Page 1 of 9 1 2 3 4 5 ... LastLast
Results 1 to 35 of 306
Thread: Back home with the GTR. Thoughts and early review plus a few pictures.
  1. Member Toaster29's Avatar
    Jan 19th, 2000
    Birmingham, Al
    2010 GTR
    11-23-2011 09:51 PM #1
    Ok, I'm back and a bit rested. What a crazy 30 hours, but everything turned out fine with no issues or surprises. The GTR is a phenomenal machine, I'm extremely pleased with it. The transmission is interesting in it's quirkyness. I like that it isn't perfect like a torque converter auto from a stop. You can literally feel the clutches engaging and you must feather the throttle in like on a manual car in order to leave from a stop perfectly smoothly. It takes some attention and a little finesse and I'm glad it has that.
    The car is BIG. In relation to the other cars here at the house, it is very big. It also feels very, very solid. The doors are large and relatively heavy. You sit down in the car with a high belt line which makes you feel nestled down it in. Everything about it feels firm, and secure. You can definitely see where the nearly 3900 lbs comes from as the car feels like it was hewn from a block of granite. Unfortunately that applies to the suspension as well In comfort mode, it is a bit better, but make no mistake, the suspension is very, very firm and will crash over anything other than average imperfections in the road. Doesn't bug me, but if you don't like the flinty ride of an Evo, you won't like the GTR.
    Speaking of the Evo, this car just feels like it's big brother in so many ways. The steering is nigh identical. Super quick ratio, absolutely no slop, and razor sharp reflexes. Sneeze and you change lanes, just like an Evo. The ride is flinty like the Evo. The car has a lot of really great mechanical whines and wheezes as it goes about it's work. You can occasionally hear the actuators selecting the next gear, the pump adding pressure to the clutches as you feather in more power on the hwy, and even a little clutch chatter as you try super low speed maneuvers. The turbos are quiet, only occasionally hearing a very slight compressor whine at various spots in the rpm band. Again, being a mechanically inclined guy and knowing all the engineering behind all of this, I find it fascinating.
    As for the powerband, it is excellent. The transmission is so quick to react that if you leave it in auto mode you are never really caught with your pants down. Locking it a higher gear and rolling into it, the true dynamics of the engine are apparent. It is a little soft below 2500 rpm...again a relative term. The turbos and the engine come on progressively and the power seamlessly increases endlessly through the rpm band pulling hard all the way to 7k. It is very turbine-like in feel and sound. The gears are snapped off almost instantaneously. The midrange is ferocious especially in the first 3 gears. The car will scrabble some in first on WOT. The car is immensely impressive to 100 at which point the acceleration drops off some.
    My car is modified with a resonated midpipe which drops two cats as well as some weight. It is good for around 20 whp on a stock car. The sound is much more aggressive than the sterile stock hardware and has a really, really great note. It's a little higher pitched, and while it is a little on the loud side outside it is basically perfect in the interior with no boom or resonance. The interior noise is also well controlled with really nothing other than a little tread roar noticeable. I added a cobb access port to my car today and have the stage 2 beta maps. Running map 2 until I have a chance to log and make sure everything is kosher before I go up to map 3. The car screams. It is ridiculous to 100 mph. Judging from the times on the boards, it should run a very, very low 11 at around 125 mph with the canned tune and midpipe.
    The gadgets and gizmos are nearly overwhelming at first. The sheer amount of information presented to you takes a while to organize and memorize where it is in order to access it. If there's a fluid in the car, you can know it's temperature. G forces in all axis, torque split, instant mpg, aggregate mph, gear efficiency, tire pressures, you name it, it's all there. The car keeps up with maintenance as well. The creature comforts are nice with auto dimming mirrors. Mine is a premium so it has a great nav, heated seats, and some other BS. You definitely get your fix as far as toys. The bluetooth connection with my iphone works very well and has less road noise than average according to those I've chatted with so far.
    Economy coming home was commendable. At 70-75 mph the car was averaging 25 mpg per the MFD. Bump that up to nearly 80 mph and it drops to 22-23 however I find that completely acceptable.
    Overall I'm very happy with the purchase. This car fits me and my interests a good bit better than the Z06, however I will miss that car. It was great in it's simplicity and the shape oozed sex. There are some cheesy parts but the overall combination of speed, reliability, and low price point cannot be beaten in this segment.
