VWVortex.com - Coolant leak...how to find it?
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 31
    Thread: Coolant leak...how to find it?
    1. 11-25-2011 11:04 AM #1
      So the car broke down on my wife while on the way to work again. This time the coolant is completely drained from the system. It is all over inside the engine compartment so it's impossible to tell where the leak actually is. Within the last year we have replaced the pump and thermostat so I am going on the assumption that neither of those are an issue at this point. Although I figure a stuck Tstat might cause too much pressure to build up and blow a line. Ill cross that bridge when the time comes. I also assume there should be nothing wrong with just putting water in there just to find the leak and then of course draining and putting the proper fluids in. Is this a wise course of action to take? You never know with these German things. I would of course use the same type of water that is used to mix with the coolant already.
      My wife also stated that she did not see any smoke coming out of the tailpipe and only the engine. This means the engine itself should be safe and no gasket blew inside.
    2. Member linchpin.666's Avatar
      Apr 14th, 2010
      San Diego, CA
      2015 GTI
      11-25-2011 11:05 AM #2
      Common point of failure is the coolant flange on the driver's side of the engine. If there is more coolant pooled on top of the transmission on the driver's side than anywhere else, that's probably it. If not there, check the O-ring at the coolant temp sensor.
    3. Member yivek's Avatar
      Nov 16th, 2010
      Austin, TX
      2003 Jetta 1.8T Wolfsburg Edition, 2013 CC 2.0T Sport
      11-25-2011 11:10 AM #3
      What I did is bought a UV dye kit from the auto parts store that had the UV light and glasses and then bought dye for the coolant.
      After a day of running it I was able to locate the spot where it was leaking. In my case it was the coolant flange on the driver side of the engine. You also might want to clean down the engine with some Simple Green before you do this to make it easier to see.
      2001 Jetta 1.8T Wolfsburg Edition
    4. 11-25-2011 11:11 AM #4
      Yeah...I am dreading taking that thinng out again...
      But still...can I just use regular water to FIND the leak before I just go taking crap apart?
      I might point out that the coolant is completely drained. This isn't a small leak.
    5. Member yivek's Avatar
      Nov 16th, 2010
      Austin, TX
      11-25-2011 11:18 AM #5
      If it is cool enough and you have someone watching the temperature gauge while you dye it and let it run you should be ok. But you should get some coolant in it if you are going to dive it. Also make sure you get the VW G20 fluid for it. From what I have heard it can cause issues when you don't use it over time.
    6. 11-25-2011 11:20 AM #6
      Not planning on driving it at all until it is fixed. This isn't going to be a little drip leak. The fluid is quite literally sprayed all over in the engine compartment. There is no way I will drive it with that going on.
    7. Member JERSEY_WABBIT's Avatar
      Oct 14th, 2011
      Wildwood, NJ
      09 MKV Rabbit, 2001 MKIV Jetta Wolfsburg 2012 Tiguan, 2012 Beetle , 2015 mk7 GTI
      11-25-2011 08:51 PM #7
      I just fixed a leak just like that . Mine ended up being the lower hose on the Expansion tank. The plastic Y on the lower Expansion tank hose cracked on me spraying coolant everyplace as well. Fill it with water and rent a cooling system pressure tester from any good auto part store. Fill the system up with water . hook up the pressure tester and apply pressure to the cooling system . If its a big leak it wont take alot to find it.
      Quote Originally Posted by Basscase View Post
      Wait wait wait...what? You'll go down on her...but won't kiss her afterward because "it's gross"? The fvck?
      FACEBOOK
      IG DUBSURF
    8. Junior Member mlemorie's Avatar
      Aug 5th, 2009
      Pinckney MI
      04 Reflex silver TDI Jetta
      11-25-2011 11:02 PM #8
      To answer your question, yes you can use water to find the leak without it hurting anything. I wasnt paying attention to your location but if you are anywhere where it is starting to get below freezing at night, make sure to get some antifreeze mixed in soon after finding the leak or put the car in a heated garage. Cracked blocks and heads are a bummer. Also I dont know what kind of tools you have access too, but to find leaks I would always pressurize the system and try to find the hiss.
      Disregard show, acquire go.
      Diesel Dub Club #37.
    9. 11-25-2011 11:12 PM #9
      If it is inside the car your heater core went south on you. There are 4 potential location where coolant leaks the thermostat housing, crackpipe, secondary electrical coolant pump, the water pump driven by the pully and your coolant reservoir.
    10. 11-26-2011 01:04 AM #10
      Check the coolant flange on the firewall, sometimes that breaks, it will literally spray coolant out directly into the engine compartment (it's a massive leak).
      Also check the lower expansion tank hoses like the previous poster mentioned, that would do the same thing.
      The leak should be really easy to find, just dump a ton of distilled water in it, then start it up and wait for the thermostat to open. Once it does and coolant starts flowing, the leak should be apparent.
    11. Member MechEngg's Avatar
      Jan 12th, 2009
      Calgary, AB
      11-26-2011 03:22 AM #11
      My reducer on the timing belt side of my engine went on my last car.....Just start checking every single hose you have
    12. 12-02-2011 11:36 AM #12
      Looks like I'm having a coolant leak also, can anyone please help me identify this hose, hopefully with a part #? It's an 03 1.8t
    13. 12-02-2011 01:51 PM #13
      bump. I think it's #17 in the diagram but not certain
    14. Member yivek's Avatar
      Nov 16th, 2010
      Austin, TX
      12-02-2011 04:46 PM #14
      Quote Originally Posted by Dave26 View Post
      I can't be sure, but I am not 100% that is the 1.8T diagram....
