VWVortex.com - radio wiring diagram?
    Results 1 to 8 of 8
    Thread: radio wiring diagram?
    1. Member EuRoGTI86's Avatar
      Sep 27th, 2008
      LongIsland, NY
      12' Jetta S, 95' Passat GLX, 93' Corrado SLC
      11-24-2011 06:28 PM #1
      Can anyone get their hands on this? i need to hook up my navi to the car.
      R.I.P. Allen A.K.A. vr6inside98. 89'-11' I LOVE YOU MAN
      Tri state area. VAG-COM (VCDS) Scans/Mods available (HEX+CAN)/Suspension install available/Fender rolling available. Send me a PM for pricing!
      Instagram- @mr_toffee
    2. Semi-n00b
      Nov 22nd, 2011
      Louisville
      2011 Jetta TDI
      11-24-2011 10:11 PM #2
      Sound System Wiring Diagram
      Click on the Blue Download button in the lower portion of the link.
      http://www.2shared.com/document/N9br..._Sound_02.html
      Fuse Diagram also
      http://www.2shared.com/document/051s...I_Fuse_02.html
    3. Semi-n00b
      Nov 22nd, 2011
      Louisville
      2011 Jetta TDI
      11-24-2011 10:35 PM #3
      More Radio Wiring Diagrams
      Again, only click the blue Download button in the lower portion of the link
      RCD 310
      http://www.2shared.com/document/xs3T...em_RCD_31.html
      RCD 510
      http://www.2shared.com/document/ZW0q...em_RCD_51.html
    4. Semi-n00b
      Nov 22nd, 2011
      Louisville
      2011 Jetta TDI
      11-24-2011 11:07 PM #4
      Coupling stations and connectors of wiring harnesses
      Again only click the blue download button at the lower portion of the link
      http://www.2shared.com/document/5mBP...tations_a.html
    5. Member EuRoGTI86's Avatar
      Sep 27th, 2008
      LongIsland, NY
      11-24-2011 11:36 PM #5
      thnx man
    6. Semi-n00b
      Nov 22nd, 2011
      Louisville
      2011 Jetta TDI
      11-25-2011 01:37 AM #6
      May take a moment or two, 1,916 KB
      http://www.2shared.com/document/O89F..._units_01.html
    7. Member EuRoGTI86's Avatar
      Sep 27th, 2008
      LongIsland, NY
      11-25-2011 02:15 AM #7
      ok so I'm using this plug and play connector. http://enfigcarstereo.com/CONNECTS2_CTSVW002.html
      I got everything spliced properly b/t the harnesses. Now when i go plug into the factory harness. the unit turns on and off constantly. Has anyone else used this plug and play?
    8. 04-15-2014 06:18 PM #8
      I am having trouble reading the diagrams... can someone help me find the Dimmer wire? The wire that sends a signal to the radio to dim like the rest of the dashboard lights, switches, etc...
      Thanks a lot!! I am having trouble finding this wire to connect to an aftermarket Pioneer radio/nav system.
      Anthony