    Still no great pics. Hopefully I get somebody who doesn't suck like me to come get a few good ones
    2010 GMG GT-R, 10.72 @ 132 so far / 09 E92 335i M-tech, JB4 and E85 mix
    Past: 300 hp A4, 500 hp Evo, 430 hp 335, and a 520hp Z06
    Jan 23rd, 2009
    Raleigh NC
    03 911 C2, 04 Passat 4mo
    11-23-2011 09:57 PM #2
    Nice! Don't get in trouble using all the performance on the street. A car like that begs for the track.
    And you aren't kidding about big. I like how cartoonishly large the exhaust pipes are, yet they fit the car perfectly.
    _______________________________________________
    http://fastwagon.blogspot.com/
    Quote Originally Posted by slomofo. View Post
    The RX-8 is like a sports team with mediocre players and no superstar.
  3. Member 302W's Avatar
    Jul 24th, 2004
    NoVA
    11-23-2011 10:00 PM #3
    Nice write up, I'm becoming a bigger fan of this thing more and more. So fast and pretty
    1988 is not an 80's car, it's an early 90s car but whatever.
  4. Senior Member Fritz27's Avatar
    Mar 8th, 2003
    Gulf Coast, FL
    11-23-2011 10:04 PM #4
    Damn man. Thing is badass. Congrats on the new car.
    PSN: PhilipGTI
    Get lost santa
  5. Member sforsancho's Avatar
    May 1st, 2010
    CA, USA
    1997 Mazda Miata, 1992 Lexus SC300 5/spd
    11-23-2011 10:05 PM #5
    Thanks for the info. I'd like to see a 25k/50k mile update. Curious to see how these are to maintain.
    Not a fan of the painted wheels, but otherwise, awesome car.
    "sports cars will get you through times without women better than women will get you through times without sports cars."
  6. Member DIAF's Avatar
    Sep 17th, 2005
    2007 GS 350 AWD
    11-23-2011 10:06 PM #6
    I got to drive one of these at an autocross this year. I've never driven anything that accelerated like the GTR. It's like a cat that rears up on its haunches and lunges forward.
    Such an awesome car.
  7. Banned AutoUnion32's Avatar
    Oct 4th, 2008
    Good Distance away from Fancy
    Truck that runs on smug fuel
    11-23-2011 10:07 PM #7
    Congrats
  8. Member Toaster29's Avatar
    Jan 19th, 2000
    Birmingham, Al
    2010 GTR
    11-23-2011 10:08 PM #8
    Quote Originally Posted by sforsancho View Post
    Sounds good. The wheels are stock. Darker colors on the 2010 with an even darker tone on the premium cars. I'm not usually a fan, but in person it is absolutely ridiculous looking.
    I'm about to do the 18k service. Tranny fluid is 570 bucks online. 120 for the diff fluid. Around 700 doing the labor yourself which is easy. Beats 1500 at the dealer. This service is every 18k. Tires are good for 10-12k and are nearly $2k installed. Brakes from the dealer are stratospherically priced, like around $8k for all 4 corners including pads. Nobody uses them for replacement unless you find cheap lightly used ones on the forum. Better aftermarket parts are available in the 1-2k range for all 4 corners.
  9. Member Deserion's Avatar
    Jul 28th, 2000
    Jacksonville, FL
    '95 Mercedes E320, '04 Porsche Boxster
    11-23-2011 10:10 PM #9
    The GTR isn't quite my cup of tea, but good luck with it. That's still an amazing car.
  10. Member Shomegrown's Avatar
    Feb 26th, 2002
    Detroit
    Current: Audi S4, BMW M5, Audi A3 quattro, Dodge Dakota 4x4
    11-23-2011 10:11 PM #10
    Congrats, love it.
  11. Banned
    Nov 15th, 2011
    11-23-2011 10:11 PM #11
    Quote Originally Posted by AutoUnion32 View Post
    Congrats
    sickening....great review
  12. Member InfinitiG's Avatar
    Oct 7th, 2006
    Minneapolis
    RSX Type-S
    11-23-2011 10:12 PM #12
    Congrats man, car looks great. Have fun.
    PSN: Silviatzero
    "I've got an idea for sweat shops: air conditioning! Problem solved."
    RSX-S
  13. Member nykwhy's Avatar
    Oct 3rd, 2010
    Central Canada.
    1998 (USDM) E36 BMW 323is
    11-23-2011 10:21 PM #13
    Please put another 85,000k on it.
    love, nykwhy.
    NYKWHY | fb Library
    98/E36 | Think the ocean is deep?
    92/AE101 | Walk the outer edges of the galaxy.