    15. Member linchpin.666's Avatar
      Apr 14th, 2010
      San Diego, CA
      2015 GTI
      12-02-2011 04:59 PM #15
      Quote Originally Posted by yivek View Post
      Engine code is AWP...
    16. Member yivek's Avatar
      Nov 16th, 2010
      Austin, TX
      12-02-2011 05:31 PM #16
      Quote Originally Posted by linchpin.666 View Post
      Ahh you are right. I just can't seem to figure it out, doesn't remind me much of my engine. I looked over at www.1stvwparts.com and couldn't find it there either. If you can call the dealer or stop in and ask for a part quote they can give you the part number and you can the price they will charge you.
      If your dealer is good, they should be able to find this over the phone for you. I would tell them it is the lower hose on the coolant flange and see if they can find it.
    17. Member David802's Avatar
      Feb 22nd, 2011
      SLuT
      01 Jetta VR6, 71 Type 1.
      12-02-2011 06:57 PM #17
      My bet is cracked theromstat housing. That mess of hoses all connect to that housing I think.
    18. Member JERSEY_WABBIT's Avatar
      Oct 14th, 2011
      Wildwood, NJ
      12-02-2011 10:46 PM #18
      Quote Originally Posted by David802 View Post
      I agree in most cases its the t-stat housing. But if it turns out to be that hose might aswell replace the t-stat and the housing since your already there
      FACEBOOK
      IG DUBSURF
    19. Member AudiUrPnts's Avatar
      Apr 11th, 2011
      Newark, De
      B6A4, MK1 Rabbit
      12-02-2011 10:50 PM #19
      That sucks man hope you find the source.
    20. Junior Member DirtMcGirt63's Avatar
      Feb 3rd, 2010
      Des Moines, IA
      '03 Jetta 1.8T, '04 350z Touring
      12-02-2011 11:24 PM #20
      on the AWP that part that you're pointing to is on the right just above all of the tranny linkage right?
      i just replaced that hose also - went into the local dealership and said i need the hose that goes into the bottom of the coolant flange - make sure you specify manual or automatic because they are different! (the auto comes straight out rather than pointing down like the manual) - after getting mine at the dealership i think i found it through ECS also?
    21. 12-06-2011 12:52 AM #21
      So I found the source. I can't find the part on those diagrams though. The part was a simple link that connected two hoses together. Plastic of course which is why it failed. It connected two hoses together that went between the coolant reservoir and the engine. It was down under a couple other hoses.
      So this link piece broke at the tip at one end inside the hose. I thought, no problem...ill get that out of there, buy the part and replace it in no time at all.
      Nope...
      The part is practically impossible to find. But that wasn't the dealbreaker for me. I went to take the part out of the other end of the hose and in true Volkswagen fashion it broke off as well and the part disappeared into the engine. So I went to Autozone. Yes...Autozone. I bought a 3/8ths 8 inch long copper tube, 4 screw tightening tube clamps and Prestone Antifreeze. Thats right. Screw this car!
      I got home...decided to not even try and bother with getting the broken tips of that plastic piece of crap out of the lines and just cut them off. Clippity clippity! I jammed 3 inches of that beast of a tube in one end and 3 inches into the other and put two clamps on each side to hold that baby in. There were flares on each end so I know the thing can't slip out at either end. It was a perfect fit.
      I then dumped that Prestone Antifreeze into the car and went for a test drive. NO LEAKS! Runs greatish again. (I hate this car.)
      So now my big question is this...I've been told by Volkswagen dealers not to use anything but their special antifreeze. I've been told by other dealers that it really doesn't matter. I've spoken to people that have owned this car using regular antifreeze for years with no problem and others that say never to use anything but the stuff from the dealer.
      So I need clear opinions on that. Whats the deal? I was told its to keep parts from corroding so I got the anti corrosion antifreeze.
      Also...Tonka has no business making cars. Plastic and heat do not mix...no matter what kind of super space age plastic it is.
    22. 12-06-2011 12:56 AM #22
      Also guys...
      Thanks for all the replies.
    23. Member MechEngg's Avatar
      Jan 12th, 2009
      Calgary, AB
      12-06-2011 08:30 AM #23
      Quote Originally Posted by Vertisce View Post
      Nope...
      Hahaha I WIN!
      That is a reducer coupling, ended up replacing mine with a brass alternative. But i did find one at autovalue in Canada a few months afterwards so i know that it is available elsewhere besides the dealership.
      I would not recommend MIXING the coolant types. Mixing certain types can cause the coolant to have a chemical reaction and actually "gel" up inside your lines or radiator which isn't good at all. Either do an entire flush with whatever coolant you want or keep topping it up with G12
    24. Member yivek's Avatar
      Nov 16th, 2010
      Austin, TX
      12-06-2011 09:09 AM #24
      I had Prestone in my car for a few weeks and then I decided after reading up on it to got back to G12. It can either cause corrosion or gel up in side of the engine and make a mess of it. I bought a jug from my dealer, I know ESC and WRD Racing sell other brands of G12 also.
      In the short term, it is ok, but you want to flush it and swap it out again to the G12. $20 isn't worth risking the whole engine in my book.
    25. 12-06-2011 09:13 AM #25
      How do I properly do a coolant flush? Can I just open the spout at the bottom of the radiator and keep pouring water in with the engine running? Or do I need to fill it up and drain it a few times?
      The damned thing was empty when it came back to me...I am sure there was a little left of the G12 though inside the system. I used about a gallon of water to find the leak and then put in only about half a gallon of the Prestone stuff...it did bubble up a bit which concerns me so I will flush it all out again when I get home assuming I have the proper procedure for this car.
