make me go nuts
    12. Forum Sponsor Sales@IE's Avatar
      Oct 23rd, 2011
      SLC, UT
      04-26-2012 08:22 PM #87
      If you have not seen it yet, head over and check out our 2.5L 5 Cylinder Engine Dyno Build-Up Thread. Get a sneak peak behind the scenes and how we develop new product for your platform.
    13. Member chadone's Avatar
      Apr 26th, 2010
      Buffalo NY
      2007 VW Golf
      05-27-2012 05:31 PM #88
      Those new intake manifolds...any chance those will be a reasonable price under $500? 1k or more is total nonsense
      2007 Bagged and Shaved MK5 Golf. -Daily Dirt-
    14. Member mldouthi's Avatar
      Jun 26th, 2010
      Austin
      08' Rabbit (Lifted), 07' Rabbit (lifted), 04 Audi S4, 02 Audi Allroad, 93 Audi 100s, 72 Type 3 FB
      05-27-2012 06:14 PM #89
      Quote Originally Posted by chadone View Post
      I bet if you pre pay for like 20 of them, they will sell you them for $500.
      Low volume equals higher prices. And those also have quite a bit of engineering time in them too.
    15. Member TylerO28's Avatar
      Jul 7th, 2008
      Mill Creek, WA
      '08 2.5Turbo Rabbit
      05-27-2012 06:25 PM #90
      Plus casting isn't exactly cheap...but if production numbers are high, the initial investment won't be too high.regardless i'm expecting at the very least 800 bucks for a cast manifold
      Sent from the bottomless pits of HELL!
      god i love my car. it may not be fast, but it's crazy fun!
      C2 stage 2 TURBO!!! ACHTUNG!!! 2.5liter 5cylinder contents under pressure!!!
    16. Member chadone's Avatar
      Apr 26th, 2010
      Buffalo NY
      2007 VW Golf
      05-28-2012 10:41 AM #91
      Prices can stay cheap if production demands are high. As long as money will be made back there's no reason to over charge. But then again, it's a car part and over charging is a common thing.
    17. 05-28-2012 11:11 AM #92
      Everything else that IE has released has been very fairly priced. I can't imagine that anything would change with this.
    18. Member chadone's Avatar
      Apr 26th, 2010
      Buffalo NY
      2007 VW Golf
      05-28-2012 11:53 AM #93
      Quote Originally Posted by DerekH View Post
      You are absolutely true about this. That's why I'm hoping it continues to be fairly priced. IE is a great company.
    19. Senior Member kevin splits's Avatar
      Aug 23rd, 2010
      Arizona
      01001011010011110 1010010
      05-28-2012 12:09 PM #94
      It can be $900 and still will be the cheapest option. Pay to play Take what they're selling the 1.8t manifold for add $150-200 and that's probably your ballpark. Tho the 2.5 doesn't have to be modular, switchable between left .and right, so maybe it will be the same price or a little more.
      "The Vile Bunch" ll v2lab ll eemilitiatv ll Stay Orange.
      2008 Mkv-sold; 2003 yellow SRT-4-sold; 2009 G8 GT-sold; 1991 Talon TSI- fully built-sold ; 2011 Mk6
    20. Member H3LVTCA's Avatar
      Oct 27th, 2004
      2009 VW Jetta
      05-28-2012 12:50 PM #95
      Pay to play
      This.
      Quote Originally Posted by TrillyPop View Post
      The 2.5L forum is full of high hopes and huge disappointment.
      MKV Rabbit Dyno Thread
      MKIII Cabrio Build Thread
    21. Senior Member kevin splits's Avatar
      Aug 23rd, 2010
      Arizona
      05-28-2012 01:00 PM #96
      I feel like a Dick! Local is parting out his 2.5 and I told him I'd take his c2 im if the buyer for his rabbit didn't want it. Buyer doesn't and now I want to wait for this. Cast is just better imo, the c2 is great, the other one is just a mail box on runners.
    22. Member tay272's Avatar
      Aug 22nd, 2007
      Zionsville, PA
      05-28-2012 02:33 PM #97
      If you had one on your engine I dont think youd be calling it just a mailbox on runners. Its alot more then that haha. Yes it might not be the most sophisticated design but it gets the job done and puts the power down. You cant argue about that. If this one ends up making more power then either of the other 2, I might give it a shot.
    23. Member chadone's Avatar
      Apr 26th, 2010
      Buffalo NY
      2007 VW Golf
      05-28-2012 03:57 PM #98
      Kevin I am in the same boat, I've been leaning towards the c2 as well over the UM endorsed one. But I'll definitely grab an IN over it based on what seems to be some great dedication to the 2.5.
      I'm just getting to the point where I've modded my mk5 to the point where all the new engine mods I have left r a grand or more! Haha
      Waiting on an IN turbo kit now!! I'm starting to get the itch for that now 2.
    24. Senior Member kevin splits's Avatar
      Aug 23rd, 2010
      Arizona
      05-28-2012 06:25 PM #99
      Well has there been a dyno for the c2? I don't know, don't really care to be honest. Not really all about power for the 2.5, just want nice things that look good to me and make the motor a little more robust. 400whp in a fwd car is pointless. We have a 600whp 20th that has drag radials on it and spins tire through 3-4th gear and will chirping in 5th on the highway.
      Hep is too big doesn't fit fresh out of the box, needs a custom intake. Not worth the price tag
    25. Member pennsydubbin's Avatar
      Mar 3rd, 2010
      Pa
      2016 GTI; 2005.5/08 Jetta 2.5T
      05-28-2012 06:58 PM #100
      yup, I went with the C2 SRI because I like the look of it over the HEP manifold. Even if the C2 mani makes like 5 or so whp less than HEP, I don't really care. My car can spare a few ponies and I think it looks better in the bay
      United Motorsports 2.5T