  14. Member
    Nov 3rd, 2008
    DC Metro Area
    06 Mustang GT Vert 5MT, 08 TSX 5AT, 95 Volvo 850 GLT 4AT
    11-23-2011 10:58 PM #14
    $8,000 for a brake service?
    That sounds nuts, like it would be for carbon ceramic or something. Doesn't the GTR have normal steel rotors?
    Or does that price include calipers or something also?
    http://sixsylinder.blogspot.com
    Quote Originally Posted by stacman View Post
    Top gear recommended it, so I bought it.
  15. Member Toaster29's Avatar
    Jan 19th, 2000
    Birmingham, Al
    2010 GTR
    11-23-2011 11:17 PM #15
    Quote Originally Posted by Wanganrunner View Post
    Yep, normal steel rotors. Many parts for this car are absurdly priced for no particular reason. Like I said, nobody uses the stock rotors new from the dealership when it's time for a replacement. They are two piece from the factory anyway, so only the friction surface requires replacement.
  16. Banned AutoUnion32's Avatar
    Oct 4th, 2008
    11-23-2011 11:20 PM #16
    Is there any truth to what Edmunds went thru with their GTR with the transmission oil changes?
    Didn't Nissan charge something ridiculous for the fluid?
  17. Member Toaster29's Avatar
    Jan 19th, 2000
    Birmingham, Al
    2010 GTR
    11-23-2011 11:28 PM #17
    Yes, typically they charge 80 a quart and it takes 10 quarts. Like I said, some Nissan dealerships online will sell it to you for around 550 to 570. It is easy to replace the tranny fluid on a lift.
  18. Member
    May 22nd, 2001
    Arizona
    2005 Nissan Frontier, E30, 1984 16v gti
    11-23-2011 11:34 PM #18
    I'm jelly
  19. Member
    Nov 7th, 2001
    The Village
    KAR 120C
    11-23-2011 11:54 PM #19
    Beautiful car. I'd be curious to hear what it sounds like with the exhaust mod. Care to take a little video?
    $8k for brakes? Wow. I think even Porsche would be ashamed at that price.
  20. 11-24-2011 12:04 AM #20
    Big baller, nice ride. Show us some videos off the exhaust.
  21. Member Nubbin's Avatar
    Mar 17th, 2007
    Holmdel, NJ
    1999 Nissan Quest GLE, 2009 Nissan GT-R
    11-24-2011 12:27 AM #21
    Quote Originally Posted by Toaster29 View Post
    I plan on replacing my OEM tranny fluid with the Dodson GR6 fluid after the warranty goes out. The Dodson costs about $490 for 10 liters and it is also much better than the OEM stuff.
    Some owners would recommend you the thicker Willall products. They are developed from the ground up specifically for the GR6 but they are even more expensive than the OEM.
    Dodson
    Willall's WR35TM
    Free 1SICKLEX
  22. Member compy222's Avatar
    Apr 7th, 2005
    Pothole, MI
    2012 Cruze Eco, 2006 Lancer Evo IX MR
    11-24-2011 12:29 AM #22
    I love it. Maintenance costs seem on par for the level of performance you're getting... Good luck with it!
    Regarding DD'ing a tuned Evo:
    Quote Originally Posted by SchrickVR6 View Post
    It's composed at all speeds and at all times...it just feels like you're holding the leash on a 150lb pit bull and praying you don't see a squirrel.
  23. Member kingrukus's Avatar
    Apr 5th, 2004
    Toronto, ON
    Ford Mustang GT
    11-24-2011 01:10 AM #23
    You are living the life my man, but I am sure it took some hard work, and smart moves. I am jealous, I love the car.
    Current: '00 Mustang GT 5MT | '04 Mazda 6i 5MT
    Past: '01 Maxima SE 5MT | '03 G35 Coupe 6MT | '00 Accord SE 5MT | '00 Maxima SE 4AT | '97 Civic CX 5MT | '98 Maxima GXE 5MT
  24. Member Charolastra's Avatar
    Aug 30th, 2004
    NoVa
    2007 Carrera S, 2003 Passat GLX Wagon
    11-24-2011 01:14 AM #24
    sforsancho
    x2.
    Great review OP, love the attention to detail! Congrats on the new purchase!
    I'm curious: why so expensive on the tires? I'm researching 997s right now, and even the OEM tires for a C4S are cheaper (~$1600 on www.tirerack.com), and that is with 19"x11" rears....What are the GTR's tire specs?
