VWVortex.com - Propane Generator - Distance from Propane Tank?
    Results 1 to 7 of 7
    Thread: Propane Generator - Distance from Propane Tank?
    1. 11-25-2011 02:55 PM #1
      Hi - I'm in the process of having a propane generator installed, and am trying to figure out where I want the generator and the propane tank. Does anyone know if the two items need to be a certain distance apart from each other, and if so, why? The generator is a Generac 20kw standby and the propane tank is 100 gallons.
      Thanks.
    2. Member barry2952's Avatar
      Jun 13th, 2007
      Farmington Hills, MI
      11-25-2011 03:12 PM #2
      The further from the tank the larger the piping needs to be. I have a 20KW Kohler that runs on NG, but I've investigated dual-fuel.
    3. 11-25-2011 03:26 PM #3
      Thanks - now that I think about it, the specs on the generator does say natural gas/propane.
      Is there a required distance that the two should be from each other, or is it just preference?
    4. Member barry2952's Avatar
      Jun 13th, 2007
      11-25-2011 03:37 PM #4
      In the electrical industry you are supposed to provide 4 feet of clearance to safely work on equipment. A bigger concern is how far the exhaust is from any windows in the house.
      I don't know if NG and propane are an either/or situation. I believe they require different size jets.
      Sep 13th, 2005
      Milwaukee, WI
      1986 IDI Golf, 332K miles, down for combustion leak into cooling system.
      11-25-2011 09:35 PM #5
      Here are a couple of indefinitive answers. You might also ask your building inspector and fire marshall. If they don't know, ask what is needed for a furnace; also electrical in nature. One reply on one of the sites was that the NEC is silent on this. A possible reason for that is because you have the potential for a propane leak at the generator as well as at the tank so it may be a moot question.
      http://en.allexperts.com/q/Electrica...nerator-11.htm
      http://forums.mikeholt.com/showthread.php?t=129641
    6. 11-25-2011 11:51 PM #6
      Thank you. I spoke to the propane company today and they said the tank should be 10 feet from the generator, but based on the limited info I found online and the links you provided, it sounds like that the 10 feet may only be a personal request from them rather than code? I hope this is the case because if it had to be 10 feet apart, I am very limited in my options based on the size/shape of my backyard and placement of my deck.
      Sep 13th, 2005
      Milwaukee, WI
      11-26-2011 01:11 AM #7
      Sorry about the links not working. I hope that they work now.
