VWVortex.com - 9A with 154.5 whp on ABF cams and Motronic
    Page 1 of 5 12345 LastLast
    Results 1 to 25 of 114
    Thread: 9A with 154.5 whp on ABF cams and Motronic
      Oct 21st, 2010
      Seattle
      Currently: '86 Wolfsburg Westfalia, '07 Audi A3, '90 Jetta GLI 16V
      11-22-2011 11:30 PM #1
      Rollers at Techtonics Tuning showed 154.5 whp
      154.5/.82=188.41 hp at the crank (this is using the 18 percent drivetrain loss method, your method may vary)
      TT 16V Motronic chip (off the shelf non-cam version)
      50mm intake manifold
      New OEM CIS-e/Motronic Bosch injectors
      Stage 2 ported and polished 2.0 (051) head match ported to 50mm intake and 83.5 pistons
      TT high flow undercut intake valves
      German light weight lifters
      Tapered valve guides
      TT ABF clone cams
      TT HD valve springs
      83.5 Supertech pistons (stock compression)
      1.8t rods
      Stock 9a crank 92.8mm
      TT 4 into 1 header ceramic coated
      TT high flow cat
      TT Borla exhaust system
      INA serp conversion
      There are tons more stuff than what I listed, but these are the ones that matter.
      Will be going back in the Spring after motor is broke in for more dyno tuning. We will be dyno testing several different cam types, somebody's prototype throttle body design, more aggressive chip tuning, and some other fun stuff.
      154.5 whp and 135.6 wtq surprised me with little ABF cams and an off the shelf Motronic chip. It will be fun to drive once I get this thing broke in. Can't wait to see what this motor does after the forged pistons settle in and we throw a 268/276 set of cams in there. I am only short 11.6 hp to hit 200 at the crank using the 18% drivetrain loss method. The 4 into 1 header, 50mm intake and head work are really going to wake up with some more aggressive cams. The adjustable cam gear is set at 0 with this cam set up. There was 5 more hp in the cam gear, but midrange dropped too much for that little 5hp gain above 5500rpm.
      All thanks goes to Josh at TT. The attention to detail on this build is incredible and I apologize in advance for the crappy iPhone pictures. The powder coat job on the intake and valve cover are tits and the zinc plating on the brackets is beautiful. Josh went above and beyond with this project and I have nothing but praise for the time and dedication he put into this project. The port and polish work on the head is absolutely a work of art and the numbers show how well it works.
    2. Member mulberrytdi's Avatar
      Jun 25th, 2009
      SK
      1981 Caddy, 1998 GTI
      11-22-2011 11:41 PM #2
      dear god. inspiration right there.
    3. Member Slow8vJetta's Avatar
      Jan 7th, 2007
      Milwaukie, Oregon
      1991 Wolfsburg Jetta GLi 16v(once daily, now a paperweight) and a 1997 Jetta GL (wifes daily)
      11-22-2011 11:44 PM #3
      Damn dude..
      Nicely done!!
    4. Member under the radar's Avatar
      Mar 5th, 2007
      NOR-CAL COASTSIDE
      disco, new wave, rave era german iron...and a Japanese V8 with a tailgate
      11-23-2011 12:15 AM #4
      hawt titties!
      Quote Originally Posted by spoon! View Post
      I'll go if Paul goes.
      Rod Blagojevich - Team My Little Pony
    5. 11-23-2011 12:16 AM #5
      all that for 150hp. im sure it pulls nice but still.
      Quote Originally Posted by dirtbaggg View Post
      is there anyway to get a new uni body?
      like can yu take the uni body off
    6. Member
      Oct 21st, 2010
      Seattle
      11-23-2011 12:33 AM #6
      All this is going to set it up to get over 200 hp at the crank while running on the early Motronic system. These lower hp numbers are just for the break in period.
      And yes it does pull pretty good. My wife's car is 200hp and curb weight is 3300 lbs and is an absolute blast to drive. This engine is nearly 190 hp and IIRC the curb weight is around 2400 for a Mk2 Jetta. Fourth gear pull is amazing.
      I looked at several swaps that I could have done cheaper but I really like the 9A engine. I got 197,XXX out of the original motor and never had any real problems with it the 5 or 6 years I daily drove it. Just consumables like clutches, brakes, alternators, etc.
    7. Member wantacad's Avatar
      Apr 3rd, 2003
      Belleville,Ill
      I haz a bunnah
      11-23-2011 12:37 AM #7
      Go with a stand alone system and you'll be knocking on 200's door.
      Buddy laid down pretty much the same numbers as you with a stock motor, exhuast and SDS almost 10 years ago.
      Quote Originally Posted by WackyWabbitRacer View Post
      You're new here but don't be a DORK.....
      Cheers, WWR.
      Quote Originally Posted by rte7x9 View Post
      Don't swap if you can't weld or fabricate. It's not a trivial task just to bolt everything up. There's a lot of nut-scratching involved. Take your time and do it right.
    8. Senior Member cyclops594's Avatar
      Sep 28th, 2005
      NorCal(Mudville)
      1991 Jetta GLI 16V
      11-23-2011 12:41 AM #8
      This thread makes me happy. Lovin' that head, it looks gorgeous!!! More info on the TB?
      Oct 21st, 2010
      Seattle
      11-23-2011 12:43 AM #9
      Quote Originally Posted by wantacad View Post
      The goal is stay on Motronic and achieve those numbers. When I get some cams in there we will see the head, 50mm intake and 4 into 1 header really wake up.