  25. Member zmt's Avatar
    Dec 7th, 2001
    DFW, TX
    '07 335i, '06 T&C, 07 Z4MR
    11-24-2011 02:14 AM #25
    How does It compare to the 335i? I need a frame of reference!
    Those upkeep costs are pretty ridiculous, but guess that's what "affordable" supercar performance costs
  26. Member ghostsof1985's Avatar
    May 8th, 2010
    The Fairfaxiest of Fairfaxes.
    His: 1993 Hondamatic Accord "The Old Man" / Hers: 2005 Civic "Jann Throbson"
    11-24-2011 02:20 AM #26
    Yeah, what they all said. Thanks for the super-thorough write-up; I could almost feel what it's like to be in the car.
    Looking forward to future reading about your new danger machine.
    steamID: GHOST[9] - [l4d/l4d2/CS:S] // PSN: GHOSTtoast85
    I read a lot of books. Cigars are tasty. I'm a big ole nerd.
  27. Senior Member PineappleMonkey's Avatar
    Mar 2nd, 2000
    Chicago
    Ninja's teleport in 2JZ's and CT9A's
    11-24-2011 02:38 AM #27
    Great write-up! Congratulations again on your purchase, I know you'll love living with this car. Your car is pretty much exactly what I am waiting to buy, only in white The ride is harsh but I think that has more to do with the size of the wheels then anything else, but if anyone has driven a car with coil overs then it's nothing too surprising; actually I prefer it!
    Looking forward to an update six months from now
    liiliilillillilililiil
    Donatello - Team Post-Killing Ninja
    I have a pet ▀□ left lane piggy □▀
  28. Member jay3737's Avatar
    May 19th, 2005
    Houston, TX
    '12 Regal GS / '93 MR2
    11-24-2011 06:25 AM #28
    very nice! what a beautiful color also...
    a local here bought a '11 GTR at the beginning of the year, and sold it a month or so ago. he found he never liked the car because 1) he could never really enjoy it on the street and 2) he said it always garnered too much attention. i could understand 1) but 2) made me because it's a friggin GTR - what do you expect?!?!
    would be curious to see your impressions after a few months of ownership.
    '12 Regal GS | '93 MR2
    Quote Originally Posted by Iroczgirl View Post
    A Buick with a manual transmission. The Mayans must be right.
  29. Member Mosbius Designs's Avatar
    Dec 2nd, 2006
    2012 Honda HRX217, 2 Golfs, and a 944.
    11-24-2011 07:29 AM #29
    Bummed to hear you got rid of the Z06 - but man those things sure do have a presence to them. Congrats.
    I love all cars, I just happen to own a few pieces of german crap at the moment.
  30. 11-24-2011 08:18 AM #30
    Awesome write-up, would read again!
    " You can literally feel the clutches engaging and you must feather the throttle in like on a manual car in order to leave from a stop perfectly smoothly. It takes some attention and a little finesse and I'm glad it has that."
    I absolutely agree
    Sega|Saturn
  31. Member scott_0's Avatar
    Dec 21st, 2010
    Oxford, Pa
    1991 Civic dx 2011 Ingot silver Mustang GT
    11-24-2011 09:40 AM #31
    nice write up congrats on a beautiful car!
  32. Senior Member 6cylVWguy's Avatar
    Jun 14th, 2000
    PA
    Blog Entries
    4
    '12 GT; '94 SLC
    11-24-2011 09:54 AM #32
    Love the car and I like your approach to just trying things out that seem interesting to you! I was on track with a GTR over the summer and I think it might have lapped me twice! Oddly, it didn't really bother me as I loved hearing it scream past me and watch how it attacked turns.
    You really need to take that car to a road course next year!
  33. Member NOTORIOUS VR's Avatar
    Sep 24th, 2002
    Toronto
    E36
    11-24-2011 10:04 AM #33
    Congrats! These cars are monsters I was immensely impressed with one (it was tuned, and had mid pipes and exhaust system).
    E36 · VEMS · TUNING
    Google Talk: NOTORIOUS VR
  34. 11-24-2011 10:37 AM #34
    What is that white car in the garage?...looks curvy.
    '11 Toyota Tacoma TRD-Off Road
    '08 Nissan Pathfinder LE
  35. Member AVWD's Avatar
    Jan 11th, 2005
    Toronto
    '01 Golf, '91 XJ
    11-24-2011 10:40 AM #35
    Quote Originally Posted by forewheel View Post
    Viper?
