VWVortex.com - Driver gear springs
    Page 1 of 4 1234 LastLast
    Results 1 to 25 of 207
    Thread: Driver gear springs
    Hybrid View
    1. Former Advertiser
      Oct 28th, 2009
      Huntersville
      11-25-2011 01:42 PM #1
      We have had a lot of questions about the driver gear springs and what part number fits what application. Here is a list so we can try to make it as easy as possible.
      2 door 2.5 auto and manual, TDI manual 5K3-071-677-A
      2 door TDI auto 5K3-071-677-B
      4 door 2.5 auto and manual, TDI manual 5K4-071-677-A
      4 door TDI auto 5K4-071-677-B
      These are items commonly replaced when replacing your suspension
      N-106-107-02--- quantity required 2--- Bolt(low rear shocks to control arm)
      WHT-002-795--- quantity required 2--- Outer axle bolt
      N-909-548-02--- quantity required 2--- Pinch bolt(holding strut in knuckle)
      N-910-216-01--- quantity required 2--- Nut (for upper strut mount)
      6N0-412-249-C--quantity required 2--- Strut Bearings
      1K0-412-331-B--quantity required 2--- Strut Bushings
      Please check our site for pricing. www.keffervwparts.com
    2. Geriatric Member Aonarch's Avatar
      Dec 4th, 2006
      Atlanta, GA
      '14 ATS 2.0T 6MT, '16 Camaro 2SS 8AT, '14 Moto Guzzi V7
      11-25-2011 02:48 PM #2
    3. Former Advertiser
      Oct 28th, 2009
      Huntersville
      11-25-2011 04:01 PM #3
      added some updated info on hardware you may want to replace.
    4. Former Advertiser
      Oct 28th, 2009
      Huntersville
      11-29-2011 07:55 PM #4
      Nov 7th, 2011
      Marysville, WA
      2012 Golf TDI
      12-02-2011 03:30 PM #5
      I was checking your site and 1K0-412-331-C doesn't return any parts.
      Can you double check the number or your site and see if something is up?
      Also, about the kit-- is anything else needed with the springs? Like suspension limiters or bumpstops or anything like that?
      Will there be new alignment specs with this kit or will it align to factory specs? Can I expect to have tracking issues or any problems or will it drive straight?
      I'm pricing things out and considering options.
      Adam
    6. Former Advertiser
      Oct 28th, 2009
      Huntersville
      12-02-2011 07:48 PM #6
      Quote Originally Posted by A.Bursell View Post
      Adam
      There is not limiters required with this kit. An alignment is always required after taking apart your suspension, but there will be no issues with making the vehicle align within spec. Part number corrected 1K0-412-331-B
    7. Senior Member
      Nov 7th, 2001
      The Village
      KAR 120C
      12-02-2011 07:53 PM #7
      Paul, my local dealer told me that the DG springs are not appropriate for a GTI "because they won't lower it any". Photos of MkVI GTI's I've seen with them installed clearly demonstrate that it will sit at least 0.5" lower if not more once settled with the DG springs. I like the idea of running a spring that (likely) won't make VW freak out that I've modified the car with non-OEM parts, and I like the idea of dropping it about that much to remove just a bit of fender gap.
      Thoughts/input?
    8. Former Advertiser
      Oct 28th, 2009
      Huntersville
      12-22-2011 04:45 PM #8
    9. Former Advertiser
      Oct 28th, 2009
      Huntersville
      12-26-2011 10:28 AM #9
    10. Former Advertiser
      Oct 28th, 2009
      Huntersville
      12-29-2011 12:00 PM #10
      Jul 6th, 2006
      2012 VW GTI 4dr Sunroof/Nav
      12-29-2011 12:14 PM #11
      Installed yesterday. Perfect ride height, excellent ride quality. Thanks boss!
    12. Former Advertiser
      Oct 28th, 2009
      Huntersville
      12-30-2011 03:16 PM #12
    13. Former Advertiser
      Oct 28th, 2009
      Huntersville
      01-02-2012 01:32 PM #13
    14. Member
      Nov 7th, 2011
      Marysville, WA
      2012 Golf TDI
      01-02-2012 05:40 PM #14
      Got mine in and they are great. Final drop on my TDI is about 1.2 all around, car sits almost level, just a hair higher in the back.
      Adam
    15. Member DRH's Avatar
      Dec 20th, 2009
      Long Island, NY
      2012 Golf TDI Man w/ Tech BUY IT
      01-02-2012 05:43 PM #15
      Adam
      are you dsg or man?
      BUY MY 2012 GOLF TDI
      2012 4dr Golf TDI Manual w/ Technology Package
      #CarlyTheCar on Instagram - CLICK HERE
      @DrDownBrown on Instagram - CLICK HERE
    16. Member
      Apr 22nd, 2006
      Columbus, OH
      15 pure white GTI S dsg
      01-13-2012 12:37 AM #16
      Mk6 versions aren't on the site anymore?
    17. Former Advertiser
      Oct 28th, 2009
      Huntersville
      01-13-2012 11:02 AM #17
      Quote Originally Posted by YukonCornelius View Post
      Im sorry our site search was down. It has since been resolved
    18. Former Advertiser
      Oct 28th, 2009
      Huntersville
      03-15-2012 12:29 PM #18
    19. Former Advertiser
      Oct 28th, 2009
      Huntersville
      03-20-2012 01:34 PM #19
    20. Former Advertiser
      Oct 28th, 2009
      Huntersville
      03-22-2012 11:41 AM #20
      all sets in stock!
    21. Member adROCK319's Avatar
      Jul 5th, 2006
      VA 23322
      2012 Golf TDI 4DR 6MT
      03-22-2012 04:34 PM #21
      Brent, you have a PM
    22. Former Advertiser
      Oct 28th, 2009
      Huntersville
      03-27-2012 05:55 PM #22
    23. Former Advertiser
      Oct 28th, 2009
      Huntersville
      03-28-2012 03:19 PM #23
    24. Former Advertiser
      Oct 28th, 2009
      Huntersville
      04-16-2012 07:31 PM #24
    25. Former Advertiser
      Oct 28th, 2009
      Huntersville
      10-05-2012 07:33 PM #25