    10. Member
      Oct 21st, 2010
      Seattle
      11-23-2011 12:45 AM #10
      Quote Originally Posted by cyclops594 View Post
      No info on the TB yet, but I hear it should be done by Spring when I go back for dyno tuning. It is somebody else's little project right now but am glad that someone wants to pick up where Velocity left off. :thumb up:
      That head was so beautiful in person seeing all of those combustion chambers at one time. Picking someone to do the head was the hardest part of this car project. Jarod at SCCH does incredible work and Brad at Scooter Racing turns out some great stuff too. I am really happy I went with Josh at Techtonics and he ended up talking me into letting him do the entire engine. I have had several engines built in the past and dealt with many different types of people and I can say with 100% certainty that Josh's port and polish work is nothing short of incredible. Combined with the tapered valve guides and undercut valve stems this thing sings. If I ever decide to to standalone and a proper ITB kit...
    11. Senior Member cyclops594's Avatar
      Sep 28th, 2005
      NorCal(Mudville)
      1991 Jetta GLI 16V
      11-23-2011 12:52 AM #11
      Quote Originally Posted by MarkTwoGLI View Post
      but somebody needs to pick up where Velocity left off.
      I hear that. So this TB is a future piece to be sold to the masses I am guessing?
      Oct 21st, 2010
      Seattle
      11-23-2011 12:58 AM #12
      I am hoping so. That would be great for everybody! It is great seeing people with engineering backgrounds that are enthusiasts stare at their cars and say "I can make that better." People like Isaam at INA and the countless others out there. We are seeing some groundbreaking stuff come out.
    13. Member Road Boss's Avatar
      Jul 15th, 2004
      Crossville, TN
      84 VW Rabbit GTI, 84 VW Jetta Coupe
      11-23-2011 02:33 AM #13
      I'm glad that some people are making good hp out of a 16v.
    14. Member Redvdubdrivah's Avatar
      Jan 23rd, 2007
      Puyallup WA
      1990 GLI
      11-23-2011 02:54 AM #14
      Video!!!
    15. Member StabPrimo's Avatar
      Mar 9th, 2006
      Monterey, CA
      1991 GLI - 1986 951
      11-23-2011 03:02 AM #15
      16V
      P O W W W W D E R R R E D T O A S S T M A N N N N N N N N N
      BRIANEDWARDTUCKER.com <--- check out my website!
    16. Member 4cedboost's Avatar
      Jul 16th, 2006
      Poland, Ohio
      2008 FSI GTI (daily) 1991 GTI (work in progress)
      11-23-2011 03:26 AM #16
      who did the port and polish? if you did, what did you use? dremel? i have a non-ferrous bit i used on mine... after spending much time i found out the head was cracked between the valve seats
    17. Member under the radar's Avatar
      Mar 5th, 2007
      NOR-CAL COASTSIDE
      11-23-2011 03:29 AM #17
      Quote Originally Posted by StabPrimo View Post
      16V
      awwww yeeeeeeaaahhh!
      i wanna see videos please.
    18. Member
      Feb 23rd, 2006
      San Francisco
      mk2, e30+e36 ///M, ap1, duc s2r
      11-23-2011 03:40 AM #18
      yes, VID please! iphone pics aren't bad, shoot a vid with it and post it up! Exhaust rev and maybe in car of you getting on it? want to see your tach and throttle response.
      redline still at 7200?
    19. 11-23-2011 08:04 AM #19
      This is really inspiring.
      I'm doing a similar, but milder build this winter. I'm going to be running an internally stock 9A with ITB's running on MegaSquirt. I won't have any of that beautiful head work but if you managed 154whp with the ABF cams then I'll hopefully be able to get similar numbers through increased tuning capabilities.
      As for why use a 16v instead of a swap? Because it's lighter, easier and cheaper to work on than a VR6 and much cheaper than a 1.8t swap. Plus it's period correct and just sounds really nice. My own personal reason is that SCCA class rules don't allow for anything better than a 9a(or maybe a G60 depending on your interpretation) to be swapped into a mk2 running in Street Prepared.
    20. Member
      Oct 21st, 2010
      Seattle
      11-23-2011 11:46 AM #20
      Quote Originally Posted by rtfmorgtfo View Post
    21. Member
      Oct 21st, 2010
      Seattle
      11-23-2011 12:12 PM #21
      I took a video of a light second gear pull and then went to 6500 through the gears. This was taken on a closed course and not on my way to work this morning.
      http://www.youtube.com/watch?v=x5Qm4UrXyFA
      I am not going over 6500 during the break in period and even this has been done rarely. If you look at the dyno graph you can see it wasn't even done then. The forged pistons are set to tight tolerances and they really need to work themselves in proper.
    22. Member wantacad's Avatar
      Apr 3rd, 2003
      Belleville,Ill
      I haz a bunnah
      11-23-2011 01:23 PM #22
      Understandable. and don't think I was trying to bash or one up you. Just tossing another idea out.
      Pulling that off with stock management will be pretty impressive and inspirational to others.
      Cheers, WWR.
    23. Member wantacad's Avatar
      Apr 3rd, 2003
      Belleville,Ill
      I haz a bunnah
      11-23-2011 01:25 PM #23
      Cheers, WWR.
    24. Member
      Oct 21st, 2010
      Seattle
      11-23-2011 01:29 PM #24
      Some more pics showing the INA serpentine conversion and other bits.
    25. Member
      Oct 21st, 2010
      Seattle
      11-23-2011 01:31 PM #25
      Thanks wantacad!
